View Full Version : Fueling & Injection
- need a little help
- Any one use this?
- help with iac
- Cracked fuel injector?
- Car hard to start AFTER fillup?
- Can stock lines/rails/regulator handle dual intanks?
- 60lb injectors for h/c car?
- Car starts but won't idle?
- carb help...
- How many 90 bends are too many??
- Racetronix plug and play,is it enough for my setup?
- Fuel Pressure guage on stock rails...
- Drive through ~FIRE~ ?
- doing my fuel system, let me see some fuel rails
- injector and spray question
- my idea for a nasty tank ventilation system
- Save PSI for My Setup.
- Fuel line help
- Racetronix pump plus a BAP can support how much max hp?
- 2 fuel cells, is it possible?
- fuel pump install questions....will this work
- Fuel system questions, turbo !
- pics of fuel systems
- 93 fuel pump problems
- nate fuel tank guys
- Fuel System recommendations for my Twin Turbo build...
- Is Fuel Pressure a PCM Parameter?
- fuel rail question
- Injector noob question...
- Racetronix fuel pump but do i really need injectors too?
- Any one used the racetronix regulator?
- Fuel lines
- Need help, possible fuel pump problem
- Racetronix pressure issue
- Fuel tank problem
- what sponsor sells the katech fuel rail adapter kit?
- 39lb injectors?
- Is 71 psi to high?
- Help needed: Intermittent dying/no start condition
- MSD BAP install question.
- going from 28lb to 30lb injectors worth it??
- Fuel Pressure Regulator help....
- how to make fuel pump shutoff?
- Kenne Bell BAP installation instructions
- edelbrock fuel rails question.
- Is 42-49psi normal on an 01 ws6?
- In the middle of install... Need help ASAP!
- dual walbro harness problems
- how big are stock gas tanks?
- There is a 15-gallon cell that works!
- ls7 42lb in ls1 ???
- stock pcm 96# injectors
- what size injectors with 610 horsepower
- SVO 42#'s good for 500 RWHP FI
- gotta replace fuel pump
- Injector Pulse-Width Puzzle
- Injector question?
- time to upgrade fuel system
- how to hook fuel lines to SPeed Inc rails?!?!
- whos using Lucas injectors?
- Submersible fuel line......who and where??
- Injectors
- whats the stock fuel system limit of a 02 fbody
- GMPP manifold and oem mounting style fuel rails?
- new dual intank idea with pictures, i guess its a new idea
- Esclade fueling help please!!!!!!!!!!
- LS7 injectors on an LS1 with a FAST intake?
- evap removed
- injector converter box... who makes
- 98 V6 Fuel pump asembly with v8 pump
- Walbro/Racetronix ?'s
- stock fuel
- My twin Walbro's/01 T/A, Pics and schizz
- 1200 hp guys- fuel rails?
- Hw to fix idle after injectors???
- do I need a new sending unit
- wiring fuel pump relay
- Where to buy in tank regulator??Help!!
- retrotekspeed fuel injection
- Return-style fuel rails on a SSR manifold?
- purchasing injectors what to know?
- need help
- Hard Starting
- Racetronix Fuel Pump Kit LS1: Do i need a retunne?
- What psi should i be at?
- Melted wires on pump harness and sending unit???
- Fuel Pump & Injectors Sanity check
- Looking for suggestions on #30 fuel injectors
- Ran into a couple of problems...
- DTC: P1441 EVAP Code? Need to know how to fix!
- fuel guage stuck
- TSP In-Tank Fuel Pump
- how do i go about picking injectors?
- Price Question (Fuel Injectors and Fuel Pump)
- Faulty gas gauge? 01 TA
- ANy aftermarket Fuel Rails still allow use of FRC's?
- Quick Tips on installing AN Fittings And Lines?
- 4th gen tank in 3rd gen car
- Speed Inc budjet rail kit
- Wheres the regulator on an 01 ws6?
- stuck in open loop??
- Question about brand of injector
- Racetronics Fuel Kit. Need to talk with sponsor!
- Calculating HP vs Fuel Injector Size
- Help!!!
- Fuel System Sale up to $100 OFF
- 39 lb mustang cobra injectors
- injector life
- trottle body
- Carb VS Fuel injected tank
- New to AN fittings, braided lines and hard-lines. School me on this stuff.
- Fuel Filter
- Injector sizing question...
- Aftermarket fuel system???
- Fuel pump overheating?
- Walbro 255 in-tank install question!!!
- bosch 420 external pump inside the tank?
- Where to find 1 30ound svo injector?
- GTP injectors
- Fuel Injectors
- Intake or Inline? 500rwhp + Nitrous.
- Injector Question??
- what are 42lb injectors good too
- Diagnostic fuel pressure guage
- big fuel injectors with stock pcm
- Nasty Performance vent fix? Maybe.
- F.I. guys with 1000-1200hp fuel set up???
- Dual fuel rails/injectors
- Is my fuel pump dead?
- stock fuel line limit?
- Fast Fuel Rail Kit
- database of available injectors and converted flow?
- how to make a dual in tank-SEARCH CUCKS
- What size are yellow top SVO Injectors?
- Simple fueling needs question
- Fuel Rail Question-Single Line, Dual Line, etc.
- stock fuel pressure regulator?
- tpi rpm operating range???
- Full tank
- 408 LQ9 F-1C vette - Versafueler????
- Slight Misfire and codes, not sure what to change though...
- Question on BAP's
- more than 80 lb fuel injectors
- Help Imput Please!?!?!?!?!
- Help
- How much power do the LS7 40 lb. injectors support?
- 7 LB pressure drop normal?
- Injectors?
- injectors
- Biggest dry shot I can run safely with stock 28.6# injectors???
- intake runner totally clean???
- EV6 Injectors
- Need part number for gas tank.
- How hard it is to remove a gas tank?
- Low fuel pressure please help!
- Fuel injector install writeup???
- SVO 30's at 90%+
- long cranking??
- Weld in bungs.
- Yes, another injector question.
- what if I have a hp goal of 450?
- How to check for leaking injector?
- What fuel pump for a 2000 Silverado tank?
- Beneficial to replace pump with high flow?
- 65lb motron help!!!
- Lose MPG?
- fuel system setup, to return or not to return?
- Walbro 255 Question.
- FI fuel line selection
- Ford SV0 42 green top injector part number?
- strange injector question
- Fuel Pressure dropping
- Anyone have instructions how to install a fuel cooler?
- LS2 return style fuel rail - anyone?
- what is stock injector rating
- CAn you tell me what this is?
- O2 Sensor Info
- low fuel pressure with key on???
- injector Question?
- **Why do I keep running rich tune after tune?**
- procharger parts?
- Fuel pump bad or what?
- fuel pumps help
- Fule pumps
- No Fuel Cyl 1,3,5,7
- fuel pump being loud
- carbon build up?
- Fuel system-HP
- 2004 GTO LS1 Fuel Setup Ideas???
- It's coming together, a little fuel help please
- LT1 Fuel Rail Setup for high HP
- Injectors
- Using a Voltmeter??
- Pressure Drop ?
- Symptoms of failing stock fuel pump
- Is your walbro loud?
- Hot Wire kit for fuel pump.
- Fule Cell
- How much whp can a racetronix w/boost a pump handle?
- -8 AN Rails? Were?
- need fuel rail install info
- How to run your LS1 on E85
- what injector size?
- What pump to go with?
- Fuel Pickup?????
- Stock injector size, at what pressure
- Plug n Play Fuel rails
- Identify these injectors please
- fuel rail fitting hitting firewall
- regulator qustion?
- '05 ssr intake on a '00 5.3L???
- 98 fuel pump
- $800 for a new fuel pump? rediculous
- Fuel Cell ???
- AZPS New Fuel Rail Fitting adapter for return style fuel system
- New in-tank pump problems for 04 GTO
- Injector?
- would adding fuel rails be the equvilent of adding a BAP?
- Got A Lean Code
- Tape on npt fittings?
- In tank wiring issue...HELP
- adj fuel pressure regulator w/ boost ????
- Please Help!!
- Cut for fuel pump location
- Fuel system for naturally aspirated 415 ci?
- Weight difference between 98-99 metal tank & 00-02 plastic tank???
- Walbro woes, another walbro pump craps out...
- Procedures when Installing Fuel Injection
- Problems after 42# injector install?
- Walbro pump install information HERE!
- injectors scaled too low
- in car rewinding tape deck noise from fuel system!
- Best inline intank fuel pump?
- Fuel Pressure 60-40psi????
- stock fuel pump
- how do i wire up & install an inline pump??
- Injector and FP regulator
- MOVED: Injectors & Fuel Rails
- weird fuel pump question
- fuel system help
- Injector questions
- 105-108 duty cycle??!!
- What would cause a car to run pig rich all of a sudden?
- I think my fuel pump died
- Will a dirty filter cause fuel pressure to drop? (pictures inside)
- 370 + t76 fueling
- boost-a-pump question
- Throttle body
