View Full Version : Fueling & Injection
- Nitro
- Flex fuel kit for GTO
- e85 aem pump plus 80 lb injectors meat my goal?
- what size injectors for my 408/nitrous car?
- fuel pump wiring
- Ford blue top 160lb injectors
- 1/2" stainless steel fuel line?
- Fuel line ?
- What do I need for the new Racetronix single pump setup for an 02 WS6?
- Switching from c 16 to q 16
- Won't start help.....
- what to do with lines after sump in tank
- LS3 vs LS7 injectors
- Sequential Dual Fuel Injection
- Anyone running dual intank AEM 320lph E85 compliment pumps?
- Need In-Tank Fuel Pump Help - Dual Pump Pickups
- Racetonix Dealers Question
- Kenne Bell BAP blown fuse
- what injectors to go with??
- vic jr porting?
- Will this racetronix dual pump set fit in the plastic bucket?
- Injectors ???? Right or Wrong
- fuel rail fitting adapters
- Getting rid of mechanical fuel pump for HOLLEY electrical pump
- fast ez
- Can you use dual aeromotive stealth 340 ' s with stock lines?
- LS1 pcm, boost and holley hi ram ls3 intake
- Edelbrock Fuel Rail Capability
- E85 setup opinions
- Will this work?
- Problems
- Bogging down
- PSI Conv fuel system,
- Quick dual 255 question.
- Setting up a fuel system......
- V6 convert to V8
- fuel leak
- 1999 Camaro SS Fuel Pump?
- Regulator question an sizing
- nasty performance pro touring tank
- Need some wisdom on fuel pumps!
- ID of fuel line
- Do you need check valves on dual fuel pump
- What fitting are these?
- Early corvette return style rails - Vacuum reference???
- FRPP Green Top 42lb/hr Injectors
- Fuel Injectors maxed out? really!?!?
- Thoughts on EV14 from Coyote on LQ4 build. (spray pattern)
- Fuel system questions
- 98 -> 99 Fuel Tank
- Converting stock feed line for return Line
- Need help draining tank
- fuel level sensor
- hard line return question
- Russell fuel elbow stripping threads...
- fuel delivery options
- Critique my Fuel Setup
- FIC 1000s and Aeromotive rails
- best fuel injectors
- diy dual fuel pump
- E85. Can I just run this fuel
- Fuel questions before I go to the dyno
- losing fuel on hard launch?
- Aeromotivr fpr 13301?
- High fuel pressure, bad idle, related?
- Turbo fuel system setup questions
- Injector data
- p0200 code traced out to grounding issue
- Aeromotive 340 Woes.
- 1500hp Fuel Pump Choices..(street use)?
- Fuel line?
- which fuel rails and regulator?
- Filtration ?
- quarter tank of fuel necessary?
- C6 fuel system advice
- Diy Hotwire from fuel pump to battery/alternator with relay and fuse
- 04 Corvette LS1 Fuel Line Question
- +Awesome deal on AEM Meth Injection kits!+
- 99 T/A injectors and rails
- What style plug do I have on my injectors?
- how much NA power can 255 pump handle with e85
- fuel sender clip
- Fuel system in 5th gen camaro
- Are injectors good for e85 if I'm currently at 60% duty cycle
- RC Racing 71# injectors. How much HP on E85?
- How to diagnose Fuel Injectors leaking?
- Dual External Pumps Fed from a Single Fuel Line?
- Fuel system layout
- LS7 magnacharger
- ITB Filter Gauze Help
- GM Computer or Accel DFI?
- Will ls1 injectors work in LT1
- Edelbrock pro flo injectors with a 5.3 intake and rails. Work??
- Low base fuel pressure...how low can I go?
- Fuel rail and fuel pressure regulator?
- Ls3 fuel rails same as ls2 fuel rails?
- Do I have enough injector for my turbo build
- Why so high?
- Rust!!!
- System is running lean and strong fuel smell
- E-85 N/A Gains
- How many feet?
- Holley injectors
- deal on 8.1 injectors for the truck guys!!
- parker push lok 801 hose
- Fuel System Recommendations?
- Flex fuel injectors
- Forced induction e85 - LSX Willys
- question on injector size
- GF481 Fuel filter fittings
- E85 and preferred fuel lines
- GF822 Fittings & LS1 Fueling
- Value?
- Whats it worth?
- What it worth?
- Walbro 255
- Switched from gas (110) to Ethanol (E-85)
- Vent Line
- determining injector size
- LM7 swap-fuel pressure issue
- whats the max hp from a stock fuel pump? and injector size help
- lsx 454 induction
- Want to Eliminate intank regulator!!
- Loosing fuel pressure at WOT w/ racetronics 255!!!
- twin in tank problem (blowing fuse WOT)
- fuel set-up for ls swap Into 73 87 chevy truck
- Car not taking gas
- 98 fuel pump questions
- LS6 Fuel line sizes? Feed and return?
- Double Pumper Install
- LQ4 vs LS1 injector flow?
- Fuel Injector Connection 1600cc injectors "LS2" style
- Running a 4150 throttle body with 411 pcm?
- Fast 92mm
- Looking for help on a holley hi ram
- whats a good place to have your injectors flowed
- 42# green giant injectors
- Single or twin
- ls2 injectors
- Extender to convert LS9 to LS1 length?
- How to route fuel line with billet fuel rails
- Bosch 044 makes a surging sound, car dies under heavy load
- LS1 fuel rails or aftermarket on LS6 intake swap??
- Squash Performance twin walbro 267's in-tank pump
- 10 awg Hotwire setup, ohm's law!
- Pumps dont prime when key is turned on
- Smartfire injectors
- Dual fuel pump wiring N/A
- Areomotive 340 Fuel pump part #
- Fuel Issues - Racetronix pump
- What Tool Do I Use to Remove Fuel Rail Valve?
- 98 to lq9/ls3 fueling question.
- Compression fitting for LS fuel rail?
- Anyone know what this is called?
- Injectors?
- Does my diagram look right?
- Pump fuel 91 / 95 / 98
- Fittings used for -8 feed and -6 return on bucket
- 98% duty cycle
- Corvette Fuel filter / Regulator for Ls1 Swap
- Racetronix pump question for a 98 camaro
- boost ref. pressure regulator vs. stock
- stock ls1 rails on typhoon intake
- testing 2 yr old walbro 255's??
- Takes a lot of cranking to start
- stock fuel line enough? help!
- Best Fuel Pump(s) Option For Now And Future Mods?
- Quiet Externally Mounted Fuel Pump Recomendations
- what are my injector specs?
- fuel gauge issue
- nitromethane!
- falling fuel pressure
- help with my fuel pump
- What Injectors need asap Everyone jump in
- ls3 holley hi Ram injectors.. which ones?
- Voltage Booster or Second pump?
- MS3 Camaro Leaning Out
- Fuel trim problem
- pump umpgrade ?
- Victor Jr Intake.. What kind of throttle body Is this?
- Help Me Diagnose Fueling Issue. O2s?
- raising fuel pressure
- Oem ls1 fuel rail an adapters
- Using '02 pump with '98 sending unit
- -8AN or -10AN for 1000rwhp turbo setup on e85?
- can't keep current to my fuel pump.
- Can you clean fuel lines on 02 WS6?
- Quick question about fuel pump wiring
- Where can I buy 1 injector???
- Advice on PCV setup with Holley valve covers abd Edelbrock intake
- No injector pulse
- What injectors and fuel pump 800 rwhp?
- Fuel Pump, Fuel Filter, Something Else?
- The book: "How to Use and Upgrade to GM Gen III LS-Series Powertrain Control Systems"
- Fuel gauge wiring questions
- injector resistance
- Holley Billet Inline + JMS Fuelmax
- E85 fuel system for 700whp 5,3
- siemens 60# vs 72# injectors
- Need help with -8 feed and -6 return
- What all do I need to replace an LQ4 cam with a stock cam from an LS9?
- fuel pump
- Adjusting fuel pressure, engine on or pump on?
- fuel tank harness
- Wagon Slosh Box
- Repairing/replacing broken fuel lines
- What yall think of this fuel setup?
- L96 intake to ls3 intake fuel injector question
- Difference in fuel pumps
- Can I use these injectors???
- Help with fuel system routing
- Can someone school me on AN fittings?
- What A/F ratio for WOT. LQ 408, 11.1/1 CR
- fast 92mm which injectors?
- Removal of vacuum plug at rear of intake 2001 LS1
- LQ4 swap fuel system question
- Intake questions
- Who sell svo injector
- Twin walbro 400's in Fbody
- Fuel pump question for 42 injectors
- 8an feed line fittings?
- BAPs
- full bolt on ms3 cam and stock injectors?
- Fuel pump + sending unit future mods
- Siphon issue with lower pressure, on Ybody
- suggestions...
- 1998 Camaro Low Pressure
- fuel pump question
- Moran injectors
- Injector question
- Need Help! Loosing fuel pressure around 5500rpm
- Racetronix FPA-001 vs FPA-001A
- 94 V6 to LS Swap Fuel system.
- one or two 450 walbros e85 pumps
- Venom hp 683-8. 83lb injectors?
- deleteing Evap, can i remove this from my tank? PICS
- Racetronix hotwire
- to much for stock parts?
- Injector Flow Data
- help me pick a pump for my turbo lq4
- deleting intank regulator? is there a how to?
- Fuel Pressure regulator mounting
- Anybody run an Aeromotive eliminator Pump in Tank?
- Replacement spring Mallory 4305m pressure regulator
- e85 fuel pumps for bucket mod
- aftermarket fuel rails pointless with stock lines??
- E85 + nitrous
- Help car runs like crap
