ls1 in a mustang
Old Oct 21, 2006 | 02:35 PM
Jasperstang308's Avatar
Default ls1 in a mustang
first off my name is justin i own a 95 mustang gt with a 347 125 shot suspension etc etc but had some bad luck and wrecked it. but i am wanting to get a 87-93 notchback and want to put a ls1 in it and 6spd.
first off what has to be done for this to work?
how much would a ls1, wiring harness and 6spd tranny cost to get?
are they any kits to make this a simpler drop in process?
what about the driveshaft and some mounts?
has very many people down this swap that i may contact anyone particluarly on this forum?
what about the clutch assembly?
any and all answers would be appreciated thanks for the help
Old Oct 21, 2006 | 02:47 PM
Red00's Avatar
Ever try the search button? Plenty of info. in here if you actually look.
Old Oct 21, 2006 | 07:21 PM
zigroid's Avatar
these are just a few of my saved LS1 mustang favorites
https://ls1tech.com/forums/conversions-swaps/528207-all-talk-about-t56-fox-so-here-s-my-swap-thread.html - LS1 fox with t56
https://ls1tech.com/forums/conversions-swaps/562594-few-pics-lsx-mustang.html - pictures of a FAST LSx mustang
https://ls1tech.com/forums/conversions-swaps/532570-ls1-coupe-t-76-a.html - LS1 fox with a T76 turbo
https://ls1tech.com/forums/conversions-swaps/487553-ls1-foxbody-need-help-radiator-hose.html - short radiator hose thing
https://ls1tech.com/forums/conversions-swaps/566329-ls1-mustang-almost-done.html - LS1 mustang
https://ls1tech.com/forums/drag-racing-results/560265-ls1-mustang-results.html - LS1 fox with t56 quarter times
https://ls1tech.com/forums/conversions-swaps/512859-ls1-notch-pics.html - LS1 fox and t56 discussion
https://ls1tech.com/forums/conversions-swaps/200679-ls1s-do-fit-mustangs-minimal-work-pics.html
https://ls1tech.com/forums/conversions-swaps/508928-ls1stangs.html
https://ls1tech.com/forums/conversions-swaps/537484-lsx-mustang-suspension-question.html
https://ls1tech.com/forums/conversions-swaps/392576-lsx-powered-mustang-coupe.html
https://ls1tech.com/forums/conversions-swaps/338338-mustang-ls1-headers.html
https://ls1tech.com/forums/showthrea...4&page=1&pp=40
https://ls1tech.com/forums/conversions-swaps/583202-pics-lq4-lq9-fox-stang-4-6-mounts-no-workie.html
https://ls1tech.com/forums/conversions-swaps/421421-some-pics-my-fox-mustang-conversion.html
https://ls1tech.com/forums/conversions-swaps/531909-who-wants-help-me-wire-my-ls1-mustang-swap.html
I got tired of labeling them. but those are most of the LS1 mustang related content ive come across
Old Oct 22, 2006 | 09:59 AM
Vcious04's Avatar
Research, and lots of it.. I am using a AJE racing tubular K for the main swap. You can use the factory a-arms but I am going all out.
Depends, for a used stock motor/t56 - $3000 - $4500
I have a 99 PCM and harness for M6 for sale for $320 ( I went carb)
NO... unfortunatly
I havent' gotten that far yet, but the motor mounts are stock 4.6 motor mounts with an extension welded on the single side (simple)
Save my info, you will see lots more info/pics once all my parts arrive and my motor comes back from being built. Good luck!
Old Oct 22, 2006 | 12:26 PM
i appreciate it. like i said i am new to the forum and i was sure the people who knew about it would chime in. also i am certain it would be an expensive swap so i am trying to figure out what i will need and start working my way to that stage of building the car. also i thought aje sold k-member kits that would work are they still 600 bucks?
Old Oct 22, 2006 | 12:27 PM
i didn't know u could make a ls1 carbed if thats the case won't it make the swap simpler?
Old Oct 22, 2006 | 04:41 PM
Vcious04's Avatar
AJE makes everything for the swap.. The reason I chose granatelli a-arms is price and availability.
I went with a victor jr. intake for holley pattern but did not buy the kit edelbrock sells. I bought the seperate controller through msd (MSD-6010) that comes with pro data+ software so I can tune it with my laptop. The MSD box that comes with the edelbrock unit only has plug-in style timing chips and no bells and wistles.
Old Oct 22, 2006 | 06:49 PM
PRAY HRD's Avatar
i just bought the car in my sig below. it's the one built by lx1 you'll find in several of the links listed above by zigroid. if you're local, you're welcome to come take a look at the car before i start stripping it for a more race type setup. right now it's still a stock ls1/6spd combo as i bought it. however, the car already has a nice set of 1 3/4" long tube header, 2 1/2" Dr. Gas "X" & dual Flowmasters with dumps & K&N filter.
-Dave
Old Oct 22, 2006 | 07:04 PM
zigroid's Avatar
pray hrd,
do you have to purchase a k-member specifically designed for use with a manual rack or will the flaming river rack work with any k-member?
I've got 4.6L mounts so I'll need a 4.6L k-member. I see QA1 kmembers are pretty cheap and seem to be one of the lightest, most drag oriented k-members. will the flaming river manual rack work with a QA1 k-member?
Im going for a bit of a crazy setup. I got an LS2 long block without rods and pistons. I bought some LQ4 rods and pistons and L92 heads. those, with GM headgaskets should give me around 9.5:1 compression ratio. I want to run mid 11s on 87 pump gas then when I get the funds I want to go with forced induction. if I could pick what today it'd probably be a D1SC but who knows in the future. the engine will be controlled by accel gen7 DFI.
Mine will be backed by a 4L80E though, not a t56, th400, or 4L60E. I just dont want to give up overdrive nor do I want to deal with a weak 4L60E. ive already had one go out twice.
Old Oct 22, 2006 | 08:49 PM
Flashman's Avatar
The Flaming River rack will work with any k-member.
Old Oct 22, 2006 | 09:25 PM
vanilla89's Avatar
zigroid
i have the qa1 k-member and my motor fits with no problem lots of room
and yes the Flaming River rack will work with any k-member
Old Oct 22, 2006 | 11:35 PM
Bandit28's Avatar
thats just wrong
Old Oct 23, 2006 | 06:34 PM
PRAY HRD's Avatar
why not go with an inexpensive stock reworked computer instead of a high dollar unit? if you're concerned about it not keeping up, or tunability issues, know this. a friend of mine on here has a twin turbo setup making 850 rwhp on pump gas and 96# injectors using efi live if i remember correctly & an acceleronics injector driver. however, you'll probably be fine with 72#-83# max. sounds like a good go fast plan either way.
oh, and as stated, any "K" will work with the F/R rack.
Old Oct 23, 2006 | 09:25 PM
zigroid's Avatar
my LS2 long block didnt come with a wiring harness or pcm.
pcm: 100-150
speartech custom wiring harness: 750
efilive or some other tuner: 400
so the total comes out to be about $1200-$1300.
considering I bought the accel gen7 DFI w/ wideband and sensor (which all is practically brand new) from a board member for $1400, I think I spent the extra $100 over going with a stock LSx pcm/wiring harness wisely
Old Oct 23, 2006 | 10:11 PM
PRAY HRD's Avatar
pcm: 100-150
oh, ok. i thought the speartech piece was $600, but free to do it yourself. but even with the pcm & harness & efi live, it's still not a bad deal considering you only paid $1400. now had you paid $2500ish, it would have certainly been a different story.
Old Jun 17, 2007 | 12:08 AM
does anyone know where you can buy ls1 ls2 motors? i would be going carbed so that would make the swap easier.
i would also prefer to get an engine and auto trans to drop in.
Old Jun 17, 2007 | 01:21 AM
also the car wouldn't have any smog, ac or power steering.
Old Jun 17, 2007 | 09:46 PM
hpmotorsports's Avatar
were are you located, I could probally find you a engine,
Old Jun 18, 2007 | 12:29 AM
KY 42301
i would prefer an auto tranny also
Old Jun 18, 2007 | 01:02 AM
does anyone have info on the oil pan or driveshaft?
