View Full Version : Fueling & Injection
- Fuel PSI REG.???????
- shoulb my fuel pressure gauge work all the time with the engine on
- Help, cannot put fuel in the gas tank! i am not fimiliar with this at all!
- Fuel pump trap door
- New injectors, now it's running rich again..
- need help with my 2002 z28
- Limit of stock '01 injectors
- What size are stock 02 injectors??
- ls1 intake questions....
- 26 to 28.8 injectors w/o tuning
- looking for low impedence injectors
- stock fuel damper hard line to TB problem
- How much should fuel pressure drop at WOT
- new regulator installed *pics*
- How do you scale larger injectors?
- fuel pump help please
- What wideband to use....
- Fuel Level Gauge working at times and not
- Fuel cutoff
- Fuel pump relay??
- Am I just stupid?
- Fuel problem
- What Injectors for a blown 408?
- wtb stock ls1/ls1 injectors
- Major Problems! Please Help Me!
- Is this for real?
- Issue with spark plug and possible faulty injector?
- need help with fuel pump on 01 ta,please.
- I need a fuel pressure regulator
- another problem with pump...
- For those who need Teflon heat shrink for soldering fuel pump wiring look here.
- asap!!where could i get a 3/8 fuel line disconecter
- Fuel Pump Question
- Methanol
- Fuel pump recommendation
- Fuel rail fitting
- faulty fuel injector causing a missfire?
- Fuel Question
- 42lbs or should I go bigger for 410 stroker?
- T1 cam, stock injectors not enough.
- fuel pump install problem...
- 120*F Fuel pump overheating - help?
- Fuel Pump gods help out a mortal lol
- Got a a pic of fuel access door!!
- Options on where to install power for Hotwire kit?
- 30lb SVO's where to get them flowed cleaned?
- Stupid Question?
- Tb Bypass
- Minimum stable pulse width of larger injectors
- How much injector?
- Water injection
- 38# Lucas Injectors F/S
- Passenger fuel rail shrader valve
- Low Fuel Pressure????
- 15 or 30 degree spray pattern, a difference of 40 rwhp???
- Has anyone got the new walbro 255lph high pressure???
- can I lower fuel pressure
- 38 or 42 lb injectors
- my car wont start...help
- Does leaded gas hurt fuel Injectors?
- Stock Regulator no good?
- Brians is the man! Re: Nibbler!
- changing fuel filter
- 28lb injectors
- GP on SD-Concepts Spring Tensioner kit
- my new fuel system. supports up to 1200hp
- Fuel system almost done... Pics
- Fuel Pump About To Die?
- 13:1+ Compression/Race Gas Discussion - Leaded/Unleaded/Oxygenated
- Quick xylene question
- alternate fuel?
- Walbro 340 pickup strainer???
- Did I put to big injectors in?
- To much fuel From where?Help
- have any idea??
- Is there a way to clean/test fuel injectors?
- Where can somebody buy teflon heat shrink locally?
- Will my car run if I install 42.5's SVO injectors and...
- Convertible FUel Pump Access Trap Door?
- 30# injectors vs. bigger MAF
- My walbro is Fu*#!ng Loud!!
- Mototrons Are Badass!!!
- how loud are the 255 intank walbros.???
- would it hurt to switch from premium to regular gas??
- Anyone use an autometer fuel gauge on cas tank
- A friend needs help with this problem about his gas tank?
- Need advice-Ive searched the forums
- Racetroniix install question
- Barry Grant fuel pumps
- Fueling Question
- Need Help With Fuel Problem
- Is there a 75 lb/hr high impedance injector?
- Worried fuel tank might ignite
- ??autometer electric fuel pressure gauge took a crap??
- What size is stock hard fuel line in 2002 Z28?
- How much Hp will 86# and 95# Injectors support?
- Has anyone that has done the access door regretted it?
- LT1 and LS1 injectors
- Need advice for my fuel system?
- After ADJ FPR install should car be hard to start
- Fuel system upgrade
- Want to install a FPR on my 98 T/A. Can it be done??
- Wiring External Fuel pump Questions...
- Tricks to installing an intank fuel pump?
- installed a walbro 340 intank and now problems....
- 28.6lb injectors rated at what psi??
- truck rails
- do i need new injectors
- FAST fuel management
- fuel pressure
- help-broke my fuel pump assembly
- What year had the biggest injectors ?????
- Newbie,what 255 pump is easiest install for supercharged application?
- What is the maximum pulse width of stock injectors?
- Installing a Walbro 255LPH in a 98 Z28
- Fuel Pump: D1-SC, TR224/227, 42lb injectors?
- #42lb injectors, no tune..how will car run?
- Got my SVO 30#ers in, are they new?
- Recieved my Motron 60#ers Today
- That was fun..
- fuel injector to big?
- Whats the max rwhp Walbro 340 intank, hotwire kit, volt booster will support? 725rwhp
- 99 TA FUEL PUMP Assembly
- WTB 36-40lb Injectors...
- 255 lph conversion to gph?
- MAF Translator Plus vs. LT1 Edit???
- Do I need bigger injectors?
- Bosch 420L next to stock pump pic?
- Na$ty Performance Billit Rails on my Weiand Intake
- 2nd Fuel filter/Regulator blown
- will stock injector's be enough??
- What kind of injectors do i have??? HELP
- What are the exact numbers the 30# SVO injectors are putting out?
- where to get 30# injectors?
- Got a problem while starting up car....
- Injector size?
- Using stock feed as return? Tube, Nut, Sleeve?
- Can someone tell me what size these injectors are??
- Walbro And Injectors: Need Tips
- Need help picking injectors
- Are there any write up on how to install new injectors?
- Cleaning injectors.
- Do I need the hotwire kit for the Walbro 255lph?
- Need Confirmation on part of this project....
- Need help finding (Race Tronics)
- 6 liter intake info
- Help With Setup Guys!
- what is up with my mileage
- 1998 V6 vs V8 fuel lines
- Have you had to remove the entire intake to install aftermarket rails?
- Can I run a Universal Fuel Pressure Regulator off my Fuel Rails?
- 90MM TB for corvette
- Selecting an Injector
- Fuel System Help
- Injector Duty Cycle
- Easiest way to remove fuel rails???????
- What injectors for 650 rwhp? 30s, 36s, or 42s?
- Need help with fuel system setup
- Anyway to get a replacement fuel sock for the Walbro?
- Dying Fuel Pump
- Ok so tell me what I am losing here?
- Would running a high octane unleaded gas help a non-FI car?
- GM GTP Injectors (Tuning Related)
- how to HOTWIRED the fuel pump
- Racetronixs intank pump???'s
- In-line or In-tank Fuel Pump?
- Walbro 255 Lph Gss307
- Stock Injectors
- C5 fuel rail covers
- Walbro pump came with 5.0 install kit. Will the gaskets work?
- any one make a "soft" rev limiter?
- What comes with an elec fuel pressure guage? How did you run the wiring?
- problem....input needed!
- Motron 60# Injectors
- VP fuel for Michigan residents???
- Installing Fuel Injectors, a few tips
- how to test fuel pressure on ls1?
- what should I get intake or out of tank fuel pump
- Pics of my speed inc rails...
- injector installed correctly?
- tape in the gas tank???
- Need Suggestions on Fuel System
- need help with walbro install 98
- What is needed to run a FP guage and FPSS on billet rails?
- Aftermarket fuel rail peeps...
- Fuel system ???s
- 340L intank
- Guys with Boost-Referenced Regulator...
- Bosch 420L inlet outlet thread type??
- Can I run 2 fuel pumps?
- Which injectors?
- Where is everyone mounting.....
- Got most of my new fuel system
- New Fuel Pump on 98 TA
- Rails lose fuel pressure after sitting ?
- Edelbrock LS1 dual Plane Intake
- $129.99 on Speed Inc Billet rails in the sponsor/GP section
- People who have done the 98 to 99+ tank swap
- 28.8# fuel injectors... any gain?
- injectors
- Inline pump just got loud?
- How to take the ring off to install fuel pump?
- Anyone running the Speed Inc. aluminum tank? Pics?
- Fuel Pump change, Access Hole or Tank drop?
- cONFUSED ABOUT INJECTOR OFFSET
- 32lb injectors
- What rating will svo #24 injectors be with LS1 fuel pressure?
- How hard is it do mount a fuel pressure reg on the front rail
- Fuel pump Harness Help
- Bosch 42# injectors?? any good
- ? Regarding Speed inc. billet rails and injectors
- Ls1 running lean from mod's
- anything else needed w/ walbro 255 intank install
- Too big an injector?
- Race gas or octane boost?
- getting new injectors, need to tune computer??????
- Larger Injectors &/or Pump Needed for This Setup?
- flow specs of GM 24508208 injetors?
- SVO 36 lb injector HP question
- Injector Cleaning/Balance Machine
- To those thinking of droppomg the tank to change pump.
- Will my stock injectors be ok on this set-up
- smallest injectors i should consider
- How true is this?: Warning About Ford Injectors
- Pics of a Sump welded on stock 98 tank.
- where can i get injector O-rings?
- Stock size of a 01 t/A
- quick question-GM injector cleaner
- Fuel tank swap help
- Fuel line rubbing coil pack!
- What size injectors?
- guys who have done the "trap door" fuel pump replacement
- Best way to clean out injectors?
- INJECTORS on stock LS1
- will 36lbs injectors work on a stock ls1
- uh oh, broke injector retaining clip? help fast please.
- TR55's v/s TR6's????
- Any good way to clean O2 sensors?
- silverado injectors
- Want to wait for the 99 + rx kit, Is my stock pump enough for a 383 while I wait?
- Do Z06 vettes and F bodies have same fuel pump?
- CAS reg owners please come in....
- Ramchargers Voltage blaster??
- What is the best Fuel pump?
- fuel pump
- Oxygen Sensor Question
- Oxygenated Fuel
- Did Walboro 340, 30 lb. SvO, hotwire kit, volt blaster and now 66 psi...
- GM 42# Injectors ?
