- Radio and windows randomly stop working?
- Replacing power antenna motor?
- Possible?
- Airbag module
- Sub/Amp wiring question
- Loud Pop when HU turns off
- Question about installing a LED Scanner Light to factory alarm.
- JL XD700/5 Stock Mounting Location Project
- How-to De-pin Fuse blocks
- pics of C5 Corvette Double Din Bezels
- Wiring Gauges
- I did something really stupid...need your advice. (Mons0on Door Speaker)
- Amp will not turn off
- kee audio package. Is there a good thread or site to see how to install everything?
- Stock Monsoon unit with aftermarket amp and sub
- Voltage goes up and down? WHY!?
- My Stealthbox Project (fiberglass)
- afr gauge install?
- Raptor shift light??
- Stereo not playing music???
- Bad battery or alternator??
- High pitch shrill coming from speakers...HELP!!!
- Cruise Control ... repair?
- speaker? figuring out what is going on
- Need help with stereo selection
- Voltage loss after system installed
- Sunday Project HU
- LED bulb works pitifully in Autometer tach?
- Amp, sub and wire selection help.
- New (to me) SS with stereo problems
- MTX 10" Thunderform question
- Adding Cruise Control to 01 Camaro
- Stereo Questions for the Gurus
- Replacing steering wheel?
- LOC error on `98 Monsson stereo
- Removing Wiring
- Window motor assembly picture?
- Radar Detector Mod/ Placement
- New goodies for the formy
- Pioneer AVH-P6300BT install...plus other crap
- power antenna...now on a switch!!!
- Where to start?
- Subwoofer placement
- what size speakers do I need?
- Anybody have Dash Gauge plate options to mount gauges in factory sort of locations
- New System so far so great
- replacing stock monsoon help!
- Switching subs? (12"-10")
- Wiring problem, rear speaker, 98 t/a
- Camaro Speakers same as TA?
- Speaker options for 4 speaker system?
- Need help wiring up power mirrors...
- Problems with AVH-4300DVD and PAC SWI
- Metra Axxess ASWC Problem - No LEDs?
- ARC Audio Mini amps in stock.. Pics of how small they are!
- ipod2car problems
- Door panel tweeter install in camaro
- Putting Stock Back In
- reverse light wire for rear view camera...
- 04 04 gto 6 disc cd changer. "cd error mech" help?
- Massive audio rk6
- Steering Wheel Controls/12v to 3.3v
- 96 Sunfire, sunroof issues
- AVH-4300/CDT install thread
- Fog light wiring help!!!
- Radar meanings
- Electronics question from another thread of mine, please help.
- Monsoon sticky faq TYPO?
- Thanks Autotrix!
- Help Identify Please
- Which Radar?
- Turn signal problems help!!!
- Anyone ever try or hear again about Stealth radar system? that shield U "supposedly"?
- Bypassing only 1 of the bose AMPS housed in rear box...
- Best Amp for 2 JL 12w3v3-4
- Need Advice from a Sound System MacGyver
- Torn off 02 sensor wire? Fixing advice?
- Just had system installed ?
- Speaker/Amp Help
- Battery relocation to rear
- Aftermarket Speaker / Amplifier Suggestions ?
- ash tray switch panels
- Alarm set now car won't start/95 corvette
- Brakelight Wiring Harness
- Steering Wheel Controls / Replacing older Sony Headunit (CDX-MP30)
- amp for single 10" sub
- Double din in an LT1?
- Need more range!
- hifonics epiccenter... any good?
- Need new sending unit...what is the harness required?
- WTF is up with my speakers
- Autotrix kit for drivers side
- Alarm question ??
- Please help!
- Calling All Electrical Gurus for Custom DRL/Wiring/LED project
- Weird electrical problem. Stereo and windows, no power.
- Corvette navi in 99 Camaro ?
- Free HUD?!
- Lighting Wiring question
- Passenger Stealth box
- I have a 2001 camaro, WHAT IS THIS?
- voltage stabalizer
- Wire connector adapters for speakers
- Distribution block help
- Kenwood DNX5160 Help
- Stereo Installation HELP!
- Is there a way to bypass the BCM?
- Best way to wire my 4ohm dvc sub
- Window issue
- line out converter
- I Think Its Time.
- Camaro door speaker wiring (pics)
- How the heck do I remove these?
- radio has power, but no sound
- Parking brake light wire location
- Will this work with the monsoon system?
- Firebird Monsoon front door speaker replacements?
- Monsoon amp part number?
- Quality Budget Sound Deadening
- Steering wheels controls wont work
- Alpine SWX-1043D VS Polk SR104DVC
- Peripheral PXDX Aux Input?
- Just installed new Metra Power antenna, need proper antenna connector!!!
- 4x6 plate speakers ??
- BIG Problems
- Is this enough amp?
- Audio help
- Stock bose? Pos New System opin!
- did my cd player die
- Key wont go all the way in?
- Aux button on Monsoon just stopped working
- Hideaway enclosure??
- Where to put subs?
- Does Monsoon plug n play with non-Monsoon?
- Radio wheel control / deck questions
- swapping from fixed to power antenna
- Monsoon head unit repairs ??
- Is 4 channel 600 watts enough for 6 spkrs
- need sub and amp for stealth box
- 6.5s behind the driver and pass seats
- What window part is this?
- HID's for Camaro
- replacement Bazooka 6.5" DVC 4ohm sub in stock $89.99 shipped!
- Alpine 6.5"s?
- Audio help...
- SOLVED: Headlights cause dash lights to turn off
- A few quick AVH-4300DVD wiring questions
- night light bulbs
- Radio and windows won't work
- hard-wiring Satellite radio
- how many hours to install system
- replacing factory door speakers
- BCM issues? Surging bucking poor idle, dash lights out, keyless fob doesnt work HELP!
- Key fob sync to vehicle problem
- 01 SS Instrument cluster intermittently fails
- fans click off without control
- NEW!!! CDT Dual Voice Coil 6.5" Sub Prototypes: Check it out!!!
- Antenna Stays Down
- Car alarm remote stopped working. Why? Yes, I put a new battery in it.
- CD Player or Interior lights wont come on
- stereo cuts off randomly
- antenna
- Head unit problem
- Autometer tach install?
- Blew my Polk SR104-DVC sub Friday night
- Monsoon Subwoofer Question.
- Completely stumped.......need an exorcist!
- 2nd gen f body system ideas ??
- Quick question on theftloc
- What is your monsoon eq set to?
- Strange Alternator code..?
- LED turn signal/socket question
- Will a box fit in the space
- Got my HU. Now need speakers and sub.
- new SONAR headlights, halos won't work!
- Kee Audio system? ('99 Camaro)
- Tired of the antenna making my car look like an RC car
- antenna issues after new headunit install
- Dual coil sub connection Q
- My Firebird's Home made Pioneer's costume Hatch! pic inside !
- Ported box question
- what battery kit
- steering wheel controls wont work
- 99 cluster connector
- Quick question for HID Light owners
- Can I use two brands of sound deadener?
- Factory 12 disc problem
- Sub and amp setups for 98-02 firebird/trans ams
- Replacing monsoon deck
- The new custom install, comments appreciated!
- adding hatch speakers?
- JL Subs
- Right Turn Signal won't blink
- A nuetral C5 Corvette Double Din install pic
- Stock Monsoon Sub Problems
- Radio Controls?
- Problem with my USB feature
- Power antenna help....
- part number for fixed antenna base for those who are converting
- Monsoon Subwoofer replacement
- ZZP alternator power cable
- Need bass out of my door speakers
- can you any of you audiophiles help out...sub box for t/a, fb, ws6?
- Door panel lights
- satelite radio question
- What kind of paint can I use to touch up my amp
- polishing hu?
- Amp rack comparison
- odometer,radio, power hatch inop..help
- Backlight on monsoon deck went out
- Antenna swap
- 1987 TA turn signals not working, flasher replaced...help
- dash voltmeter
- Help!! t/a wont start :(
- Look What UPS drop off
- Alarm going off
- Proposed Monsoon system overhaul & carPC build
- Anyone using Ensolite IUO?
- For Those with In-Dash DVD Headunits
- Big 3
- Amp Suggestions and deck install
- Reversed factory radio volume control?
- Big 3 pre-made wire package website?
- Help with Monsoon sound distortion
- "q logic" bass system
- DVC coil wiring
- keeaudio
- putting stock back in
- OnStar FMV now available for install at DD MODS
- 12" Stealth enclosure?
- vin on gauge cluster?
- Monsoon problem!!!
- Capacitor or higher amperage alternator?
- Alternatives to using Pioneer CD changer with Pioneer head unit?
- covering a sub box with fabric Q
- Aftermarket amp with CDT Audio EU-61CV components
- Rattling from speaker behind driver seat
- Phone mounting bracket question.
- Lights dimming / car alarm
- how to cut a perfect circle for my 10 inch sub
- Window Problem
- check out what UPS dropped off today...
- C5 Double Din install pic of the year! One of the best to date!
- Broken Antenna
- radio dash??
- What do you think about this setup?
- Deck mount
- Alarm Question
- Security light issues!!!
- custom chime sounds
