View Full Version : Fueling & Injection
- rusted destroyed fuel system?
- 99+ tank swap help please! Doing this tomorrow!
- Gas Gauge issues
- Will 30lb/hr injectors be big enough?
- stock injectors after head/cam swap
- Is This True About Methonal??????!!!!!!
- Fuel question
- Nasty's sending unit help
- What fuel line manufacturers are available?
- Fuel Pump install, Driveability???
- Fuel Pressure Gauge
- Fuel Pressure gauge install
- Can anyone tell me correct pressure???
- how much power can you make with svo 30's
- Larger injectors and gas mileage
- racetronics wiring harness instructions?
- svo #30 and no tune
- Throwing codes P0172 & P0175
- one for all you techies! :)
- Car Running Rough!!
- How do you disconnect the line from the rail?
- Which external fuel pump
- 39lb injectors anybody have 'em or know of them?
- Anyone heard of TRE performance fuel pumps
- How do I add an external fuel regulator up front
- Fuel pressure sending unit
- fuel pump problems please help!!!!!!!
- MS3 and heads what inj.?
- fuel rail install
- should I upgrade fuel system?
- how many HP is dual walbro's good for?
- how many HP is a dual walbro good for?
- 28.8 injectors
- 3800 series Supercharged 36lb injectors?
- hard starts
- Fuel Pump Booster Wiring
- wats a good replacement fuel pump
- Running rich/lean on fuel?
- Purge valve question
- what size injectors on stock 01 vette ?
- Question about line sizing and HP rating
- In-tank pump for 70 F body tank?
- MSD Boost a Pump Function
- fuel press at 30psi walbro pump runs nonstop
- Need help finding "Y" fitting
- How to mix Xylene?
- fuel system for my 402
- Translator
- quick plaese!! what is the stock ls1 fuel pressure reg supoosed to be set between??
- Feed the front of the rails or the back???
- Lucas/Delphi injectors
- No spark/fuel (getting 12v to injectors, no ground)
- On my way to a better fuel system for my 04' Veet FFS
- Pressure Regulator Pipework?
- Need help with fueling!!!!!!!!!!!!!!!!
- Octane rating
- What size injectors?
- Ideal injector size for my set up?
- Need a 42# table
- How are the 60 pound racetronix injectors in daily driving?
- New Racetronix Fuel System for Sale
- Kenne Bell Boost a Pump
- Which External Fuel Pump..please vote
- Car is idling really bad and misfires and sputters when I step into it
- Fuel injector size?
- What years did the F-body have a steel fuel tank?
- Pics of my Dual Intank Walbros
- Impedance Converters
- 97/98 C5 stock fuel rail question
- 190 LPH fuel pump from my 5.0 question?
- Are all injector brands created equal?
- Pumping gas
- How important are flow-matched injectors?
- How do I get the Injectors off the fuel rail?
- big injectors - problems
- Upgrading fuel system?
- small fuel leak(s)..can a sealant be used?
- Injectors and Fuel pump Questoin !!!!!
- Gas in the OIL
- Inj duty Cycle %
- fuel system for ls2 gto anybody making any
- Ethanol And E85 Alternative Fuel
- Stainless braided fuel lines and fittings
- Where can I get this hose???
- SVO injectors... What years fit?
- Aeromotiver fuel rail question. Where to mount???
- Stock Injector flow rate '91 Z28
- Do I need bigger injectors?
- MSD Boost a pump
- High pressure fuel hose??
- is this an ls6 or ls2 intake manifold?
- Picture of Racetronix dual pump harness..super quality.
- fuel system for 402/turbo??
- what is needed for a 408?
- really bad misfire
- 42# injectors 1to1 regulator 8-10#s boost
- Question about fuel pump line inside tank.
- help guys, need it asap!! thanks fuel line removal, no qick disconnect piece
- Shitty fuel milage
- fuel line adapters: AN to factory style connections
- Fuel pump from the top?
- What is THE regulator to get? for 4 bar setup, and possibly for a DP as well?
- fuel pumps...big single what you guys running
- Anyone had problems getting Racetronix tech support?
- Question on fuel pump draw...
- fuel rail covers install
- how much injector will i need?
- ATL surge tank
- who sells the best fuel rails
- Dual intank write up
- Should I ?
- which injectors..............
- 60lb Mototrons @ 80% duty cycle, how much
- Racetronix/Hotwire Fuel Pressure fluctuates with nitrous
- fuel pressure problems
- upgraded fuel pump install recommendations
- Not accepting fuel...
- Fast fuel rails to stock lines....
- Picture of Harris Speed Works teflon fuel lines, Fast Rails, Weldon Regulator w/n.
- When do I need to upgrade fuel injectors?
- Fuel system vacuum?
- High Flow "Race" Fuel Filter - Needed?
- Boost Referenced Fuel Psi Reg.
- Gas pumps with ethanol stickers
- Difference b/w matched injectors & non-matched
- Trying to make sense of Racetronix injector flow numbers
- Injector advice -H/C + FAST 90
- What size injector should i go?
- Fuel system help
- Advice: When is it time to step up to a bigger fuel pump & injectors?
- duals and fuel lines
- Using E85 as a substitute to race gas on high compression/high boost motors
- Walbro in-line pump in the tank?
- Who sells the cheapest SVO 30#s?
- What size line, -8 or -6?
- Cooling Mist?
- injector part # 12554271 doesn't exist??? any help!
- 8-160#s or 12-90#s
- Advice: Need to purchase some 42LB injectors that are flow benched where to get them.
- Cheapest 42# Injectors..High Impedence?
- getting injectors out of fuel rails
- any body have atleast a 12 gallon sumped cell
- Installed Dual intank 255's
- how hard is it to install a racetronix fuel pump?
- ac and fuel line tool
- Help with FI fuel system
- where to get 160# injectors
- enough fuel?
- tuning for E85
- Fuel rail removal????
- Gas fumes from breaded lines???
- 42# injectors
- Installing MSD Inline booster pump
- Venom injectors ?
- what fuel psi with return fuel system
- losing fuel pressure
- Dual in-tank pumps
- help walbro 255 install
- LPH of stock 02ss fuel pump??
- Fuel Pressure drops to 25 psi
- engine surge when stopping
- SVO 30 or 42 lb injectors
- Running on pure ethanol
- What fuel pump for BIG Nitrous LT1???
- fuel system
- Need More??
- 60# injectors
- Fuel Injector Help!
- Need help choosing right injector
- How do I identify ls6 28.8 injectors?
- Should I upgrade my fuel system?
- ebay fuel system ?
- what injector size should i get???
- Mods and maybe new injectors?
- Tuning Before / After a Racetronix
- Please help me with my fuel system
- fuel pump sock?
- air/fuel gauge help
- Fuel pump install, wiring harness?
- little help please
- help with fuel pump decision....
- Cowl mounted FP gauge
- injector flow rates with a rising regulator 1:1
- the last fuel system you will need
- Truck Fuel Pressure
- fuel gauge not working
- ethanol
- fuel gauge weirdness
- Electric fuel pump?
- What kind of fuel pump?
- size of C5 fuel lines?
- Do I need bigger???
- Will Truck Throttle Body Work? Worth It?
- can the 1999 fuel tank be droped without a lift?
- Fuel Pressure Question
- Problems after Walbro 255 install
- ATTN: All owners of Nasty Performance fuel tanks
- Stock fuel feed to AN adaptor
- Fuel Pump
- Walbro 255???
- Fast fuel rail pics.
- Wiring BAP
- How many gallons does my gas tank hold on my 01 SS?
- Gas Gauge Not working
- need fuel part #s
- Racetronix Fuel Pump Install
- Guys w aftermarket fuel rails, how did u run fuel lines?
- Carb'd LS1 ...Anyone done it?
- 600hp on 42lb injectors?
- Bigger inj. w/ heads cam?
- NOS octane boost? Raise octane by 60 points?
- Help w/Fuel Pressure Issues with Vortech
- To return or not to return....
- injector messed up??
- Anyone else have a nasty perf.fuel tank
- 98 gas tank
- Fuel pressure regulator on a '98
- 42lb Ford Lightning Injectors?
- what size are red top SVO injectors?
- fuel pump install gone bad?
- ok simple race fuel ?
- regulator necessary for 255 pump?
- Racetronics 32lbs inj good enough for this set up?
- Fuel problem or Ignition problem
- Switching from stock 01 injectors to ford 42 lbs
- Convert your car to Hydrogen
- Plastic or steel fuel lines
- Fuel gage ohm readings for custom tank installs inside.
- quick disconnect -an fittings?
- nitrous newbie
- Will it idle with 30# SVOs and no tune?
- 2 tries to start engine
- Fuel filter options..
- what threads do edelbrock fuel rails have?
- Fuel Injector Size w/my setup?
- Returnless style regulator?
- anybody installed nasty performance
- Fuel Hose
- supercharger noise
- Slightly bended the fuel line
- Quick Injector question?
- help on fuel pump install on a 98
- stock injector sizes
- Fuel Logs
- direct replacement injectors 6.0L
- Simple question
- Largest high impedence injectors?
- gas milage
- Racetronix hotwire kit
