View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58
  1. new injectors
  2. Help me out with my fuel system.
  3. LS1 injectors on LT1 car? How well does it work
  4. At what HP do recommend upgrading to large Fuel Rails?
  5. Quick Question about injectors from Texas Speed and Performance
  6. Who all makes 75 lb/hr. high imp injectors.
  7. What sponsor sells fitting to work w/ factory line
  8. whats a good a/f to run with?
  9. Stock Fuel Pump Limit?
  10. Another dumb ass injector question
  11. Hey I got A Problem
  12. Fuel Rail plumbing for better pressure?
  13. a couple ?'s on fuel pressuer
  14. fuel pump cutouts!!!
  15. Should I get the size injector I need now or may need in the future?
  16. W T F was speed inc thinking
  17. Does a thirdgen pump fit the LS1 cars?
  18. I did my research and the winner is..........
  19. Problems with Fuel Gauge Fluctuation
  20. inline or intank
  21. Help me design my system
  22. injectors
  23. Does anybody know if this pump will work on my car?
  24. how much fuel line to order??
  25. Carb Vs EFI discussion
  26. Speed inc. fuel rail fittings
  27. Speed Inc plastic tank fitting pics??
  28. Fuel Pressure Varies
  29. ? on wiring for walbro 255 fuel pump
  30. 36.5# GTP injectors
  31. newb injector question
  32. Kenne Bell Boost-A-Pump $100 +s/h
  33. What kind of injectors will I need?
  34. Stock feedline-aftermarket fuelrail connection???
  35. Another Fuel System???
  36. fuel fart
  37. will a 43gph at 40 psi pump be enough
  38. Whats the part # of the 28lbs injectors?
  39. hotwire for inline?
  40. need some help on injectors
  41. ? for those who have brazed a fitting on rail
  42. How much HP can 26lbs injectors handle?
  43. Should I use 2 filters?
  44. my stage 3 fuel system
  45. Hgh and low impedence Injectors.
  46. How to set up dual walbro 255
  47. bbk 80mm
  48. Fuel Tank harness diagram?
  49. What color
  50. should fuel pressure stay the same
  51. error code
  52. Fuel Pump Wiring
  53. Dual or a single pump.
  54. Fuel Pump getting noisy?!?
  55. Anyone use dual rail feeds?
  56. Bulkhead Fitting w/Nylon Washers?
  57. '97 Vette Rail Pipe/Compression Fitting to 6AN
  58. How far will 28.8lb '02 injectors take me (in RWHP)?
  59. 408 plus 150 wet shot
  60. Could my Injectors be going out?
  61. Anybody have a cool can??
  62. Can I use Barb fittings on fuel system
  63. alky and fuel injection
  64. Aeromotive 13101 FPR fittings
  65. Got my injectors today and........
  66. walbro gss340M replacement
  67. Mounting a walbro inline 255LPH pump, above or below tank?
  68. FAST fuel rails and injectors
  69. Help
  70. help car running lean
  71. New injectors
  72. INjector Specifications
  73. Carbed vs. fuel injection
  74. Max stock fuel pressure
  75. Is my stock fuel system enough?
  76. Reccomend me a Fuel Pump for my FI setup
  77. custom fuel rails
  78. What size fuel line?
  79. Electromotive tecIII ??
  80. 39# injectors and Stock Pump
  81. Will this work, return system with reg way before fuel rail?
  82. 408 + 300 shot fueling questions
  83. Question on injectors
  84. Anything else I need for Racetronix intank system?
  85. Help removing fuel pump!
  86. Going from 26lb injectors to 28.8, lean or rich?
  87. Injectors
  88. EVAP as return line question
  89. How can I hook a A1000 to suck from a stock tank?
  90. injector price
  91. fuel tank weigth for 98 and 99
  92. what are the limits of power with 75# RC inj's?
  93. Scrader Valve part #
  94. Factory Fuel Pressure Regulator:
  95. Billet Rails...what about te dampener???
  96. Russell Tube adapter users
  97. Fuel system 4 procharger!
  98. new injectors????
  99. Do I have all my parts?
  100. What brands for fittings?
  101. injectors
  102. will these injectors fit?
  103. Racetronix-- are you going to make a plug n play Fuel Pump for the rest of the Trucks
  104. OK to run injector upgrade a while before tune ?
  105. are Mustang GT injectors compatible with an ls1?
  106. which fuel pump for me?
  107. HELP ! how to disconnect fuel line from rail ?
  108. 204 GTO with wet nitrous system...FP question????
  109. Help burns fuse on fuel pump in gear
  110. How to contact Racetronix!?
  111. 00 injectors into 99 - retune ?
  112. 1997 vette rail, to AN adapters.
  113. HP Levels
  114. Need help with inline! easy qeustion. Did search 999 times.
  115. sending unit the same for 98 and 99 models?
  116. Question?? AN fitting and fuel line install?
  117. Rating Pressure for the SVOs
  118. Adapter, old style injector harness to new style injector
  119. How do I set up a fuel level on the 98 and up camaros?
  120. Will 42 # injectors work for 500rwhp N/A?
  121. what do i need to do to make the walboro 255 fuel pump work in 98z
  122. Need help identifying this stuff.
  123. Installing fuel pump from the top?
  124. Build Me My New Fuel System
  125. Fuel Managemnt When Boosting
  126. Need to build dual in-tank pump setup - where to buy Walbros?
  127. Pressure in tank
  128. Just installed Walboro 255 LPH. No pressure
  129. What is the purpose of an aftermarket Fuel Pressure regulator?
  130. Fuel Injector Size
  131. Anyone have a diagram of the fuel lines running threw the car to the in tank pump?
  132. Car cuts off when launching at full-throttle WITH traction!
  133. siphoning gas?
  134. Fuel pump question?
  135. How to get mileage with 96# injectors
  136. Using stock feel line as a return...
  137. Can you have too much injector?
  138. removing fuel line..
  139. new injectors
  140. Fuel Upgrade
  141. Injector Issues??
  142. Anyone know how to figure out/has the injector offsets
  143. HELP - How do I take the pump basket apart?
  144. Anyone made their own fuel pump hotwire kit?
  145. Editing fuel maps so I can start car tonight...
  146. Fuel Line at the Pump..now has a slice in it...help!!
  147. Should I get new injectors with my new mods?
  148. Surprised on a Price/Fuel Pump Went Poopie.
  149. Rich Condition On Start Up
  150. Can a walbro gss340 keep up with -8an feed line?
  151. Throttle Body
  152. Remove Rear end to remove Tank?
  153. In line pump install
  154. 408ci + 200shot fuel system - what will I need?
  155. what is this part?
  156. Anyone have a 98 Fuel sending unit...
  157. 98/99 fuel tanks
  158. Fuel pump change for H/C 98 Ws6..
  159. Will my fuel system be enough for my setup?
  160. injectors
  161. Need a fuel system!
  162. Relocated Fuel EVAP
  163. Crappy gas
  164. Racetronix fuel pump
  165. Ruff in the rain? - your knocks are swimming
  166. Octane level question
  167. trex inline fuel pump...
  168. Walbro 255 pump..what modifications?
  169. I cant maintain fuel pressure
  170. What is max hp for stock 2000 pump
  171. Where to get a replacement fuel line that...
  172. What fuel filter w/ racetronix pump?
  173. my truck doesnt like to crank when its hot
  174. Speed inc impedance converter - how to wire?
  175. Who drives in the rain?
  176. Where to buy high quality 96-105 lbs/hr injectors?
  177. Fuel Gage Not Reading
  178. modifications needed to install new fuel pump?
  179. sporadic fuel gauge, what parts ...
  180. Anyone have a regulator mounted ON the rail?
  181. Strange fuel pressure reading... key on/engine off. Help?
  182. Upgrading injectors require upgrading fuel pump?
  183. help.. are LT1 and LS1 injectors compatible?
  184. help..are LT1 injectors compatible with LS1?
  185. Who's FP for 1100+ FWHP?
  186. Need help from the experts...fuel problem??
  187. '02 Gas tank question
  188. Fuel Injector Upgrade.. Tune Required?
  189. Upgraded fuel pump needed ?
  190. Fuel gauge not working, and low coolant light is on..WTF?!?
  191. Fuel rail pressure too high
  192. tpi problems
  193. Fuel system help!
  194. Anyone rotated fuel rails 180 degrees?
  195. Will changing injectors in a basically stock ls1 help?
  196. Injectors...high/low impedance...
  197. idleing problem
  198. 408 fuel help ...
  199. Are these injectors LS1 compatiable?
  200. Gen7, 2002 TA
  201. Which pump an regulator?
  202. desperatly need help!
  203. Corvette sumped tank?
  204. Plugs fouled in one bank but not the other
  205. Where is the fuel pump relay located on a 98Z?
  206. C5 Racetronic Flow Rate
  207. What brand sumps are being used?
  208. Weird issue w/ SES light and gas level.
  209. RCI Fuel Cells
  210. 427 fuel help.
  211. 70+lb injector optoins
  212. 50 pound question.
  213. Racetronix 32# best injectors for LS1?
  214. 98 fuel lines on 99 car?
  215. How to Disc Evap purge Can
  216. Need a injector/rail clip. Where?
  217. Wiil 42# injectors be overkil for H/C 250 wet shot
  218. Walbro 255-Lph in -tank fuel pump...
  219. My Fuel Gauge is...
  220. Need some help on mileage, i figure the experts are in here!! help!
  221. Major Fuel Drop Problem
  222. Check out MSD's new Ignition box for ls1's
  223. 02 sensor ???'s
  224. Holiday Injector Special
  225. Any high pressure regulators in the $50 range?
  226. Help ran bad gas
  227. Size injectors???
  228. Fuel injector driver box?
  229. what size injectors
  230. WS6 Fuel injector question
  231. Will this be all I need? LS1 fuel system in 97 car
  232. What do I need to make 39# cobra injectors work?
  233. Fuel System Pics
  234. is there any instructions on how to install a racetronic
  235. does bigger fuel pump need more juice?
  236. another question for Racetronix
  237. Are the 00+ fuel rails larger than
  238. Roughing in IFR for 60 lb Mototrons? (with fpr?)
  239. Stock Fuel Pressure?
  240. quick question about AN fuel line
  241. Difference in two injectors on websites?
  242. How big of a shot can I go???
  243. Anyone have any experience with these injectors
  244. Fuel pump wiring
  245. Maybe the fuel pump??
  246. External FP recomendations?
  247. Power capability of 43.5 multec II
  248. Is this Fuel-System related?
  249. Bosch 420 l/h inline questions
  250. Roughing in IFR for 60 lb Mototrons
