02 WS6 Oil?
02 WS6 Oil?
I just got my 02 WS6, did these cars come from the factory with synthetic oil? I'm not sure what is in there now. I was thinking of switching to Mobil 1 synthetic. Or I might just use regular oil since I change the oil often. I know with synthetic your not supposed to change it every 3k miles, right?
oil info
Here's a bunch of threads discussing oil
https://ls1tech.com/forums/generation-iii-internal-engine/147090-cam-spec-sheet.html
https://ls1tech.com/forums/generation-iii-internal-engine/66308-when-rec-use-synthetic-oils-new-car.html
https://ls1tech.com/forums/generation-iii-internal-engine/181274-switched-mobil-1-0-w40-now-less-oil-pressure-higher-temps.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/196081-conventional-vs-synthetic-oil.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/133308-conventional-synthetic-oil-process.html
https://ls1tech.com/forums/generation-iii-internal-engine/146746-synthetic-oil.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/156026-15w-50-synthetic-oil.html
https://ls1tech.com/forums/generation-iii-internal-engine/1054-new-quaker-state-synthetic-oil.html
https://ls1tech.com/forums/generation-iii-internal-engine/155787-synthetic-oil-redline-oil.html#post1215204
https://ls1tech.com/forums/showthread.php?t=147639
https://ls1tech.com/forums/generation-iii-internal-engine/162666-mobil-1-ok-not.html
https://ls1tech.com/forums/generation-iii-internal-engine/141531-what-engine-oil-use.html
https://ls1tech.com/forums/generation-iii-internal-engine/2019-what-weight-oil-you-using.html
https://ls1tech.com/forums/general-maintenance-repairs/635-why-engine-oil-causes-noise.html
https://ls1tech.com/forums/generation-iii-internal-engine/66326-oil-filter.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/192005-synthetic-oil-question.html
https://ls1tech.com/forums/general-maintenance-repairs/58075-synthetic-oils.html
https://ls1tech.com/forums/pontiac-firebird-1967-2002/208434-changing-10w-30-5w-30-opinions.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/149076-ls1-oil-consumption.html
https://ls1tech.com/forums/showthread.php?t=104276
https://ls1tech.com/forums/generation-iii-internal-engine/125526-cause-2000-ls1-burn-oil.html
https://ls1tech.com/forums/generation-iii-internal-engine/61070-engine-break.html
https://ls1tech.com/forums/general-maintenance-repairs/1877-oil-change-intervals.html
https://ls1tech.com/forums/generation-iii-internal-engine/65365-new-mobil-1-supersyn-formula-yay-nay.html
https://ls1tech.com/forums/generation-iii-internal-engine/137060-synthetic-oil-life-study.html
https://ls1tech.com/forums/general-maintenance-repairs/28194-changing-oil-change-oil-light.html
https://ls1tech.com/forums/drag-racing-tech/172674-15w-50-oil.html
https://ls1tech.com/forums/generation-iii-internal-engine/93622-re-build-how-soon-change-oil.html
https://ls1tech.com/forums/general-maintenance-repairs/49830-oil-filter-question.html
https://ls1tech.com/forums/generation-iii-internal-engine/69540-oil-questions.html
https://ls1tech.com/forums/generation-iii-internal-engine/78269-oil-gets-darker-car-running-rich.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/139210-what-kind-synthetic-motor-oil.html
https://ls1tech.com/forums/generation-iii-internal-engine/172097-mobil-1-a.html
https://ls1tech.com/forums/generation-iii-internal-engine/158892-want-change-synthetic.html
https://ls1tech.com/forums/general-maintenance-repairs/127484-mobil-1-synthetic-5w-30-newer-vehicle-formula.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/149395-oil-change.html
http://www.f-body.org/faq/4/4_2.htm#ch4_2m
(woah, I didn't realize how long the list was until I submitted it )
I don't care what any motor oil company says but I willc hange my oil every 3k or if it has been ran hard. Cheap insurance. Of course, if the oil company wants to buy me a new motor then I will change it when that say to.
I prefer synthetics. Mobil 1, Redline, or Royal Purple.
Originally Posted by LoudmouthLT1
Use synthetic and change at 3k or 3 months.
I second that.I bought my 2002 WS6 new and at 1000 miles i switched to Mobil 1.Since then I have changed the oil every 3months or 3k miles.The car now has 24k miles and hasn't used a drop of oil between changes.I know that some people say you can go longer between changes but to me changing the oil every 3k miles is cheap insurance. Besides ,it's my money my choice!
Kleeborp the Moderator™
But you are right...it is your money.
Originally Posted by pewterta
synthetic...can go 5k easy.... 3k is a waste of money...time to get with it slug
You're that cheap that you can't spend the extra $20 every 3k? I prefer my car to last with no problems. And the fact I work with cars for a living makes me believe I know a little something about them. I don't care what the oil advertises, 3k or 3 months.
The last time I checked, the materials for my oil changes cost around $40, AT LEAST. And to the best of my recollection, you can really only tell when oil needs to be changed by doing oil analyses. Most of those indicate that you can go well over 3K miles with good oil (remember - I said GOOD), provided you don't go out road racing or auto crossing all the time.
Just my $.02
Jiffy lube are idiots. They say you need to get winter blend oil...wtf is winter blend oil? They put in synthetic blend and say thats whats for the winter. I still say 3k or 3 months. Completely your decision.
Originally Posted by MeentSS02
Winter blend? That's pretty common knowledge ...they put that in, flush out your blinker fluid, and rotate the muffler bearings. Apparently, you don't know anything about winterizing your car
