Additional (Older) Stickies and FAQs
Old Nov 26, 2007 | 07:51 PM
Ragtop 99's Avatar
Thumbs up Additional (Older) Stickies and FAQs
There are many good threads in this forum. They all can't be Stickies, but here are a few. Use "Search" to find more.
Common Questions
https://ls1tech.com/forums/automatic...questions.html
General Maintenance Tips, Coolers, Trouble Codes and Other Issues
https://ls1tech.com/forums/automatic-transmission/886087-tech-info-codes-coolers-fluid-levels-cooler-flush-more.html
Understanding and selecting a Converter stall speed
https://ls1tech.com/forums/automatic...een-noobs.html
Tips for pulling your Tranny and doing a Converter swap
https://ls1tech.com/forums/automatic-transmission/819894-transmission-install-write-up.html
https://ls1tech.com/forums/automatic-transmission/821738-torque-converter-installations.html
Pictures from inside a failed converter and some pictures of sponsor converters
https://ls1tech.com/forums/automatic-transmission/862534-torque-converter-education.html
Tearing down and rebuilding your 4L60e
https://ls1tech.com/forums/automatic...60e-build.html --> An excellent and recent (2021) thread with many pictures and extensive discussion
https://ls1tech.com/forums/automatic...turbo-car.html --> Another recent (2021) thread with many pictures and extensive discussion
https://ls1tech.com/forums/automatic...ld-thread.html ---> (2016 Thread) Includes 100 Hi-Resolution pictures covering every step.
https://ls1tech.com/forums/automatic...rebuild-2.html --> (2016 Thread) Includes many photos and good discussion
https://ls1tech.com/forums/automatic...ld-thread.html ---> Many photos and detailed explanation
https://ls1tech.com/forums/automatic...up-photos.html -- A bit older but still useful
https://ls1tech.com/forums/automatic...lot-pics.html] -- A bit older but still useful
4L60e Line Pressure
https://ls1tech.com/forums/automatic-transmission/114376-line-pressure-discussion-when-too-much.html
4L60E Case, Valve Body, Pump differences between years
https://ls1tech.com/forums/automatic...vs-2001-a.html
Transbrake in a 4L60e
https://ls1tech.com/forums/automatic-transmission/482258-4l60e-transbrake-installed.html
M6 to A4 and A4 to M6 Conversion info
https://ls1tech.com/forums/automatic-transmission/200477-m6-a4-a4-m6-conversion-info.html
TH350 / TH400 / Powerglide: Everything you need to know including how to swap it into an F-Body
https://ls1tech.com/forums/automatic-transmission/815618-th350-th400-frequently-asked-questions.html
https://ls1tech.com/forums/automatic-transmission/197642-what-would-you-like-see-addressed-th400-faq.html
4L80e Information including how to swap it into an F-Body
https://ls1tech.com/forums/automatic-transmission/699277-whats-needed-4l60e-4l80e-swap.html
https://ls1tech.com/forums/automatic-transmission/771278-4l80e-slip-yoke.html
Dope Style Transmission Cooler Mounting for those with FTRA and SSRA ram air intakes
https://ls1tech.com/forums/automatic-transmission/476059-trans-cooler-dope-style.html
Old Nov 26, 2007 | 07:52 PM
Ragtop 99's Avatar
We will update these as other noteworthy threads are created or bubble back to the top
