PDA
View Full Version : Advanced Engineering Tech
Pages : 1 2 3 4 5 6 [7] 8
  1. X-pipe... the TRUE explaination please
  2. Nice intake manifold... - The ITB thread
  3. Correct A/F Ratio...
  4. solenoid valve timing
  5. Lightweight Rotating Assemblies
  6. Milled Heads direct relation to shorter Pushrods
  7. List of bore/stroke combinations
  8. LSx Ignitions
  9. Advancing cam to gain DCR....
  10. Mirconite vs REM Polishing and Cryo?
  11. Possible to create variable runner length/diameter based on rpm?
  12. ARP L-19's...
  13. Where to find Aluminum flanges for cylinder heads
  14. Some advise please Re: LS1 Victor Jr. Intake for street.
  15. What are piston heights for the LSX's?
  16. Turbo vs CID
  17. Skuff marks on psiton skirts-please look
  18. what size holes
  19. What are the benefits of lighting a stock 5.3 crank?
  20. Camshaft Idle Lope... How to "Guess" How Much There Will Be?
  21. 4.8L crank and rods and 6.0L bore for E85
  22. How would you design an intake manifold(ET 245s)
  23. help me please
  24. Header length and size calculator
  25. Those who build/have built many different types of engines...
  26. Braided fuel line "Paths" to the motor: Anyone have ideas?
  27. What's the deal with Porsche's?
  28. looking for the formula
  29. Physical limit to power?
  30. Building A Better Cooling System
  31. Effects of free-reving an engine
  32. O.k., I have a tough math question for those who dare. Educated guesses are fine.
  33. another oil question. why dont oil pumps use gaskets?
  34. hone pattern for hellfire rings???
  35. Groove between compression rings?
  36. mean and connecting bearings size ???
  37. Piston/valve clearance and cam duration relationships??
  38. Engine Calculator App for Evaluation
  39. compression height
  40. effects of headers too big?
  41. Attn Engineers: Modifying subframe for exhuast
  42. Valve Shrouding and rings?
  43. Aerated Oil?
  44. General Engine Dynamics
  45. Morel Lifter question...
  46. Oil compairson report
  47. Can I cc my heads with a pipet and graduated cylinder?
  48. Head bolts cutting to lenght?
  49. rod bearing plastigage help?
  50. how do you self-BALANCE an engine?
  51. Building a 402 or 382 - clearance issues???
  52. Correct timing at idle, normal driving and WOT determination.
  53. bearing damage ?s
  54. 10% Ethanol?
  55. The True Benefit of Skinnies
  56. Advatages of an equal bore/stroke motor?
  57. Cam + Turbo Questions about LSA, ICL and DCR
  58. OAT vs. IAT: Linear or exponential?
  59. Anyone seen or heard anything about this engine?
  60. Terminator Boxes Underway, comments appreciated.
  61. 402 Big compression, Head advice
  62. Why are there no Large single pattern split cams?
  63. Cam shaft selection with N20 use in mind (CamKing , racer7088 etc...)
  64. For honing a LS1 block, which stone/grit is good for steel nitrate rings?
  65. What's the ideal DCR for LSx Engines
  66. Measuring piston to deck height properly
  67. how many guys weld their reluctor wheel to crank throw?
  68. Need FAST EFI Dashboard sensor descriptions..
  69. Piston Ring install INFO
  70. Warped Heads - What's Acceptable
  71. What Is The Effect Of Different Lifter Wheel Diameters
  72. Some Reher-Morrison Info (Rod Length Ratio, Coatings)
  73. Stock Pulley as Harmonic Balancer?
  74. Tuners Inside, loaded vs. unloaded wot a/f ratios (long)?
  75. Bi Fuel Engine
  76. Exhaust flow question
  77. what are the pros/cons of fly cut pistons?
  78. What spring are they using?
  79. How to calculate difference in .004 to .006 Adv Dur in a cam specs
  80. Port size vs. Flow Potential???
  81. I Beam vs H Beam
  82. Morel lifters and preload?
  83. Nitrous on engine that uses Alcohol
  84. Compressor back-pressure from twins?
  85. Help me with a oiling system
  86. Optimal Ring Package
  87. If you have an engine that is compression limited(low) can you still make good power?
  88. boost as a linear equation
  89. What's the rationale behind this?
  90. air distribution
  91. diffrence between??
  92. TSP SR 408 helped needed
  93. How DA affects Compression?
  94. What are the advantages/disadvantages of longer connecting rods?
  95. Valve spring locators, to use or not to use?
  96. Multiple TB questions
  97. mechanical vs hydraulic clutch physics
  98. compression test question
  99. Detailed Cam Spec Determination ?'s
  100. Knife Edging Cranks?
  101. Valve Spring Life vs. Lift
  102. How to make torque at higher RPM...
  103. Combustion Chamber Size Versus Piston Dish Volume for a Fixed CR
  104. BMW Direct Injection Engine
  105. New GM Hydra-Matic 6 speed RWD Planetary Manual transmission
  106. Strokers and Oil Consumption
  107. fast 90 mm intake question
  108. When does the bore of a 5.3 liter vortec start to hurt headflow?
  109. Toluene
  110. peak rpm
  111. Aluminum VS Steel Frame
  112. Designing optimum runners and plenum?
  113. Pump gas cam vs: Compression, Cylinder Pressure, Timing, etc.
  114. possible to change the firing order?
  115. Water temp w/ flow restrictor instead of thermostat
  116. BIG Power Questions: Small/Big CID? NA/FI Setups?
  117. Why hasn't VTEC been adapted to pushrod engines?
  118. Using boost pressure to increase exhaust velocity.
  119. How Boom tubes work?
  120. Gasoline VS Diesel Engines....
  121. Cryogenics
  122. "CFM vs Horsepower"
  123. How little quench with Aluminum block & heads
  124. Piston speed, Displacment vs HP?
  125. Miller Cycle engine
  126. New Gun Engine, real or no?
  127. How does 94 Octane gas with 10% methanol affect your performance?
  128. What happens on in gear decceleration?
  129. Running surface - Lifter / Cam
  130. Fast intake improvement
  131. Whats the leanest one of these LS1 can physically start/hold idle?
  132. Intake Manifold info needed...
  133. Effects of preloading frame during SFC install
  134. How does pinion angle adjustments help in terms of traction?
  135. Valve Material Question For 2.200"+ Valves
  136. downside for extra stroke
  137. Effect of Lifter Diameter on Ramp Rates
  138. How do YOU explain "area under the curve" ?
  139. Port flow and velocity questions
  140. Bruce Crower's 6 stroke engine
  141. Line of action & torqe arm mounting location
  142. Lightest Rotating Weight 4" stroker combo?
  143. What determines engine redline?
  144. Cam gurus inside
  145. direct injection
  146. convert from water to mercury.
  147. Phenolic Carb Spacers for Victor LS1 EFI
  148. turbo idea
  149. Header Primary Size Mathcing w/ Cam and Heads
  150. Ls1 specs for mathematical engine model
  151. Need octane? At a moments notice?
  152. How bout an Advanced Head/Cam type guide?
  153. Volumetric Efficienty
  154. #7 Piston Failure FIX !!!
  155. Help!
  156. Fluorescent Wet Flow Testing (cylinder head)
  157. vic Jr versus Standard intake question....
  158. F1 style transmission?
  159. Reversion and turbocharging
  160. Exhaust Sound - What are you hearing?
  161. Header Modifiaction to Reduce "Choke"
  162. Intercooling taken to the next level
  163. drivetrain loss in relation to rwhp?
  164. Do Belt Cam Drives Add Horsepower?
  165. Bricklin-Turner Rotary Engine
  166. LS1 Oil Pump Pressure Relief Study
  167. Milling Heads Versus Air Flow
  168. Rocker Arm Geometry
  169. Piston Rings and Their Placement
  170. Oversized valve stems?
  171. Valve idea
  172. valve spring pressure discussion
  173. Offset Pin Pistons and On-Center Rods
  174. How much, if any, of the combustion chamber should be in the piston?
  175. How to figure optimum DCR?
  176. Fuel Vaporizers and Super Carbs...
  177. Anyone Entering the Engine Masters Challenge?
  178. LSX Cad Model
  179. 5 questions rattling around in my head....
  180. Valve seal Material
  181. water assisted engine!
  182. Piston material
  183. 105mm TB and 90lb injectors
  184. Injector timing relative to cam angle
  185. Mikronite gears
  186. Figuring out if a cam is twisted
  187. Ram effect
  188. Manifold test on AFR 225
  189. Stoichiometric question
  190. Connecting Rods- On center?
  191. ET Splayed / Canted LSx Heads
  192. Question About Tuning ITB Manifolds
  193. Tapering the exhaust piping to keep exhaust pressure up
  194. LS1 engine builders/assemblers: Installing cam bearing question...
  195. Intake TB combo for high revving 347
  196. Interesting Crankshaft Technology Article
  197. Aerodynamics
  198. Vehicle dimensions?
  199. Question About Solid Roller Valve Springs
  200. Bore & Stroke Limitations (forced induction)
  201. Exhaust gas temp's influence on turbine speed
  202. Why is negative crankcase pressure hard on rod bearings?
  203. Boost as it relates to relates to port air-flow characteristics
  204. ceramic coating of the combustion chambers
  205. Knock Sensors....
  206. Teach me about Fast Burn Combustion Chambers
  207. Reversion
  208. SAE technical paper on how mass air flow sensor/meter works
  209. Fastener Selection
  210. Power from Forced Induction
  211. What accelerates an engine?
  212. how brakes work
  213. What kind of testing would you like to see?
  214. Valve Spring Retainer Fitment/Tolerances
  215. Proper way to test compression?
  216. Was is the advantage of a 1.7 intake rocker and 1.6 exhaust rocker?
  217. LS1 dry sump help
  218. main bearing clearance hmm
  219. Advertised duration v. .050 duration
  220. Reverse split cams
  221. question abou exhaust port shape
  222. Effects of piston speed.
  223. Benefits of a 32 valve heads
  224. Can you build a 8,000 rpm LS7?
  225. Dcr-scr Compression For Cams Help
  226. Importance of high lift flow vs mid lift flow for power
  227. Engine Braking
  228. Vacuum build up on start.
  229. Aftermarket Casting VS Stock Casting
  230. Trying to learn more about my old setup.
  231. Piston thermal barrier coating
  232. Short vs long air intakes... a few q's...
  233. Can someone explain this to me?
  234. The Little Power Gains
  235. How much exhaust pressure is there behind the muffler?
  236. Fantastic Magazine (A MUST read with lots of Advanced tech content)
  237. Lilfter Preload vs. Pump Up
  238. Three angle valve cut - Where does seal actually occur
  239. Need Exhaust Flow
  240. instantaneous piston speed?
  241. Optimal Clearances for Different Setups
  242. Intake design
  243. What's better for FI LS1, Hi CC Low DCR or Low CC Hi DCR?
  244. Combustion Chamber Width
  245. My 1st post in Hcore. Using 2 Lunati grinds as examples, help analyze (springwear).
  246. Converting to Methanol
  247. Valve OAL Question..
  248. optimising fueling vs timing
  249. Valve shrouding
  250. question about gasoline direct injection theory
