View Full Version : Fueling & Injection
- Fuel injectors?
- ok I need instuctions on where to cut access panel on 01 Z
- programming
- car starting to over load
- Which brand of injector is best?
- Octane
- Where to get the 3M fuel injector cleaning kit?
- Fuel tank/cell install in bed
- Will Walbro GSL394 Inline 190lph Pump support 400 hp?
- C5 fuel pump---it is a Walbro
- External Aeromotive and Filter FOR SALE
- MSD Booster and racetronix harness
- help
- somebody with a 98 and intank pump
- Have a Walbro pump, not sure which one though, need help identifying
- Is this fuel system design any good?
- Summarize injector pro's/con's please?
- LS1 with no return line-Dead head pressure?
- Few fuel system questions
- Fuel pump questions... which one...
- Racetronix PnP question...
- Where can I get used Vette return style fuel rails?
- Return styl Vette fuel rail line sizes?
- Speed Density vs. Mass Air
- Injectors: need some help!
- NEED HELP-Injector install gone bad!
- Racetronix install ?
- Injector Impedance
- yes another inline walbro 255 question
- Whats wrong wiht my car. Video
- Best injector cleaners?
- racetronix
- forgot to cut the side of the fuel pump bucket out
- SVO vs Delphi injectors
- my new injectors dont match... help!
- 408 stroker? will 30lb injectors work good or not?
- Tried toulene. It worked great.
- Racetronix
- Racetronix Plug and play pump not doing the job!
- With Racetronix 99+ F-body fuel system, do you NEED to run the new harness as well?
- may as well go big or just big enough
- Do I NEED a bigger injector?
- What to do for fuel system, LT1/LS1
- External fuel pump question?
- Corvette fuel rail adj. FPR?
- How many of you guys have installed your own fuel pump?
- Racetronix No instuctions or diagrams?
- what aftermarket fuel rails are out there?
- Fuel Pressure Regulator Question
- What to do about my gas
- what fuel pump to use?
- Autometer AFR Gauge question
- Is this my fuel pump going bad?
- sumped factory metal tank and exhaust
- Need fuel pump for truck
- Racetronics questions
- Installed the Racetronix PnP C5 Fuel System...
- Racetronix ... have a question ?
- Have a few questions about a fuel pump and injectors....
- Does the t block have any restriction to it?
- HP limit of stock fuel lines?
- Fuel rails add HP?
- Please Help me with this fuel related problem
- Installing new Fuel Rails and lines, any good writeups anywhere?
- best fuel setup for..
- racetronix 270 lph is king
- Nasty Performance Gas Tank/Exhaust clearance/Safety
- Fuel system greamilins....
- I need a fuel pump. Which one and who sells them?
- Different 42lb injector
- Walbro GSS340 v. the GSS340M
- Does anyone use Cam II
- Racetronix ? from Customer
- Why dual feeds from sump?
- Would dual in-tank pumps out flow 1 in-tank and 1 in-line?
- No Fuel Pressure...WTF???
- Clear style fuel filter
- Fuel Pump Question?
- do-it-yourself dual pump 2.0
- Fuel System Questions
- Dual Fuel Pump and Controller
- Vortech T-rex question
- LS1 fuel tank for a hybrid conversion
- Do I need more injector 28.8's @ 470 rwhp
- Just fired up the new motor for the first time....
- RC Engineering 650cc injectors
- Fuel Pressure Regulator Problem??
- Inline vs. In tank fuel pumps?
- where can i find...
- New Shell V-power?
- Dual or single
- new supercharger - new injectors - have problems tuning - help??
- how much hp are 30# SVO injectors good too?
- 97 vett fuel regulator blew off help
- Fuel pump help
- fuel system failure causes boom!
- Stock fuel pump size?
- Will my old LT1 injectors work on a 99 v6?
- Fuel Pressure ?
- WOT Fuel Pressure??
- racetronix wiring harness
- tsp 231/237-heads-nos combo fuel sys
- Injector information needed
- multiple misfire code... fuel filter? fuel pressure? what could it be?
- Anyone use/using the Speed Inc fuel system kit?
- 440rwhp. Just upgraded to 30#SVO's. Now fuel pump?
- Racetronix 99+ installed
- Aeromotive Fuel pumps Who's using one?
- yellow top injectors? generally means...36lbs.??
- fuel problem or tuning problem?
- walbro installation on ls1 convertible help!!
- Fuel Pressure Drop! Help!!!!
- am i crazy on can this work?
- What connector for Fuel Rails?
- 98 vs 2000 pumps and evap
- 96 z28 hesitation
- Do these Ford 42# injectors plug right in?
- Anyone using external EFI pump instead of In-Tank?
- Race Gas (Wow)
- racetronix....got a question
- Sending unit off calibration!
- HELP!! Can't fill gas tank??
- would this fit an ls1?
- Racetronix 99+ Fuel Pump installed… First Impressions.
- Misfire after injector install?
- injectors for boost
- walbro inline
- Injector Size
- verification questions for 60lb mototrons?
- cross over line on custom rails, in the back vs in the front...
- Race Fuel users: fast question plz
- Question about aftermarket fuel rails...
- Injector Wiring Problem Please Help
- Fuel system needed for 700rwhp?
- Best fuel system setup for 427
- real quick fuel pump question
- Racetronix 98 Fuel Pump...no instructions
- Fuel pump install instructions?
- Delphi 32/37lb/hr Disc Injectors
- Electric Fuel Press Gauge
- Help-need pics of fuel return lines-getting ready for spray
- ? on carbureted ls1 setup
- Question for those with stand alone fuel systems.
- What fuel pumps are safe for use with E85?
- BAP Sensor
- Will a 2001 fuel pump work in a 1998?
- will i need new fuel rails?
- NastyPerformance Race Fuel Tank
- Fuel System Cleaners
- lost gas mileage
- fuel system in 03-04 Z06?
- fuel system for new cam and juice
- Tb Help
- what size injectors?
- How do I modify 94Z fuel system to 98+
- LS1 Injectors in LT1??
- inline walbro pump question
- fuel pressure guage question
- New 38 lb injectors installed: now B2 is lots richer than B1, what should I check?
- NeEd HeLp! Fuel pressure 20 psi
- Need help with Walbro inline wiring
- in tank hose??
- Injectors-When to upgrade?
- How hard is it to remove the fuel tank and what has to be done?
- Does running your car w/ less than 1/4 of a tank often, affect the life of the pump?
- Injector questions??
- Where to get an adapter for fuel pressure sender ??? Need today
- Locking gas cap question...
- 1000hp 1st gen Fueling help
- Need advice for 67 Camaro w/ 433
- How do I get and adjustable fuel psi reg for my walbro 340
- Maybe a tired question but.....
- Need help identifying an LS1(?) gas tank
- fuel pressure
- will these injectors work
- Gas Question.
- Powder coated fuel rail?
- Now more pressure!
- Wiring F-Body injectors into a Silverado 5.3
- So, my LS1 has a returnless fuel system...
- What fuel pump?
- im missing bad
- Larger injectors
- Racetronix 99+ system installed, is it supposed to sound like that?
- What's Better???
- Fuel rails
- For Sale: 42# SVO Greens, only used in Dyno Testing
- Might Need Single Injector - Help Me Figure This Out!!
- cam and nitrous, what needs to be upgraded?
- How much does the fuel pressure drop at a WOT spike
- DSM fuel injectors fit?
- Ford SVO 30lb max milli seconds
- Maxed out fuel system with TNT ring kit, need opinions?
- Fuel gauge not working!
- Inline fuel filter placement
- Racetronix 37lb inj....what lb @ 58psi?
- Probably the dumbest question to date
- :) Add Evap?
- Where can I get replacement parts for a 42 lbs. injector?
- Theoretical Q: DC of 110%...
- Does running leaner than 14.7 = better gas mileage?
- pressure issue
- race fuel
- Granatelli fuel pump problems????
- Will i need to upgrade fuel pump???
- Fuel pressure Q
- FAST billet fuel rail
- Racetronix 99-up pump assembly installed!
- Car running too rich, what to do?
- 30# injectors too much for stock?
- Bigger OEM-style Pumps That Fit?
- Racetronix 99-up (plastic tank) system delivered! Started install
- New FP gauge ... acting weird ?
- Questions about the Walbro 340 pump.
- Show Me Your Setup
- Racetronix pump system with what inj ? for a stroker..
- amp rating for the 420 L bosch pump?
- Remove Evap?
- Flow rate of stock fuel filter
- Pick up for external fuel pump?
- Fuel check valve question?
- What Injector for stock replacement?
- Question about Siemens Injectors
- Anyone know what goes to top passenger side of throttle body???
- anyone have a stock injector for an 02??
- Fuel Pressure- Needs to be 58psi?
- funny noise...??.
- What's your injector scaling for 42lb's and 60lb's...
- Sumped Tank users inside please.
- How Do I remove the Fuel Rail
- Mototron 60# Injector Scaling at 58psi?
- Where To Get Inj's Flowed/cleaned?
- Completely stock fuel system, is there anything I could upgrade 2 pick up some power?
- Injector scaling for Lucas 38# injectors on a 98 car
- 60# Mototron Rating at 58psi?
- Gasoline?
- Anyone ever have any problems with 340Walbros crapping out?
- 38# injectors
- fuel pump install
- Alky Mist/Inj Where can I get kit? Methenol?
- How does fuel feed/return work on 2002 LS1?
- Please Help! 40PSI and steady after brand new Walbro 340
- Lucas 42's?
- Walbro Intank GSS340 ????
- Stock Injector Flow Rate question...
- 42lbs...to much for my application?
- Anyone installed Weldon stepdown box? (Dial-a-flow)
- How to replace fuel filter??
- Finished my injector install yesterday... Have a question.
- stock LQ9 inj. flow rate/fitment
