- LQ9 Cam tune
- SBE LS1 Prc 215 Torquer 2 Ls6 intake.
- 408 stroker numbers
- New heads & Cam results
- Cool Dyno HP Wheel to crank converter
- 454 LSX, need some help with the graphs
- 715RWHP C7 Z06 - time-lapse, walk around, dyno, street action
- Cam only LS1 Exocet dynod...
- Bolt-on G8 GT Dyno Results
- Does this C7 Dyno Graph Look Weird?
- 349@ 6100 331@3900 bolt on cam ls1
- [VR] Corvette C7 3LT Z51 MT - VRSC785 Performance Package - Pics & Results Inside!
- [VR] Corvette C7 - ECS Novi 1500, VR Cam - Results and Pics Inside!
- how much is my exhaust holding me back?
- Any Hedman mid length header dyno results?
- f1c-94
- loss of power ?'s
- Redyno'd my heads/cam LS3...
- 408 results what ya think?
- 2006 C6Z dyno numbers
- My 403 ls swap! Dyno sheet and pictures!
- Turbo ls1 Hp guesses?
- Cam Motion LLR + Pro1 LS3 Heads = 707 FWHP
- 2000 Camaro SS with minor bolt ons DYNO TUNE~!!!!
- What are the highest stock bottom end LS dyno numbers?
- LQ4, PRC 5.3L Heads, 231/235 Tick cam, LSXrT intake - results
- 00 camaro D1sc dyno
- Something is up here...
- SBE LY6 S475 T4 1.25 83mm-798 RWHP @ 17 PSI Through Unlocked 4L80e
- 451 lsx
- 814 RWHP ECS kit and Jam cam on 151LE
- C6 & C6Zs, what power difference are you seeing stock clutch vs lighter ones?
- Drivetrain loss
- [VR] Corvette C6 Z06 - Kaotik Cam, WCCH Heads, ARH, MSD - Results/Dyno/Idle Video!
- 2002 trans am LQ9 370 nitrous cam
- My GTO N/A and Nitrous runs.
- Headers & Cammed L92 w/ VVT Dyno Results
- Mickey Thompson Pros Question
- Before & After NEW TSP Lobes Gained 78rwhp @ 6000rpm!
- ls2 with TEA 243 heads/FTI cam/MSD Intake. 500 hp
- 2008 Challenger with Whipple
- Dyno #'s seem low on 99 SS
- My 408 results
- small EDC cam,TSP 1-7/8 LTs Dyno
- BONE STOCK lq4/t56 dyno results
- Any car dynos with tsp 220? Just see 4x4 results
- 408 PRC 247 251/259 results
- [VR] Corvette C7 Z06 A8 - VR Stage I Performance Package - Pics and Results Inside!
- [VR] Laguna Blue Corvette C7 Z06 - VR Stage IV - Dyno Results and Walkaround Vid!
- [VR] 100th Anniversary C6 LS3 - ECS Novi 1500 - 655.87whp / 596.44wtq - Pics/Dyno
- Dyno Numbers - '99 Camaro 6-speed with long tubes + LS6 IM + air lid
- Ls3 418
- Gen IV 5.3L ASA cam, Holley Hi-Ram
- Built Ls7 in my C6Z Finished
- Stock 1999 Firebird Formula Dyno
- Dyno numbers for stock ls1s with 100-150 wet shot
- Expensive build
- Dynos in Champaign, Illinois?
- What do you think it will ET?
- Dyno numbers
- Dyno results
- SSHT cam only results
- Dyno numbers from build.
- Dynotuned 416 LS3 Today
- LSX 376 B15 builds?
- couple dyno questions
- 5.7L H/C/I swap numbers are in!
- Question about dyno tuning process.
- my stock bottom 4.8
- 404” puts down 529/ 476 NA and 606 / 541 on 100 shot
- Hitting the Dyno today
- [VR] Corvette C6 Z06 - WCCH Heads, VR SumBich Cam, ARH, Fast - Results Inside!
- 441c.i. LSX Nitrous Build N/A dyno as well as other dynos...
- estimate rwhp on engine build n/a spray c5 corvette
- 98 SS A4 heads/cam LS2 480rwhp/417rwtq
- H/c/i + spray
- 2002 Trans Am Dyno Results and Vids
- 408 build. Numbers are finally in!
- Dyno'd my 1LE today with the ECS kit on my Jam cam-732 rwhp-no meth!!!
- dyno results on a very stingy mustang dyno
- [VR] Shark Grey C7 Z06 A8 - VR Stage I and Stage II - Results and Pics!
- 402 stroker 12.1 compression guess
- [VR] CTS-V Coupe - VR Stage IV+ Performance Package - Pics, Results, Dyno/Idle Video!
- Stock bottom 4.8 + 78/76 + C16 = Oh my..
- ls1 build nitrous and dyno numbers
- ~100% IDC. Would more injector increase power?
- H/C LS7 swap C5Z. Engine and chassis dyno results.
- 5.3L+224R 323hp/302tq
- Exhaust smell questions
- Want to move to a smaller cam. Realistic expectations?
- UPDATE! This doesn't sound right does it?
- 228r Cam Only dyno
- Iron ls2 with 216/220 .560/.560 and AI 232 799 heads. Predictions?
- Weird results...
- Another what might my numbers be question?
- LQ408 Power Estimate
- Effect of higher stall on dyno numbers?
- will i make over 400whp now
- My car dynoed procharged
- 427+YSi+JamCam=1030 rwhp!!!!
- N/A Jam Cam 470 rwhp on a 15 1LE
- Is 10.99 possible with this setup???
- Low numbers?
- High Altitude dyno numbers?
- Crate ls6, BTR cam and bolt ons
- LS1 stock 243's, FAST 102, Tick SNS stage 2
- 408 stroker. What am I going to run?
- Ls1 h/c dyno number?
- does drag radials cause dyno losses ?
- [VR] Camaro SS LS3 - ARH, Cold Air Inductions - 422whp / 424wtq - Pics and Results!
- [VR] Jet Stream Blue C6 Z06 - Cam/Heads Package - Pics, Dyno Vid, Walk-Around Inside!
- [VR] Black Diamond CTS-V Wagon - Stage 2 Performance Package - 537whp/554wtq!
- Dyno Virgin
- H/C/I/E LS1 vs H/C/I/E Coyote
- Cam only guys - looking to see your dyno and a/f ratio, and timing if possible
- [VR] Daytona Sunrise Corvette C7Z06 - 724whp / 723wtq - Pictures and Video Inside!
- [VR] 503whp / 488wtq 402 LS2 Pontiac TA - Specs, Dyno Results and Walkaround Video
- [VR] 891whp/786wtq ZR6X Supervette - RHS, MAST YSI - Pictures and Dyno Graph!
- 416 - from TEA TFS 225's to Stock LS3 heads - Dyno & Track Results
- LS3 crate swap 2002 Camaro Dyno results. 450whp/440tq
- New LS402 Build - Dyno Results.....
- Searching for tuner in Louisiana
- Dyno results with graph in video
- Dyno results in
- Looking for build results using TFS 260 LS7 head
- LS2 Chevelle: Cam Motion cam, ported 799s (GRAPH ADDED)
- High mileage short blocks and dyno numbers
- dynomite dyno question
- Dyno results; LQ4/4L80, D1SC, FMIC, ect "6/05/15 UPDATED with track results"!
- 2nd gear dyno
- Motor combo
- ws6 dyno results are in!
- Cam only LS7 dissapointing dyno numbers
- Dynoing new 408 this week. what will it make? ::: EDIT numbers are in! :::
- New AI 226 heads, fast 92, nw 92 install w/ numbers
- [VR] 572whp/523wtq 427 Corvette C5 Z06 - VR Cam Kit - Pics and Dyno Results Inside!
- Dyno test RPM vs Speed
- LS3 tune in LS1 pcm?
- 2010 SS M6 - interesting results
- remove seals from airbox when using SSRA on dyno?
- Dyno Next Week....Estimates
- 2000 Camaro SS Cam Only Dyno Results
- 418ci N/A cts-v dyno numbers. I'm happy and surprised
- 1999 LS1 H/C/I 449/403 on Dynojet
- Dyno results are In
- 03 vette streetweeper ht variant dyno numbers
- [VR] Commemorative Edition C5 Z06 - Cam Only - 438rwhp - Pics & Dyno Results Inside!
- FRH Cathedral 408 565rwhp/520tq
- 1999 Firebird Fomula 391whp/395wtq with a baby cam!
- 01 SS M6 H/C build, Tick Cam/Stock Castings
- LME 445, FRH TFS 235, Martin @ Tick build
- Weekend Dyno Pull!!
- 2006 Corvette Z06 620rwhp 523rwtq
- 2000 Firebird Formula Dyno Results
- Critique my Dyno Graph Procharged!
- LT1 hp prediction
- TMS 408 D1SC 10psi 790hp
- 418ci LS3 dyno low??
- [VR] Corvette LS2 C6 Auto - 532.66whp / 486.15wtq - ECS SC - Pics and Dyno Graph!
- finally got my cammed g8 on the rollers.
- [VR] Flex Fuel Corvette C7 Z06 - 734.56whp / 761.52wtq - Pics, dyno graphs and video!
- EPS 234/246 FAST 92/92 PRCls6 9" MADE 448/398
- what will it make? tick sns3 ai226
- [VR] Corvette C6 Grand Sport - A&A Supercharged - Pictures and Results Inside!
- [VR] 713whp / 652wtq Corvette C7 Auto - Heads/Cam Upgrade Results and Pictures Inside
- [VR] Cadillac CTS-V Sedan - 641whp / 625wtq - Pics and Dyno Graph Inside!
- [VR] 2015 Corvette C7 Z06 - VR Stage II Package - Pictures, Results and Dyno Video
- 408 Build dyno numbers are in
- Ls7 Fast 102 vs MSD airforce comparison
- 436whp LS2 bolt-on only!?
- HP Estimate?
- What is the highest HP Cam-only LS3?
- EPS 222/226 CAM, STOCK 243's
- 427ci, FRH ported TFS GenX LS3, EPS cam, Vic. Jr.
- how much power will I give away
- A little bolt on LS1 dynoed
- LS3 exhaust/chamber ported vs. LS3 Stage 1 fully ported
- how much power will she make and et guesses?
- 2009 Challenger with Whipple
- Stock 4.8 Longblock w/Borg Warner S475 Dyno Results
- Finally: The LSX 427" Lives!
- LS2 / TEA 2.5 / BTR Stage 2 / Fast 92 / LG 1 3/4
- LS3 231/236 cam and intake 513 RWHP, 452 Torque
- Ls1 cam and ported 241 heads or stock 243 heads what are u making?
- Power estimations
- H/C tune results
- how much hp guess?
- Cam, intake, and nirtous 6.0 dyno numbers???
- Bolt on LS6 1st Gen CTS-V; 392 whp/378 lb-ft
- 408 build dyne
- Guess my SS's HP!
- Tell me what this 408 will make!
- What do you think my number will be?
- 2003 holden monaro coupe (pontiac gto)
- Figuring out dyno numbers.
- any 5.3 nitrous peeps care to share?
- 408 build. please critique... New numbers 782rwhp 608rwtq, 300rwhp on a 200 shot
- LS3 487 RWHP & 448 RWTQ w/ Tick Stage 2
- [VR] Vengeance TT C6Z06 puts down 1419RWHP/1321RWTQ on E85! Pics/Details Inside!
- in search of dyno results for 96mm typhoon intake on stock cubed ls1
- LQ408 in WS6 results
- Highest horsepower stock bottom ls1 with stock GM casting?
- Cam/fast90 Ls1
- [VR] 754whp/709wtq 2015 Corvette M7 C7 Z06 - Build pics, Dyno Results, Video Inside!
- Bolt On G8 Dyno Results
- what do you think, ls3 g6x3 dyno results
- 00 WS6 Heads/Cam and 100 shot results
- G8 headers and LS9 Cam
- LS1 4L80 C10 with procharger
- Difference in dyno numbers normal?
- C5 Z06 Cam / Exhaust results w/ vid
- Jy lq4/ls3 heads & intake/vtc3 turbo cam dyno results!!!
- Fast 92 vs 102
- AI 226cc heads and PatG EPS cam dyno results
- LS3 headed 408
- 383 H/C/I Results!!
- 01 ws6 H/C/fast102 dyno results
- A&A TI trim supercharger results 802Rwhp 660 rwtq
- [VR] C7 Corvette - 851whp/794wtq - VRSC850 Package - Build pics and results!
- [VR] 712whp / 644wtq Cadillac CTS-V Sedan - Build Pics/Dyno Results Inside!
- 347ci dyno numbers
- [VR] 2009 Cadillac CTS-V 6MT - 1,216whp / 1,077wtq - Build/Dyno/Burnout Vids Inside!
- [VR] 675rwhp / 584wtq C7 Corvette - VRSC750 Package w/Methanol - Build pics/dyno
- Vengeance Racing Back to Basics - FAST Intake Comparison vs. OEM
- PRC 243's & Tick SNS Stg. 2: 428/377
- 2000 Camaro z28 bolt on m6 dyno result
- Dyno 537 on my pontiac ls1 with afr
- 427" LS3 Engine Dyno Results
- SHITLOAD of power from a stock bottom HCI ls1. come in
- [VR] 416c.i. YSi Supercharged LS3 C6 Corvette - Build Pics/Idle Vid/Results Inside!
- [VR] Theta's 416/Novi 1500 C7 Build - 881/802 on 93 octane and meth
- [VR] 2014 Camaro Z/28 - ARH Headers/VR Kaotik Cam - Video/Pictures/Results Here!
- Lq9 trans am build
- 98 vette budget build results
- 1999 Turbo Camaro 737 rwhp 738 rwtq
- C6 ls2 h/c/i
- finally hit the rollers
- 445", TFS 245, Fast 102, direct port, 4L60E = 605/550 N/A
- What should this H/C LS1 dyno?
- More dyno tuning H/C/I
- New numbers! LS1 cam/heads swap
- 391/366
- [VR] Vengeance Racing CTS-V Coupe - 2.3L Blower/Nitrous Outlet - Pictures/Dyno Result
- [VR] Vengeance Racing C6 - LS2 | VR | ECS | ARH | AlkyControl
- [VR] Vengeance Racing VRSC660 Performance Package on our first 2015 C7!
- [VR] Vengeance Racing Stage I CTS-V Cranks Out 554/553 on 93 Octane!
- 408 stroker what will it make? details inside!
- Stock bottom end ls1 dyno results
- Speed Inc's new C7 Z06 finally arrived!!!
