Slotted Rotors Worth The money??
Old 05-11-2007, 09:08 PM
JayBirdWs6's Avatar
got a link to these Brembo blanks?
JayBirdWs6 is offline
Old 05-11-2007, 09:16 PM
Black02SLPSS's Avatar
The only reason the rotors crack at the cross drill location is because whether the hole is cast there or drilled there, there will be a stress line or riser around the diameter of that hole. The simplest way to eliminate that problem is to countersink or champher the hole. When you do that it removes all the stresses created by putting a hole in that particular spot.
Black02SLPSS is offline
Old 05-11-2007, 11:11 PM
Copy & Paste Moderator
VIP1's Avatar
Check out the sponsors.... for example Sam Strano and Tire Rack both have them.
VIP1 is offline
Old 05-14-2007, 12:35 AM
Kage's Avatar
Cool
Originally Posted by Prerun4fun13
I am thinking about going with the $170 rotors on WS6 Store. I would go with slotted because i hear that drilled are more prone to cracking. The rotors on my car right now are warped and pads are pretty gone. So my question is, is it worth my money to buy those rotors and hawk pads? Or should i just machine my rotors and put the hawk pads on, i can do machine the rotors myself at school for free.
Slotted is good.
Kage is offline
Old 05-14-2007, 12:36 AM
Kage's Avatar
Cool
Originally Posted by patred48
I love the $80 rotors I bought at Auto Zone because they perform just as well as pimp $200 rotors.
Pat
Sure they do.
Kage is offline
Old 05-14-2007, 12:39 AM
Kage's Avatar
Cool
Originally Posted by 01pewter2001z28
I love mine well worth the $204 shipped.
Look just like mine. Paid $260
But why front's are drilled w/4 and rears w/3?
Kage is offline
Old 05-14-2007, 08:01 AM
patred48's Avatar
Originally Posted by Kage
Sure they do.
Tell me how cross-drilled brake rotors help my car stop in a shorter distance.
Pat
patred48 is offline
Old 05-14-2007, 04:41 PM
2001somws.6's Avatar
Here ya go.
2001somws.6 is offline
Old 05-14-2007, 06:54 PM
mitchntx's Avatar
Pat
Give it up Pat ... vendors love lemmings.
slots and holes for everyone!
mitchntx is offline
Old 05-14-2007, 06:58 PM
Kage's Avatar
Cool
Pat
Ummm....cause they just do. True story.
Kage is offline
Old 05-14-2007, 07:00 PM
Kage's Avatar
Cool
***** and Hoes for everyone!!!!!!!!!
Kage is offline
Old 05-14-2007, 07:29 PM
  #32
sleepinghawk's Avatar
Originally Posted by VIP1
Casting the rotor with the hole is stronger than drilling the hole into the rotors, but a rotor with holes is still not as strong as a solid rotor. There are some pictures floating around on here of Porsche drilled rotors (supposedly cast with the holes) that are cracked.
At the bottom of this are the pictures you are talking about.
https://ls1tech.com/forums/suspension-brakes/353903-brake-faq.html
sleepinghawk is offline
Old 05-14-2007, 10:37 PM
  #33
VIP1's Avatar
Read the FAQ:
https://ls1tech.com/forums/showpost....91&postcount=5
VIP1 is offline
Old 05-14-2007, 11:47 PM
  #34
patred48's Avatar
I still wouldn't pay $200 for an $80 ho.
Pat
patred48 is offline
Old 05-15-2007, 12:09 AM
  #35
Kage's Avatar
Cool
Manufactures make them because people buy them. Manufactures even admit that they are of no benefit with todays brake pad compounds. Hearsay.
Had DuraLast rotors on my truck before they sucked ballzzzzz.
I do agree on good Q brake pads making a big impact on braking performance *** well. All i know is i have Slotted & Cross Drilled rotors on my 4x4 and camaro and i can tell you i can feel big f'n difference in stopping power then before, period.
Oh yeah and they run a lot cooler too. Call me crazy. No BS here.
Kage is offline
Old 05-15-2007, 10:12 AM
  #36
VIP1's Avatar
Not this again. This back-and-forth argument comes up every once in a while.
Here are some more threads on the subject
https://ls1tech.com/forums/suspension-brakes/609794-i-need-rotors-used-cheap.html
https://ls1tech.com/forums/suspension-brakes/477787-need-help-explain-slotted-drilled-rotors.html
https://ls1tech.com/forums/suspension-brakes/435436-do-i-really-need-cross-drilled-slotted-rotors.html
https://ls1tech.com/forums/suspension-brakes/416955-warped-rotors-need-advice.html
https://ls1tech.com/forums/suspension-brakes/400960-simple-question-rotors-will-give-me-better-performance.html
https://ls1tech.com/forums/suspension-brakes/379657-rotors-pads.html
https://ls1tech.com/forums/suspension-brakes/325290-dimpled-vs-cross-drilled-rotors.html
https://ls1tech.com/forums/suspension-brakes/262940-replacing-rotors-what-get.html
https://ls1tech.com/forums/suspension-brakes/242301-drilled-slotted-rotors.html
https://ls1tech.com/forums/suspension-brakes/228985-brake-pads-rotors-you-been-through.html
https://ls1tech.com/forums/suspension-brakes/226769-need-rotors-resist-warping.html
https://ls1tech.com/forums/suspension-brakes/185268-power-stop-rotors.html
https://ls1tech.com/forums/suspension-brakes/185467-do-cross-drilled-rotors-improve-wet-braking.html
https://ls1tech.com/forums/suspension-brakes/172453-power-slot-rotors-any-good.html
Here is the infamous thread:
https://ls1tech.com/forums/showthread.php?t=262940
(Don't do what absolut said, he was joking.)
Wilwood:
http://www.wilwood.com/Centers/Infor..._answer/07.asp
Baer:
http://www.baer.com/Baer_tech/FAQ.html
StopTech
http://www.stoptech.com/tech_info/te...e_papers.shtml
Cracked Rotors:
https://ls1tech.com/forums/showpost....2&postcount=94
https://ls1tech.com/forums/showpost....6&postcount=14
Here is some good reading on brakes:
http://home.columbus.rr.com/trackbir...led_rotors.htm
https://ls1tech.com/forums/showthread.php?t=226769
https://ls1tech.com/forums/showthread.php?t=172453
especially this one:
https://ls1tech.com/forums/suspension-brakes/211436-how-about-some-hard-core-brake-tech.html
If I do some more searching, I'll find even more threads.
VIP1 is offline
Old 05-15-2007, 03:07 PM
  #37
mitchntx's Avatar
Call me crazy.
OK ... you're crazy
mitchntx is offline
Old 05-15-2007, 04:21 PM
  #38
z28bryan's Avatar
Some people have amazingly thick skulls and refuse to consider anything in those threads. I'm not saying that drilled/slotted is bad, but at least consider the information that's been given to them and drawn your own informed conclusion
z28bryan is offline
Old 05-15-2007, 04:36 PM
  #39
Kage's Avatar
Cool
OK ... you're crazy
wasn't necessary.
It's my f'n story and i'm sticking to it.
Like i've stated before i have Power Stop Cross/Drilled on my Ram 1500 4x4 had them for the past 5-6 yrs and not one friggin' issue and i do ride that bitch hard.
On camaro i haven't had the chance to even break 'em in yet, but so far so good, i love the stoppage power.
Question- Why should I use cross drilled rotors?
Answer- The primary reason is that cross drilled rotors run cooler, approximately 200-250 degrees, when used with high quality pads. This reduces the chances of warping, which has become a major problem in recent years, particularly on late model U.S. made vehicles. Additionally you will experience improved wet weather braking with shorter stopping distances. If you are experiencing pulsation on the brake pedal, your rotors are warped. It may be possible to turn them, but they will then be thinner and unable to dissipate heat as quickly as before, and will soon warp again.
Power Stop rotors are manufactured by Autospecialty, a subsidiary of TRW, and are used on many law enforcement and emergency vehicles which experience severe braking requirements, and are popular with taxi companies.
Original equipment quality rotors are used as a base stock. Each rotor requires a specific drilling pattern in order not to interfere with the cooling vanes, and this information is programmed and run on a CNC (computer numerical control ) machine. The end result is a brake rotor that is
Kage is offline
Old 05-15-2007, 05:54 PM
  #40
Ironhead's Avatar
FAQ from Baer's web site :
Will slotting or cross-drilling my stock rotors improve my car's stopping performance?
DEFINITELY NOT!
From Wilwood's site:
Drilling diminishes a rotor's durability and cooling capacity.
From Stoptech's site:
Unfortunately the drilled holes also reduced the thermal capacity of the discs and served as very effective "stress raisers" significantly decreasing disc life. Improvements in friction materials have pretty much made the drilled rotor a thing of the past in racing.
I'll alert the major brake companies that they have it all wrong.
To add my own $0.02....
I can provoke excessive ABS engagement on a set of four sticky Kumho V710 315s with heavy wheels using only blank OEM style rotors and what is basically a street pad.
How much more "stoppage power" do you think you need?
Not that you actually have more with those rotors...
Ironhead is offline
Quick Reply: Slotted Rotors Worth The money??
