SFI 25.2 Mustang/LSx build "The Renegade"
#2210
Yes, its going up front where it sits in the 1st pic. I'm heading over tomorrow to pickup some 1.25" CM tubing for the nose structure. The rear mounted cell works fine, we're trying to cut some weight between the size and the weight of the -12 SS hose.
#2211
Race your car!
Alot of weight to be saved by putting the cell in the nose or sure. Dropping the stock tank out of my junk, and putting a 3 gallon cell in the nose saves about 20 lbs, and that's ove the STOCK fuel lines in the car.... with -12 line you're probably looking at twice that much
#2215
Jesus, went to pick up some tubing today, 6.50 for scrap tubing that isn't the correct size for certification. Called air parts inc. in Kansas, 4.40/ft for 1.25" .065 CM tubing. If anyone needs CM tubing http://www.airpartsinc.com/ is your spot.
#2218
Thanks, went by the welding shop today and exchanged 2 bottles of argon and picked up some filler. I've got maybe an hour between welding and finishing to get the headers finished. Shawn hopes to have the Racepak 300/EGTs/bungs here tuesday or wednesday. We're hoping to pick up another .15 next time out, 4.6x is the goal is the track is there.
#2219
WOW, I was told this was a GOOD long read... Great documentation!
I met you a couple of weeks ago at the track and asked you some questions about your car, I was standing with Arnold at the time... You had some great runs that night, I ended up leaving early though, how did you place?
#2220
