- Engine mount replacement
- getting shift knob off...*pics added*
- Chippewa Valley Cars and Coffee (Western Wisconsin)
- Anyone want to sell their maggie?
- Um.....why has no one spoken of this?
- The V bit the dust today...
- lug nuts...
- CTS-V Heresy!
- Reverse synchro question
- Clutch Drag
- CS vs. UMI motor mounts
- Drive shaft Opinions please
- Did the V1 come with a suede shift knob?
- Balancing Clutch Assembly...
- 5 lug conversion...offset change?
- What is the logic behind the shifter/trans setup we have...?
- how did Mallett do it...
- Kooks Headers finally in! (Uncoated)? Question
- ls6 value
- rts's on a v1!!!
- No Communication to ECM from BT Dongle
- 5 lug conversion with Z06 Wheels
- V went on the dyno
- DIY Plastidip
- Help identifying these rims on my V and if there trade worthy.
- Revshift Motor Mounts, Rear Cradle Bushings
- Brian(PISNUOFF) Shifter Ordering has been stickied.
- Anyone gone from Specter Werkes cradle inserts to CS/Revshift cradle bushings?
- Creative Steel Subframe Front sway Bushings INSTALLED!!!
- srx floor mats in a V
- Austin Area
- Bay Area Body Shop (Quality) needed
- A runaway shopping cart viciously attacked my fender.
- H\C\I and now Headers Dyno
- Boost for Boobies
- Anybody have an extra clock spring?
- Got my CTS-V dyno tuned today.
- Running right? After header install...
- what metal is the stock exhaust pipes on V1?
- Has anyone heard of a subframe swap?
- Weight of accessory wheels
- forgestar limited avail.
- diff oil spot??
- anybody changed ALL the interior lighting color?
- DW301 Came With The Wrong Fuel Filter
- Where to buy Coilovers?
- Huge Thank You To Revshift
- K-Sport or D2 Coilovers IN STOCK???
- Nitrous V1.
- Just replacing mufflers with after market
- Cts-v1 > = < c5/c5z
- Looking for an A/C block plate to convert to regular o ring fittings
- ecm pinout??
- cryo treated rotors
- Is anyone running a Diablosport Trinity tuner on their V?
- LSA heads on LS6?
- Computer gremlins, need help
- Brake Rotor/Pad options
- Best Headers for the price/$ install prices in Michigan
- Trailing Arms?
- Opinions on mods im going to be doing
- Noise AFTER bushings???
- Gen 3 diff plus upgrades for 550whp street car?
- who's car is this
- Could a ls9 cam improve highway mpg?
- Any Amsoil dealers around? I need some DOT 4...
- What are your thoughts on new clutch break-in periods?
- plastidipping the grills
- Has anyone gone with the Creative Steel "Mega Deal"?
- Hydraulic E-Brake
- Output shaft seal
- MN Cars & Coffee event,bring your V
- ATI Part Number??
- ls7 clutch install - pressure plate bolts
- 1st Post! | Just bought 2005 CTSv | 100k mile maintenance?
- loose/broken ground wire- where does it connect?
- CTS-V Clutch Install Write Up Monster Twin Disc
- Spectre cold air intake?
- Shimming ls7 slave
- lq4 swap
- Possible new CTSV owner....need the skinny
- Pics, burn out vid, FUN!
- Place to buy new inner fender??
- Re-coloring V badges
- Need rear shock hardware
- the v1 reverse fix
- anyone have their starter drag?
- Anyone near Denver Colorado?
- Tryin to buy a V1
- Strange XM problem
- 8.8 guys come in
- Buying Headers
- Rev Limiter in 1st?
- Brights and Fogs on at same time
- Lowered the V: H&R springs w/ MM spacers
- Officially Welcome 07CTS-V as a sponsor!
- V1 compared to V2
- What fan comes in 1st?
- plug in & play AUX input!
- V1 Projector (Low Beam) Lens Upgrade
- 54inch shifter installed
- Custom Interior Trim
- stock 2013 CTSv dyno numbers Tampa Tuning
- Need part number
- Left rear speaker
- How many of you still have the 1-4 shifter lockout ?
- Checking out 05 V tomorrow..
- Lower steering shaft removal help
- '05 V, cam setup or "all around" mods
- V1s on Drag Radials
- Stabilty DTC Codes
- So this happens...
- Cutting springs
- TPS Replacement? Pics
- Dual Halo Projector Headlight "Bounce"
- Creative Steel: CTS-V 5 Lug Swap
- Abnormal Engine Temps.
- New member
- head light plug pinout
- CF Drama/Vendor Drama.....
- Replacement front badge
- NAV screen replacement....
- mellowing out the exhaust
- Shout out to 07CTSV
- Looking for ABS Connector Pinout
- Spark plug change, anti-seize?
- Welp, just my luck.
- Catastrophic RacingBrake 2-piece rotor failure on track
- Removing rear deck on V1
- Should I buy, says "stability system" needs service
- Sucky dyno numbers
- Need help Cam install
- 450-500rwhp goal build. Thought & opinions
- lowering my 05 cts-v
- amp install
- Is this a good deal?
- The consequences of a suspected broken valvespring
- Motor build has begun, having second thoughts
- Dyno tuning April 4th & 5th in St. Petersburg, fl
- INDY V MEET. May 31 2014
- Steering Shaft Part Number
- Cts v clutch issues/ACT clutch install
- Bad vibration in steering wheel...sometimes.
- anyone's steering feel "notchy" or feel like it wants to stop at a certain position?
- It appears the Powertorque CS2529 is available again
- Revshift takes care of you.
- Fluid change
- Which bushing/mounts to inspect?
- Need help with next mods
- Cleaned TB now high idle..help?
- Need some opinions to justify my OCD
- Exhaust leak
- 4/5/2014 Cars & Coffee in Plano (Meet at Shops of Legacy @ 6:30am)
- Exhaust Hanger bushings
- V2 Caliper on V1 How-to
- Downgrading GPS firmware
- You can rent a V2?! TX2K14 clip inside.
- Fender stripes on CTS-V...thoughts?
- Steering Rod removal
- Rod knock or dual mass flywheel?
- MM frustration!
- Question To Experts
- Clutch time again, what's the concensus?
- clutch install thread
- O2 simulators
- Fuel pump replacement
- Finally put on the F14's
- Cts v license plate ideas!!
- Anyone have Brian's (PISNUOFF) shifter install instructions hanging around?
- Well the V got backed into
- Emblem placement
- Opinions on my modifications
- 8.8 question...
- Removing metal from backseat and losing lb's
- FE4 Stud snapped
- Where did he get this front lip....
- Replace that driveshaft bearing!!!
- Yaw Sensor ?
- Had to do it...New tag
- Syncro grind at high rpm
- Some Minot T56 Carnage
- Anyone know what wheels these are?
- First time down the strip
- Anyone recommend a shop NW IL burbs?
- Which one do I buy Hendrix or Gforce Axles
- Red Line HeavyProof Gear Oil
- muffler delete
- Colored Wheels Or calipers on a V.
- Nice deal
- $100 off $400 at Discount Tire Direct
- Emblem mounting?
- slp 25 percent ud pulley, which ac belt?
- Highest Mileage V2
- NAV radio knobs question
- 1000hp V1 on eBay
- dual programming in ECU
- Is This the Same Caliper? ACDelco 172-2308
- CTS-V Blacked out Turn Signal
- Is there really any danger in driving the V with no exhaust?
- PCV question
- Parking Brake/Stability System Lights
- Track Event Memphis, TN May 16 & 17 2014
- Valve springs/timing chain
- Who bought team dynamics wheels on eBay?
- Cradle Bolt Part #
- high flow cats and plug defoulers
- GA TN AL SC FL folks step right in! Drag strip rental 03/22/2014
- Joing the club! FBODY to CTS-V :))
- 05 V wont start after radiator install
- Massive pile of V1 problems!!
- It's me or the V! A good one for V1's lol
- Aftermarket headlights not fitting (UPDATE)
- 8.8 Rear end out of a 2001 Cobra?
- What is an 04 shell worth?
- CTSVOwners.com
- forgestar group buy?
- Electronics question about LEDs and diodes
- Ls6 gone at 96k, ideas for build?
- Damn turbo Buicks:
- Wiring issue on V1
- terminal?
- 2010 V Dyno Pulls
- Those w a light flywheel - Post your HPT file?
- My V1 ls6 Cam dnyo :)
- Add me to the V list
- Would anyone be interested in some V1 weight information?
- CTS V Car Covers
- Possible wheel hop cure?
- Just ordered Revshift Cradle/Diff bushings, what else?
- LED switch
- V1 carbon front splitter
- Just got off the dyno
- Alradco radiator group buy...
- Joined the Club
- Options to turn off rear o2's for CEL
- SoCal V Owners Canyon Cruise
- T56 5th and 6th gear vibrations
- Added several motor parts. What should be next?
- Tell why NOT to buy Pacesetter headers
- New to me CTS-V!!!!!Project
- B&B 3 inch, drone, and cones.
- Exhaust is done on v, not loud enough
- Best place for aluminum radiator for 05 V?
- E85 practicality
- Another cts v rear cradle question
- Arbor Press or Ball Joint Tool?
- Totaled my V1 and need a little assistance
- Trans Exploded!!!
- Need a input shaft
- Need new fuel pump
