PDA
View Full Version : General Maintenance & Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Which Radiator?
  2. Voltage Drop at WOT?
  3. Head light ???
  4. Dashboard Issues
  5. Clacking noise help!!!!!!!!
  6. can you fix windshield wiper wind deflector on camaros
  7. crankcase ventilation problems
  8. Fuel pump relay
  9. One of my T/A Fog Lights Isn't Working
  10. Loss of battery power / AC/Heater Blower
  11. 1999 Camaro SS fuel filter
  12. What else to replace when swapping transmission?
  13. 98 Firebird won't start
  14. Name that water leak!
  15. rattling after intake installation
  16. 1993-97 trunk latch
  17. Floor Jack Clearance 01 Camaro
  18. Recommended higher-milage maintennance
  19. Will these jackstands work?
  20. broken sensor?
  21. stuck fuel line
  22. HVAC control problem
  23. need some help replaceing the rear rotors on my 2000 firebird
  24. fluid on engine block
  25. Need tips for replacing the Oil Pressure Sending Unit
  26. Window motor... HELP!!!
  27. Opti Problem?
  28. Pic of jack and spare tire installed?
  29. Check engine light came on while driving thru rain
  30. Tranny & Rear Diff Fluid Change HELP
  31. Help with missfire problem
  32. 2001 trans am won't fillup with fuel
  33. Vibration in the back
  34. 96 Z28 no heat, poor mpg's
  35. smoking
  36. 01 trans ampass side lights are dimm
  37. Broken throttle Cable Bracket
  38. battery is dying overnight
  39. getting steering wheel straight after alignment ?
  40. Oil LEAK
  41. What is 100% amount of oil for oil change
  42. security light is on in 02 ss
  43. Faulty fuel sending unit?
  44. 09 tb ss randomly wont start and dies randomly
  45. oil pressure bouncy as hell etc... (video)
  46. Window motor/regulator
  47. Passenger side mirror wont tilt up
  48. Checking OIL level!!!!!
  49. 2 questions
  50. name that sound
  51. SES Code P0410
  52. Low Coolant problem/question
  53. Does bad oxygen sensor always mean SES light?
  54. opinions?
  55. P/S pump symptoms
  56. Looking for Part #
  57. What kind of filter is this?
  58. Driver's side view mirror part... help
  59. new hawk hps pads......drilled/slotted rotors, heavy braking=airbag light
  60. Jack and Spare Tire Hardware??
  61. How did this break the Cruise Control Motor?
  62. No tach? Just the tach, all other gauges work?
  63. dash pad firebird/Trans am
  64. Need some cooling system help
  65. Bogs after starting
  66. Complete interior rewire?
  67. A/C not working.
  68. 2000 camaro issues
  69. 03 silverado won't start
  70. Couple questions before I do plug/wire change
  71. clunk!?
  72. Strange studder in 2nd gear at WOT
  73. How ****ed am I?
  74. P1133 on 2002 stock camaro, 60k miles ???
  75. Need To Buy a New Tool Set
  76. TA just started mis firing I need some help
  77. Did some work on my car today and had a question about a noise??
  78. Fixed My T-Top Leak! (write-up inside)
  79. Alt. issues
  80. Blown AC fuse in my DD
  81. Weird exhaust noises
  82. Coolant Light
  83. NGK Iridium TR55-IX Spark Plugs and MSD wires
  84. Valve or lifter noise on cold start LS1. Please help!!
  85. I lost this piece
  86. Bad effects from MCCC?
  87. Passenger Window stuck..Need Help
  88. Noise
  89. Engine sputters during driving
  90. Wiper motor install..
  91. Alternator trouble
  92. Terrible gas mileage help!
  93. Coolant issues, pls help
  94. Identify this noise
  95. Emergency Brake Handle Rattles & Aftermarket Handles
  96. Is the headlight motor or gear messed up?
  97. Tranny?
  98. Help needed with identifying a part that fell out during radiator/thermostat swap :).
  99. Power steering loud and weak at idle
  100. 98 trans am idle help!!!
  101. My car hates me!
  102. Headers Rust !!
  103. Bad gas mileage (o2 sensor?)
  104. oil pump 99 camaro ss
  105. new A/C comp not engaging
  106. throttle body vaccuum hose
  107. 02 Transam Hard Ride and Squeak???
  108. 07 gmc ac temp controle
  109. Alternator replaced, still not charging and power steering leak
  110. Traction control comes On when I get to 50 mph
  111. a/c whine help!!
  112. 02 codes
  113. Diagnosing Vibration
  114. Doing Ball Joints
  115. GearHeadDeals.com Daily Deal Thread 3-26 to 4-01-2012 (Updated Daily With New Deals)
  116. 98 LS1 rotten pcv hose repair.
  117. 98 Camaro z28 oil pump (HELP)
  118. u joint...i guess not?
  119. tq arm
  120. Found out my rear O2's are gone...Need some help
  121. Headlight harness comes loose
  122. 01 Camaro Water in Trunk??
  123. Spring poped out when I opened my door
  124. Power Windows
  125. Spark Plugs, Fouled or not?
  126. Did my power steering pump just go out?
  127. date and time auto reset
  128. Heater/Coolant Issue
  129. Help with a squeak/rattle (video inside)
  130. Car stalling please help!
  131. Engine overheating, or not ??
  132. Engine Coolant Change
  133. Gatorback belt fitment
  134. Fuel Gauge Issue? or Is this normal?
  135. drvr window motor? acting strange
  136. Write up for steering rack replacement?
  137. 99 ws6 p/s pump question
  138. Rpms drop during braking?
  139. heater core pipes
  140. 02 z28 idles and dies PLEASE HELP
  141. Chatter comming from rear of car when stopped?
  142. Which radiator should i get??
  143. No Turn signal power
  144. vacuum leak through the oil fill cap
  145. Alignment issue
  146. Please help with new 98 Trans Am... I have error codes.
  147. Need Help!!
  148. Upper radiator hose wont stop leaking!!!
  149. New power steering pump making noise
  150. Driver side power window won't roll up!
  151. Squeaky wheel while driving, not while braking
  152. looking for a good shop within a couple hours of southwest michigan
  153. Cracked dash
  154. 3rd gen firebird headlight motor
  155. What does this code mean?
  156. Dirty Air Check Valves
  157. Locked up A/C compressor. What do you think of this kit?
  158. oily residue in exhaust ports??
  159. Loud Whine when turning ?
  160. Part number for catalytic converter
  161. Fluid info :)
  162. need quick AN fitting and hose tutorial
  163. HELP! With driver's side window!
  164. Idler spacer
  165. odd turn signal problems
  166. fuel fillter
  167. ac delco fuel filter
  168. Tune up time!
  169. car runs rough
  170. 01 Z28-turn signals stopped working both sides/headlight come on auto w/o switch
  171. Replaced IAC, is this normal ?
  172. Loss of power, mph and et
  173. headlight motor
  174. New alternator, dead speedo
  175. 3 hours and 7 plugs later...
  176. Battery problem?
  177. AC Delco Iridium Spark Plugs for $20.72 after savings
  178. both power window not working???
  179. What's up Doc?
  180. 2000 camaro guage cluster ...uh ... issue
  181. motor is sounding rough
  182. relieve pressure befoer fuel line disconnect?
  183. drivers side exhaust leak
  184. Grinding sound while stopped in gear
  185. Chirping sound when the motor shuts off
  186. Driveline vibration issue
  187. Master torque setting list?
  188. Pulley chirp, replaced everything
  189. Rear clunking after install!?
  190. VERY TRICKY problem... maybe headgasket
  191. Need help with failed items after scan
  192. Outside of front driver tire wore VERY fast, any ideas?
  193. DRL help!
  194. Grinding or Rough Vibration when foot off gas
  195. '98 camaro M6 idles high + maybe need a clutch.
  196. New car, next move
  197. P0405 EGR Code- Car won't rev past 2k rpms
  198. Proper Grease for Poly suspension bushings
  199. wide open throttle
  200. How many qrts - flush power steering system?
  201. mccc
  202. Alternator pigtail question
  203. Alignment & "Clunking" Noise
  204. power steering pulley squeak now
  205. No heat
  206. GearHeadDeals.com Daily Deal Thread 3-12 to 3-18-2012 (Updated Daily With New Deals)
  207. Fuel pump doesnt get power
  208. Need help fast! Were does this go?
  209. 305 engine sputtering while driving, need help. (Updated 3/17)
  210. TCS/ABS delete throttle cable
  211. Header bolts keep popping off
  212. LT1 Popping
  213. 01 Camaro Gauge Bouncing
  214. PCM ECU Wiring Problems !!!
  215. car overheating 210+
  216. Please help me ID this rattle (evolved, build thread)
  217. Engine oil in radiator - UHG
  218. tachometer
  219. A/C compressor WTF???
  220. Power Steering Oil Cooler(Quick Help Please)
  221. Car cut itself off wont start now
  222. need help
  223. power window motor???
  224. steering shaft bearing
  225. Which power steering line connector is better?
  226. need some help please!
  227. Tail lights, fog lights, and gauge lights out?
  228. Power steering pump replacement - OEM/Aftermarket?
  229. Converter Removal
  230. VATS fix with a twist
  231. Hatch won't close...please help
  232. t56 wont go in reverse
  233. My Seat Lever Broke
  234. 2002 WS6 misfire and knock
  235. Coolant leak under water pump
  236. Severe engine overheating problem!!!!
  237. Best way to protect a splice
  238. Gargling noise from cooling system?
  239. Clutch pedal switch wiring shorted out!!. While trying to install msd 2 step......
  240. Broken wheel hub?
  241. Finally fixed odd brake light issue
  242. Bad mpg. Idk why.
  243. How to change TA blinker/DRL housing?
  244. Formula Drivetrain Vibration
  245. Cooling system question?
  246. Part help
  247. Driver Side Window Help!
  248. WEIRD door window gremlin..........
  249. Dash light: "fluid low," but radiator full - WTF?
  250. GearHeadDeals.com Daily Deal Thread 3-5 to 3-11-2012 (Updated Daily With New Deals)
