- TSP 228R cam only results!!!
- NEW 400rwhp CLUB MEMBER!!!
- horsepowerenginering 434 dyno numbers 562/507 !!!!!!!
- TR224, LS6 intake, LTs, 3500 stall.....340HP/340TQ?
- Okay, what is this "dip" in my graph?!?
- Ati + Sm 370 = 687rwhp.
- New member of the 400 club
- any mustang dyno numbers?
- Just dynoed tuesday. Happy with results
- Going to do a good copmarison of Grott/QTP 1 3/4 headers vs. Grott/QTP 1 7/8 headers.
- DYNO # on = 224/220 .581/.581@116lsa + headers + intake
- Any TSP Torquer results yet?!?!
- HPE "S" Cam Dyno Results!!!
- Finally dynoed APE 370, Patriot II's, 238/244
- new dyno numbers...
- ATI new 8 rib setup Final results
- AFR LT4 H/C Dyno results
- my Stock #'s, whatcha think?
- FMS Cam, small head 408, 542rwhp/535rwtq
- AS Stage II 6.0L head dyno
- Highest HP AFR 205 car to date...
- Hows this for a correction SAE,uncorrected
- Dynoed 11/13/04
- Finally....441hp...394trq
- Added LS6 intake, stage 3 trans and car dynoed much lower
- Dynoed the car!
- HP From a Tune?
- I came up short...
- can i get 350 rwhp?
- These results normal?
- Dyno figures for Hooker LT's and TSP true duals
- ATI D1 Procharged Camaro - 538rwhp broken d/s
- First Time on Dyno... Odd Results ???
- New Dyno with slight tuning
- PRC 5.3's and Futral F15 cam dyno
- New dyno numbers are in!!!!!!!!
- Dynoed the SS
- Before/After pulley install
- Dyno Results
- Are these good numbers for a stock car
- z06 Before/After: TEA 1.5 swapped to AFR 205cc, lost HP
- Those w/stock heads, stock bottom end, N/A, T-Rex user, please post dyno graph.
- Dyno question???
- Anyone have any Head/Cam Dyno Results with the CMMG Exhaust?
- My first ever dyno .....
- Fresh 422", TEA AFR 247cc, A4 C5 Dyno results
- '99 M6 with boltons... low #'s?
- HP Numbers on the N20
- Dyno help w/ numbers please!
- Went to the Dyno yesterday
- AFR 205cc 346" Z06 501.3 rwhp, 454 rwtq!
- Sad Sad Day!
- A4 Dyno Tune
- anyone dyno a stock 00 z28
- got a time slip to go with the dyno #'s
- Any AFR results on A4 cars?
- My cam only results after adding the 90/90 setup
- Bolt Ons dyno-graph
- How is this 1/4 time?
- dyno #for my 99 SS
- What kind of power can i expect if i went turbo on my 408?
- ATI 8 PSI 8 rib, on stock head/226 cam car
- TR 230/224 Cam Only!!!
- Will I break the 400rwhp mark?
- DNYO Graph inside: C6 with a NX 150 HP
- Another AFR 205 dyno result: 490/443
- W/B A:F through cats... how?
- First Every Dyno Pull
- Converter Efficiency by Dyno Results
- Dyno related question
- SLP 402, AFR 205, TSP MS3, Rapid Tuning
- Freak dyno results?
- Dyno my car 4 first time (baseline runs)
- Best air/fuel ratio for making power and staying safe?
- Not and LS1 or LS2 - '04 Cobra Dyno
- T-ReX + 100 Shot = 528 RWHP, 580 RWTQ
- D-1SC stock heads and bottom end
- first time on Dyno
- Thoughts on dyno parasitic losses
- new dyno numbers 231/237 PPII
- 400rwhp and 523rwtq...
- Dyno results for ls6 intake...and short belt
- First time to the Dyno with our cam only cars
- First Dyno Results
- Any graphs with valve float?
- PP LS6 stage II Heads & TS 237 cam
- 98 Z28, M6, bolt-ons and small shot
- 250 shot on stock bottom end.
- Looking for dyno results of one cam but 112 and 114 LSA.
- results from Next Level Performance (Norris) dyno # VRS McDonald Motorsports
- TTP S3 AFR H/C Package Results on 03 Z06
- Dyno results for bolt on only LT1
- 422 results
- Just added alot of power, want to guess dyno numbers??
- Losing HP? How bad do i need the dyno?
- TSP 231/237= 67 rwhp gain!
- How much HP will these give me?
- Does this sound plausible?
- headers,ory,loudmouth only dyno#'s
- H/C dyno results.
- Post 9" Dyno Numbers
- 225 shot was fun! Dyno numbers on a 225 shot and new all motor best....
- G5X3 112 Cam Only Dyno Results: 434 rwhp and 405 ft-lbs
- Z06 P1SC, cam, LT's, methanol, tuning....
- Dyno numbers for a 98 Formula
- AFR 205 / G5X-3 Dyno Results....
- 2001 SS #'s
- How much RWHP will it give me?
- opinion on Dyno #'s
- My dyno #s...
- Speed Inc.-Single Turbo-348ci -844rwhp 813rwtq-stock pcm
- some nitrous numbers
- Old dyno of LS6 Intake hp/tq gain!
- TSP Magic Stick Dyno Results!!!
- Auto Vs. 6-Speed power lost to the wheels
- What are you guys seeing out of this combo?
- Best Headers
- Just added ported TB and ASP pulley
- WHO here on this forum, REALLY knows transmissions, converters & dyno's?
- TTP ATI Procharger Stock H/C ZO6 "606RWHP"
- Just back from 1st ever dyno - a little dissapointed...
- just dynoed my car today kinda low
- Is there anyone who Has Dynoed Holley Power shot or K&N Filter?
- Torque converter lock up on dyno question
- MTI G1 cam and Kooks LT header Dyno results...
- is 450 rwhp possible with these mods?
- good tuner in NJ/pa?
- first dyno results
- what kind of gains???
- New APE 408 dyno #s :) NA and with 150 shot..
- 346 with baby cam dyno
- 454 Impala SS Final Numbers
- Engine dyno in Dallas area???
- Difference between AFR on dyno vs the street
- Dynoed the Trex-GTP combo...peaked awefully early...
- dyno results for a stock 2002 ws6 m6
- What #'s to expect from my combo
- 01 Ws6 Dyno!!!
- 383ci 496rwhp Z06
- Any mustang dyno guys out there?
- First Time Dyno - Results good?!?
- HP seems a little low?
- Dyno Results: TSP 231/237 and Patriot 5.3 Stage II Heads
- 1998 Bolt On Results step by step
- Is This A Good Number
- 347 RWHP Bolt On LS1
- My Absolute/ G5X3 dyno...
- Race-Prep 434 91 Octane Pump Gas Dyno Results!!
- SAE corrected or actual rwhp?????
- Cam only dyno
- Just dynoed today at lunch... what do you think?
- Livernois C6 Head Swap Dyno Numbers
- Going back to dyno tomorrow for retune with LS6
- f10,tr228,cc228 dyno #'s..lets see what you got!!
- Speed inc. 427.
- 295 RWHP WITH LT's, Lid, Borla ????????
- More AFR 205 results: 481/417
- How Much HP Would an Exhaust Leak Rob?
- My first dyno runs
- oil pressure sensor pin outs for 98 LS1?
- New dyno #'s on 150 shot, still getting there.....
- 383dyno 360rwhp why did the car dyno so low on mustange dyno(what will it make on jet
- dyno tuning in san diego
- AFR 205, 60cc, 234/238, 90mm results
- First ever dyno/tune after new parts install
- Rwhp/trq estimates based on my setup?
- TTP AFR 205 H/C Combo Results
- APE 427 C5 Vette Dyno Results
- APE LS6 H/C Results
- My second Dyno session, still can't figure it out...
- APE Z06 Vette w/Magnacharger dyno results
- EZSS's Dyno Numbers
- Gained 15 rwhp with LS6 intake.
- Icon Autosports 408 Preliminary Results
- average #'s?????
- All my dyno sheets
- advise on exhaust gain/losses
- MTI Comp Stealth II cam Stage I trans and retune
- question...need to free up 15rwhp....
- First Dyno #'s
- Baseline for project Orange Krush
- Please post dyno #'s achieved OVER Pred/HPPIII
- Baseline Dyno Last Night Lid/LM/LS6 Intake
- Any HP gains with roller rockers
- Elevation Matter and dyno matter?
- my tr 224/224 cam dyno tune numbers
- Dyno Results 9/26 - 1999 Trans Am
- NEW #'s
- 365 RWTQ bolt ons
- Dynatech Supermaxx 1-3/4 LTs
- Dyno'd my car for the first time - 98 Z28
- Most disappointing modded ls1 I've seen
- good dnyo # or not with heads,cam.6.0l
- Full Bolt-On Dyno #s right on
- New Dyno Numbers
- Good numbers? and ABS LIGHT ON!!!
- SLP 234/228 cam/heads package
- Dyno in 3rd Gear?
- Dyno numbers with TSP "MS3" cam only??
- c1 cam only results
- Low Dyno Numbers With Cam
- New 383 TSP Magic Stick Numbers
- Good AFR 205 Results...
- NO heads or cam DYNO
- 89 TTA - 698rwhp
- Y2K Camaro cam only: FIRST DYNO!
- Cam Only Dyno Thread
- RWHP loss with heavy wheels. How much?
- dyno tuning ohio
- TR224 cam only A4 redyno dual/dual 372/365 locked (vs. magnaflow previously)
- How much rwhp will Fikse 17x11's cost me?
- Any idea what's causing this dip in my curves?
- Just dynoed and 02 w/Bolts/02 LS6 cam...
- what is your thoughts?
- new numbers from saturday 433/385 cam only
- Altitude comparison Here
- New car Dyno....
- D-Day
- Dynojet correction question?
- TEA stg 2.5 LS6 heads and G5X4 dyno and track times within.
- patriot stage 2 heads/comp cam/all bolt on numbers inside.....
- Are My JBAs Killing Me
- Going from a Vig3200 to a Yank SS4000 a loss of Power on Dyno?
- Cam, Headers, Bolt ons 1999 Z
- TEA Stg. 2.5 LS6 heads/G5X3 cam makes 447rwhp/400rwtq today
- Mixed Results on a 231/237 Stage II Patriot 5.3 Setup
- Are there any dyno gains when bypassing PS pump
- any estimate on my output?
- what do you think of these #s
- how much rwhp difference th400-4l60
- Sotck manifolds on my H/C cam - how much is still on the table?
- with my setup what should i pull?
- Any big HP AFR cars yet?
- 01 WS6 M6 w/hotcam + 5177
- Going to dyno my lt1, what to expect?
- Need Dyno Results for 2000 SS's
- 2002 WS6 with almost-full bolt-ons
- 2k2 A4 Z/28, Absolute stg 2, MTI Stealth II..
- Input needed on a poor performing heads cam combo, Help please!
- Got some Results!
- Highest HP Tuner RWHP dyno #'s out there
- Vettes first dyno run
- first dyno a lil disapointed
- Any LS2 VS. LS6 or LSX -fast-Dyno results out there
- Single Turbo V6 Dyno Graph
- V6 to V8 swap results...
- Initial results of my AS stage 2.5 5.3 heads
- cartek heads give me 37 rwhp on my B1 setup
- tr baby cam and bolt on numbers
- Absolute 5.3 heads, TSP 231/237 Dyno results!
