PDA
View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77
  1. CAS drag tank owners does your fuel gauge work?
  2. 2001 Camaro fuel system dumb questions. *DELETED*
  3. 02 Fuel Pump fit on 98?
  4. boost-a-pump and Racetronix Question
  5. A/F ratio question
  6. Need tuning going from 26# to 29# injectors??
  7. Who makes an aftermarket fuel rail kit?
  8. Need tuning going from 26# to 29# injectors??
  9. Whens a good time to replace stock injectors? (mileage)
  10. do i need bigger fuel injectors?
  11. Fuel Injectors
  12. GMS Intank Fuel Pump
  13. What fuel system parts do I need for my future setup?
  14. ??What size are the port openings on the CAS FP regulator??
  15. Inline booster pump
  16. 26# to 29# LS6 Injectors
  17. anyone tried this? USEFUL a/f gauge...
  18. Fuel Fragrances--Good?, Bad?....
  19. Installing walbro and have a question
  20. Racetronics kit is in... but wont go!
  21. Air/Fuel ratio question?
  22. AN fittings for stock lines?
  23. --///*** Need some help ASAP ***\\\--
  24. running very rich waht can i do?
  25. What is a good fuel pump for a stock motor with a 3000stall?
  26. Racetronix fuel pump kit in my unmodded Z
  27. Connecting fuel pump to fuel lines
  28. Intrest for a drop in dual walbro pump for 99+ for $500?
  29. help me install inline fuel pump
  30. which is better? lid or fipk
  31. Fuel line size
  32. aftermarket intakes
  33. Installing intank and inline walbros.
  34. anyone heard of ADS injectors?
  35. What size injectors?
  36. Ford injectors that will work on our cars and pictures here.
  37. Stock scale for 36# injectors?
  38. How much RWHP can the SVO 30 lb/hr support with Racetronix?
  39. Fuel Pressure for LS1
  40. quick connect to an adapters??
  41. Injectors running out of steam (gas actually) early
  42. Max RWHP with Racetronix setup?
  43. Who has tuned with 57#
  44. Location of fuel pump relay?
  45. Anyone ever consider this idea for a fuel system?
  46. With all these H/C cars
  47. twin in-tanks, stock lines, hi imped. inj box, &huge injecto
  48. Fuel pump problem
  49. what size injectors?
  50. How do inline pump works?
  51. What Size pump and injectors?
  52. Injector flow 4 bar vs 3 bar
  53. Ford/Bosch 42# injectors...
  54. 30# injectors and tuning questions
  55. where to route braided lines
  56. Where to find injector offset values...
  57. Billet Fuel Rails for LS1..anyone make'em??
  58. Injector replacement
  59. how to setup aeromotive system on 99 plastic gas tank
  60. Dual intake Walbro 340's...
  61. Fuel pump gone, I think..
  62. Bigger injectors, spray patterns, disc vs. pintle, etc.
  63. Bosch or SVO which is better
  64. What would cause a rapid jump in FP?
  65. Line length from tank to rail
  66. Need help on injector sizing
  67. Anyone use braided line in the tank?
  68. Where can you buy 36lb SVO
  69. Bosch or SVO injectors
  70. Highly Recommended/ Racing GM EFI Fuel Filter
  71. use z-max? yes or no?
  72. Annoying Problem Please Help
  73. will this be enuff...
  74. Car running rich trouble.
  75. Carburators Vs. Fuel Injection
  76. Need help on Walboro 340 install ASAP
  77. Whats the rating on a Walboro GSS340?
  78. any pics of fuel rails....
  79. Is the Stock FPR Adjustable?
  80. Tell me if this is a good idea?
  81. Stock sumped tank pics...
  82. Upgraded Injectors on a 347cid H & C car....
  83. Adjustable FPR w/ stock lines??
  84. Why can LS1s run pump gas (90 octane)?
  85. fuel injector cleaners? fuel systems service?
  86. how much hp can I support?
  87. nyone running a deeicated fuel system for nitrous kit???
  88. tell me if i need a better fuel system
  89. SVO 36 or 30?
  90. HELP, Car trouble starting, fuel pump issue?
  91. Stock Fuel Pump Problems
  92. What to cover FP Wires after Soldering?
  93. New FP Gauge / Installed new Fuel Filter and lost 2-3 PSI??
  94. Fuel Pressure Question and Problem
  95. High flow fuel rails.
  96. Need to get new injectors, heads/cam LS1 w/100 dry shot...
  97. Help Me Build a 350
  98. Injectors and FMU question
  99. Will I need an adjustable FP regulator with dual Walboro 340
  100. Green Top injectors?
  101. WHERE TO BUY Walbro 340GSS fuel pump
  102. Bosch fuel Pump Rating ?
  103. Need some fuel system advice
  104. Racetronix fuel system
  105. How to connect 4 AN fitting to NPT fitting?
  106. Shraeder Valve...what's type of threads?
  107. LS1 running way TOO HOT!!!
  108. Fuel Pressure Sending Unit........Help!
  109. Need info on Fuel rail and regulators
  110. Strange fuel pressure issues
  111. delete
  112. Manual fuel pump and 5 gallon cell questions..
  113. Anyone got a picture of the 1999-up tank?
  114. Peak/Hold Injector vs. Saturated Circuit Injector?
  115. Billet Fuel Rails For LS1? Source?
  116. fuel gauge always stays on F
  117. huge low impeadance vs big high impeadance
  118. Granatelli 85mm MAF
  119. What could be causing the slug?
  120. Stock Gap???
  121. race gas vs. o2 sensor life.
  122. anyone with aftermarket fuel sending unit/gauge?
  123. Differences between '98 and '99+ fuel tanks?
  124. gas gage!
  125. Will 98 sender line up with 99up tank
  126. Race Gas?
  127. questions about v-6 fuel lines
  128. SVO 30lbs injectors helped - For Team-ZR1
  129. What size are white top bosch injectors?
  130. Check it out
  131. CAS Sumped tank
  132. Whats the latest on the SVO 42# Injectors
  133. regulator how to
  134. Wiring for in-line pump?
  135. injector clips won't fit SVO injectors
  136. fuel pressure release
  137. do I need a bigger pump?
  138. Flushing Fuel Tank
  139. Anyone with 99+ car use the 98 gastank and the Racetronix???
  140. To Walbro users, did you upgrade wiring as well????
  141. loosing fuel pressure at high rpm
  142. Best place to buy walboro 255 fuel pump?
  143. Ideas for intake swap?
  144. Fuel pump pressure?
  145. Whats the Best Place to Get Ignition Wires.........
  146. What Fuel Pump and Injectors for my H/C 150 shot combo?
  147. What will happen if I upgrade my fuel system befor I go F/I
  148. What octane to cure pinging?
  149. will these fit my car, help quick
  150. If I get bigger injectors do I have to change computer stuff
  151. What size are White top injectors
  152. Do fuel additives help with LS1's performance?
  153. Whos Runnin what injector with 400 to 440 RWHP
  154. Help car wont rev past.....
  155. Fuel Guage Stuck Past Full, Any Suggestions?
  156. fuel pump feed hose keeps blowing off
  157. SVO #30 injectors?
  158. fuel regulator?
  159. 30lb SVO injectors enough for a 422
  160. balancing of fuel injectors
  161. Paging TeamZR-1.....injector questions
  162. fuel systems
  163. Gas Fumes!
  164. Quick question for replacing injectors
  165. Fuel Injectors and Intake vs. Nitrous questions...
  166. wot pinging
  167. Dirty injectors/throttle body making SES light turn on?
  168. K&N-Smooth Bellows=bad milage
  169. Do 39 lb. injectors sound right for a bolt-on/cam car?
  170. I need somebody to ATAP me!!!
  171. Low Impedance Box
  172. Racetronix obviously not coming out, Need dual Walboro setup
  173. Injector Offset table for a 2001-2002
  174. Any problems with line connecting on a Walbro???
  175. fuel pump faqs
  176. Has anyone heard anything new on the Racetronix '99 & up?
  177. part # for bosch pump?
  178. Ford SVO Injectors
  179. Easy fix for high rpm fuel pressure drop.
  180. Hella deal on Accel 32lb. Injectors. Check it out.
  181. Fuel Filter Replacement What Kind?
  182. What size Injectors and Output are 94-97 LT1 Camaro/Firebird
  183. how do i check 2c if injectors are getting constant signal?
  184. Is my fuel system enough??
  185. fuel
  186. injector size ?'s
  187. Fuel System layout...Need opinions
  188. what burns faster?
  189. Whats going on with the Racetronix intank for us 99-up guys?
  190. Car Pops @ 5000 rpm in 2nd gear
  191. Weight saving: Remove fuel pump!
  192. Help! Not gettin' any gas at injectors or spark....
  193. what modification is needed for 5.0 rails?
  194. Size of stock pump?
  195. Need help with Walbro 255 inline install!
  196. The best way to hook up fuel ratio to o2 sensor?
  197. stock fuel system enough
  198. Pressure dropping UPDATE
  199. how did you get your hose from coming off your walbro pump?
  200. Using stock in-take fuel pump as boost pump?
  201. Discussion: Fuel system cleaners
  202. Injector Sizing..
  203. Making 400 RWHP w/ 26 lbs inj. Do I need 28's
  204. fuel problem, need help!
  205. Anyone run new feed line from tank?
  206. Any one use a boost-a-pump?
  207. How much HP can stock fuel rail support?
  208. Fuel pressure dropping on new gauge
  209. intank pump users within!
  210. Inline Fuel Pump - Where to run wires?
  211. Where to mount 'box' for fuel pressure gauge
  212. Where can I get a high horsepower fuel pump for my Z?
  213. got the double walbro in the 99+ plastic tank
  214. Do I need an upgraded fuel pump?
  215. WHY IS GAS LEAKING OUT OF MY FPR.
  216. I need colors
  217. What's The Difference between mechanical and electrical gauges?
  218. best replacement fuel filter
  219. Any hints or tips on Walbro 340 install on 99 up F-body
  220. Injector Duty Cycle - How to calculate?
  221. Fuel Pump: intank or inline? which would you do?
  222. How much HP will the stock fuel rails support?
  223. Installing 255,any probs with fp reg after install?
  224. Return line to the tank??
  225. Whats the best fuel inj. cleaner & oct. boost? Got a prob. 2
  226. vapor line and boxes what do they do?
  227. 26# vs, 28# Questions on flow???
  228. Fuel pump went out, Need advice on new one.
  229. What do you think about this Product Line?
  230. i got new fuelpump put in dont think they put it right
  231. vaccuum piece near fuel rails what is it
  232. Stock fuel gauge?
  233. Need bigger injectors, what size/number/brand?
  234. What year LS1's have gas lights?
  235. Poll: What kind of fuel filter are you using?
  236. One cylinder isn't getting fuel, please help!
  237. `02 LS6 injectors different than `02 LS1`s??
  238. Fuel press? and boost
  239. My #8 injector is leaking from the rail...
  240. NEED INFO ON TWIN INTANK SETUPS....
  241. Walbro install, need help
  242. running rich
  243. If an injector is clogged, is the extra fuel still used?
  244. Fast/DFI
  245. How do you install an external FPR?
  246. Where to mount in-line pump?
  247. Do I need to upgrade my injectors?
  248. gas tank wont eat!!
  249. Is this a fuel pump sound?
  250. need an injector calculator and help
