- Ls7 clutch on ls6
- ? About running a oem ls9 clutch and flywheel *asap*
- Dynamax VT, do yours "clank"
- The end all shifter bushing thread
- v1 cts non-v. Worth modding?
- Gen2 Engine trouble Any Midwest guys have any hookups?
- Cam Swap!!
- PLEASE help with my stereo mystery!
- 04 cts v t56 leak
- Trans noise
- Anti-Wheel Hop on a budget
- pilot bearing removal
- PSA - Fuel Module/Harness Recall (N140405) is now actionable
- 3rd. brake light murdered out.
- Hadn't seen this one till today.....
- chevk engine light on BANK1
- Cadillac makes its move on not only the initial GT-R, it passes a second one in the p
- Well, shit.
- Brake pads grinding on rotor
- Need help identifying replacement hose (throttle body coolant hose)
- teaser Tuesday
- Cam ideas needed!
- What's better than finding $20 in your laundry?
- Cts-v supercharger recall questions
- Thanks to VooDoochikin04!! (drive shaft repair)
- mp112 front pulley issue - jackshaft size?
- custom V and Crest inserts...w/ pic UPDATED pics on car
- 04-07 cts v test pipes
- Battery in Trunk, Disconnect Switch & Fuel Swirl Pot
- Creative Steel v. Katech Shifter
- c6/LS7 Luk Repset clutch & flywheel
- Stage II cams on DD
- Fuel pump
- V1 5 lug swap [complete]
- Fluid Capacity
- should i delete resonator for an xpipe?
- What kind of power from these mods Ls6
- clutch drag? but passes the test..
- Those with T-56 bronze isolators cups, please check in.
- crank pulley
- Cadillac Challenge | Buttonwillow Raceway March 8th, 2015
- Oil Pan Gasket
- what CAI for my 06 ctsv
- CTS-V LS2 tune vs non-CTS-V. What's Different?
- '05 won't start, ground issue?
- New project. Comments and advice please.
- Service airbag codes B0066 B0092 U1016
- Recaro Seats - Gen I
- Replacement Brake Rotors
- Hot Chicks and V Gear! Come inside!
- cts-v noob clutch help
- My budget regulated return
- connection is whooping my ass
- What to do with 12k on my First Gen V...
- Water/Meth Injection
- Ctsv grill
- Throttle response controllers?
- CCW 505a Chrome Issue
- V2 guys with EFI Live.
- Why NOT to Buy One of These Blowers
- Fuel pressure regulator plumbing
- Mil Spec harness for CTS-V
- 2005 CTS-V I just bought as a daily!
- V1 Headlight issue.
- I need a driveshaft CV.
- Torque arm for wheel hop?
- Team Dynamics center caps? What's the deal?
- CTS-V as a daily. What to look for?
- V1 aftermarket D1s ballasts
- Why all the locked threads?
- wheel guys step inside
- P0641 Plus a few other codes
- removing maggie from ls2
- ASP crank pulley
- clutch hydraulics suddenly on the fritz
- 04 cts v racetronix pump wiring?
- G force axles
- Slotted only rotors?
- Slimline fan graft into stock shroud complete.
- Cooking clutch fluid
- No power getting to the starter. Please help.
- DRL wont turn off
- New V Hats.
- Dyno results, cam added to 1:1 rears.
- Looking for an engine dyno near DFW
- stroker......... again
- replacement starter
- Clutch line part # request
- Cam Install questions
- Another hilarious Craigslist ad for a "CTSV tribute"
- people with cradle bushings, chime in
- Will Katech slave work in a V with PMC Master?
- Normal engine temp?
- Spotted V1 in MD on Norbeck Rd in Rockville
- Magnuson upgrade ?
- Anybody run M4?
- Van meets cts-v
- CTS-V V2 curb weight? Requesting 2009-2015 owners post scale results inside. Thanks
- My '09 Cad CTS-V:
- Magnuson MP112 differences between GTO LS2 and CTS-V LS2
- ls2 mp112 killer deal.
- Exhaust sounds Brian Tooley PDS stage 3
- Megan coilovers
- Bleeding a Clutch Master Cylinder
- Stock fuel gauge ohms rating
- Motor Trend's ZL1 vs Hellcat comparo vid
- Best differential gear ratio for 1/4 mile
- revshift motor mounts
- SMH... Clockspring...
- Looking for HP Tuners 2.23
- Hellcat vs the World vid
- heater cores are a blast!!!
- Installing Gauge Next to Coin Tray
- who is this V1 turbo build?
- YAW sensor? Or no TPMS sensors causing problems?
- So that happened...
- trouble shifting into 5th
- 3.3 Whipple on E-bay
- mm spacers won't stop clicking
- Smoothest shifter
- end links for really low cars
- [VR] 712whp / 644wtq Cadillac CTS-V Sedan - Build Pics/Dyno Results Inside!
- haunted radio
- Who runs a boost-a-pump on a V1?
- Shout out to vendors Tick, CS, MechMan, Voodoo, Brian,
- What do you guys suggest for spark plugs?
- Cam swap, is bumper removal required?
- 1,200whp+ Dyno Pull Video on 2009 CTS-V 6MT
- If it meant a 30% Discount on insurance........
- ATS coupe emblem on V1?
- Brian Tooley blower cam V1 Maggie
- The 2016 Cadillac CTS-V at the North American International Auto Show in Detroit
- Subwoofer replacement
- getting my headers installed... anything else?
- Brake, TC and ABS light on
- 2007 CTSV won't start.
- Comments welcomed on LS7 set up.
- XMas again for Nadine, she's got voodoo now.
- The Best Deals On An Awesome CTS-V Clutch @ Hinson Motorsports
- Dyno results, 1:1 rears
- OBX headers install..anyone do it?
- New to the GM world and considering a CTS-V
- Burning smell after driving
- Electrical Specs for our cooling fans.
- HELLCAT vs C7 Z06 VETTE
- The 3 Kings left a present at my door!
- 07' V Motor coming out. Any tips?
- Radiator recommendations ('06)
- 05 ctsv Ls2 block swap/conversion
- Cable hanging from under front bumper
- Weird sound
- Just Bought 2011 CTSV ... Known Issues? Fixes? Recalls?
- Shifter remote linkage bushings?
- What is everyone's battery voltage showing?
- Heat Shield Rattle? 05 V
- Wheel hop...fucking wheel hop
- What computer is in the 05 gen 1 v?
- Ouch!!!
- Quick nav question
- click, no start...(intermittent)
- New aluminum pulley kit installed
- Could I install a resistor (for an LED blinker bulb) at the fuse?
- New CTS_V not afraid
- 2014 CTS-V rattle sound
- 2016 Cadillac CTS-V - Official
- New V styling
- Is my rear finally going? Sound clip, tell me what you think.
- Looking for measurements for Kooks/OBX and Corsa
- Tell us all your problems
- Clutch line "check valve"
- New borla stinger exhaust
- need help with lean evap and map codes
- Voodoochikin04 Driveshaft Carrier Bearing and Bushing Review
- yanking an 8.8, the process?
- Just bought an 04 cts-v and have some questions
- [VR] Vengeance Racing CTS-V Coupe - 2.3L Blower/Nitrous Outlet - Pictures/Dyno Result
- Like a Kid at Christmas
- Does this mean what I think it means? (rear end)
- Installed My MM rear shock spacers with a TWIST
- What the hell are all these connectors in the trunk?
- Jacks for lowered V1s
- Stainless Brake Line Solutions
- Bleed brakes, terrible pedal.
- Custom air box lid for volant CAI
- After shifter install, wont start!
- What causes rear ends to blow?
- Hard to shift into gear - Bad clutch mstr?
- Anyone installed Philistine's MC along with a slave spacer?
- speed (NOT RPM) related vibrations - culprit?
- dilemma...
- FYI: OEM transmissions mount
- Hemi hellcat smokin' a cts-v video
- What color are your headers in the Winter and Summer?
- Engine shudder on shut down
- Blew a Fuse - Rear View Mirror
- Check those brake lines!
- Shifter installed....progress report.
- my BADILAC
- Activating Alarm Horn without Stock Radio??
- 12 Days of Christmas Deals @ Hinson Motorsports
- Creative Steel adjustable shifter
- Plug N Play Customizable Dash for Your CTS / CTSV @ Hisnon Motorsports
- Squeaky poly bushings in front end
- CTS-V on Big Bang Theory
- 2005 LCD display oddities
- 2007 CTS-V video
- Sweet cyber Monday deal on the Eastwood Fender roller
- 07' CTS-V Single Bolt Cam?
- Had my engine mounts replaced this past weekend...
- Does anyone recognize this V2 that I just purchased?
- Banski RSM install Q
- Stability Control on 05 V, inconsistent?
- V1 suspension question
- V1 fuel return
- Steering wheel mis-alignment after clunk noise
- 2010 cts wagon (3.6) burn project underway (V2 lsa swap) not pretty
- dumb A/C question
- Black Friday 9.55 ring and balancer kit special
- Identifying marks on FG2 shocks?
- Transmission noise - video inside
- 05 power steering pump?
- Fast 102mm Intake
- GM Part # 19299070 on back order...till when?
- 4th Gen Rear Question
- been thinking about custom light weight things.....
- V2 cradle and rear in V1??
- Fuel smell & sucking air after pump replacement
- Axle popped out, or is something broken?
- Considering 09+ A6 V Sedan - what to look for?
- Leaking radiator or hose?
- 07' CTS-V dyno results
- Sound of a diff going out? Or paranoia?
- First time w/V at track 11.468@121.44 mph
- Stock Axle Information Needed
- Having problems putting into gear
- Deformed prop shaft, what happend?
- Freezing Temp Affect Valve Springs Life?
- I finally fixed my faded V badges :)
- Knock Knock...Who's There? Rods...Dangit!
- How to hook up a raptor shift light on 2014 CTS-V
- Auto lights issue/function
- More pics of new ATS-V Coupe
- UMI motor mount inserts
- Mille Miglia MMS wheels
- Mille Miglia Wheel as a spare
- 05 Cts-v
- Had the CTS-V 1 on the scales last night to see
- 8.8, cheap axle chat
- HARD left steering
- How do I read codes on a 2014 cts-v
