PDA
View Full Version : Wiring, Stereo & Electronics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89
  1. aftermarket head unit
  2. subs that make the most BASS
  3. Panasonic 2-ways
  4. phazer 2 any count? Any other jammers?
  5. Body Control Module (BCM) Location??
  6. Trip odometer resets when cold! Help!
  7. What does the 530t do?
  8. Retractable Antenna?
  9. Where do I get a remote turn on 12V source - radio Question
  10. NEED HELP ASAP!!!.......PLEASE READ
  11. Which Radar Detector?
  12. Infinity 652.5i installed
  13. New window motors installed...
  14. box dimensions NEEDED!!!
  15. rear defroster problem
  16. Driver's side mirror
  17. High intensity tail light bulbs
  18. pics of sub boxes....
  19. Ignition problem
  20. Interior Lighting/ want to light up the cab
  21. Help Help Help...Subwoofer problems
  22. PPI PRO 6800C
  23. A4 gear indicator light
  24. hooking up oil pressure gauge
  25. harlan shift light
  26. Head Unit
  27. Steering Wheel Stereo Control Lights DEAD. How to fix??
  28. know of good system (ex. Alpine) that would look roughly stock ?
  29. Fac. changer and aftermarket head unit?
  30. where to sell stock monsoon h/u??
  31. Factory Alarm
  32. Has anyone replaced the window motor with a faster unit?
  33. Speaker screens rattling?
  34. HELP! Interior light ??
  35. truely custom install
  36. truely custom install
  37. Damn... 12" sub hits hard!
  38. is it possible to have the fogs to work as brights as well?
  39. Where is the tach wire on a 98 t/a for the window switch
  40. head unit
  41. Window Motor
  42. Trying to wire Tranny temp and Oil Temp guage to 98?
  43. FS 2 audiobahns excursion series in box
  44. Can a wire run directly from the batt. to the head unit?
  45. Anyone who is planning a DEI 530t install... ---->
  46. audio experts...i need help
  47. FS: TV Tuner and Alpine Switcher
  48. trac control
  49. Stock AMP location?
  50. show pic of where your V1 is
  51. Alarm problems!
  52. Passenger window
  53. multi colored shift light
  54. doing a total upgrade this winter, need advice
  55. where to get DEI 530T window module
  56. help with changing bulbs
  57. HELP!!!! Is this a big problem or not?
  58. bose class d amp
  59. HOw do i make it so my passanger window can have auto-down?
  60. What is the little wire from the alternator for?
  61. Hooking up gauges... need a relay?
  62. non popup light kits???
  63. How much is too much?
  64. Electrical problem
  65. Shift Light Help!
  66. Turning singnals went out! HELP!
  67. Fog Light Relay!
  68. Convertible Speakers
  69. Splicing in a line-level converter on my 2000 T/A
  70. box for the trunk
  71. how to get access to wire loom past the door jam?
  72. code for stereo when disconnecting battery???
  73. Gauge cluster question, I just found out some crap....
  74. How do I wire it? Anyone.....Beuller....Anyone?
  75. safety switch
  76. stock alarm
  77. headlight/electrical problem
  78. HELP! Shop installed MP3 Player and now the steering wheel controls....
  79. ABS INOP/TCS off lights
  80. QTP switch... what are other options?
  81. JL Stealth Box For Sale
  82. I finished my HID projector conversion for the Pontiac
  83. Car audio guys...need some help.
  84. ANYONE with Gtech Pro
  85. headlights high-beam flash-to-pass
  86. AC compressor oil(green stuff)???
  87. What about putting tweeters here......
  88. Valentine One Owners... Come on In
  89. monsoon upgrade
  90. How do i fix my turn signals??
  91. Looking for Stock (Camaro) Monsoon Head Unit.
  92. ? on headlights
  93. Who makes 6.5" subwoofers?
  94. Stock alarm
  95. Converting from tape HU to cd HU
  96. aftmrk head unit to stoc k 12-disc??/
  97. Anyone have a stock Trans Am Monsoon headunit for sale?
  98. Cheap CD upgrade?
  99. FS: Home Audio Stuff
  100. Switches
  101. READ THIS!!! ABOUT THE MONSoon SYSTEM
  102. Punchier Bass for Stock System - Recommendations Needed
  103. Disabling automatic headlights on a LS1 Camaro
  104. Capacitor bad, Battery bad or both?
  105. MONSOON HEAD UNIT
  106. Need good HU and amp for my stereo
  107. Just got an autometer tach with shift light...
  108. Wonder if GM will follow suit after ford's mach 1000?
  109. GM-fit aftermarket headunits.....Who has one ?
  110. TCS and ABS buttons in the dash questions...
  111. WIRING A 12 DISC TO STOCK HEAD UNIT
  112. JL or Kicker?
  113. What color wires do I need to splice the PAc in to?
  114. Please Help-Car won't start after clutch install!
  115. Please Help!! CD Changer Question
  116. best 2 10's or 12's out there for $350?
  117. Need advice and help ASAP, sale pending!
  118. FS: Alpine 7949
  119. Built-in Radar Detector / Scanner Question
  120. DVD/Screen install question
  121. Does anyone sell a speaker box (only) for a 12" sub?
  122. DRL question??
  123. Headlight Switch
  124. Triple Sub Box
  125. Here's a PAC question I didn't see in the Archives... how to hook up...
  126. Monsoon Replacement
  127. Monsoon replacement door speakers??
  128. fs:kenwood indash tv
  129. which stereo use the sterring wheel buttons?
  130. How do i run wires from a-pillar to the engine compartment?
  131. need help with gages, wrong sending unit
  132. Anyone know how to hook up a microphone to a VCR
  133. factory keyless entry wiring?
  134. low level inputs
  135. easy to swap head unit?
  136. the factory monsoon subs keep blowing
  137. Hazard/Blinker Fuse keeps blowing
  138. Electrical problems?.....
  139. Factory CD player
  140. Autometer Tach question
  141. loking for aftermarket alternator that produces more power than the stock one
  142. Passenger Head Light won't pop up?
  143. Beeping
  144. PAC OEM adapter
  145. Should GM supercharge LS6 ¿?
  146. how to remove front speakers?
  147. installing PAC adapter
  148. Dynabatt Qs
  149. changing the factory speakers
  150. HELP! all new bulbs & turn signals STILL DON'T BLINK!
  151. All you guys with headlight questions...INSIDE!!!
  152. How does this setup sound to you?
  153. Security light on ALL the time
  154. Door panel speaker covers??!
  155. Auto headlights SUCK
  156. Power antenna?
  157. My TCS stays off when I start the car now?
  158. Automatic Headlights
  159. Monsoon unit.. 99 z28 to 99 TA
  160. Alpine DIN 1.5
  161. FS: Fiberglass/MDF 2 12" Subwoofer Box
  162. monsoon cd player problems
  163. 99 monsoon head and changer to 95 bird?
  164. Fact. Monsoon am/fm cd w/speakers for sale
  165. Stupid question about hardwiring a radar detector....
  166. Where are the instructions for disabling the DRLs????
  167. Headlight mod for TA..HELP.....¿?
  168. curse the monsoon
  169. 98 wiring schematic for heater/fan control panel
  170. Speaker options?
  171. Whats the BEST WAY to get Through the FIREWALL of a 95' CAMARO???......
  172. oh, oh, i'm out of power :(, help, bettery is dieying
  173. How to work CD Changer??
  174. Installing a "ENGINE START" button
  175. Equalizer
  176. Amp for 12 inch sub and rest of speakers
  177. Auto redlines....
  178. HELP! does anyone know why the fogs turn off when the high beams are on?
  179. PAC OEM-1/2
  180. i didnt think it would happen to me :(
  181. Help!! Gauge lighting???
  182. Speaker questions
  183. Ticking noise with RPM...
  184. FS Alpine CDA D857!!!!!!!!!!!!!!!!!!!!
  185. amp wiring ?
  186. Monsoon worth it????
  187. For sale Electronic equipment
  188. First New Install on '00 SS
  189. FS (HOUSTON): 5-Channel Amp
  190. How can I output more power and clearity for my system?
  191. Alpine Sub Amp FS
  192. 6 1/2 Components for rear?
  193. Help Me, Please!!!!!
  194. What you think about my setup
  195. HELP.. can i do this to my headlights without any damage?
  196. HOUSTON FS: 2 Lanzar 10's with Bandpass Box
  197. how to disconect the stock alarm?
  198. MTX Audio Thunder8000 T8104A
  199. Needed: Power antenna for 93-02
  200. CAN I USE STOCK DECK WITH OTHER SPEAKERS??
  201. My Stereo Setup.
  202. ? about motor antenna
  203. Fuel Cut-Off switch?
  204. New HU with monsoon...!?
  205. need info about putting a system in!!!!
  206. MP3 players for F-bods
  207. Both doors unlock mod ¿?
  208. Selling Stereo Monsoon System!
  209. Automatic headlights
  210. FOG LIGHT WIRING
  211. Newbie + new speakers...
  212. Rockford Fosgate Punch 300 for sale
  213. Can you remove the face of the stock HU w/out breaking it?
  214. cd player install
  215. leftover monsoon cd headunits
  216. monsoon cass played to a monsoon cd
  217. Shift light install?
  218. new head unit question
  219. TransAm Deck in a Camaro??
  220. ***WANTED*** '15 SubWoofer W/ Box and Amp!!!>>>...
  221. BLINKER SOUND.
  222. the DING DING DING sound
  223. RCA Jacks
  224. alarm help
  225. Rear Seat Speakers
  226. FS JL 300.2 amp NEW!!! and NEVER installed!!
  227. Delco CD Changer Problems... Help!
  228. Onstar
  229. DRIVING/FOG BULBS
  230. 8" or 10" Bazooka
  231. which fuse controls headlights?
  232. Damnit!!!!!
  233. crossovers
  234. HUD for a 99 camaro
  235. Need info on how to get to the ignition tumbler and switch.
  236. Location of Crossovers for Fact. subs
  237. Sub swap to bigger sub.
  238. Radar or the "Cloak Unit" (that screws up radar gun)?
  239. C5 audio - whats everyone doing?
  240. Got new subwoofer/amp.....how to install?
  241. Amp istallation question.
  242. Can you do this without any problems?
  243. Install of Line Level Convertor question
  244. !speaker mod and car still sounds good :)
  245. Replacing Stock Subwoofers
  246. Stock Speakers?
  247. What is needed to have a decent system?
  248. alpine iva-c801
  249. Power cable through firewall
  250. Wanted: Stock Pontiac rear speakers....
