PDA
View Full Version : Advanced Engineering Tech
Pages : 1 2 3 4 5 6 7 [8]
  1. "Advanced write up" request
  2. How do you calculate how much seat pressure you need?
  3. Effects of different cam centerlines on performance
  4. Desired Compression ratio for nitrous??
  5. Nitriding Valve Springs - Daily Driver
  6. Anyone have LS1 file for Dynomation advanced?
  7. Valve train Q>
  8. Measuring Bearing Clearances - Help
  9. Displacement vs BSFC range
  10. Help with Dynamic Compression Ratio
  11. Engine Rotation Direction
  12. Advanced Book Selections
  13. Official: Volumetric Efficiency
  14. Converting CC to ML?
  15. How does the intake manifold "work"
  16. Ping, detonation vs. engine load, GenIII motors
  17. Flycutting Mayhem
  18. Another "Does anyone still use this old hotrod trick?"
  19. Does this old hot rod trick work or is it just a myth?
  20. Internal Combustion Engine basics, mainly airflow vs TQ&HP
  21. LS1 Reverse Cooling
  22. cylinder pressure
  23. Dynamic Effective Compression Ratio
  24. Piston "side play" question???
  25. Valve Spring Component's
  26. Weight over the lifter verses weight over the valve?
  27. Pistons with Lateral Gas Ports?
  28. Difference in horsepower production and cylinder pressure...
  29. Miller Cycle Cam with big twin screw blower?
  30. Crank Snouts
  31. Figuring Cam Overlap
  32. Head EI vs. Cam Duration
  33. Advanced Reader Poll
  34. Dynamic compression..
  35. Valve Tech
  36. HP gains from blueprinting alone.
  37. What about these clearances??
  38. Displacement formuals
  39. Carbon Fiber Driveshafts
  40. CR, Squish and Octane
  41. What is reversion?
  42. Cam Lobe Question
  43. How important is Exhaust diameter
  44. need help with car
  45. piston-wall clearance
  46. Is there an Optimal timing for overlap?
  47. Rod/Stroke ratio and other questions
  48. combustion in chamber or piston?
  49. Air: Fuel, Emissions and spark timing.
  50. Size Variance in Exhaust Ports?
  51. Ok, how about electromagnetic valvetrain
  52. technical power differences from 4* ext. duration
  53. One + inch of tire diameter = ratio?
  54. Desmodromic?
  55. Questions on Reversion
  56. Bore materials: Steel vs Nikasil (or chrome)
  57. Overlap, how much do you need?
  58. Cylinder Head Degreeing Question...
  59. Taper in cylinder bores
  60. Cast Iron Versus Aluminum Torque Plate
  61. Port volumes vs port cross section area
  62. How do NASCAR engines make 750+HP?
  63. Two must reads for advanced engine heads
  64. I got a good question for you cam guys
  65. Software Packages
  66. Material Selection
  67. short deck
  68. How ICL effects power on cams
  69. Heads... Intake and Exhaust Port Surface Texture
  70. What is this forum for? PLEASE READ BEFORE POSTING!
  71. A new way to check P/V clearance?
  72. Rocker Arm Round-up
  73. What Runner cc for stock cubed ls1
  74. How the MAF really works
  75. Cubic Inch / Nitrous ratio...
  76. Tuning Docs, VE/MAF, SES Lights, FAQS + more!
  77. How does increasing exhaust duration and lift affect the torque and hp curves?
  78. Unit Conversion calculator
  79. Ignition timing 101
  80. Updated Valve event / DCR / SCR / Header length spreadsheet
  81. Cylinder Head Discussion
  82. Idle Operation Part 1
  83. Post up any car math formulas you may have.
  84. Technical links and technical discussion forums.
  85. Camshaft discussion: CFM requirements by RPM.
  86. Camshaft Discussion Part III
  87. Things they dont tell you about building a stroker..
  88. VE Table Cracked
  89. Instant center
  90. Why "zero deck" custom pistons?
  91. How critical is piston deck height & quench distance for an LS1?
  92. LS1 head combustion chamber CC volume vs CR
  93. What affect does advance ground into a cam have?
  94. More engine math...
  95. For those who want big nasty cams with lots of lift, etc...
  96. Math to figure out if your car will run on pump gas.
  97. Camshaft Discussion part II
  98. Updated Cylinder head flow numbers spreadsheet
  99. Changed VE Table now i have a slight Hesitation!
  100. Need Proof That More Aggressive Lobes Are Better!
  101. Ignition Timing Vs. Compression Ratio
  102. The truth about LSA
  103. Camshaft Specifications Discussion
