View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. do i need a set of inj ?
  2. stand alone fuel system???????
  3. Accufab 4150
  4. WTB: Fuel Injectors and TB Whats the best set up
  5. whats the best way to wire dual bosch 044 fuel pumps??
  6. help with new plastic straw for walbro
  7. Fuel pump blowing bubbles after water in the gas?
  8. Regulator vacuum reference on N/A motor?
  9. Well I think I FINALLY figured out whats wrong with my car(6.8mpg)... Fixable?
  10. anyone dealt with nasty performance before?
  11. 98 z28 keeps blowing fuel pressure regulators
  12. what 60# injectors
  13. Fuel System Part of My LSX Build
  14. Fuel psi ??? Help a brother out
  15. injectors not firing?
  16. Fuel Level Sender Question??
  17. Symptoms of a failing fuel pump?
  18. Symptoms of a failing fuel pump?
  19. Fuel tank interchanging?
  20. E85 conversion
  21. Racetronix hotwire observation
  22. walbro 255lph procharger ok?
  23. Installed 2nd pump now down on fuel pres.
  24. Are fox body mustang injectors a direct drop in for ls1 camaro?
  25. Help em with flow-through rails ...
  26. Gas Leak
  27. Installed Hotwire..question
  28. What do I need to run e85?
  29. Fuel Pump Question
  30. P0172 & P0175 code need some HELP!
  31. Best way to test for leaking fuel injectors..
  32. Fuel rail thread size
  33. Is Racetronix and Walbro fuel pumps the same pump?
  34. Will stock fuel lines and rails handle 700rhwp?
  35. max compression on E85 only?
  36. who has heard or has used the new bosch 95# high imp injectors
  37. Camaro fuel filter
  38. Heads & big cam is 26lb can make more hp??
  39. Fuel Pump question?
  40. Fuel troubleshooting
  41. Wideband and air fuel ratio
  42. Quick question about LS2 fuel rails
  43. C5 Fuel System Upgrades?????
  44. Thinking about buying Speed Inc. Fuel rails I hear there is more needed please help
  45. What is the max hp u can get out of the Ford racing 80's and which pumps?
  46. Differences between 1998 and 1993 - 1997 gas tanks
  47. Gauge/ Tank/ Sender/ 98 vs 00 Question
  48. I think i'm experiencing vapor lock on e85
  49. injector for e85?
  50. Vapor (Charcoal) Canister
  51. Fuel level sending unit without pump?
  52. Thanks to FICINJECTORS!!!
  53. Quick suggestion for H/C/I car
  54. Do I need a pump?
  55. vic jr fuel rail question
  56. fuel tank
  57. Broke the evap
  58. Is there a tool to remove sending unit and pump??
  59. fuel psi change require new tune?
  60. help with weak injectors LH side 69 camaro ls1 swap!!!! problem
  61. Is this a probelm?
  62. Trying to find a fuel pressure regulator
  63. how to remove this injector clip
  64. air/fuel ratio with blower
  65. fuel pump hotwire upgrade kit - how does the pcm know?
  66. Are LS2 injectors shorter than LS6 injectors?
  67. Dual in-tanks, or a big single? 750-1000RWHP
  68. Loud whine..
  69. What kind of Wire Connectors in Tank?
  70. Help with 98 fuel line routing!
  71. Casper hotwire kit and Walbro 255 pump.
  72. MAF change recommendations
  73. Crossover and Pressure Line in Rear?!?!
  74. any ideas on what i should do?????
  75. Noob to playing with fuel systems
  76. Fuel gauge inop.
  77. Retune after installing walbro 255
  78. L76 intake and rails on my 408?
  79. Injector Upgrade
  80. na 650 rwhp what fuel system
  81. teflon an hose and alum an hose ends?/
  82. Wastegate question
  83. Magnafuel MP-9950, now i need boost reference
  84. Anyone have a link to VP dealers
  85. help with fuel setup
  86. Will I need a Walbro
  87. need help with fuel set-up
  88. FP pressure
  89. Acceptable voltage drop at fuel pump?
  90. Help with hotwire kit
  91. draining fuel tank
  92. Will I need injectors?
  93. Odd Miss Fires??
  94. '99 LS1 injectors - '03 LS6 injectors ANY DIFFERENCE???
  95. does anybody make this part ???
  96. Fuel Pump Sock Question
  97. need help
  98. rookie needs help
  99. fluctuating idle vs fuel mixture?
  100. Fuel for 550ish rwhp?
  101. Stock lines, connector to rail??? Return?? 650whp?
  102. Need Fuel Rails for Super Victor ASAP
  103. Non-LSx Weber carburetor question
  104. e85 vs. pump gas+meth
  105. 2000 TA randomly wont start
  106. anyone ever make an injector driver?
  107. Intermitant popping and backfiring on startup after new fuel system.
  108. How Do You Know If A Car Need Bigger Injectors?
  109. Injectors not spraying help
  110. fuel pressure - help
  111. how much rwhp can the stock 26lb injector make
  112. Need some EFI feedback/opinion
  113. problem still there...
  114. Nylon supply and return tube where to get it??
  115. Friends car... fuel issue help plss
  116. APS dealers step in . need a part
  117. If you have a magnafuel pump come in here!!!
  118. Why are my fuel pumps going bad all the time?
  119. Got a question about dual pumps?
  120. Help! Fuel Trim problems
  121. How can you tell when a fuel pump diaphragm is good or bad??
  122. Fuel Pressure After Racetronix Install
  123. telling when you have a bad injector?
  124. Injector ratings
  125. Ford 460 with excessive gas in the oil...
  126. Would this work for wiring in a dual 255 setup Mighty Mouse style??
  127. Injectors not firing; VATS disabled. Common causes?
  128. Pics of my fuel regulator relocation
  129. FRPP 80# injectors...any feedback?
  130. What is the stock fuel pressure
  131. Camaro Tank Pickup/Wiring/Fuel Line Questions...
  132. Ls3 injectors on ls1??? Help!!!
  133. Trick Flow injectors
  134. Dual Bosch 044's
  135. fuel pressure vs idle/cruise AFR?
  136. aeromotive fuel regulator garbage?
  137. fuel pressure regulator
  138. Ok I need a fuel system that wont vapor lock?
  139. fuel pump???
  140. racetronix hotwire kit?
  141. Are Big $$$ fuel pumps nessary?
  142. Fuel gauge randomly drops to E while idling
  143. fuel pump question!
  144. fuel pressure regulator problem
  145. 24508208 injectors what are flow rate
  146. What injectors/pump should I be looking for?
  147. Can I use a stock 69 camaro tank with return lines
  148. Need Relay for my racetronix fuel pump
  149. going thru relays w/ the inline Bosch...
  150. Busting Gas Lines in Pump
  151. help with stock tank and taking stuff off
  152. No Fuel Pressure. NEED HELP!!
  153. injectors
  154. injectors?
  155. Possible Sabotage
  156. Hotwire Kit - loose crimps in connectors
  157. Car died.
  158. Problem with New Edelbrock XT Pro-flo.
  159. Help with 98 Fuel system
  160. a-1000 no return ??
  161. Fuel System Question
  162. Dirty injectors?
  163. Which wires?
  164. 496 BBC Electronic Fuel Injection
  165. race fuel????
  166. wideband o2
  167. What injectors with my setup
  168. Fuel system upgrade, again. Twin A1000's!!
  169. What Inj. do I need?
  170. Siemens Deka on NA ok?
  171. injector help ASAP
  172. 99' Z-28 hesitation?
  173. Switched power source needed for meth injection system
  174. Bosch Injectors
  175. Bosch 040/044 HP limit?
  176. Racetronic problem anyone
  177. Injectors
  178. car died and then its fine?
  179. One Pump Ok?
  180. full or empty tank for fuel pump door cutting?
  181. No Fuel Pressure
  182. Injector placement
  183. any ideas guys?
  184. evap question
  185. Help, I need a odd part
  186. converting to E85
  187. Ethanol and Timing
  188. In Need of some Fuel System Part #'s
  189. Ls1-lt1 fuel pump question
  190. Is ther any way to swap a complete plastic tank in a 98 and have it work correctly?
  191. Fuel pressure issues...
  192. Two injectors died....
  193. Bosch 380cc injectors???
  194. Wiring dual relays for magnafuel pump?
  195. will nasty fuel rails work with fast intake?
  196. Fuel Rail Fitting
  197. 80lb injectors 114%, fuel system upgrade options
  198. Fuel system questions
  199. Where to fit a fuel pressure regulator?
  200. **PLEASE HELP** Build 99% complete BUT fuel pump issue
  201. Possible fuel problem
  202. Any Issues with Walbro 255s
  203. Are all LS1 injectors the same size?
  204. 98 Corvette fuel gauge problem, 2 pumps?
  205. Do I need to replace my fuel pump?
  206. How Much Pressure is Too Much Pressure at WOT
  207. filter sock ring for racetronix
  208. Auto meter fuel pressure gauge help
  209. A fuel cell worth seeing!!!!!
  210. HELP!! What would cause an injector to stick open??
  211. Thoughts on Fuel System
  212. difference in FP Hot wire kits?
  213. Fuel pump
  214. Where to buy injector extensions/adaptors?
  215. Fuel pressure problem with dual Walbro 255's
  216. Lightning injectors in an my LS1?
  217. fuel pressure issues
  218. Best fuel injectors?
  219. Installing a Walbro in a 1998 F-Body (Small Write-up)
  220. A1000 vs dual walbro's for F/I
  221. Fuel rail ?
  222. Im doing a 98/Walbro write-up.
  223. My gas needle is lying to me!!!!!!!!!!
  224. Fuel pump help
  225. i might have ordered the wrong size injectors..
  226. LSX intake, which on is on my 00 formula,pics
  227. Cant identify my 60lb injectors??? Help!!!
  228. Deleting evap on my 98. Need diagrams.
  229. fuel pressure regulator ???'s
  230. What can cause my fuel pressure to lower under acceleration??
  231. Twin Pump wiring question..
  232. will bigger injectors make any problem
  233. Methanol Questions (Noob)
  234. twin fuel pump
  235. best injector for 600rwhp on e85
  236. boost referenced fpr
  237. Which injector for this combo?
  238. INJECTOR MATH HELP??? Spread sheet users welcome!!!
  239. need help with 98 fuel system!!!
  240. Lq9 and 42lb injectors
  241. What pump and injectors for a head/cam ls1 running E85?
  242. Help, Fuel Trim on passenger side Bank
  243. Anyone ever maxed out an A1000?
  244. Fuel pump on a 01 camaro v6 car
  245. ughh... please forgive my short term memory
  246. MSD 6A with Fast XFI or not ?
  247. injector/ pump question
  248. Fuel Rails
  249. metal to plastic tank swap Q's
  250. Walrbo GSL392 the same as AEROMOTIVE 11109
