View Full Version : General Maintenance & Repairs
  1. 6k RPM car shut off, cranks but won't fire.
  2. Squeek
  3. Factory Alarm problem 2002 Z28
  4. Multiple random misfires??
  5. Is this a window motor problem?
  6. loose rocker
  7. wuts up with the smell
  8. NO OIL Pressure
  9. Modded DRLS
  10. Daytime running lights keep blowing...
  11. T-Top lock fell out...
  12. Cruise control dont work.
  13. Lt1 Fuel Pump
  14. Service Engine, ABS INOP, BRAKE, lights
  15. o2 sensor!!
  16. LS engine consumables?
  17. spec clutches any good?
  18. Drove in heavy rain/snow today. now misfires..
  19. quick question
  20. how to replace tensioner pulley
  21. Cleaned MAF and o2 Sensors and what a diff
  22. Just another Misfire question
  23. E-Brake Handle Vibrates
  24. where can I get German castrol and whast does the container look like?
  25. LT1 Cranking Trouble
  26. Need help before I spend $$. window relay
  27. Car sputters but SES light?
  28. Desperately need help with grounding issue
  29. Not starting.. HELP! :<
  30. Help!!! My car has problems getting tuned due to o2
  31. The Infamous Ticking
  32. Need Help Asap
  33. P0405 , Is this what the bottom of the EGR should look like?
  34. Bad bearing noise... help identify
  35. bad battery?
  36. Changing the blinker fluid...
  37. Misfire PLEASE HELP!
  38. Car trys to run after key is turned off?
  39. fluids
  40. Tranny or PCM?
  41. Removing ABS and TCS
  42. 00' ta keeps blowing headlights
  43. Windshield wiper woes...
  44. Stop Leak Engine Fluids Safe?
  45. How To Read Oil Dipstick
  46. i need of new clutch
  47. 98-02 Camaro Projector Fog Light Lense
  48. PCV replacement
  49. Question on removing the clutch fan assembly
  50. How hard is it to install power steering rack?
  51. Dude someone help me i hate my hatch
  52. After installing headers and true duals I have a weird sound...
  53. clutch wet or is it going out
  54. 2 quick questions guys...
  55. What gap on ngk tr55 spark plugs
  56. Power Window motor
  57. squeaky brakes
  58. Car dying?
  59. Power Steering Rack? Where 2 find & how much?
  60. Running horrible
  61. humming while driving
  62. drill mod and clutch questions
  63. NEED HELP, QUICK! Bad fuel Pump?
  64. Visor Mirror Cracked...What to do?
  65. T top starting to rattle
  66. Identifying an exhaust leak?
  67. hopfully just a little problem
  68. Water pump replacement. Help!!!!!
  69. Car won't start. Sometimes....
  70. A/C clutch squeak
  71. car runs too cold
  72. Engine coolant leak plus white smoke.
  73. WeLL F@#k me
  74. Seat Belt Guide help
  75. Oil light is staying on
  76. somebody help
  77. help changing formula headlight housing.
  78. 2200 REV LIMITER clutch pushed in, neutral will goto 6k
  79. Security Light came on
  80. Car runs really bad in the cold
  81. left rear shock??
  82. fuel filter
  83. Rear main seal on the engine...............
  84. Squeak from left rear on driverside
  85. Squeeky driver door hinges...........
  86. 1998 fuel sender
  87. random surging at start up
  88. Turn Signal Question
  89. Problems with new LS1
  90. How much coolant?
  91. is my motor mount gone??
  92. leaking hose
  93. need help cant fix my problem
  94. Oil In Coolant Reservior
  95. Loud, obnoxious noise when lights are turned off in my WS6
  96. 2001 Firebird "Clutch Master Cylinder" how do I bleed!!!
  97. Went in for a check-up...
  98. Squeaking from rear at 110+ speeds?
  99. disabiling an engine topend speed limiter
  100. trouble starting
  101. Radiator Drain plug issue
  102. Yellow gunk under oil cap
  103. 100,000 Miles!
  104. my temp gauge wont come on
  105. Any idea on what a mechanic would charge me to get my spark plugs and wires changed.
  106. Knock Sensor Replacement?
  107. Low coolant light is on
  108. Coolant light?
  109. Car feels sluggish
  110. slight knock when cold
  111. Radiator part ID, please...
  112. Can no one make a power steering pump correctly?
  113. Anything needed...
  114. Asr
  115. 160 stat whats the part number???
  116. noisy suspension?
  117. what oil and filters to get...
  118. car acts like its missing when cold?
  119. another vibration!...
  120. High idle while moving
  121. power steering pulley removal
  122. 3 months vs 3k for oil
  123. help!! plug on top of alternator
  124. Easy fix for rear hatch's that don't pop
  125. Front Blinkers not working
  126. "Do'h!" of the day
  127. Broken widow washer
  128. help with seafoam please!!
  129. Power window issues....AGAIN
  130. help!!!!
  131. looking at a 99 z28 had a high idle
  132. Power steering Pump!
  133. 2X electrical problems
  134. Misfire after Shifting
  135. How to clean an intake?
  136. looking for the name of a part for firebird or trans am
  137. Low Oil Light On
  138. AIR problem
  139. odd engine stutter
  140. rear brake screeeeeeech! please help
  141. Horn Question
  142. Amount of p/s fluid needed to flush the system
  143. 98' Z28 A4, What Go Bad First Driveshift -u Joint
  144. Fuel Leak.. Out the CAP!
  145. No Heat
  146. Issues...
  147. Service Vehicle & Airbag lights
  148. 80K mile maintenance
  149. Driver side window
  150. Power Steer Pump Question..
  151. Sun Visor Repair
  152. New Alternator which one
  153. Did Spark Plugs - Now 6 Codes
  154. Help me, door latch problem..ahah *pics*
  155. o2 sensors in wrong place
  156. o2 sensor ?
  157. Heater core Flush
  158. squeaking in the engine bay area
  159. T/A Headlights Open/Close When Locking/Unlocking
  160. what is the best atifreeze to use in a 99 ls1?
  161. F*cking Exhaust Leak!!!!
  162. change oil reset..now new dash light problems
  163. Loss of power around 2k rpm
  164. TA Healight Caught On Hood (Resolution)
  165. Engine Rebuild Question
  166. ls1 firehawk hood fit my vert without issues?
  167. Oil Leak, WHERE??!?! OMG
  168. How to replace Window Motor ?
  169. po300 = msd coils ???
  170. Knock Sensor.
  171. check engine light w/ hesitating acceleration...
  172. AC drain tube?
  173. Pinion seal on diff
  174. fuel hand works then stops then works???? help!
  175. Car wont fill up/ poor mpg
  176. wiper trouble
  177. Battery nut wont come off
  178. Bad vibration at highway speeds
  179. Problem continues
  180. P0200 Injector Circuit Malfunction
  181. O2 Sensor Question
  182. Power antenna problem
  183. Body shop guys please come in, or GM Body shop guys
  184. How does this plug look?
  185. Need some "fix it" advice
  186. Antifreeze leaking out of the cap????
  187. grand am won't start...'95 v6/3.1
  188. Starting Hesitation
  189. valve cover removal
  190. Backfiring during high engine load?
  191. Fuel Sending Unit Repair
  192. my rear differential is leaking...
  193. Windshield Wiper Woes
  194. oil leak....
  195. chassis lubrication
  196. Need help asap!! Power wire to starter touched headers, fried wire. car wont start
  197. 150 miles to the tank
  198. LT1 starting issue
  199. Help with 02 SENSORS
  200. A/C blows but not cold, won't accept refrigerant
  201. ABS inop, traction control off and brake light on? What should I check first?
  202. SES light again !?
  203. Whats the easiest way to change spark plugs on an ls1
  204. Hit And Run God Dmanit
  205. Any sponcers here offer the poly torque arm mount?
  206. Vibrations: challenge mode
  207. Power steering question, with PICS
  208. Is there away to prevent headlight motor tabs from bending?
  209. Removing carbon buildup
  210. MAP sensor high voltage
  211. Oil Change
  212. What should a Stock 00 SS Idle at????
  213. winshield wipers stuck in up position
  214. Are sparkplugs the ultimate indicator if your car is going lean/rich??
  215. window motor dead. how to replace?
  216. Whistling/whining noise from gear box...
  217. Edelbrock y-pipe will this work with Pacesetter Longtubes?
  218. drivers seat belt not working. how can i fix it?
  219. Help with codes and weird cats
  220. spring broke :(
  221. sparkplug change
  222. maf cleaning question
  223. slow turn signals
  224. clicking sound at high rpms
  225. Backup Lights
  226. True duals vibrating, need help
  227. Should i buy new spark plug wires?
  228. how long did your original window motors last?
  229. Driver Side window trouble!! AHHHH
  230. ford rangers
  231. Passenger Side Wiper Trouble.
  232. A/C issues. (scraping noise)
  233. new ceraminc breaks sqeaking.. normal?
  234. Engine Coolant Temp Sensor for 243 castings
  235. part # for trans am power seat wire harness/air tube
  236. Spark plug wire resistance
  237. Vibration/Knocking through acceleration
  238. Starter shield??
  239. Overheating
  240. Spare tire rattle - mysterious
  241. Belt Squeak
  242. Racket from A/C , I think, quit and so did A/C
  243. Headlight/electrical problem
  244. 01 Grand Prix - High rpm issue
  245. Reccomendations for engine bay cleaning
  246. what should i do my car has 30k on it
  247. egr cleaning
  248. Loss of Power / Misfire
  249. Water in the oil?
  250. Ses Light
