PDA
View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77]
  1. Swapping in 42 lb injectors, can i tune for this with LS1edit
  2. Maxing out the stock fuel system
  3. Confused about stock fuel system
  4. Bad gas?
  5. Need to know SVO injector size for the following number?
  6. Fuel Pressure at Wide Open Throttle( Whats your pressure?)
  7. starting problems?
  8. Help!! Trouble with Walbro 340 install on a 98
  9. At what power level is a walbro 340 needed?
  10. I have a '99, Should I change injectors?
  11. Help, How to program for 30# injectors????
  12. How does an inline pump boost lph after the stocker?
  13. Stock Fuel Pump better than Walbro 340 Intank??
  14. Need fuel line plumbing help
  15. Question? How to change gas?
  16. Optimal Air
  17. SVO 30# injectors best place to get them
  18. Fuel system for Hotcam and 125/150 Dry kit?
  19. Stock fuel pump whine
  20. poor gas mileage help..
  21. '99 stock injectors good enough for Z06 swap?
  22. When do I need to upgrade my fuel system?
  23. Ford injector question
  24. Will 99 tank/sender line up with 98 lines
  25. #30 svo big enough for 422 and 100 shot????
  26. best drop in pump for a 98 TA.
  27. LS1 Injectors
  28. still big trouble
  29. AN fittings and hose install?
  30. FORD SVO 30lb Injector Questions, Duty Cycle
  31. What FP for a 99 T/A with S2 H/C
  32. Aeromotive Fuel System Controller
  33. 98 fuel "sender" unit in a 99+ tank?
  34. Do I need to get bigger injectors?
  35. Throttlebody question
  36. Do 1999-2002 F-Bodies have the same Fuel Rails?
  37. I THINK I MIGHT HAVE A PROBLEM, SOMEONE PLEASE HELP
  38. Do I need a High Pressure or Low Pressure Walbro 340?
  39. HP capabilities of 2002 Z06 fuel pump
  40. Speed INC inline fuel pump!
  41. octane?
  42. 19 lb. injectors maxed out?
  43. xylene mixed with gas
  44. Confused about Intank FP's
  45. fuel pump problem??
  46. Where does the grey fuel pump wire go?
  47. Sheet metal intake injector hole question & concern
  48. aftermarket throttle body???
  49. Problem With Gas Gauge
  50. Cant get rid of ses light code P0327
  51. Where to run wires for electronic fuel gauge
  52. How much for 50lb injectors
  53. If we can get 5 to purchase the Intank Fuel Pump,
  54. What size injectors for my 125 dry shot?
  55. Should I replace the pump if I need to replace the sending assy?
  56. Question for guys using Aeromotive A1000 Fuel pumps
  57. what should i do to make my car run seftely with NOS
  58. H/C car and 125 wet shot.... Will the Walbro 340 support it?
  59. how come everyone selling used weldons wants like 80% of new price
  60. BAD GAS!!!
  61. bouncing fuel pressure
  62. Any reason not to use brass fittings for fuel line??
  63. What is a good fuel pump for nitrous?
  64. 87 octane
  65. injectors size?
  66. ANY 1 any info
  67. i need the best injectors
  68. Fuel pressure and injector questions
  69. Fuel pump limits
  70. SVO 30lb Injectors
  71. How to adapt fuel line to braided line
  72. Will 99 and up tanks bolt up to a 98?
  73. Is it hard to install an intank walboro pump?
  74. Turbo? school me somebody???
  75. I nominate MightyMouse for moderator of fueling and injection
  76. Anyone running the Weldon 2015 external pump?
  77. injector ?
  78. Fuel sender failing?
  79. External fuel pump noise.
  80. AIR FUEL RATIO
  81. good idea!
  82. fuel pump problem
  83. How do you make a fuel cutoff switch?
  84. new fuel pump
  85. Fuel System Help ASAP
  86. Fuel Pump question
  87. Any of you guys runing Custom Fuel Rails?
  88. Can't maintain fuel pressure at WOT or turning right?
  89. what to use for fuel lines
  90. What injectors are these?
  91. bosch fuel pump part #s
  92. external fuel pump?????
  93. What size (GPH) fuel pump is needed for this combo?
  94. FUEL PUMP --- What does this mean "must be run with a bypass/return style regulator"
  95. walbro fuel pump question
  96. Fuel pump install help.
  97. Which wire goes to fuel pump?
  98. any good in tank fuel pump's for my 409 stroker?
  99. fuel injectors???
  100. I have a problem
  101. what fuel injectors for a 480 rwhp NA stroker engine
  102. Fuel Pressure Drop On Acceleration
  103. The end all injector post
  104. 2nd Fuel Pump ON Switch Trigger?
  105. 2nd Fuel Pump ON Switch Trigger?
  106. Questions about stock fuel line and 50 lb injectors
  107. Fuel Rails?
  108. Anyone have instructions for installing an inline fuel pump?
  109. Fuel Pump Question
  110. Identify these injectors for me!
  111. Why not use GTP Injectors?
  112. How hard to swap in-tank fuel pumps?
  113. Problem between injector and PCM!!
  114. where did you mount your fuel pressure gauge?
  115. How many of you run around with 100 octane??
