PDA
View Full Version : General Maintenance & Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Car overheating...
  2. possibly fried windows and radio at once
  3. clutch problems
  4. anti-seize compound
  5. Key fob program....
  6. Weird electronic seat problem... Drivers side controls passanger?!
  7. Hard to find gears
  8. Misfiring...fed up with it
  9. need help with seat removal...can't get electrical connector disconnected
  10. yet another starting issue thread... I'm stumped
  11. how much Hub play on rear axles?
  12. So my car won't start once the engine is hot, help!
  13. spark plug wires
  14. What would cause only front brakes to work?
  15. VATS question, help please
  16. Weather stripping maintenance?
  17. Help! Car shut off at automatic wash and now has low oil pressure...
  18. Help diagnosing misfire/skip/surge
  19. Help!!!!! P0102, P0135, P0155
  20. Water pump, hard to do?
  21. my AC doesn't work?
  22. Help with installing brake pads
  23. Brake problems.. wierd to me.
  24. oil pressure gauge
  25. Burning oil EGR/AIR the reason?
  26. Replacing ECBM 02 Silverado
  27. Battery Keeps Losing Charge
  28. please help cant figure out this exhaust pops
  29. ***Weird Miss....PLEASE HELP!***
  30. Bad oil leak...need suggestions
  31. Is the driveshaft greaseable?
  32. Strange creaking coming from the rear
  33. Car dies after warm up
  34. 1992 Camaro Torque Arm Bushing on trans. replace?
  35. What kind of power steering fluid?
  36. How do I replace my power motor
  37. How do i get into my ac vents?
  38. Replacing window motor PITA???
  39. oil leak problem HELP!!!
  40. NEED HELP!!! BATT KEEPS DIEING A PLACE CHARGED FOR 1.30min
  41. Warped Rear End Cover
  42. Need help guys!!!
  43. '95 Formula Exhaust Question
  44. HELP car is eating batteries
  45. car won't start
  46. metal cable attached to the pcv valve
  47. catalytic converters?
  48. rough start up, then high idle
  49. radiator problems
  50. oil and ????
  51. 02 z28 cranks wont fire sometimes?!?!
  52. ???stock oil pressure gauge.....???
  53. changed brake pads now ABS light on
  54. ABS INOP and TCS off light
  55. could this be the head gasket?
  56. 1998 WS6 17" x 9" high polished aluminum rims......who restores them??
  57. 3 SES Codes. Help
  58. What is going on with my car!?
  59. wiping problem
  60. Where to buy a drivers side window motor from???
  61. Door won't open, what kind of shop do you take it to?
  62. 98 Trans am Window motors
  63. what kind of brakes on a stock SS
  64. 98 z28 Convertible -Water collecting in car cabin... HELP!
  65. Trip odometer keeps reseting
  66. something wrong with my vents
  67. Low Voltage Issue
  68. rear brake pads
  69. 160 thermostat and still running at 210*
  70. weird noise with ignition on acc.
  71. Someone with a digital camera and 5 minutes PLEASE HELP!!! SOS!!!
  72. Windows rattle when 90% up
  73. Oxygen Sensor O2 Locations? SES Light Blinking
  74. Door wont close!??
  75. oil leak out of main?
  76. Windshield wiper removal
  77. Very different door issue. Internal lock malfunction.
  78. Brakes - what would you choose?
  79. simple question
  80. Dim Driver Side Headlight Issue
  81. Rearview light not turning off
  82. Car is giving out at certain rpms
  83. turn signal and electrical woes
  84. Coolant leaking???????!!!!!!!!!!!!!!!
  85. Traction control shuts off?
  86. Tachometer problem
  87. ???broken parking lamp lenses???
  88. Engine swap?
  89. gas guage problems!
  90. Interior under seats and mats always wet after driving in rain..
  91. Running no cat, what is involved?
  92. Gas treatment preference??
  93. Need help on a 96 V6 Firebird
  94. Need help.
  95. E-brake Handle Vibration...Fixed
  96. Changing Clutch Fluid
  97. Remanned Alt. Giving Problems
  98. Oxygen Sensor extensions, which do I need?
  99. Exciter Wire Location
  100. Rough idle/ missing
  101. Help..Pics inside
  102. Is engine still good?
  103. noises in the back end
  104. Car doesn't start
  105. Car runs like crap on cold starts
  106. Rediculously low voltage(Long post, bear with me)
  107. headlight failure
  108. Noisey Lifters
  109. fuel filter
  110. brake light
  111. Hvac contol problems
  112. Steering knock?
  113. PVC valve question, with pic
  114. Dumb question
  115. hard starting
  116. Seafoam question
  117. Coolant in p/s pump
  118. Getting Rid of Rust
  119. noob questions
  120. coolant question
  121. vacume line
  122. Spark plug broke and left threads in head!
  123. LCA'S & Panhard bar
  124. Knock Retard, a little long, need help!!
  125. Turn signals
  126. oil everywhere
  127. gauge question
  128. 2000 ss my gauges quit working!
  129. need help!! few problems
  130. Oil Leak
  131. Emission Question
  132. Need help!
  133. Car will not start!!!
  134. How do you change lock/unlock settings?
  135. Idle Relearn?
  136. Quick help needed with headlights issue
  137. headlight problem!!!! help
  138. Help
  139. help dtc 0102 after stall install
  140. Fuse keeps blowing. Help please.
  141. Problem with lights / fuse please help
  142. Hesitation issues, 2x00 rpm.
  143. EGR Vacuum Solenoid Location
  144. Hard Starts
  145. Corners
  146. alternator question....whats the wire plugged into the back.
  147. cooling problems
  148. Prestone OK for power steering flush?
  149. Fingers crossed for insurance claim
  150. Keep blowing headlights
  151. my heater/ac blows off and on by itself... HELPPP
  152. Replacing a Steering Wheel for a '94 Z28
  153. I think I have a case of another bad optispark ??
  154. Two striped bolt holes in aluminum block???
  155. Horn wire issue
  156. Rack and Pinion Problem
  157. idle problem, but only sometimes...
  158. opti spark
  159. car sat for 2 years
  160. vibration at high rpm
  161. Need some help here...
  162. Alternator Code?
  163. need help with 2000 mitsu eclipse!!
  164. coolant leak insde the car from heater :(
  165. Replace a battery terminal
  166. sat 2 months, now no idle 00' T/A
  167. my car was dinging.. never done that before??
  168. If you run hotter when you turn on the A/C in city driving, this is probably why..
  169. Belt woes...
  170. Seriously strange "low coolant light" situation. Please help!
  171. Weird Low Coolant Light problem on my 99 Trans Am
  172. Sealed Beam head light aiming...
  173. Power locks not locking - the fix
  174. cruise control not working right ?
  175. Steering Problem
  176. What is the size of the bolt that connects the brake bracket to the spindle?
  177. Cooling system issues
  178. Mineral based oils vs Synthetic Article
  179. radiator swap DIY???
  180. how to move seat forward without power
  181. Resuing sparkplug wires? (MSDs)
  182. Replace window regulator?
  183. overheating or low coolant?
  184. New High Performance Alternator. (Where to buy)
  185. Cost of new steering rack?
  186. steario get louder when i press on gas pedal
  187. 94 Z28 mis
  188. Cooling Fans Temp Change
  189. 98 Cavalier Z24 possible engine blown
  190. Weird Idle problems? (and gas problems)
  191. not warming up, heater not working??
  192. Replacing knock sensors and wire harness
  193. turn,washer and cruise control lever broke...
  194. wrecked my car, got really lucky
  195. wierd idle problem?
  196. Waterleaks, wet floors
  197. oil gauge reading when car is off
  198. NEED HELP. Car Bogging
  199. Pass air bag removal on 98Z28?
  200. Dead Car
  201. thread size for power steering hose?
  202. I need some Help
  203. Maybe my steering column?
  204. No HVAC controls or turn signals....wtf?
  205. car overheated in very cold wheater
  206. Motor mount question...vibration
  207. Car shakes at idle
  208. I defeated the Passenger Headlight Motor Monster!!!
  209. y-pipe question
  210. Water in the trunk...and flat.
  211. stock idle for 2000 a4 trans am
  212. cruise control
  213. temp issues
  214. Should I Be Concerned?
  215. How to remove fan?
  216. loud exhaust rattle help!---video
  217. Window and door panel problem
  218. Frankenstein Exhaust Leak
  219. Cruise control
  220. Need help ls1 not running right
  221. Intermittant Wiper
  222. what oil do you guys use for leaky engines?
  223. Clicking sound when i turn the steering wheel??
  224. Window Problem
  225. Squeak when it rains? (believe its a belt)
  226. SECURITY Light on
  227. Loud Ticking/Clicking Sound
  228. Car stalling
  229. Baffled Oil Pan??
  230. Will a?
  231. My starter keeps cracking!!!! HELP
  232. Motor mount - to - block bolt size?
  233. Service light on, then off?
  234. Questions about my exhaust
  235. NOT LS1, 3800v-6 tranny slipping...
  236. 00-02 dashboard question
  237. ac compressor
  238. Coolant in the Oil Cap!!!
  239. Will the hvac panel from a ls1 vette fit in an fbody?
  240. security light on?!?!
  241. streeing column swap
  242. T-top windnoise question
  243. oil gauge
  244. 0w30 question
  245. window track roller arm broke,,,any ideas for a fix?
  246. What is the thick, black, sticky snot like stuff used to hold weather strip in place
  247. Heater problems on a 95 Z28
  248. Tranny rattling sounds exactly like muffler came loose but its tranny.
  249. Crazy Power Steering Leak
  250. how to adjust passenger door.
