- Car sometimes has trouble starting after it dies
- Clicking noise when I turn my heater on?
- Odd problem in the rain (SES light)
- LS1 service schedule??
- Spark Plugs
- Swapped Positive Lead, Car Dies When Braking
- Overheating- Coolant Leak
- Squeaking, E-Brake Not Engaging on an 02 Z28, etc
- what fluids to use?; headlight motor
- 65+ on highway car starts to vibrate
- BCM help! Doorlocks broken
- Spoiler light '02 TA
- Oil Pressure and Temperature readings
- 5w40 syn
- terrible screeching noise with smoke coming from alternator side of engine (LT1)
- Intermittent rattling
- HVAC actuator valves
- Color of your oil?
- What Spark Plugs Should I Use?
- Change Oil Light Reset
- Tie Rod Replacement?
- She's Leaking!
- Headlight motor question
- Strange electrical issues
- Lots of "clunks" from the drivetrain...
- Low Oil Light?
- No Brake Lights
- Fuel Filter / Pump Problem?
- Where can I get a headlight motor?
- defroster = AC
- LT1 ques need help asap, how do i repress the studs in the axle, how can i take itoff
- Riddle me this Batman
- The brake light is on?
- Unknown part?
- Scheduled Maintenances
- Need part numbers for starter, gasket, seals...
- strange sound from rear
- How to fix Rear Defroster?
- No headlights
- How to take out passenger window? (2000 Camaro)
- Clunka-Clunka from rear end
- Rear bumper corner not lining up? Any clues.
- Compressing Caliper Pistons
- where can I buy this part?
- Tick when A/C's on
- Steering wheel off center
- Prob Starting help
- Power locks not working
- Fed up with power windows.
- stripped negative battery terminal bolt
- 1990 K1500 truck - won't accelerate well, has steady knock
- Strange Tire Wear
- Removing center console from 01 Z28 M6?
- dex cool vs regular antifreeze
- Need a new wiper arm
- U-joint cost repair
- my windows don't work sometimes
- So, Wal-Mart sucks more... (refused oil change)
- Headlight turns on, but doesn't pop up, no grinding noise
- Front fender bulge
- Winterization??
- Wiper fluid problem Maybe motor?
- replacing vent
- Putting my SS away for the winter - battery?
- floor boards soaked
- Weird ticking noise coming from engine
- Rattles under accelration
- noise while turning?
- noise from front end is driving me crazy
- Cruise Control Cable
- 1997 firebird 3.8L V6 auto, shutters and studders while accelerating
- my horn stopped working
- could use some help
- You know those little lights...
- what type of oil?
- Alarm and Headlight Problem
- Help me find my rattle!
- still having low coolant light problems
- Ignition Problem
- Blinker problem? Don't blink stay solid?
- Best oil for the '05 GT?
- Weird noise in front
- horrible squeal!
- Alternator died
- engine shakes to a stop ofter ignition kill
- starts and stalls
- Overheating? Water pump?
- Cruise Control
- Possessed 95 TA, Bad Key Or What?
- A Case of the Ticks.
- problems starting LT1
- Rattling noise under car.. Please help..
- coolant level sensor
- little light
- storing car in the winter?
- Didn't put oil in oil filter; is that bad?
- LT1 oil leak!
- Cricket-like chirping from engine, increases with RPM (drivebelt maybe?)
- how much to change pan gasket?
- trouble turning the key to the off position
- Vibrations through the gas pedal?
- Sometimes Car Wont Start
- Odd electrical issue?
- Dash Lights not working
- Rack and Pinion?
- Doing an Oil Change
- Replacing the alternator today
- Coolant light problems
- Car jerk/bucks when under light load
- Cleaning Fouled spark plugs
- Strange noise
- Oil Pressure Drops
- Car acting funny.
- Bad squeak/creak from rear
- Pontiac Bonneville problem
- Rear Light
- Block leaking... what would you do?
- Thermostat?
- U-Joint bad?
- sunvisor fell off
- want to turn on all parking lights, but without headlights coming up, on 99 TA
- Oil change - what's wrong?
- injector cleaner
- Misfire
- Intermittent Starting Problem
- Weird noise - Vibration with speed
- Terrible screeching from motor after turning off car??
- running lamps
- how much fluid is in the PS system?
- Damn Rattling Noises!
- clunking sounds?!?!?
- New wierd Window problems
- no compression in cyl#6?
- bad sound in first gear
- Where is my coolant going?
- Backfiring during deceleration
- 1974 Mercury Monterey won't start
- weird stuff goin' on (gas smell, not starting well)
- How often to change synthetic oil and filter?
- LT1 alternator problem
- Oil Change Light Came On
- starter problems
- losing power, clicking sound
- Anyone had problems with NGK Iridium plugs?
- What oil to use?
- Headlight problem on my TA
- car cranks several times before starting, and idles poorly
- Turn Signals?! Wtf...
- leaky steering
- whirring sound
- do i need a new water pump?
- what battery to use?
- Fuse for the Rear window defroster?
- Starter compatibility swap
- Did Seafoam change their label or product?
- bent steering knuckle
- How to dispose of oil?
- Ticking
- smoke at the dyno...
- TCS question
- Plugs supposed to glow at night?
- Pink fluid leaking near the alternator
- Hold Downs on floor above the rearend
- 98 Camaro Sebring Silver paint code; how to remove mirrors?
- doc, is it bad? (hissing sound)
- How to test fuel pump?
- replacing window motor.
- fog lights
- what Relay controls the front electric fan?
- Check gauges light when at 1/4 of a tank (plus just generally way off)
- Camaro antenna mast part number?
- Whistling Noise when Idleing
- jump-starting a motorcycle?
- what causes hard starts?
- Clicking noise between 800-1800 rpms?
- Buzzing Noise From Back
- Low coolant warning
- noise coming from radiator
- One headlight dim
- lt1 cooling problems
- Car's idling higher then normal after 1/4 run
- horn beeps twice for no reason
- Keep Blowing IP Dimmer fuse
- popping noise
- Is this the plug for the TCS switch?
- won't start on first turn?
- vibration at speeds of 70 and over
- I need a Part Number
- Extra Cable On TB?
- Help with a 99 grand am
- Any GM techs / air bag experts? (B0090 code)
- car wont start
- gauges keep resetting
- Replacing Lower Radiator Support?
- Pulsing lights
- how to remove AC lower hose?
- SES codes, misfires
- LT1 clicking and shaking while idling
- E-Brake
- is this bent/ broken? (pictures)
- Fresh 427. Need help with noise!
- security light problems
- my oil pressure drops to 0 and the Check gages light turns on
- Car making more bad noises, more serious
- Good AC pump and clutch, but it's not coming on
- Need some body parts
- Speed Sensors
- Part number for TCS switch
- knocking noise
- Firebird turn signal replacement.
- ASR & comfort control lights out
- starting problem on lt1 formula
- Car won't fire?
- got an idle problem
- Windshield Replacement?
- replacing headlight motor, how to get it out of down position?
- Dealership to order parts from?
- Hydraulics on hatch
- Auto Window Issues.
- Headlight noise when closing?
- 85 firebird headlights help
- popping noise
- Funny noise
- 96 T/A turns on, then loses power, then turns off
- bucking/clunking from M6
- OMFG Has everyone forgotten how to lift these cars?
- Air Conditioner
- tough to turn the wheel when stopped
- AC orifice filter Help
- Rough Idle and Surging
- Bad O2 Sensor = horrible gas mileage?
- Slight grinding noise on turns??
- a/c problem
- SES Light?
- stuck @ WOT
- 1999 Civic Help!
- low rough idle, no power, running on 4 cylinders?
- A4 Idle Vibration
- Car doesn't start
- lights grinding
- power steering pump
- Tail Light Lenses Dented??
- engine knocking
- Anything wrong with this radiator flush method?
- M6 maintenance
- blinker flasher
- radiator air dam bolts
- Horrible pulley squeal!
- crazy headlight problem... help
