PDA
View Full Version : General Maintenance & Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 [117] 118 119 120 121 122
  1. damged wells
  2. Installed P/P throttle body, coolant everywhere!!!
  3. Power Steering Problems
  4. Parking lights not working
  5. Knocking!?!
  6. need a part number for an AC line
  7. Replaced all cooling stuff and a 160, and still running 205*
  8. Water spitting out of exhaust
  9. window rattles
  10. problem with dealer telling me my a/c isn't leaking.
  11. Burning OIL like crazy!
  12. thanks for the help ls1tech!!!
  13. Weird electrical problem
  14. wheel squeak
  15. seat noise
  16. Head lamp motor arm
  17. one more headlight question
  18. LS1 Won't Start!
  19. Fog Lamps not working...
  20. power steering fluid flush
  21. When does one say 'I need a new AC condenser'?
  22. Dealer says nothing is wrong. (brake pulsing and engine cutting out)
  23. Belt Noise?
  24. Front Foglight Bulbs
  25. grinding/popping noise when turning??
  26. Change your own spark plugs or take it to get serviced??
  27. oil leak - cost of getting gaskets replaced?
  28. car won't start
  29. The F-Body window Curse...
  30. car doesn't start
  31. Overheating
  32. battery tray Part number please
  33. Synthetic Oil
  34. car doesn't start
  35. "applique", small black triangular piece behind window
  36. electrical problems
  37. window rolls up very slowly
  38. smoking LS1 - does oil weight make a difference?
  39. Autolite XP spark plugs?
  40. Low Oil Pressure or High Oil Pressure?
  41. 4.3 liter vortec hesitation problems
  42. Clicking Headlights
  43. Ticking?
  44. Ignition troubleshooting - Coil or Plug bad?
  45. what does this sound like??
  46. My Car Wont Start
  47. Turn signals don't flash
  48. low coolant warning?
  49. 98-02 trans am headlight motor
  50. Oil Filter Options?
  51. Wierd noise in rear end
  52. AC leakdown problem
  53. vibrations at highway speeds
  54. Random Tinking Sound
  55. Trying to track down a squeal under the hood...
  56. good spark plugs?
  57. Service Interval Question
  58. weird problem... i think it's the rear?
  59. Royal Purple Or Mobil 1
  60. Just killed My compressor
  61. What oil should I use?
  62. Cruise won't work over 65 mph after gear swap
  63. What the hell is this noise?
  64. Part number for EGR intake o-ring?
  65. Left Turn Signal not working, What's wrong?
  66. Shudder/jerking still here
  67. oil change light??
  68. Wrong oil?
  69. Advice or secret hints needed for dealer repair
  70. overheating
  71. Whistle from engine bay
  72. window motor and regulator change
  73. A/C Compressor Switch
  74. Security Light on! Why?
  75. AC compressor issue
  76. Headlights pop-up on first dial setting
  77. Head Liner
  78. window motor?
  79. Any info on these problems? (driver seat inflation; brights)
  80. Does anyone know an easy way to replace the daytime running light assembly?
  81. loss of idle and serious surging at about 3k on full throttle
  82. Hideous whining noise, changes with RPM
  83. Should I drain my radiator?
  84. What's the best oil??
  85. jacked in the wrong spot, bulged fenders, help
  86. Charging issue - help!!
  87. headlights pop up with fog lights? no running lights
  88. RPMs drop with A/C
  89. Helms Manual?
  90. flakey electrical problem?
  91. oil
  92. E-brake quit
  93. Manual Tranny Mount data for all
  94. Bogging Issue
  95. wtf? (starting problem)
  96. Howling Noise From Engine
  97. Spark Plug Install Problem
  98. Strange Noises coming from Under the car
  99. how do I get the maintenance done on the rubber
  100. how can I clean my engine?
  101. Key Fob will not unlock Passenger door
  102. Blinker Failure
  103. What parts should I be changing regularly?
  104. Car runs hot
  105. Help A/C went out
  106. Car Died!! No Start!! No Power Up!! Completely DEAD!!!, Fully Charged!
  107. permanent fix ta headlights
  108. Pinging is Gone
  109. How hard is it to replace window motor?
  110. problems in paradise
  111. can too much coolant cause your car to heat up?
  112. What would cause these lights to stay on?
  113. Need help hooking up oil pressure gauge
  114. front bumper
  115. Spark Plugs?
  116. light fixing
  117. Electrical drain from "H/L DR HORN" fuse, cause/fix?
  118. oil leak on C5 Corvette
  119. Another Power Window Thread
  120. white residue on rear bumper
  121. ls1 oil pump
  122. newbie oil change
  123. Weird Sound Under the hood
  124. Which Spark Plug wires?
  125. What other maintenance items are needed for a 72k LS1?
  126. Tach response is slow
  127. which cylinder is #2?
  128. Strange Noise & Vibration when turning
  129. ticking noise coming from the rear brakes
  130. Plugs/Wires install done - Pics
  131. AC not blowing
  132. breaking in an engine on synthetic?
  133. cooling problems
  134. MAF question
  135. AC cold then hot?
  136. How to check for vaccum leak
  137. Getting a Trans Am door panel off
  138. wiper problem
  139. Where can I buy the Mobil 1 Oil filler cap Online?
  140. humming noise?
  141. case of the shakes
  142. car won't start
  143. HVAC mode switch not working right
  144. passenger-side spark plugs
  145. Fuel Pump mishap?
  146. I'm Running too hot....
  147. Ignition Cylinder in steering column bad?
  148. Distributor (Not F-body)
  149. smelling gas again
  150. Anyone know how to siphon gas?
  151. how to check for bad mount -motor & tranny.
  152. Need to fix or replace popup headlight motor
  153. cost to replace two airbags and a windshield?
  154. Your experiences at the Dealership
  155. Electrical issues on an 02
  156. Improving Fuel Economy of your F-body
  157. Headlights turn on / pop up all the time - possible short
  158. Mixing 5w30 with 0w40?
  159. Help with a vibration part 876432
  160. Don't Laugh... (replacing spark plugs)
  161. oil leak rear of block
  162. K&N air filter - which side do I clean?
  163. What is this?
  164. Does anyone have a problem with driver mirror shaking?
  165. Change Oil Light?
  166. Vibration when AC is turned on
  167. New rear shocks ALREADY?!?!
  168. so uh.. my Sun Visor fell off. :(
  169. Which suspension/mounts are most likely to creak/groan?
  170. Help Diagnose vibration problem
  171. possible bad cat?
  172. Electrical problem
  173. ticking from valve cover? gas gauge acting up? car at dealer currently.
  174. Water damaged car - what now?
  175. Vibrations coming from hatch area!!!
  176. Headlights flip up when you lock the car?
  177. Chassis Lubrication?
  178. window motor covered by warranty?
  179. man, i just need to vent (scratched plastic)
  180. Vibrations at 1000-1400 rpm...what could be the culprit?
  181. Major sources of drive pulley belt squeal?
  182. gas smell
  183. BOOM!!! hole in engine block
  184. Flasher Question
  185. How difficult is it to change a window roller?
  186. how to change rear hatch struts?
  187. No rear defrost
  188. Bit of an electrical problem... Help!
  189. high battery voltage
  190. NGKTR55 or BOSCH platinum 4 spark plugs?
  191. Cracked plastic around mirror adjuster....
  192. What Oil and Filter are you guys using??
  193. Reading Lamp?
  194. Coolant leak causes car to run hot?
  195. weak parking brake
  196. royal purple? oil filters?
  197. quick question about front fenders
  198. Automatic Transmission Indicator Lamp
  199. headlights go up and down when i lock and unlock the car now
  200. Oil Gauge fluctuations
  201. starting issue
  202. 91 rs camaro has been running hot
  203. oil question
  204. which car battery?
  205. Disable headlight doors with "parking lights" on?
  206. Ticking sound from under valve cover
  207. Stripped plug
  208. Tick-ticking noise from front pass. side when low-speed turning
  209. low trac light ?
  210. low trac light
  211. 00 Camaro a/c recharge?
  212. Headlights grinding
  213. Car running bad! Need Advice!
  214. drivers window rolls up SLOW
  215. coolant system question
  216. trying to track down a misfire, nasty when cold, intermittent mid range...
  217. 94 Camaro Headlight Burning Out / turn signal
  218. Squeaks when cold
  219. Replacing lower ball joints & bushings
  220. No 'BRAKE' light on cluster?
  221. Changing Radiator How long does it take??
  222. turn signal flasher?
  223. Replace blinker bulb
  224. Part # for T/A lenses (amber driving lights)
  225. Finally, an A4 shifter rattle fix!
  226. pcv valve, fuel filter, on v6 camaro
  227. Need help to remove the AC clutch on our 94 Camaro
  228. Could this be bad lifters
  229. Oil Change Light?
  230. Rearend Rattle - Driving me Crazy!
  231. Bleeding air from coolant?
  232. Windshield wiper won't come off, ideas?
  233. Thinking about pulling motor
  234. pound noise in the engine bay like if a engine mount is broken or lose
  235. Wiring harness question
  236. buzzing vents?
  237. Proper way to store car for two-three months?
  238. gas gauge not reading correctly
  239. Burping the Coolant System
  240. Spark Plugs/ Wires, questions
  241. freeze plug
  242. Leaking front turn signals...
  243. Headlight motors
  244. A/C condensation puddling on floor: where to unclog?
  245. Head gasket question...
  246. barking noise from underneath center console when accelerating
  247. Oil usage with synthetic.
  248. check gauge light (low Battery)
  249. Barking noise on 10%+ Acceleration
  250. Engine light on again
