Cam Only Dyno Thread
Old Jan 23, 2008 | 05:59 PM
  #281
Sabre002's Avatar
Default LS1 RX7 cam only
ok I can add mine to the mix here
Custom Comp cam .589/.589 236/236 112LSA
Comp push rods 7.4
Comp 918 springs
Harland Sharp rockers
SLP DR timing chain
JTR 1 7/8 headers
dual 2.5" exhaust with X pipe into a dual 2.5 Apexi N1
Ported oil pump
stock crank pulley (when dynoed)
LS6 intake
Stock TB polished
4" LS7 maf (104mm) Custom CAI
spec 3 clutch
Fidanza Alum fly wheel
Old Jan 24, 2008 | 01:47 AM
  #282
ru_ssmaro's Avatar
custom cam 415/ 400
next week 215 tfs
Old Jan 24, 2008 | 10:13 PM
  #283
ru_ssmaro's Avatar
http://
Old Jan 24, 2008 | 10:20 PM
  #284
ru_ssmaro's Avatar
Old Jan 24, 2008 | 10:23 PM
  #285
ru_ssmaro's Avatar
Old Jan 24, 2008 | 11:25 PM
  #286
Midnight02's Avatar
Just got back from the shop with my cam install and I put down 389 HP @ 6200 rpm and 384 TQ @ 4600 rpm. The numbers seem a bit low for a M6 given my mods, however others have commented that this dyno is a bit stingy.
As for the cam...see my signature. The idle has a bit of chop to it for the nice, lopey sound, however it still has good street manners and a TON of power under the curve!
Old Feb 14, 2008 | 09:00 AM
  #287
Z28Fanatic's Avatar
2002 M6, TR224-112 cam, Pacesetter LT headers, ORY, Hooker Aerochamber, Donaldson Blackwing Lid, Factory LS6 intake, Dyno tune. 371rwhp/366rwtq. These numbers are with a chokemaster muffler instead of the hooker... Dunno what kinda difference that would make.
Old Feb 22, 2008 | 02:53 PM
  #288
02Ls1Formula's Avatar
Default cam only numbers
2002 Pontiac Firebird Formula
LTs with true duals
Ported Throttle Body
LG Motorsports G5X1 on a 112
UD pulley
LS7 clutch assembly
417RWHP 401RWTQ
Old Mar 19, 2008 | 03:23 PM
  #289
ArklaTexan's Avatar
My Mega Death Cam made 418rwhp cam and longtubes/exhaust
Old Mar 20, 2008 | 08:18 PM
  #290
bad6as's Avatar
1998 z28 m6 100K on the clock
slp lid, shanner ported throttle body, ls6 intake, edelbrock long tubes, ory, slp loudmouth II, 232/234 110+3 xer cam, 7.425 pushrods, melling oil pump, prc dual springs, LS7 clutch moser 9" 3.90s
MUSTANG DYNO NUMBERS from same dyno. CAR DOES NOT HAVE A UD PULLEY
pre cam 346 355
post cam 388 367
Old Mar 21, 2008 | 07:46 AM
  #291
Flamin' bird's Avatar
2000 Formula w 73k miles M6
Si5 cam
Patriot Extreme Springs
Futural PR 7.4
SLP UD Pulley
SLP LT's
LS6 Intake
Ported LS6 oil pump
LS2 Timing Chain
SLP Loud Mouth Catback
Gutted Cats
and....slipping old LS6 clutch
Khaotic Kreations, Warrenton VA using Dynomite Dyno
405 hp
388 tq
Old Mar 21, 2008 | 06:55 PM
  #292
Detoxx03's Avatar
2002 Trans Am with 56k on the clock
Slp lm2 catback with borla xr1 muffler
slp smooth bellow
qtp headers
custom ory-pipe
mti lid
k&n filter
yank ss3600 stall
tci cooler
futral motorsports cam 228/230 114 lsa
fast 92mm intake
ptm 92mm tb
slp u/d pulley
all work done by futral motorsports & tuned by Allan Futral
414rwhp
386rwtq
Old Mar 26, 2008 | 04:16 AM
  #293
jessesta's Avatar
Default 2000 ws6
tr230/236 112
hooker long tubes no cats
flomaster catback
lid/filter
tuned
380/380
not bad cant wait to get some more mods to support it.
idles and drives great
whole different car when you can rev to 6800plus!
Old Apr 1, 2008 | 05:34 AM
  #294
LSWONGTO's Avatar
2006 GTO with Full boltons untouched tb and intake (cam is in sig). 457rwhp 429rwtq on a generous mustang dyno. I think it is probably closer to 430rwhp but i have beat 2 of my friends pulleyntuned 03cobras from 40rolls so not sure.I will have to dyno on another dyno when I put on Trickflow225,s
Old Apr 12, 2008 | 03:22 PM
  #295
svodave's Avatar
Default Vindicator
2000 Z28 M6
405 HP - 370 TQ
SLP lid
p/p TB
LS6 intake
"Vindicator" cam pkg .608/.596 240/244 112LSA
Ebay headers O/R Y
Magnaflow CB
Slightly rich right now 10.8-12.3 AFR. Tuning ought to help quite a bit!
Old Apr 13, 2008 | 01:32 PM
  #296
scramblerman's Avatar
mods and dyno results in sig.
the Ls2 tb needs to be ported, maybe get a couple of hp more.
Drives like stock and still gets over 25mpg on the highway in fifth. Can put it in sixth around 60mph and no lugging. Car pulls hard all the way to 7000rpms! The hp drops just a bit between 6800-7000rpms.
Old Apr 25, 2008 | 02:23 PM
  #297
666 speed's Avatar
math > me
More along the lines of the cam only topic.
2004 GTO M6
TSP 233/239 .595/.603 112
Patriot Gold .650 dual springs
Hardened 7.400 pushrods
And a tune...
326/312 rwhp/rwtq on a Mustang dyno.
I'm kind of surprised.
First pull after the basic tune put 277/271.
Old Apr 26, 2008 | 04:21 PM
  #298
bad6as's Avatar
pre cam 346 355
post cam 388 367
WENT TO ANOTHER TUNER AND HE PICKED UP 10 RWTQ AND 8 RWHP CORRECTED ON MUSTANG DYNO, AND IT DRIVES WAY BETTER
Old Apr 29, 2008 | 10:05 PM
  #299
Kurt's Avatar
TSP Grind - 231/237 Duration @ .050, .581”/.587” Lift, 114 LSA
Hooker Long Tubes
3" True Duals, x-pipe, single chamber Flowmasters
Z06 85mm MAF
Ported TB
Lucas 30lb Injectors
SLP Flow Pac
T56 and 10-bolt with stock gears
395hp @ 6500 rpm
354ft/lbs @ 5000 rpm
Old May 28, 2008 | 09:09 PM
  #300
LS1-NAVY's Avatar
no torquer v3 graphs
