View Full Version : Wheels & Tires
- Psi Question
- Cleaning aluminum wheels
- Best tires for an 00’ firebird
- Question on replacement tires
- Can someone school me on wheel offsets?
- 15" Wheel balancing
- Wheel color change
- 15x12 fbody fitment
- Part Number for N66 Center Caps?
- Wheel set up good or bad
- Front wheel size on 99 trans am
- Best 2000 firebird wheel and rim sizes
- 17.4.5 jegs rims,what tires you guys using
- Very impressed with these wheel spacers! 1.5inch
- Weld RTS 17" w/ ctsv brakes
- 15x10 & 17x4.5 jms avenger wheel review.
- Picture Thread!!! Sticky?
- Help with wheel specs...
- Changing tire size to 275/40/17
- Forgestar F14 Pictures
- Budget drag pack
- What HP determines what tires you buy for grip?
- Help finding a reputable place to buy 18x9.5 C6 "spyder" wheels
- Cheap 245/50/16 Tire Review: Kumho Ecsta Tires
- 315/40/18 tires.....what are you guys finding....? Nitto NT555 G2...?????
- Tires clearance needed between them and the bump stop
- New Esr Cs1 wheels on my Ws6
- Extended Wheel Studs
- 275/40r18's on lowered T/A...fit ok?
- RPM R-505 are they still available?
- Billet Specialties 15x10 Fbody Specific Wheels Do Not Fit
- 2000 WS6 - Old ZR1’s for New ZR1’s
- Clean/Wax tires and rims
- The Unanswered Camaro Tire Question
- Shank Style Lugs - OEM Wheels?
- Will these CCW fit?
- Front 17x9.5 Rear 18x10.5 315 Fitment?!
- BFGoodrich g force 2 as vs Mickey Thompson street comp tires
- Drill them, or send them back?
- New wheels for T/A with Brembos
- Valve stems for Vision/Jegs SSR Star wheels.
- anyone know what wheels these are?
- M/T ET Street S/S: 305 on 9.5" Wheel
- Dark bronze matte wheels
- ZR1 Reproduction wheels???
- Time for new tires. Need recommendations.
- 20mm spacer on 4th gen
- 2018 Z06's to BMW'S...
- Weld rts bolt pattern
- wheel hub fitment
- Extended wheel studs necessary for street car?
- ZO6 rims on a 2002SS
- What drag radials????
- '00 SS Tire Sizing
- 15x10 7.5 b/s RTS S71's
- Inexpensive tires???
- Torq thrust M's package deal?
- Drag set up..Help
- 345/35r18 are not fitting what size tires pics inside
- Rims are old and leaky
- New Forgeline FF3C are on. Wanted to share.
- Front tire Recomendation
- New GS wheels/Toyo tires
- Z06 wheels
- 275/50r15 weird fitment?
- New record....trans am on 30s
- Toyo Extensa HP ll
- 325 45 17's,,, Anyone?
- Do these new tires look right to you?
- Hawks replica wheels (35th Anni.)
- Just because. FIKSE FM5
- 28" tall front runner question
- Chrome ZR1/Grandsport wheels
- Will 295s fit
- RaceStar Lug nuts
- picked me up some wheels... FIKSE
- 28x11.50 on stock rim? Will it fit?
- Weld RTS S-71 help
- FM5 color
- Need help looking for rims
- Moser 9 inch, tire clearance issues
- WS6 rim polishing?
- Where to Find 17x10.5" Torq Thrust M's
- Who here has hawks chrome 10 spoke reps?
- Rc comps
- 02 vette wheels fit 99 ws6
- LT1 rear brakes and WELD RTS low pad?
- 305 tires on 4th gen camaro
- 2018 camaro rims
- F14 Super Deep, Toyo R88R 315/30/18 Narrow diff? (pics)
- 81 Firebird tire size
- Forgestar CF5s are on!
- Wheels on sale @ Strano Performance Parts, Black Friday 2019
- Correct tire size for 17x8.5 wheels
- Lil old, lil new with Welds
- 3rd gen rearend users,What wheel combo are you using
- Fikse FM 10 wheel offset question
- C7 Z06 rims
- 335 size tires (18")......with high treadwear rating?
- 18x9.5 55 / 275/40 R18
- Narrow differential or order rims first?
- Alternative for BFG KDW2?
- Tire pressure question???
- Wheel and tire combo 2002 Z28
- what tires??
- 18x9.5 tire set up
- Best wheel offset/size for a firebird?
- 18” ESR SR12’s on an 02 Z28
- What's the biggest negative offset rim you can get in a 15x10 and 15x12?
- Just got my Mickeys today!
- Anyone ever see a wheel break like this.....
- Will these fit my 95 z28
- 315 fit on a 10 wide wheel?
- 7.25 backspace on rear 15x10s?
- Trick ABS/TC for Big Rear Tire?
- 99 trans amp wheel spacers/adapters
- 2002 WS6 Front Tire Aspect Ratio Help
- Toying with the idea of new wheels
- Will these rotors clear rims
- Cant find answer about Weld vs Jegs Prostar wheels.
- OE wheels 18" CV22s Satin Black
- 10 Ply tires....🤔 what brand for me ?
- Good dr for my setup?
- TSW Bathurst wheels
- Replace skinnies...
- Just installed 305/40/18s on my 2001 Trans Am
- 2002 SS SLP, old new tires??
- 4th gen wheels
- C5 Z06 with C6 Wheels
- My experience with Foose Legend wheels
- Are these OEM?
- Forgestar CF5 and tire size
- NT555R vs NT05R
- Need Help Mini Tub Set-up Wheel Back Spacing etc.
- 18x12 C7 Z06 wheels
- Proxes TQ 275/45-16
- Thinking of going wider
- Looking for tires
- black c4 ZR1 wheels on a firebird/TA
- Tire fitment and brand opinion
- Suggestions on tire fitting....
- Wheels and Tire sizes for 02 Z28
- Boyd coddington forged wheels
- Wheel spacers
- OE C7 wheels fitment
- Does it matter...
- New to thread. Looking for 18" all black c5 z06 wheels...
- Bent drivers side wheel but dont know how or when...
- Anyone running Mickey Thompson S/R 27 x 6 x 15 front runners?
- Any Pics of White ZR1's on a white T/A?
- From these pics what's my backspacing?
- Lugnuts
- My Hugger Orange 99 Z28, Billets & Narrowed 9"
- Correct Forula centercaps?
- How old of a date code would you accept on "new" tires?
- Quality of Reproduction WS6 Wheel Center Caps
- Forgestar F14 on my SOM Ws6
- Looking to put on 18" c7 rims
- Wheel spacer
- What wheels are these? GMT 400
- Billet Specialties Street Lite - Gunmetal Centers
- How to guard against tire shop damage
- Will these fit 99 trans am ?? Lowerd with eibach kit 17x8 in fronts and 18x9.5 rears
- What Wheel/Backspace For 2" Narrow Rear End
- wheel rub
- 305 BF Goodrich G-Force Comp 2
- Looking for Hellcat style wheel for 4th Gen
- Vogue Tyre Signature V, are these any good?
- Kumho tires input please
- C5 5 spoke DD Polished wheels??
- Race Star Options & Differences
- Tire recommendations...
- Continential extreme contact sport tires
- Billet Specialties Streetlite backspacing
- offset question
- Daddy's got sum'new shoes !!!
- Fitting 2018 factory Camaro wheels on my 1988 Camaro?
- 3/8" spacer question for rear
- Serious wheel stud issue, help!!
- Smooth riding tire 275 40 17
- Wheels for White TA’s and WS6
- 2018 1LE Camaro - Tire size recommendations?
- Grinding bump stops ?
- LG World Challenge wheels..
- Will these front runners fit?
- What Wheels for 305/35r18 TranAm
- Fikse ProFil 10's Back from the dead- PIC HEAVY
- 19x12 OEM 325/30/19 Camaro
- 19" CCW 505a on NBM TA
- Corvette Crays
- Hoosier Drag Radials 295/50 R16s
- Corvette wheels on a fourth gen Camaro
- Looking for ROH RT 18" wheels Desperately!
- Well, f'd that up pretty well...(fixed)
- 5 of the Lightest Economical Wheels To Purchase Now
- What is the widest tire to put on a 18X9.5" wheel?
- Will they fit?
- Wheels for street and track. What option should I go with?
- Those with 15x10 Race Stars come in....
- tire pressure question
- Forgestar D5
- Tire recco for 9.5x18 and 10.5x18 won't trip ABS/TCS
- Weld rts 15x10. 7.5 bs
- Rim and tire clearance????
- Tires on C5 Magnesium Rims
- Race star dark star black chrome wheels
- 15x10 forgedstar wheels
- New Fikse FM-10 on NBM WS6 *Pics*
- Billet Specialties Streetlites on, final wheel choice...I hope, lol
- Bronze Racestars
- Tires
- need wheel help for C6 vette
- Spacer recommendation
- Michelin PILOT SPORT 4S
- F14 wheel grinding calipers
- OEM C6 GrandSport wheels
- 16x8 OEM 5 Spoke Wheel Question
- C7 Z06 OE Replica wheels
- Forgestar CF5
- Need help with rim fitment
- 17x4.5 or 18x5 fronts fbody or c6 zo6 offsets? Help!
- Drag radial size
- Want: Shelby Series 1 wheel replicas / lookalikes
- Where to find 4mm wheel spacer?
- Radial for Daily
- Looking at some C7 Z06 wheels, will they fit?
- Tire size question....
- M/T ET Street R Vs S/S
- 275 vs 295...
- 18/19 c6 5 spoke
- HF wheel dollies for 18x9.5 rims will they work?
- Formula got new shoes
- New C6 ZR1 wheels on Camaro pics
- Drag radial or slick?
- Y2k wheels
- Will these fit
- C5 Z06 Wheels on Camaro Z28?
- Weld RTS Fitment
- Niche wheels
- Best 275/40/17 non-drag radial tire
- How Do People Like Those Nitto NT05 fronts and NT05r rears? Input
- 4th Gen Wheel Fitment
- Tires suggestion
- New Member - camaro rim & tire question
- Weld -23 offset with ctsv calipers?
- Longer Wheel Studs
- Can you tell if a tires has been mounted?
- New wheels and tires
- AFS wheels still in business?
