PDA
View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77
  1. MMS 7.875" Crank pulleys back in stock
  2. Will I need new injectors?
  3. has anyone installed speedinc. sumped tank?
  4. Anyone have any hints or tips for removal of gas tank.
  5. is octane booster a good thing to run in car regularly
  6. Billet regulators now in stock
  7. Can I make it to a shop with stock fuel pump after s/c?
  8. Ford injector info.
  9. Need advice on intank and inline pumps for my application...
  10. Car dying off at WOT
  11. what to do with evap system
  12. Racetronix Pump and Fuel Level Sender
  13. What size injectors are in my 02'?
  14. What to do with purge/evac thing by manifold
  15. fuel pump humming all the time
  16. FUEL QUESTION
  17. Walbro 340 intank....
  18. SVO 30# injector max HP?
  19. gettig ready for head swap!! what tools needed?
  20. cutting rear hatch area for puel pump?...
  21. Walbro 255 GSS340 Intank question....
  22. Why does my FP gauge sometimes read 50psi?
  23. Warlboro 340 questions
  24. 100 LL Aviation fuel
  25. Question about racing fuel
  26. 99+ FI F-bods, what's your fuel setup?
  27. When do the injectors need to be upgraded?
  28. NEW Intakes for our cars ????????????????????????????
  29. Racetronix Install, something still isn't working right..
  30. Is this enough?
  31. Paging J-Rod regarding the o2's that can tolerate leaded gas
  32. will SVO #42 LBS injectors work in LS1
  33. ordered parts fuel system parts *DELETED*
  34. fuel mileage?
  35. HELP ASAP!! 98Z28 fuel pump started whining louder today???
  36. ACCEL INJECTORS ?
  37. Fuel guage stuck on E How to make it read F?
  38. upright throttle body
  39. What fittings for electric fuel pressure guage?
  40. fuel pump
  41. 98 Racetronix pops the fuse any ideas
  42. hooking up after market regulator, disconection old.
  43. Fuel injectors
  44. Fuel gauge reads empty after fuel pump install
  45. where is the fuel filter located on my z28?
  46. Fuel system mod idea; comments?
  47. who makes best fuel injector cleaner?
  48. Where's the fuel pump located?
  49. OCTANE BOOSTER?
  50. Need some help identifying fuel lines
  51. Starter battery cable shorted, fuel pouring out airfilter...
  52. For those of you who have cut to get to your tank
  53. What should LTFTs be???
  54. its it worth swaping to 28lb. ovr my 26lb injectors?
  55. 38 lb. injectors and Edit?
  56. Hole in my Fuel Tank.
  57. 100 octane unleaded
  58. Which fuel pressure gauage?
  59. looking for pics of fuel systems
  60. Walbro 340 assistance...
  61. WalbroGSS340 not enough pump for 42# SVO injectors?
  62. Stock Injector Issues
  63. Fuel system advice needed on 388 all-bore
  64. fuel injector plugs/pigtails
  65. Cold start poping or backfires
  66. What size fuel pump and injectors for all bore+wet shot moto
  67. Walbro plus stock pump???
  68. In Line Fuel Pump Install
  69. Why walbro fuel pump isn't for everyone.. Install warning..
  70. 98 Racetronix kit in 2000 TA?
  71. New 55# Siemens Hi-Z Injectors
  72. Has anyone Carbed an LS1?
  73. Need help with 99+ walbro install...
  74. Should I clean used injectors before installing?
  75. Octane Booster, any good?
  76. SVO 30# Injectors
  77. low buck fuel rails *DELETED* *DELETED*
  78. What part of cam causes bad gas mileage?
  79. Fuel Filter Change?
  80. I need new injectors. ASAP What do I get?
  81. ohms for fuel gauge?
  82. Another Fuel pump & Injector for NOS car with CAM?
  83. Anyone have Walbro install pics?
  84. fuel system ideas
  85. injector question
  86. new fuel system what size lines?
  87. Anybody have any clues?
  88. Pics:Racetronix intank install in a 98..
  89. Optimum Air/fuel Ratio?
  90. Are 38lb. injectors enough for H/C car with N20?
  91. Will a Walbro 307 work?? Will it support 500 rwhp?
  92. Need help quick - fuel pump replacement
  93. why cant i get my fuel rail disconnected??
  94. possible fuel delivery problem - need some experts
  95. connection for vacuum referenced regulator?
  96. dual 340 walbro setup for 99 up pics
  97. Fuel line questions for new Walbro 340
  98. Should I get bigger injectors?
  99. Big injectors,tune diff /w 98 vac fuel regulator?
  100. Injector pulling time!!!
  101. DUAL WALBRO 340
  102. Red top Ford injectors...what are they???
  103. Octane?
  104. Looking for fuel pump input.What is working
  105. can i remove the stock regualtor?
  106. Will my stock 99 Fuel Pump be enough for a 388?
  107. Which fpr to get?
  108. cheapest place to get 42 lb svo injectors
  109. 28 lb injectors
  110. Anyone replaced the rubber fuel lines with bradied
  111. how much is this f-up gonna cost me
  112. T REX PUMP
  113. 01 injectors
  114. Fuel Line to Fuel Pres. Gauge
  115. best TRUCK fuel pump???
  116. Where can I find the part# for 02 Z06 injectors?
  117. Where can I find the part# for 02 Z06 injectors?
  118. LS6 intake.....Z06 intake
  119. Best way to up Octane?
  120. ?? flat-lined flow table, now L&S trims Zero!
  121. Walbro 340 Kit
  122. Fuel Injector Cleaner
  123. Something is wrong with my car =(
  124. external regulator
  125. Switching to LS6 rail. Where is fuel return line?
  126. Bosch 42# Inj, what PSI are they rated for?
  127. Fuel injector flow and duty rating ?
  128. Billet Regulator
  129. Injectors that do not require splicing the harness
  130. Car running lean
  131. 42# injector install question
  132. Green top injectors (42lb svo) are they the same?
  133. Carbon build up on exhaust tips.
  134. Fuel Pressure low
  135. How does fuel system work... Please explain
  136. Question about in-line fuel pump
  137. Fuel
  138. Will leaded gas harm fuel injectors?
  139. Ford or any other injectors
  140. NM
  141. fuel pressure falling
  142. Crimped Connections on Walbro
  143. High Pressure on Injectors
  144. Backfiring....could it be a fuel problem?
  145. Making a 42lb a 38lb by less fuel pressure??
  146. Can't turn the ring
  147. Charcoal Canister hookup?
  148. In need of larger injectors
  149. What pressure are ford injectors rated at??
  150. Injector choices I need a little help on this one
  151. A few more injector offset questions :)
  152. Autometer gauges Fuel Pressure and A/F ratio gauge
  153. How do I fatten up PE?
  154. How much engine coolant do I need?
  155. A couple fuel setup questions
  156. HEADS/CAM AND 26LB. INJECTORS
  157. BOSCH, LUCAS or CPR injectors?
  158. Access panel to the top of Fuel Tank
  159. Need a fuel circut diagram
  160. OK to run car w/broken EVAP?
  161. h/c swap
  162. Any benefits to bypassing Fuel Rail Pulse Dampner?
  163. Injector Question
  164. Pics of my Dual Walbro GSS340 Intank Mod
  165. Racetronix 99-up f-body pump coming very soon!
  166. External Fuel Pump Question
  167. Fuel Gauge Question
  168. Walbro 340 Question?????
  169. Bogging BIGTIME. Any assistance please?
  170. Car pops and stumbles after injector upgrade
  171. What's the best Spark Plugs to run?
  172. Where to mount inline pump and relay
  173. Fuel Gauge problems
  174. How much RWHP will Vortech T-Rex Inline FP hold??
  175. Test forum 4
  176. Question about PE and flow rate???
  177. What size screw fitting is going into the fuel line T-Block?
  178. Stock pump
  179. Fuel pressure dropping at WOT. Help!
  180. Leak after Walbro 340?
  181. Why buy a second walbro intank if the stock one would work?
  182. Mileage helpers????
  183. Is the inline pump overkill?
  184. Will my stock injectors hold up with H/C and N20?
  185. Walbro in tank install on 98 question
  186. FP gauge
  187. Walbro Installed with Access panel for plastic tanks - PICS
  188. FI Guys, how should I set up the Fuel system for my Procharger?
  189. ??8 psi Pro-charger & 42 lb/hr injectors: Walbro 340 + ATI inline or just the 340
  190. Better way to Wire Walbro than inline Splice??
  191. Can injectors be rebuilt?
  192. Need help w/ Propane Injection. LS1
  193. Is there a cheap way to hook up a F.P.G?
  194. Do I need to retune for SVO 30# injectors?
  195. Walbro Wiring hell
  196. heads/cam what size injectors??
  197. Need help with sugar in my tank
  198. F/P?? How common???????
  199. a fuel pump
  200. best/easiest way to install in-line pump...
  201. Best injector SVO (Bosch) or Accel?
  202. Who has the best price on a Walbro Intank Pump 340
  203. Ticking from fuel Rails?
  204. Material to make bellow from????
  205. Locking gas caps for Fbods
  206. Alternative to the CAS boost referenced FPR?
  207. Fuel filter, STUPID question...
  208. Fuel system for 600rwhp?
  209. 30# SVO Injectors enough for a 388 big bore?
  210. Swapping injectors, how do I do it?
  211. nos inline pump help
  212. CAS Regulator Install
  213. hmm??
  214. Redundant injector question
  215. tb/maf porting polishing
  216. replaced fp, lost fuel guage days later
  217. are inline pumps worth it?
  218. any body using accel injectors?
  219. fuel line question
  220. Regulator
  221. need fuel pump
  222. Fuel support system help needed
  223. No dual Walbro 340 intank pump?
  224. How to install Filter/Sock on Walbro
  225. Flow rating of stock injectors
  226. Fuel pump cutting out
  227. Effect of injectors on idle quality
  228. Fuel pump ?? please help.
  229. Fuel Cell
  230. Badass Canton Racing Fuel Filter Installed
  231. Car is hard to get started after nitrous run. Have ?
  232. Need to upgrade my fuel system, please help me..
  233. Fuel Pump for a 427 LS1
  234. Lubricant for Injector Install?
  235. Walbro 340 install pics
  236. MAF Translator> good or bad?
  237. Do I need to upgrade my Fuel System?
  238. Fuel pump ???
  239. How much horsepower will 28 lb injectors support?
  240. LS6 manifold
  241. What is the part number for stock 98 injectors?
  242. Major questions about 99+ fueling system...
  243. Cranking prob's. I Think?
  244. Fuel system Question ??
  245. Air flow
  246. Stats for 42lb SVO injectors
  247. Question about Injector Offset Table in LS1-Edit
  248. running out of gas...
  249. Injector flow Pattern
  250. What Size Aeromotive pump for a Turbo Stroker
