- 04-07 CTS-V general question
- Couple group buys coming up
- Radiator help
- New rear cv-joint from oem prop shaft available
- Elusive water leak into cabin...
- Front Factory Spring Rates
- Group buy for subdued US flag crests.
- Complete Street Performance Fall Specials
- Buying a gen 1 cts v help****
- Maybe I'm Crazy
- I'm back
- Another reverse problem.
- Looking for a service manual download for Cadillac CTS-V 2004-2007 (Gen I)
- Alternator R&R...
- Bottom Front Shock Bushing
- Brakenetic GT Style Rotors
- First trip to the track...HOPPPPPP!
- Are the Corvette jack pads a good investment?
- Ridiculous Autotrader Find...
- Hit the Dyno for science: 1088whp 1051wtq
- Need HELP clutch issue
- Air pressure release sound from engine bay...
- GEN1V Diff Brace!
- Catalytic Converter replacement
- Electric/vacuum actuated mufflers on a v
- 06 cts w/random multiple misfire issues
- Question about ac makeing a lil noise
- Difficulty shifting into reverse...
- Neep help to post a video
- ATI Harmonic Balancer Install
- Cleaning headlight lenses...
- Know a mod on another forum?
- What are the diff cover bolt torque specs?
- Gen 1 CTS-V rear diff
- Some love from Farah
- Want to return front end to original height...
- ACT Twin
- Rebuilding the factory driveshaft cv joint
- Aftermarket keyless entry
- security system
- Old thread request. Stock muffler mod
- Front turn signal upgrades?
- Trash Can Mod
- Anybody rebuild our CV's
- Oem 2007 cts-v muffler
- Fully built Iron block LSA with 8.8 walk around
- The ultimate solution to the CTS-V1 shifter and transmission issues - Magnum XL Swap
- CTS-V 2005 6 Lug😩
- Stock replacement clutch MC vs aftermarket MC
- New V-owner! Want suspension, exhaust, etc.
- Problem: New LS7 Clutch - Cant shift and Slips in 2nd and 3rd Gear
- 173.7mph in the 1/2. Video Inside
- Cheeeeeep 6-lug rotors $12.38?
- New to me, 2007 CTS-V owner here...time to mod!
- Question for the FAST 90 and 92 guys.
- 2 problems - Nav DVD wont load and right speakers out
- What you guys think?
- New stablemate for my V1.
- Need help!!!! Bad!!!!
- Need opinions/options splitter rods
- Radio Graphics Repair Kit
- Help with tranny scensor leak?
- Threw in an Android deck in my V....I like it!
- Almost 30whp gain from tune *Video*
- Latest episode of Detroit Muscle
- Calling all axle experts
- Spoiler for my V
- switched accessory power
- 04 V, won't crank
- Beginning to mod the 05 V.Corsa resonator delete.*VIDEO*
- Fuel smell near rear/side of car after track sessions - any thoughts?
- Bought an 05 ctsv...need advice?
- What do you use?
- alternator pulley size and voltage output?
- Rear cradle needed for diff brace template
- 2005 Silver CTS-V. 77k miles
- Creative Steel Stage 1 Motor Mounts
- Calling all smarty pants people...
- RPM specific vibration
- Dyno tuned the V today
- What Happened To My Turn Signals?
- Accel ceramic plug wires
- V2 front cradle swap....
- V2 Parking Brake
- Bad power steering pump?
- Need some exhaust advise
- Anyone on this site own this v
- Squeal at high RPM
- Group Buy Feeler: Flat Steering Wheel and Fast Ratio Steering Rack
- 20th Annual Buick/Olds/Cadillac Race/Show Nationals at Norwalk Raceway July 23, 2017
- Anyone use cerrakote C-7600 coating?
- Fml...
- Fortune Auto 500 series coilover CTS-V Gen 1 group buy interest
- 8.8 Swap
- Front bumper sag
- What size tires are we running?
- Interior Protectants - 3-Way Shootout (Mothers, Blackfire, and 303 Aerospace)
- Need help finding the right bolts
- Those with aftermarket seats, airbag bypass?
- V1 drag pack
- New to me FAST92 ported intake.
- Rear A/C
- ThatKevinC's '04 CTS-V Progress Log
- Tick Polluter v2 Dyno Results
- Some upgrade/replacement options please. Shifter and exhaust cutouts
- Power Steering Return Hose
- Sunroof Delete... anyone want one??
- Base cts axle vs V axles...
- A/C Compressor DIY Needed
- Front splitter to buy or to make?
- Dorman shaft
- Anyone in the Houston area available to lend a hand?
- Revs hang between gears
- Brake switch replacement
- Overclocked steering wheel...what did i break?
- Need replacement shifter assembly for '05 CTS-V.
- Need help starting the car after harness repair.
- Has anyone tried these TPMS sensors?
- How to flash the navigation
- Pulled the plug!!! Here she is!!
- V-Series Emblem Comparison
- 05 blew rear end ,now what?
- New V owner needing help diagnosing clutch issue - HELP!
- Hotchkiss sway bar nut size
- CTS-V shopping - a couple questions
- New owner here
- Headers and emissions
- Loose steering?
- Bare block
- Coolant Fan Problems
- Tech2 road trip silver state race ely Nevada
- Dropped the bumper for headlight bulb replacement now issues
- Ect
- OC MD cruise
- Had the V on the Dyno
- 06 V Steering Rack question
- Question about the XM roof antenna
- Looking for fender flares for V1
- Help with foglight HID
- Any interest in Improved Racing's CTS-V oil pan baffle?
- Clutch Master Cylinder installation tricks?
- 19'" Wheels on Stock Suspension?
- LSA Crank pulley on LS2 crankshaft
- Driveshaft fiasco continues?
- Braking after 5 lug swap?
- All of the sudden a/c problems
- Wear on UCA bushing rearend
- Engine splash guard
- ECM Upload
- Blown FG2 Shock, replacement?
- Ls7 clutch parts
- Racetronix hotwire kit instructions?
- Driveshaft decision
- Can u use a carpet cleaner on the seats?
- DIC workaround
- Tint questions........
- Lug nuts. Yes, seriously, lug nuts.
- Lowered and too much camber
- Clutch pedal sensor or sensors?
- Folks with Luk LS7 clutch issue, pls chime in
- Anyone have a 5th gen Camaro?
- Help please. Airbag light
- Help with engine rebuild
- Reverse Lock Out and Automatic Locks
- Slave cylinder compatible?
- My hidden nitrous wet system
- LS2 Spark Plug Wire questions
- V2 speed + diff
- Anybody up for the seat challenge?
- Axle/Diff compatibility
- High frequency vibration 80+ MPH
- LS2 Clutch swap to LS7 locations in South Florida
- 06 Steering wheel functions
- 8.8 vibrations...who has them, who doesn't
- Torque To Yield Bolts
- Looking for Oil Pump Recommendation
- GTO frcīs on LS6
- TPMS relearn procedure doesn't work
- 5 lug Pros I need your help
- Wheel fitment
- Grind Grind 0 Oil Pressure!
- radio change
- What is the normal battery draw?
- New V owner with an A/C problem...
- Driveshaft alignment
- PA15-VETTE display?
- 2005 CTS-V Headlight washer removal
- Coolant Temperature Sensor
- Is this the rear axle pinion seal leaking?
- 5 Lug drag tire wheels??? What are you using?
- ARP bolts for LS7 clutch?
- How to properly center the clamp in this
- Converting To A 4L80E Or TH400
- G Meter reading off?
- Big 3 question: ground location
- TPMS fix/replace/remove
- Anything else I should do, "while I'm in there?"
- Dash Cam
- Windows and radio not working
- new solution for more power!
- What tranny will work on 2005 ctsv
- Please help
- Chinese Android Double DIN Head Unit w/ Retained DIC
- OEM Rear Deck Spoiler
- Tires
- Crank Relearn not possible
- Mounting plate Issue
- Can some please help me i have an issue with my 05 cadillac
- How to lower fuel rail pressure
- Horrible vibration from rear
- Replaced Cradle Bushings, still have wheel hop
- Borla MufflerPart Number
- Two new electrical problems
- Diagnosis Help!
- Quieting the v
- V2 headers on V1?
- CTS sun visor question.
- tail
- Guys that convert to 4l80e
- Fuel pump ground wire
- Parking brake retention spring
- 2005 CTS V Build
- Market Values
- Should I keep comp and collision?
- Getting this right
- Ebay shift boots
- Anyone have pics of the diff-to-cradle rear bushings?
- Replacing rear subframe bushings
- 2005 ctsv , what to look for?
- Frankenstein TFS heads in stock!!
- 2005 Dyno results
- Clutch Position sensor replacement. Easy way.
- Traction control and Rear/Front tire size difference?
- 04-07 CTS-V Edelbrock E-Force Supercharger
- Aftermarket Grill?
- Looking for my (old) 2005 V vin #1G6DN56S550164332
- Cheap SRX Diffs
- Valve spring replacement with trunnion upgrade
- Fuel system
- CS 8.8" driver side axle removal / reinstall tips
- Help with factory cd player
- Trying to get power to starter wire??
- OEM Lug nut part #
- New to me, 2007 CTS-V!
- Hood vibration at highway speeds
- Best/cheapest fix for shifter slop
- VMS Coilpacks?
