View Full Version : Fueling & Injection
- hey all first post here
- Any difference in a 01 and 02 tank?
- 383 Stroker...Do I need bigger injectors?
- Speed Inc Fuel Rails - New Look
- mototron 60#ers are the shizzle!
- Anyone hooked up a A/F guage?
- CAS rising rate FP regulator question....
- pleas help!! Gas Gauge problem
- Dual intank pumps?
- what size AN fitting fits on the end of the fuel rail?
- Fuel System Troubleshooting.....car won't start
- 00 Plastic gas tank.....Will it work with a 98?
- How do you diagnose a bad or plugged injector?
- Sumping a plastic tank fro external pump...
- leaded race fuel
- 99' plastic gas tank in a 96'
- HELP!!! what injector do i have????
- stock fuel pump problem
- Fuel filter ?'s
- 57lbs injectors?
- Walbro intall for 99 and up.. Searched and cannot find.
- Fuel problems...need advice please
- Need some fuel rails
- Fuel Volume Problem
- Using SMC alcohol injection with alcohol???
- Car in storage and now tank is empty
- Does Lucas Have a website?
- I want vac/boost referenced fuel system.
- Additives
- injector installation checklist
- any1 using the accell 30ib injectors
- injector size??
- people with upgrade inject
- Will this max out my stock injectors?
- walbro 255 inline
- Z06 Injectors
- downgrade injector size
- Centrally located Oklahomans...
- Which injectors for 550rwhp?
- do i need to tunne after install INTANK pump
- Larger Fuel Injectors for LT1
- where do you buy fuel injectors????
- Speed Inc. Fuel pump
- What is this**pic**?
- How to tell if 28lb injectors??
- Problem in stock Fuel Pumps
- need help with the wabro 340 install
- gas mileage
- LS1 Fuel system for 2nd gen Camaro
- Another question for Racetronix - dual 340 setup
- better for 100-150 wet shot?
- Stock Fuel Pump Question
- Another should i upgrade question
- Fuel Pressure Question (look)!!!!
- Jack@Racetronix Question for you
- Fuel Gauge Not Working
- Do The Clips On The Fuel Rails Have To Be On The Injectors....
- Need Custom Fuel system pic's and directions
- 6.0L FPR vs 5.7L FPR
- Does anyone know the factory fuel pressure range for a 98 Trans Am?
- will a walbro 340 and a boost-a-pump support 700rwhp?
- what's the stock fuel pump on the ss or z
- Yet another regulator question
- Low impedance converter box & 72# injectors.....
- Adjustable Fuel Pressure Regulator
- Fuel System Qs
- Tell me about 42 pound injectors
- fuel flow/line size/pump calculator.
- possible to test a used gs340?
- Injector Questions
- Ultimate 4 fuel= 4-5% hp gains???????
- Fuel Pressure Gauge Question.
- Racetronix fuel pump for corvette......questions
- how far can you push the stock injectors.
- Help installing 420L in a 99 tank...
- shouldi change the injectors
- Whos running the Siemens 57# injectors??
- those running dual fuel pumps...
- Jacked up plugs, how bad did it hurt me?
- stock regulator...can it hold dual pumps?
- What size injectors 550rwhp supercharged?
- Alcohol ls1
- which injectors to use???
- LS1 fuel injectors
- help please
- fuel pressure question...
- Advice:how Big Pump 4 Nos??
- Fuel Filter location???
- 2002 Intank fuel pump recomendations
- Lucas Injectors?
- whats the stock injectors in a 2003 Z06?
- Will I Have To Retune....going From 38lbs To 42lbs..
- fuel system for ls1 in 1st gen camaro or other cars
- How to make inline pump connection...
- gettin new fuel injectors
- Need write up in installing intank Walboro 340
- Confused about Fuel Pumps
- disconnecting fuel line?
- Who makes/sells a replacement fuel line???
- What pump is going to keep up with my set up?
- Fuel Pump set up
- where to get injectors?
- Anyone use "voltblaster" and "hotwire kit" from LS1-Speed?
- MSD or Kenne Bell boost-a-pump for LS1???
- Are 30lb. injectors to big for a stock motor?
- How to wire dual intakes?
- Injector question
- 104 octane 50/50 with 93
- What else to check in the fuel system?
- Walbro 355 intank pump?
- Fuel Injection Cleaning?
- Want to move fuel lines
- anyone using accel 30#
- what gas is good??
- T1 cam ?
- Do i need a bigger injectors??
- Fuel Pressure Gauge Install Question
- inline with intank pump ?
- Keep hitting reduced power mode
- How do i get a Bosch 420l inline pump to work with my 99 Plastic tank?
- Took the fuel line apart, and apart it came...
- Noisy Injectors?
- How often to change fuel filter?
- Inline Pump vs Intank Pump
- 8100 Big Block Injectors
- Will the PCM just learn out an increase in fuel pressure?
- Bosch 30# or SVO 30#, which is better
- How Long do the Stock Injectors Last?
- what size are H2 injectors
- Stock Air/Fuel ratio?? problems??
- Need help: Is this the right fitting to hook into end of fuel rail?
- what injectors for 150 dry
- welbro 255 fuel pump replacement help
- New pan and water pump
- fuel pressure gauge stuck at 100psi. help
- Hardcore Fuel System Supplies>
- when to upgrade fuel system?
- Were to get locking gas caps for 98 trans-am&camaro
- Are your injectors REALLY maxed out???
- Bosch 420L pump sale
- Been a while since I have checked in on this
- 42#ers for a H/C car?
- Fuel PSI @ WOT?
- What size injectors for 402 stroker?
- help! installing speed inc fuel rail's need to
- Where to rout the wires for Autometer gage.
- Stock throttle body?
- Question about INjectors for 02 vetts and 02 Z28's?
- Will the racetronix be enough?
- New 90mm TB
- Fuel pressure regulator gone bad?
- Inline and intank fuel pump discussion
- What's the rwhp limit with 02 - 28.x pound injectors and fuel system?
- Are the 30# SVO injectors...
- How to take out the old 26.3 injectors and put in the gm 28.7 injectors
- Racetronix 57# injectors?
- Does anyone know?
- Racetronics fuel pump
- Should I upgrade to bigger injectors/better fuel rails?
- going through 02's..why?
- Help me figure out why I am lean. Kind of long
- How far will 50* go???
- will 30lb svt injector work with my set-up
- going from 00injec to 02 injectors
- LS1 fbody fuel pressure regulator?
- Too much fuel = studder?
- Bad FP or bad regulator...
- Fuel System/Injectors to Support 600+rwhp?
- Quick Disconnect fuel line
- What size injectors did the 97 Vette come with?
- FP and fuel level
- Right Walbro in-tank pump?
- Anyone replaced the steel fuel tank with a plastic one?
- Difference: Racetronix and Walbro pumps??
- autometer guages
- 98 racetronix pump setup.
- round silver thing on fuel rail
- Head/Cam car benefit from bigger injectors?
- Car will not Run
- Stock fuel pump.. Whats it good to
- WS6 with CNG - is it possible?
- Plug and Play Pumps for LS1's
- Octane and Compression ???
- 10% to 25% Off Fuel System Special
- Leaded gas
- Alright, installing FMS 30LB'ers tomorrow, any tricks?
- fuel gauge sender
- need injector scaling for 50# holley injectors
- tr220 question
- Air/Fuel Gauge Connection?
- Huge Aeromotive inline pump question
- What octane gas?
- Will stock 28.8lb injectors support my 383 stroker?
- How do you remove the EVAP system?
- 99-00 Injectors comparo to 98, 01-02
- stock fuel line support
- Should I get the FMS 30LB injectors?
- I can get 30LB FMS injectors for 213.00 now Should I????
- H20 in PVC oil catch can???
- Switching to 30lbs FMS injectors, YES, or NO
- Using Techron to clean injectors?
- Putting a fuel cell in spare tire area...
- Injector Upgrade
- raising the fuel pressure?
- Throttle Body
- Aftermarket LT1 fuel rails?
- Power Potential for 340m Fuel pump
- Who makes a good fuel PSI gauge?
- LSX Injector question
- Harley Davidson injectors
- External fuel system
- Fuel System for 427
- Part # for holley intake gasket
- how did u wire up your aeromotive pump?
- Injector lower Oring question
- How to trace an EVAP leak?
- fuel reqirements needed to support a 200 shot of N20
- Help Walbro Wont Pump.
- do i need a bigger fuel system...
- injectors
- injector question
- How do you install an intank fuel pump?
- ls1 injectors in a lt1?
- Stock fuel pump safety shut off or ignition. (look)
- Fuel pump etc. recommendations
- Need help with fuel pump install
- So my fuel pressure was 100psi at idle all week thanks to..
- will i need new injectors and different fuel pump
- Gas Tank Swap?
- Were can i get a locking gas cap
- tornado fuel saver?
- ? About running 28 # injectors
- What is a good, nice priced electric fuel pressure setup?
- Fuel System Lean Bank 2
- Bigger injectors?
- fuel ?
- WHAT SIZE INJECTORS SHOULD I USE?
- Where to buy new GM sending unit?
- Fuel Return line size -- 1/4" oK???
- Is return line needed to auxillary fuel cell (nitrous use)??
- Do you recognize these "30" lbs injectors?
- does this car need bigger injectors?
- ??42lb/hr optimal FP(43psi,57psi,66 psi) high or low??
- What is the right part# for single Walbro & where to get it?
- Blowby/PCV question
- Where can I find Denso O2 sensors?
- what is the stock fuel pump lph
- 98+ fuel cells......they are coming
- Carbon Build Up..
- 2001 SS Camaro Fuel System
