View Full Version : Fueling & Injection
- SVO 42#'s and a stock tune...
- Fuel Pumps
- What are the DANGERS of Meth injection?
- when time for rails
- APS GTO twin fuel pump system - available April 07
- How do you get 500 hp from 24# injectors
- Difference between Racetronix '98 and '99+ models?
- retrofitting lt1 into carb'd gbody- fuel situation
- Boost A Pump - Kenne Bell or MSD
- sump vs dual intank
- Fuel System Help Please!!!
- will fuel system handle it?
- carb style throttle body?
- ls1 swap help
- Fuel pump advice for my setup?
- Should i get bigger injectors?
- HELP ASAP!!! Fuel pump working right?
- Fuel pressure...
- Where does this go?? Pics inside
- Aftermarket fuel pump
- WALBORO Fuel pump help
- 2002 28lb injectors vs Ford motorsport 24lb injectors ???
- Pics of fuel pump access door.
- Fuel injector size?
- Injectors?
- Fuel Pump question
- Which injectors are best for my app?
- What else do I need for this install (97 vette rails)
- please help fast, instalinf new pump
- 1998 Fuel pump trap door?
- Fuel Pressure PSI
- What material would you use to build a fuel tank?
- dumb question but someone answer me this...
- Anyone hear that SVO's suck?
- fuel pump differences for 98
- Racetronix is in,still having problem,sponsors help!
- Recommend me a fuel pump!
- racetronix, #42inj, + nitrous....
- Racetronix Pump Melts Fuses?
- vert pump change
- Buying a Walbro 255,High or Low pressue?
- Injector question?????????????
- Boost Referenced FPR on Stock Fuel System?
- Best injectors?
- 2 Ohm injectors with a 10 Ohm resister...okay?
- Anyone sump there stock tank?
- LS2 Fuel Rail
- Fuel System Setup
- my dual walbro setup has burnt up!
- What tool for cutting acces panel for fuel pump?
- Do new fuel system parts need cleaned?
- Racetronix question not addressed in search... 1998 specific...
- just finished my dual intank walbro setup, pics
- fuel pumps or no fuel pump?
- Injector lube?
- fuel pump filter sock mod.
- What brand injectors?
- Injector Clip PN Correction
- New Engine break-in A/F
- What injectors...
- so close to getting dual intanks with venturi system!!! pics!
- 42# injectors max hp with bap
- 3.8L fuel injector size
- Fuel Pump upgrade confusion..
- Injector swap
- Bad injector symptoms
- Walbro 255 OEM replacement?
- FAST Fuel Rail Install Pics?
- will high octane fuel hurt anything
- Custom Sender for Nasty Tank
- Heads+Cam=new fuel pump?
- Stock Fuel Pump Question
- MSD Boost a Pump not working. :(
- Can one Walboro 340ss handle 525 rwhp?
- When do I have to upgrade injectors?
- Evap line as a return line??
- fuel pump install question
- Stock fuel lines
- what is stock fuel psi
- Nasty performance.....
- Need some tech specs for SVO 42lb injectors
- Lets talk 98 fuel systems
- Biggest injector with stock PCM?
- Mototron 60# Injectors
- Fuel Pump failure sign, or bad wiring?
- Experts Please: Returnless system and constant voltage pump?
- fuel line questions
- 42#'s enough
- 1998 T/A Fuel Question
- strong gas smell help!
- Correct injectors for break in?
- Speed inc Fuel rail hose size?
- I need fuel system parts... any suggestions? (pic inside)
- Stock Fuel Pressure Droops at WOT
- Car wont start (3800 V6)
- injector knowledge
- stock 04' cobra 39# injectors.... ???
- Walbro Intank pump question
- push SVO30s or do svo42s
- New fuel/evap lines, how to make them???
- stock injector flow rate
- Standalone Fuel System Question
- fuel pump swap question
- parts.
- HELP on pump install QUICK
- when to upgrade fuel rails
- TSP fuel pump kits?
- gas mileage
- help. installed intake, car shuts off on startup
- Reulator or Pump is Bad???
- fuel pressure regulator slowing down car?
- Understanding fittings...
- Internal vs. External pump
- MS3 new injectors AND pump?
- Flow checking injectors
- quick injector question
- Power to the fuel pump...
- mojofinger needs advice
- What is the optimal fuel rail feed setup?
- Help! Engine dying
- Boost Referenced Fuel Pressure Regulator
- New Era Performance can now Flowtest your injectors!
- HELP! What the hell is this?
- do you really need the EVAP system?
- Fuel/Evap lines??
- Fuel rails and injector size???
- Nasty Stage III fuel system install tips
- problem with racetronics system
- Got sent the wrong pump can I still use it
- Q. installing fuel injectors without damaging the o-ring
- broken fuel sock $60 wow
- Pulling 98 Fuel pump, yellow connector on tank cap
- Ford test pressure 40 or 43.5 psi?
- pros and cons to fuel pump trap door
- What make/model/year takes this type of injector
- fuel question for head & cam swap
- Procharger warranty transferable?
- will i need bigger injectors???
- differences between tb's
- this is getting rediculous
- Help Plz!!!
- What injectors for 355 LT1?
- Stock fuel vent system
- Car Dies at 5000 RPM's
- What size injectors and fuel pump for MS4 and 125 shot
- sts kit @ 5psi 42# delphi duty cycle
- 383 lt1 fuel pump reccomendation
- What kinda of fuel injectors are these?
- Checking fuel pump relay...
- What fuel pressure? 06 GTO
- Where to buy flow matched injectors?
- Installed Walbro....now it won't start...
- No clutter fpss and sending unit?
- 42lb SVO VS. 42lb Lucas....any difference
- APS C6 fuel rails
- professional products fuel rails
- H/C set up questions
- %$%# What is this??
- Fuel gauge not working right.
- Would this be okay or is it a big no no.....
- Injector size recomendation
- Wiring question
- LT1 Fuel rails
- have a question: Racetronix fuel pump install
- little white clips
- NE1 had SVO 30's flow tested @ 58 psi?
- Cobra 39lb injector questions??
- BAP wiring diagram?
- Fuel Rail O-rings
- Vaccum ???
- Looking 4 a fuel rail?
- Fast 36# injectors
- Fuel lines?
- Vacuum modulated FP or static?
- Fuel Problem? Cutting out past 5K. help
- 16 volt setups...for 160lb injectors
- Need help, in the middle of fuel pump replacement
- Fuel line question???
- Fuel pressure?
- Why is this not working
- fuel rails/line help please. w/ pics.
- Max RWHP on stock fuel pump
- 96# vs 160#
- Anybody bought a pump from here?
- Ford SVO 30's?
- Fuel System Suggestions wanted
- What fuel system upgrades are needed for Heads/cam and a dry 100 ?
- ls2
- Tailoring injectors to specific cylinders
- How to drain fuel from tank?
- Quick release fuel tank fitting
- injector size on stock cube single 76 gts?
- Where To Get Oring For Mototron Injectors
- need some help on injectors
- Need fuel system suggestions
- Is pump always on at same speed when engine is running?
- Whats stock fuel pressure on ......
- 40 psi ????
- fuel pump assy/sending unit
- High fuel pressure that goes up and down
- anyone ever use this fuel pressure gauge?
- Can anyone define the fitting on a stock LS1 tank?
- Help! Gas Leak
- O2 sensor help
- car not starting?!?!?!?
- evap question
- Racetronix pump dropping to 40 psi at peak rpm.. Is this about to fail or what?
- Any Help W/Fuel Pump Install (Lonnies Twin Intank)
- Fuel Gauge...
- are lt1 and ls1 injectors the same?
- what size injectors to run on a 418ci 12:1
- injector, fuel sys. suggestions
- injector size?
- Injector ?
- Will I need tuning immiatly after injectors?
- Speed Inc. Fuel Rail install ????
- What is my pump doing?
- Running evap without the solenoid
- Injectors for a 98 Camaro
- 402 with 150 hp wet shot Fuel setup question
- Dual intank and New Feed line questions
- My proposed fuel system...please make suggestions
- Idle A/F with versa nd 96lb... outcome?
- Pump gas...
- what upgrades for fuel system and 700 rwhp?
- Is the trap door measurements in a 98 the same as the LT1
- Fuel Pump Install Help!
- need help
- pump is stuck
- stock fuel sys + 60# Injectors supports ?HP?
- Correct SVO 42# Part Number ?
- Driving w/ Stock Injectors on 60# Injector Tune?
- Best Injectors ?
- Relieving fuel pressure before removing intake?
- 1500hp fuel system sugestions?
- pushloc, twistloc plastic fuel lines nhra legal?
- need some tech. info?
- Who sells direct fit walbro 255
- Boosta Pump Install?
- Need Help - leaning out 4500 rpms and up
- Would a stock fuel pump run lean @ 4000rpms in 408cid?
- Anyone just replacing the pump?
- Fuel Pressure Regulator to look into?
- Help me choose injectors
- We need a "fuel systems" sticky in here SOOOO bad!
- pump install
- Injectors- high or low impedance?
- What to do for fuel??
- Do stock fuel systems on ls1's have a return line???
