View Full Version : Fueling & Injection
- anybody running methenol on a NA setup
- Fuel Consumption
- Tank for 4303 pump
- Ls fuel rails that don’t leak ?
- Need fuel pump setup/advice for 1200 RWHP...
- L83 Fuel Lines
- Gas Pedal replacement
- Terminator X...
- Low fuel pressure
- 12609749 on TBSS intake
- Fuel tank mess
- Best LS1 Harness
- 4th gen F body, -8an squeeze between floor and tank?
- Mpg drop
- 5.3 turbo fuel setup
- Recommendation needed - Who can clean my injectors?
- Fuel Pump Sock
- Looking for fuel injector opinions
- What fuel pump part # for 2000 Camaro z28?
- Need some help with fuel pump-Internal vs. External
- Terminator injectors
- Retern line needs a check valve?
- L83 fuel rail sensor 3 wire to 4 wire
- Newb here wiring Holley terminator x max questions
- Need help, building a custom GTO fuel pump bucket
- Stock LS1 injector data on C5 corvette
- Walbro 525 w/check valve vs without check valve
- Turbo 5.3 S488 Fueling problems
- ATL CFD-504 Fuel Bulkhead Connector Question
- Factory fuel rail to return regulator adaptor
- Holley terminator x question
- New set of injectors
- Intake manifold, fuel rail and injectors Truck interchange ?????
- Stock LS6 Injector Questions
- PWM Selection: Vaporworx vs. Aeromotive
- Replacement fuel nozzle cup?
- Factory flex fuel setup
- Fuel Setup for Procharged 700whp LS1
- fuel rail questions
- Choosing a Flexfuel Sensor?
- aeromotive 16306 pump controller, PWM ?
- Fuel pressure falling off.
- Ls1 injectors not working. Need help!!
- Gen IV to Gen III fuel rails?
- Fuel level sensor ohm readings
- Magnafuel 625 rebuild
- Corvette Regulator Issue
- Fuel pump venturi line
- Fuel Pump and Injector for Procharger recommendation
- BBK rails with 92 fast intake
- 6.0 Wont Start
- Q? Cleaning fuel rails and injectors LS6 on intake
- Fuel sending unit
- Fuel pump recommendations
- What will a Walbro 525 Pump support ?
- corvette regulator filter or fuel rail regulator
- S197 5.3 80mm turbo fuel set up?
- Stock F-Body Tank Dimensions ?
- Repurpose Alky Control System CTS-V LSA
- Is there another throttle pedal that can be used in place of the GTO?
- FAST 102 intake on a cammed 5.3?
- Aftermarket rails on tbss
- P200 help new pigtails and 42# injectors nightmare
- Losing fuel pressure before and after installing new pump
- edelbrock pro flo 4 vs holley efi
- Dual hellcat 525's
- "Corvette" filter pressure
- 2001 Corvette Fuel Line help(tank to filter)
- Dual A1000s sumped
- Could this be a fueling issue?
- Need a fuel pump relay for Fitech 70050
- Critique My Fuel System Plans E85 700HP
- How many feet of -8 an feed and -6 an return
- Best Map sensor for turbo f body right now
- L96 flex fuel sensor
- 50lb Injectors
- Fuel line Warning !!! Gas Leak
- l83 fuel rail removal
- Fuel return/feed question
- Injectors pissing everywhere
- FUEL PUMP wiring questions.....
- Converting to DBC, need help.
- FPWK-017A - Melted Relay connector
- Can a Stock ECU Control an Aftermarket Fuel Pump?
- Ford Green Top Injector Data
- Fuel return/fuel feed question.
- intake chipping away around injectors
- Fuel system issues.
- LS1 Injector Plug - Terminals Part Number
- How much are OEM LS3 injectors worth?
- 98 guys get ready!
- Too big of injectors?
- Boosted LQ4 fuel line size recommendation
- No start , everything is fine, can’t figure out.. HELP!!
- Return system - regulator off front of rail?
- WS6 Store: Racetronix Fuel Pump, Hotwire & C5 FPR Conversion. Trap Door mod (PICS)
- 255/340/Hellcat modules for 98 and 99-02 fbodys
- Help me choose injectors
- fuel pumps
- Holley Terminator wont idle? Try this!!
- Bigger Injectors For Ls Swap Needed
- Aeromotive 5.0 GPM pump
- HELP! Problem with Holley Sniper EFI Fuel Rails
- Using rail's fuel pressure test port for return line?
- Fuel Relay Help
- Lq9 intake
- Injector Selection Help
- Injectors for 5.3
- fuel pump prblem
- Future proofing fuel system with new feed and return lines
- Dual intake 450s dual feed lines??
- What's the other fuel line?
- -8 to stock truck fuel rails
- Fuel Pump Relay Not Receiving Signal to Prime
- Help with fuel pump/ injector sizing for 408 stroker
- Carb to FI ?
- Injector/Fuel rail combo
- Decapped fuel injectors flow results
- E85 Injector and fuel pump sizing
- Need IN tank Pump recommendations for S-10 tank basket?
- E86 sensor placement
- anything new-E85 in a separate fuel cell for my wet kit. 93 octane in the car?
- Modifying stock plastic truck fuel rails
- ZL1 Fuel Pump Questions
- C5 Regulator flow???
- Upgrading to -8AN lines... some questions
- Fuel Injector Data
- Truck intake fuel pressure regulator
- Fuel system for F1A on kill
- Should I be smelling fuel?
- Replacing stock fuel pump
- Does a modified fuel bucket cause fuel starvation?
- Anyone use a cheap ebay fuel bucket?
- 2 fuel pumps and still loosing pressure..
- Does this fuel pump wiring diagram look right?
- Having a lean spike issue
- Check Valve/Fuel Pump Issues on LS Swap 68 Firebird
- Slightly larger injector
- E85 and 80 lb injectors rwhp limits
- Fuel system help.
- E-85 upgrade question
- UPP Secondary fuel system issues
- Making sure it’s fuel lines so I don’t buy another set
- Misfire due to poor fuel pump?
- Dual feed or Crossover (aftermarket rails)
- Fast 92 with Holley fuel rails and LS3 injectors - inj brackets do not fit - SOLVED
- 07 Silverado injectors and fuel pump
- Fuel cell set ups
- New walbro 450 dropping fuel pressure under boost??
- PWM Fuel Pump for L83
- Twin walbros for 800+??
- how much boost can the stock 5.3 fuel regulator take
- Holley Dominator ECU and smog ???
- need help, LS3 swap into 70 Camaro crank no start
- V6 vs V8 tank/pump assembly
- Fuel starvation issue on ls swap
- Fast Fuel Rail Leaking
- My 22 pages of notes on Holley Terminator install
- E85 and return line
- Any safety issues with running !EVAP this way?
- What does this do?
- Walbro 450 Fuel Pump Install
- Racetronix
- High Fuel Pressure - 84 PSI
- Holley Dominator Overview
- Will these tin snips work for trap door mod
- VE Table fall off at 100 kpa
- Racetronix 255/Racetronix hotwire kit is 16 ga bulkhead to pump wire ok?
- Fuel line and fittings
- Racetronix 48lb injector data
- New injectors for stock LS1?
- Killed another AEM fuel pump
- Snorkel hat ideas?
- 00 firebird 3.8 injectors won't fire.
- What pump and injectors for my setup?
- fuel pump which pump to use
- Anyone run a wakeboard 450 as a primary and a1000 to come on under boost?
- Engine stumbles after twin fuel pump setup.
- fuel pressure bleeding off
- Injector question
- Fuel pressure drop after startup (4.8 - LY2)
- 1987 K10 305 TBI to 5.3/4L60E swap HELP
- 99-02 Fbody module kits
- Car starts and turns off after about 2 seconds
- FPR making annoying noises
- ws6store c5 regulator and 340 racetronix pump, no pressure!
- Fuel injector plastic
- What else do I need to buy for my fuel system
- 2007 Callaway Corvette injector size question.
- Help diagnosing 6k blip - Holley Datalog
- 80psi at Idle? What do I do?
- What to do with STOCK intank regulator when using adjustable external one?
- Help with Injector Spacers
- 416 stroker fuel lines
- Reality check on running 2 gas tanks and pumps...
- Replacing the hard plastic line off the fuel pump assembly
- FAST TB insert came out.....
- Fuel Rail/ Return Line Question
- 2001 WS6. No spark out of Ideas!!
- Should I use an unbranded throttle body?
- LS 3 factory intake return line
- Fuel System Pressure; Am I Overthinking This?
- Replacing Corvette style filter/regulator with an adjustable fpr.
- Ev6 or ev1
- Injector height clarification needed.
- FIC resizing injectos
- Limit of Bosch 210s on e85
- Boost Reference Fuel pressure regulator
- 96 firebird 5.7 lt1
- 5.3 conversion fuel rail questions
- Fuel smell and hissing gas cap
- Fitech Ultimate LS Efi system 70013
- Bosch 210 fit on LS1
- Gen V L83 misfire, out of ideas
- FAST 102 and FAST fuel rails/cross over front or back of intake?
- Microsquirt fuel only - MSD 6014 for ignition - on 58x 5.3
- Can I Use One Intank Pump and One Inline Pump
- splicing into fuel rail crossover tube. Any issues with this?
- Question adding another Walbro to existing Racetronix pump
- Ls1
- 04 Silverado double pump
- E85 dual 450 Waldron Hobbs switch
- LSXR 102 billet fuel rail choices?
- Holley Terminator Maxx and AC on LS1 car
- Racetronix ??
- Modify? Ls3 Fuel rail w ls1 injectors and ktech spacers oring help?
- Eating Fuel Pumps
- LS3 in a g body fuel system questions.
- Source for decapped+flowed injectors.
- Throttle Cable adjustment?
- Venturi Line with Racetronix 99-02 Fuel pump kit
- midnight teaser pics
- Need fuel pressure help big time
- GenIV pump/FPR work around?
- E 85 Fuel And Motor Oil Change
- GenIV returnless option for factory fuel regulator?
- E85 only GenIV 4.8L: order of restrictions?
- Holley Sniper on a LQ9
- rusted 98 Z-28 fuel tank
- 2005 LQ9 - Stock Fuel Rail to Return - Bosch 210 EV6
- What are the signs you maxed out your LS2 / LS3 fuel rail?
- Single fuel line setup. Check valve needed?
- 98 sending unit in a 99 tank
- Spectra Fuel Pump Problem
- HELP!! Fuel Pump Ground Wire
- No fuel pressure in rail!!
- TRE 80lb injectors worth trying ?
- l96 fueling needs
- Using methanol injection to help IATs
- FAST 102 & GM LS2 TB fitment Question
