PDA
View Full Version : Wiring, Stereo & Electronics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87 88 89
  1. PIE adapter 2000+ Monsoon
  2. Someone please explain the OE alarm
  3. Does anyone know where the turn signal relay is in these cars?
  4. Hooking up sub amp and I have a ?
  5. Electronic Techs???
  6. Headlight Broken?
  7. monsoon question
  8. Anyone have their car broken into for audio equipment?
  9. stealth box and JL sub
  10. FS: Wire Harness
  11. Monsoon Security Lockout Feature Bypass
  12. Rockford 6 1/2" subs vs JL 6 1/2" subs
  13. redz_02 clear your box so i can buy focals
  14. Stock cd player problems/please help
  15. Delco theft lok bypass trick HELP!!
  16. Need info on speaker size please.
  17. Theftloc (HELP)
  18. 2000 Ws6 Headlight and Alarm Activation problem/question.
  19. someone please help
  20. FS: Monsoon CD Player
  21. How to control sub with Alpine HU?
  22. will the work in the hatch
  23. shift light prblem
  24. tell me what you think
  25. BIG alternator?
  26. Focal poly kev k2's for sale
  27. need new sail panel speakers
  28. Doors won't lock...
  29. custom kick panels
  30. changer mounting brackets
  31. Speaker guys help, did I just get screwed?
  32. Unloaded Stealth Box Question
  33. Let see your TV
  34. Running lights and blinkers out! Help!
  35. AUX question
  36. clairify about passive arming...
  37. factory temp gage irratic - HELP!!
  38. Wiring help!!
  39. who rebuilds Pioneer/Delco CD Changers?
  40. New T-Top Storage location??
  41. line output converter?
  42. subs out of phase?
  43. Neo car Jukebox in monsoon deck???
  44. Laptop Charger
  45. What is this? Electrical problem
  46. stock head unit with amp and subs?
  47. Cobra 9870
  48. WTB: PPI amp & JL subs
  49. EL12's, signal won't work
  50. Harlon shift light users
  51. Alarm and remote trunk opener failed at same time on 94 Z28
  52. Is there any way to get a factory 12 disc changer to work on a '99 CD Head-unit???
  53. New Apine and JL installed but needs some advice
  54. Changing to Aftermarket Head Unit
  55. 12 Disc Changer
  56. monitor mounting question
  57. changer wire location
  58. Does any know ...
  59. Custom tv mounted(pic)
  60. Help with jbl bp 1200.1 amp wiring
  61. Hooking up a MP3 player to Monsoon
  62. Rear Defroster Fix
  63. T/A sail panel subs
  64. Speaker locations.
  65. XM for the Monsoon
  66. finally got my headunit!
  67. Sony XM Receiver FS
  68. JBL GTO636 6.5's any good
  69. monitor in steering wheel question
  70. 15's
  71. Stock Alarm
  72. Satellite Antenna
  73. OK to add powered hu to factory monsoon?
  74. IS 2001 Monsoon H.U. same as 2002?
  75. Antenna
  76. what would cause this?
  77. Electrical problem
  78. Elemental Designs
  79. got some stereo stuff for sale
  80. 2 10w3v2d4 and 1 300/2
  81. Monsoon amp just for rear filler?
  82. power antenna
  83. stock amp?
  84. full range speakers in stock "sub" location
  85. Need Monsoon speakers! PLEASE!
  86. Pioneer wont work all of a sudden. Help please!!
  87. adding sub to Bose
  88. bass speakers part number?
  89. monsoon power antenna rewire
  90. rear hatch problem
  91. Pioneer XM Tuner for sale
  92. Keyless Entry
  93. SECURITY light?!?!
  94. Isolation Question ??
  95. Turn signal flasher
  96. Tran Am Head Unit
  97. f.s. JL-Audio TR-650 CSI
  98. Pager alert alarm...........................
  99. Curtesy light won't turn off, help!
  100. replacing Monsoon receiver, is it necessary to rewire to stock amp?
  101. My opinion on the Escort Passport SRX
  102. need Opinions for sub and amp setup
  103. Which JL amp?
  104. Help! Have Motor Noise Coming Thru Stereo
  105. Annoying horn honks
  106. Automatic radio shutoff.....
  107. damn things are getting cheap
  108. selling my system
  109. is there a RCA input adapter for moonsoon
  110. 6 disc in-dash changer?
  111. Planning new system...
  112. lookin 4 gague install pics for 3 ac vents over radio in t\a
  113. Mini Toggle switch pin connectors???
  114. Anybody know how to fix digital display?
  115. Need help installing Pioneer DEH-P47DH ASAP
  116. Taillight problems???
  117. High beams/Low beams
  118. Lights burned out on stock stereo
  119. Installing an aftermarket CD Changer
  120. Should I go with 12's or 10's in my Z28.
  121. Lower speaker replacement
  122. Anyone tapped in AFTER amplifier?
  123. RF Punch 401s vs 400s
  124. Where is the Monsoon Amp
  125. alarm on 2003 silverado
  126. JL Audio rocks -- 10W3v2 with dual 6 ohm voice coils
  127. Truck audio questions
  128. What size speakers
  129. wiring issues with 275 g4 orion amp
  130. Need amp suggestions
  131. '98 Monsoon tape questions: in-dash CD or changer?
  132. Replacement Speakers for the TA?
  133. Getting Rear Panel off to access rear sub? HELP!
  134. Good System Idea?
  135. Blinking halos
  136. Looking for Pics on Monitors.. Need Ideas.
  137. Found out that SWI-X does not work with my HU.
  138. Pioneer TS-W253F 10" Free-Air Subs
  139. Installing new speakers in 99 SS
  140. Horn problems?
  141. Damn Trans Am headlight motor
  142. Mailman brought me a present *pics*
  143. Where to buy JL
  144. Monsoon stolen; replacement ideas
  145. those that know how to install remote starters....
  146. Stock Alarm Problems.
  147. Where is....
  148. Drivers side window won't go down
  149. Rear side marker lights don't work.
  150. I need help replacing the door speaker, taking off the door panel?
  151. Gauge lights won't come on.
  152. Replacement Power Antennae
  153. Monsoon Code E20
  154. New style factory radio in 2000 camaro
  155. What 6.5" Component set fits in the front door basket?
  156. My QTP electric cut out fell apart???
  157. Anyone buy that Passport G-counter?
  158. NEED HelP: RE battery relocation question
  159. Base Setup for High pass and Low pass filter
  160. Fosgate went old school again thank god!!
  161. Turn Signal Problems need Help!!
  162. ASP plulley with subs/amp???
  163. Buying a new Box
  164. 12 disc monsoon cd changer
  165. Any one replace factory monsoon amp?
  166. XM antenna..........splice?
  167. CD changer
  168. static sound-->cd changer-->problem-->help (long'ish)
  169. Speaker selection for 98z
  170. Accidently cut ground to cd player
  171. '01 Suburban details?
  172. ZR3 Laser Shifter
  173. How do you disable OEM Anti-Theft
  174. Relocating head unit and HVAC controls
  175. New Battery Suggestions ?
  176. FS: 3-12in infinity subs, 2 Visonik amps, 93+ sub box
  177. Another Stealthbox Question.
  178. tired of your doors rattling from the bass?
  179. HELP!!! Short somewhere in Radio...
  180. Replacing monsoon
  181. Where did you mount component set crossovers?
  182. Navigation systems... looking for advice
  183. Headunit Dilema
  184. Wiring up new deck to stock speakers?
  185. Another alarm Question? Please HELP!
  186. Need Metra Wiring Part Number
  187. How to Get Security Light Out?
  188. Best componenet speaker set: Focal vs. ID
  189. Just ordered some Focal 165K2's
  190. Valentine 1
  191. Now the car won't start!!!
  192. Which wires for DRL's?
  193. Wiring layout of monsoon head unit and amp
  194. Problem With my Alpine SPS-170A 6 1/2's
  195. 1100w + 300w + alternator underdrive pulley
  196. What's this plug for?
  197. How to install...
  198. Why don't rear seat speakers work with aftermarket head unit?
  199. looking to customize the box in a camaro need tips
  200. Adding Power Window Options
  201. 2000 Camaro Audio Problem
  202. Audio Upgrade Questions?
  203. Stock radio in 2000 Camaro fits what model yrs?
  204. strongest cd player???
  205. Monsoon Amp Bracket?
  206. Looking for guy with RCA mounts on top of his head unit (camaro)
  207. correcting the coolabnt gague
  208. perimiter sensor
  209. Security System Question
  210. need a new amp not sure what to get opinions
  211. Wiring harness question (aftermarket radio)
  212. Selling Car Stereo Products!!
  213. Pioneer DEH-P77DH
  214. Start a list of all 6.5 inch Woofers.
  215. i just bought sum a/d/s 235is 5.25"'s...
  216. Selling Car Stereo Products!!
  217. Attn: Rogue Leader
  218. blew two fuses after amp/sub/headunit install
  219. AUX/MP3 input for 2000 Camaro with Monsoon & CD Changer
  220. radar detectors
  221. re-programming a keyless fob & front speaker replacement?
  222. Need some wiring help
  223. Thinking about selling subthump box with 3 10L7's.
  224. What should I do with this amp?
  225. Volume Steering Wheel Button Doesn't Always Work?
  226. No Longer Pissed!!!
  227. Keyless Entry/Push Button Start
  228. Disc Changer is not reading discs??
  229. Stereo wiring question
  230. stereo stupid, need some help please
  231. Custom Headlight Install Question
  232. Air Conditioning
  233. focal component install
  234. Stealth Suburban install?
  235. Any experience with JL Audio 10W6?
  236. Mixing off brand crossover with component set
  237. Stock Stereo Button Question
  238. Think this will work on an F-body?
  239. Nice refreshing news in Car Audio
  240. Alternator clock position?
  241. Alpine 9815 w/ PAC SWI-X
  242. Looking for install kits
  243. NOW I"M PISSED!!!
  244. Whats goin on, or am i nuts ?
  245. Want XM radio?
  246. Whats The Best..
  247. Where are you guys mounting your XM radio?
  248. Which Subs?!
  249. Replacing monsoon speakers in a convertible
  250. JL 6450 AMP Overheating
