View Full Version : Fueling & Injection
- Fuel Cell Install
- Do i need a fuel pump adapter?
- Plug vacuum brake booster port opening
- 42# injectors too big?
- Fuel pump setup good for 800whp?
- FIC Fuel injector help!!
- Nylon fuel line compatibility with standard barbs? Or whatever im trying to say..
- Are ti automotive pumps real walbro pumps?
- fuel rail questions
- Which style of injectors do I need?
- Joining the failed fuel pump family
- Mustang fuel pump for carb?
- Fast 92/92 cam car.. 36lb injectors good?
- Anyone run these 36lb injectors from eBay?
- Fuel pressure question
- dipstick and fuel rails
- Need help picking injectors
- Five O Motorsport injectors 1400cc
- LSA Fuel rail connection type?
- Drivers side bank not working
- Help! Problems with my fuel pum/hotwire installation
- Fuel Injector O-ring
- 1500hp on methanol!
- best injectors/rails/fuel pump for H/C/N02 setup
- What line is this?!?!
- remove stock fbody regulator for return system question
- E85 conversion questions
- Hose Length?
- Ls1 fuel rails oe vs aftermarket
- Need 14mmX1.5 fuel line junctions
- Injector Selection
- turbo lq4 help
- Will ford green tops fit ls6 intake
- coils and brackets
- WTB Ls1 intake
- injectors help
- pump,line,and injector questions,please help me finish my heinz57!
- Fuel pump
- what to do with fpr vaccum port when NA
- Fuel Leak
- LS2 bogging at WOT
- More cost effective? Sump/Dual intake/Fuel cell?
- 72 Chevelle LQ4 idle ?
- Which Fuel Rails will fit my '06 truck 5.3 for Returnless setup?
- cylinder 1 misfire issue
- help me with my fueling setup!
- Driving to tuner with bigger injectors
- help diagnosing long crank/hard start
- pintle caps for injectors
- Fuel system enough for twin LS1
- Rear Cable Drive Belt Drive Fuel Pump Installed
- 89 Jaguar xj6
- Easy fix for 98-02 f-body fuel regulator housing issue. (READ THIS)
- Random start issue....
- Is there a higher flowing bolt in replacement to a Walbro 255?
- Injector pulse
- No Fuel pressure after fuel sender & ractronix pump install. UPDATE: (Problem Fixed!)
- Newby Fuel Injector Confusion, Help Needed.
- turbo fuel supply
- 1998 racetronix fuel pump ground wire doesn't reach
- Is a Walboro 255 enough for this set-up?
- tanks inc module vs ls1 module
- Poll: Would you rather see a Flex Fuel dyno test...
- Racetronix 340 Install Questions
- Injector and pump question
- Anyone run a dual fuel system with a Procharger?
- cts-v and procharged 408
- Fuel Pump or Fuel Pressure Regulator? (p0171,p0174)
- Who has drilled an aftermarket pump to accept 99-02 venturi/jet pump?
- twin turbo fuel system help
- Help me ls1 pin flex fuel?
- Fuel Burn Rate Question
- FIC Bosch/ANSU 1650cc injectors?
- Problem with Injector Dynamic Fuel Injectors.
- Stock Vortec 5.3 Return, Flex Fuel style - FPR Question
- Can sensor delete? Can't find the plug
- 1998 racetronix help
- Fast fuel rail part number for Fast 78mm
- Faulty Corvette FPR
- Melted/Fried Aeromotive Stealth 340
- fuel line fitting question
- Injector swap question
- Fuel Pressure Drop with inline regulator...
- Narrowing it down
- Injector Questions????
- Are these Bosch Injectors?
- Racetronix fitting question, same part number two different items???
- Sorry for the stupid question but....?
- Parker 801 Push lock hose
- Holley 160 injector o rings to fit ls7 manifold
- Want to setup my FPR and run lines this way, any problems?
- HELP ASAP... Holley fuel rail install, need grounding strap??
- Hellman fuel sump
- Is there a write up for running an fuel lines
- Tubro chevelle LQ4 fuel system
- Bad check valve
- Vacuum leak
- walbro 400, stock truck regulator, 600 hp???
- fuel line question
- -6 or -8 size fuel crossover?? HELP!
- FS: Blue Demon LS1/LS6 Injectors Super CHEAP! - SOLD
- accufab 4500
- LS EFI fuel system help? - Pressure falling off
- 99-02 fbody Venturi tube/check valve replacement
- Help!! LS1 Fuel crossover question
- Ls6 Flooded Bad - Scared to start
- losing PSI
- Direct fit pump in a 98 car?
- Cheap injector recommendations
- I need help on a fuel tank for my gbody 5.3swap
- Adapting LS2 style injectors to LS1 intake
- 06 truck intake without return fuel rail
- Aem E85 320Lph Pump
- Getting a spike in my AFR's under WOT in my data log
- Is there a way to guess an injector offset?
- HELP picking injectors please!!!!
- lQ9 kitcar Fuel system
- Stock zl1 Injectors for my build?
- Help:What kind of Fuel Injectors?
- Changing injector preassure to half. Anyone done it?
- Lq4 injectors
- Thinking of going carb
- What psi hobbs switch to use
- Another injector thread....
- Ls custom fuel tank
- any issues getting lq4 injectors redone to 42lbs?
- Bad Racetronix 255lph?
- Fuel Pressure.
- Fuel pump for 700rwhp turbo lsx?
- Siphon fuel pump
- What should the Fuel Pressure Be?
- Off Idle Hesitation
- Help with injector O-ring sizeing
- Fueling Issue? Or injector?
- swap fuel system questions
- Can a weak fuel pump cause hp loss
- Quick disconnect at fuel filter
- Please help me with some e85 questions
- Is this a sign of a bad fuel pump?
- Pump or Upgraded wire harness failing
- Fuel Line Issues
- Return line restriction in tank
- l96 intake
- Fuel Bucket Issue..any input would be great
- 5.3 twin turbo fuel pressure question
- Car won't start need HELP!
- Convert to a rail mounted FRP
- Fast injectors any good?
- 95 z28 lt1 fuel pump not working.. need help.
- Holley Intake 300-137, How to hook up PCV & power brakes? See Pictures and Questions
- what triggers the fuel pump?
- Belt drive help decisions
- dual phantom
- TECH legal fuel system
- Fuel Pump Relay Issues
- Racetronix? trying to make sure i buy the right stuff
- Any pics of Sumped setups?
- SPEC my fuel system E85, LS3 TT
- Holley 300-137 intake help
- Hooking up electric fuel gauge
- Stock Injectors max'd out already?
- fuel lines
- My Fuel problem 5.3 swap
- what do i need for ls3 injectors on a ls1??
- Injector leak down
- 5.3 build
- Flex fuel sensor part#
- need help adapting fuel line to -6AN
- source for "bundy " fittings?
- 2001 Trans Am WS6- in tank options
- Will 03 terminator injectors work in my 99 FRC?
- Turbo 5.3 Setup in 2001 WS6 / injector & fuel pump suggestions
- Fuel rails and boost reference regulator
- Fuel on top of intake. Car wouldn't start this morning.
- Injectors / fuelrails
- Who's running a cell?
- LS3 external electric fuel pump options
- fuel pump wont stop running
- Which ID2000's for LS3 Hi Ram intake?
- Labor day sale 20% off CBM Motorsports
- HFP fuel pump
- Great experience with "Fuel 1 injector services"
- Need Help
- Cross section of an injector
- C5 LS1 swap (race Jeep), worked great, then suddenly won't run right
- thoughts on these injectors and fuel pump
- No fuel pressure (new pump)
- Losing fuel pressure after drive
- Stock fbody fuel regulator questions
- Fuel pump strainer?
- Fuel issue
- 00 camaro won't stay running codes p0171 and p0174
- Fuel pressure sender T-splitter & WOT fuel pressure
- No Injector Pulse. HELP
- Where can I buy the connector lock for the fuel pump wire?
- 99+ Plastic Tank Swap in 98 Trans Am Write Up
- Will this fuel line routing work?
- DBC throttle body
- In desperate need of answers - FAST 102/LSXR Rails/LS1 conversion
- Can a bad fuel pump cause this
- Fuel pressure regulator
- Siemens Deka 110324 80# injector questions
- Over-axle dual exhaust, fuel tank options
- Fuel System for LSA swap?
- Starting problem?
- Sunoco e85-r vs. VP c85
- Need help with injectors
- Louder than normal hissing sound from rear. Fuel pump??
- New Pins for Fuel Pump Pigtail
- LS3 injectors on Ly6/L92 intake
- 98 H/C Z28 thinking of spraying in the future.
- 5.3 swap fuel info need.
- Bigger injectors with GMPP ASA Cam?
- Needing some 160-lb/hr injector inputs
- What is the best flowing stock location fuel filter? 99 Formula.
- Procharger guys Lonnie's performance fuel system
- Fuel pressure extremely high!?
- 80s, Twin Walbros, -8/-6 Lines enough for 750rwhp E85?
- Car Idling high and ASR light comes on. . .
- LSA return fuel line
- Fuel injector harness?
- Idle Air Control Valve
- Rear End Out. Should I replace fuel pump?
- Bad fuel pump?
- Building a Holley EFI Dominator setup!
- WHat style injector is prefered?
- 98 Camaro Losing Fuel pressure when turned off
- Good 60lb injectors for an lq9 build
- Trap door/Racetronix pump/Hotwire kit INSTALL **lots of pics**
- Fuel pump HELP!!!!
- Ls3 injectors with fast 90
- fuel system kit for 1000whp
- Fittings from T-Block to AN
- fuel pump for boost
- New cheap 2 micron spin-on filter thats E85 compatible.
- Suggestions for LSX external turbo pump
- What do I need?!?
- Drive by cable setup
- where can i i get a racetronix hotwire pump kit
- cammed bolt on 5.3 tech questions
- Fuel pump working half the time
- Car dies randomly at idle
- 4303 and starting issues
- Fuel pump and fuel system ???'s
- Need Injector Data ASAP
- Fuel pump wiring getting extremely hot!
- fuel complication.
- Anyone Using FIC 127# Injectors - Please Come In
- Cleaning Injectors...
- Surge tank.... sort of
