- 98 LS1 Wiring Schematic
- Removing OEM stereo
- Alternate Route for Subs - what do you think?
- 3rd gen with a monsoon
- Antenna mod need help
- redtop optima?????
- what type of battery
- ipod mod
- Premium Sound
- bezel for touchscreen is done
- 03 cavalier dash
- battery or altenator issue
- want a new head unit with usb what is out there
- Ugh...Amp install problems
- custom sub box for dual 12s FS
- Speaker Replacement
- best 10inch speaker for Bazooka bass tube
- Electrical Issue.. everything dims..
- Getting a short I think?
- original monsoon head w/ aftermarket speakers
- Dynamat ......
- Head unit mount for a Firebird
- Security Light came on
- mtx 4500
- 93 camaro, BOSE system, Wiring HELP
- stereo dimming
- camera mount
- Water Temp Gauge Starting High
- Details of how the steering wheel controls work
- Help with ignition tumbler
- need help asap
- Monsoon wiring harness
- h/o alternator
- help changin speakers
- Finding the DIMMER Wire?
- Dual Ip-Bus inputs?
- Tint guy crushed my tweeter and pod..
- BCM Bypass and wire clean-up
- Dash Alarm Light???
- radio wires
- ground causing starting problems
- Headlight module?
- installed an FM transmitter to use for audio input
- WS.6 major audio install
- Moderators!!!
- Sub is tapping
- Good sail subs?
- Disk changer problems.
- Need help installing pac swi-jack lol
- Finally got my system
- Component vs Coaxial
- GPS for laptops
- Speaker Set Up Help in Vert SS
- subs on a budget
- camaro vs firebird sail panels
- Sain panel speaker question!!
- What other sub box options do i have???
- Cutout Wiring with ASR Switch..
- keyed ignition wiring?
- ASP 25% underdrive pulley with a H/O Alternator
- Alpine source units now available from KEE AUDIO!!!
- Need help spending my Tax Refund $$$.
- Firebird sound setup recommendations
- Replacing my speaker grills
- C5 audio sound worse than 82 Ford F250! Ideas?
- body control module
- Hooking up tach Advise?
- My progress so far.
- Trans Am DVC sail panels subs now available!!
- tachometer help please!
- Disc changer stuck
- Box selection...
- Help picking out a headunit
- Car alarm keeps going off!!!
- I Want Your Old Keylock Cylinder Vats Connector
- headlight problem
- Dumb question, quick answer
- should i use car stereo front rca?
- Whining sound only when using Sirius Radio
- Anyone running multiple batteries in there vehicle ?
- Daytime Running Lights and Light Turn signal
- Need a easy ground
- HID headlight problem - Pass. side flickers.
- 2 12inch subs, amp, box, wiring in for sale section
- sirius
- Lighting
- Changed up a little bit (Pics)
- Strange Fuel Guage Question
- Turning Off randomly?
- Would two 1 farad caps be to much
- 8in speakers in sail panels?
- Is it worth the money
- Newbie looking for some stereo advice.
- In dash t.v./cd player?
- Need some tips
- Wiring differences between 98 and 00
- Radio Delete Panel Part Number?
- Help me get a pin out of the monsoon wiring harness
- remote wire
- help fixing locks
- Any interest in a documented install I am about to do to my WS6?
- Anyone here have the Alpine KCA-SC100 w/Sirius
- How to install the "Simple iphone car kit" into your Camaro (or 'Bird) *PICS*
- amp wire ?
- Need Alternator, is this a good buy?
- DIY Monsoon repair
- Anyone running the JL TR650-CSi?
- Whats your opinion of Kee Audio
- 2 ohm amp with 4 ohm speakers?
- Need some seriouse help with wiring.
- Dynamat door kit
- Cheap stealth boxes
- doors keep locking
- Replace sail panel's or add a sub? give me some advice
- Engine bay wiring harness swap question!!!
- replacing bose head unit..
- Running aftermarket speakers in parellel?
- Help with Xenon HID headlamp
- Tell me what I need guys, kind of new to car audio...
- Onstar
- Factory VATS/Security delete?
- Looking for complete stereo install walkthrough??? 56k = death
- Just finished building a Stealth box... PICS
- Wiring Help
- monsoon help????
- Kinda a noob here.
- how to hook up power doors to a car with manual doors?
- Diamond Audio?
- Alpine 7864 headunit question
- window motor
- help please
- 1998 Trans AM Parking light housing & bulbs
- Driver side speaker blown. Need replacement
- Monsoon and sub tech question
- new speakers
- Drivers side door speaker mid not working?
- stock cd player
- shift light
- Don't get Infinity Kappa Perfect component speakers for your f-bod, Thanks Ian@Kee!!!
- Defroster
- mono vs. stereo amp
- 2004 Corvette... Tape Player?!
- Tach install
- Question about ALpine SWR-1042D sub
- Dukes of Hazzard Horn
- Instrument Cluster not lighting up?
- Red Top battery
- Wiring Sails
- Two questions: Sub/amp compatibility, question about stock speakers
- Discrete place to hide an amp?
- No sound from speakers
- sub and amp setup what you guys think?...
- spl out of sealth box
- need 1 or 2 channel amp
- Factory CD Changer Help
- Relocating Window switches
- What to Use: Bolting Down Enclosure...
- interior lights pulse..headlights are steady
- amp questions
- Non Monsoon ?
- Help! Need a battery
- Alpine ida-X100 - Got mine!
- CD Changer Help
- Driver side automatic window
- Speaker Help... Im going nuts!
- IDMAX question
- stock radio making noise
- LED tailights...how to?
- HID wiring question
- Windows barely work.
- New subs and amp for the DD. What class do I fall into?
- Did i screw up my amp/sub combo?
- new system for my car subs and amp
- New kicker woofer for sail panel!! #CVT65
- CD Changer Harness/I-Pod
- JVC head unit troubles
- Looking for advice on incar pc setup
- I need help?????
- Need Some Audio Advice for the Daily Driver
- Indash install
- Stereo sound goes up and down
- Build 10" subbox for Fbody
- Blowing Courtesy fuse
- Flashing high beams without lights on?
- location of ignition wires
- please help a/c in seats
- question on HID's
- Blowing Fuse #7 Power Accy?
- DEI 508T install
- Looking for Custom Amp Enclosure Ideas - Post Up Pics!
- Any way to make a kill switch work with a remote start?
- Really dumb stealthbox question
- help finding a small enough touch screen!
- jvc hu with red lighting and humount!
- door speaker help
- How much power???
- No sound from tweeters in sail panels.
- mid-bass questions
- 2000 Firebird and add on remote start
- Kee Audio I need some speakers
- Gauges
- Need help with Alpine 9884 with built in amp
- battery keeps draining! need help/advice!
- cd players with red lighting?
- Is anyone running 6x9's or 5x7's
- Complete SHORT somewhere...
- removing door panel with roll up windows?????
- Need a lil help wiring new HU
- Best system for Heavy Metal???
- No power inside of car!
- suggest an amp for single 10" DVC sub
- cartridge eject, stock Delco changer
- iPod
- Need a lil help with my halos
- IPod Connector Q?
- Adding amp question
- 05 GTO wiring scematic
- 02 f-body b-pillar monsoon speakers
- pioneer deck stops reading 12 disc changer
- Battery relocation help.
- can some one help me out
- Stock deck doesn't read burned cd!?
- Black Halo Headlights (Help)!?!
- people that have installed guages.
- I need a speaker wiring diagram for a Bonneville GXP
- LED Z28 brake light
- help rear sail mids!!!!!!!!
- is there a 5v wire in the harness?
- Anyone have used ALPINE wireharness from Circuit City?
- Ian @Kee Audio, I need you!!!
- Can my amp sufficiently power my setup?
- What Infinity speakers for Camaro Monsoon
- door light question
- Buying Alternator off ebay???
- anti-theft problem
- Did I get ripped off? Need subs too..
- Trouble code: P1502 - Any thoughts?
- Constant "Humm" from speakers
- anyone looking for an alpine iva d900 complete?
- Where to mount Amp?
- Best 4 Channel Amps..
- problems with front bulb sockets!!??
- JL or memphis?
- new head unit sticks out too far
- SQ system install
- Halo Bulbs
- Fuse: Door locks and Map/Dome lights
- Help with sail panel speaker..
