View Full Version : Dynamometer Results & Comparisons
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39
  1. Read these 2 dyno sheets please
  2. Guy On ebay Claims 470rwhp.... Can it happen with this Combo??
  3. Can you tell vavle float form dyno sheet?
  4. 224 dyno today!!
  5. Guess what i'll dyno on Tuesday.
  6. Finally got the Chevy II on a dyno
  7. 377RWHP cam-only LS1 plus stock LS1 numbers/vids
  8. Dynoed my 01 Z today
  9. Dyno with radials or et streets?
  10. A/F 13.9 how to correct?
  11. Lightly cleaned up stock heads.. NICE gains!
  12. cam HP
  13. How Much Hp With, Heads And Trex??
  14. TEA 5.3's stg. 1.5, FMS F14 dyno results..
  15. TRex results with stock heads
  16. TEA 5.3's,FM13,Fast 90w/ NW TB
  17. is 400rwhp over the top?
  18. Stock motor with only GMMG exhaust Dyno Numbers
  19. Random Tech Flow Results - Q?
  20. Dyno Question
  21. Straightline baseline dyno run!!
  22. Expected RWHP on 402 with AFR 225, TH400...
  23. g5x3 434hp and 430 tq what LSX fast intake will add??
  24. question about fast 90/90
  25. 6.0 + 244/248... hp/tq predictions?
  26. 6.0 carbureted cam only #'s
  27. What do black hawk's dyno?
  28. Dynograph and Dyno vid
  29. 372 RWHP here, what gives?
  30. slipping trans, should i dyno tune on friday
  31. '01 z06 G5x3 results 412rwhp/380torq
  32. Disappointing results
  33. Dyno results...are the numbers as bad as they look?
  34. almost stock??
  35. x3 112 dyno results
  36. Guess my numbers
  37. AFR 205 heads install..dyno numbers inside
  38. slp package on a 99 ss
  39. AFR 205 and TR224 results
  40. Small cams over 400 rwhp (SAE)?
  41. are factory hp ratings crankshaft, rwhp...what?
  42. 393ci 6.0L heads, what should I make?
  43. Stock 02 Z06 and AFR heads=414 rwhp!
  44. Straightline dyno tune!!!
  45. what #'s should i expect???
  46. Anyone heard of Dyno Dynamics?
  47. AFR205s and F13 dyno 440/420 SAE
  48. Dyno Results of My TSP 232/228
  49. Big #'s for this setup?
  50. what should i ecpect?
  51. Dyno number on a F-13
  52. Dyno-Jet vs Mustang Dyno
  53. does anyone have dyno resaults with the TR 230/236 cam?
  54. hot cam results
  55. Are these good numbers for the mods I have?
  56. Bad f13 cam dyno!!
  57. May 27th, MTI stage 2e heads/T1 cam/LS6 intake results..
  58. GTP Stage I and CC 220/220 results
  59. Please explain to me....
  60. H/c 2002 Ws6 M6
  61. Asa Cam Dyno Results
  62. g5x3 with bolt on's #'s
  63. Dyno #s w/ non lock up converter?
  64. Cam results
  65. Dyno Results for my 2000 SS
  66. ls1 383 140 dry dynograph
  67. Dyno results for TSP magic stick..........
  68. 455rwhp/413rwtq H/C
  69. What cam makes the most HP??
  70. Stock 05 LS2 GTO numbers!
  71. F13 cam only and bolt ons
  72. Blew a head gasket on the dyno SRVIDZ!!
  73. MS3 results
  74. slp 500 hp head and cam package results
  75. H & C w/automatic & Moser 12 bolt #'s inside
  76. ls1 383 140shot
  77. Opinions on my dyno results
  78. Dyno inconsistancy?
  79. Dyno info
  80. Projections?
  81. Procharged WS.6 Dyno Graph
  82. New bolt-on Dyno Record????
  83. What to expect?
  84. Can you do WOT dyno tuning with New motor and clutch?
  85. 01 Z28 dyno - lid/ftra on mustang dyno
  86. dyno #'s seem funny
  87. '01 Z mild bolt on dyno results
  88. What happened at 4400 rpms?
  89. Anyone spray their F13 or F14?
  90. New dyno numbers.
  91. TSP 233/239 Dyno Results
  92. results before mods...
  93. 04 Whipple Cobra dyno!
  94. Tell me what ya'l think this should make.
  95. LS2 402 with AFR 225 heads...
  96. PRC Budget Stage 1 Heads Dyno Results!!
  97. Question for Dyno Gurus
  98. Finally tuned my set-up @ W2W
  99. Is This Normal?
  100. My HP & TQ were way to low! Whats wrong?
  101. My results!
  102. What numbers to expect?
  103. Thinder Racing tuning...?
  104. 2000 m6 ss with cam and most bolt ons
  105. another what if ?'
  106. Dyno Results
  107. Look at this Dyno, power drops at 5,200RPM - WHY?
  108. anyone running AFR 205 heads and F13?
  109. Z28 dyno graph and pic
  110. WHY only 315/330 Dyno after Crane 1.8 rockers and with Headers & True duals?
  111. Absolute 2.5 5.3's & G5X3
  112. New Prc 5.3 -2.5's/torquer Cam!!!
  113. How much hp do you think I have???
  114. Any dyno comparisons on a NW TB
  115. Head and cam that has biggest #'s
  116. Tsp 231/237
  117. FFHP Stage 1 5.7L Heads and T-Rex Dyno Numbers
  118. F-13 dyno #'s
  119. Weird Request - 70 to 120 mph run times?
  120. Coming May 11, MTI Stage 2E/G1 Dyno Results
  121. '04 GTO: stock + MagnaCharger + Magnaflow = :)
  122. about how much hosepower do I have
  123. 787 rwhp nitrous dyno vid
  124. First Dyno tune at TTP w/ Vortech
  125. bolt on dyno numbers
  126. T-Rex results (cam-only A4)
  127. Any way to convert 2nd gear hp to 3rd gear hp?
  128. f14 w/ disappointing nitrous results
  129. Almost final dyno numbers on FMS 408...
  130. "Small" cam results
  131. Any one have dyno numbers on LS2, LS6, LSX intakes?
  132. Stock C6 Auto Dyno
  133. Tell me what you think...
  134. D1sc + Fm7 = .......
  135. Bolt on dyno result
  136. 98 Ss Dyno #'s
  137. ZL-402 Iron Block Dynos Anyone have some?
  138. How much are H/C cars picking up with Just a Pulley?
  139. Lid and Catback -- How much HP?
  140. Cylinder head question '98 vs '02 stock
  141. HELP!! Lean car
  142. 2001 Z-28 Dyno Numbers
  143. gtech pro any good???
  144. Rev Extreme 408 ci and dual stage nitrous graph 787 rwhp
  145. Just how much can a tune help?
  146. cheap dyno?
  147. How much power am I losing by using these items???
  148. NEW TSP 233/239 R2 & PRC Stage 2.5 Results!!!
  149. what the hell is wrong with my car?
  150. Interesting Concept on Drivetrain Loss...
  151. Anyone ever gain HP by changing to aftermarket plug wires?
  152. Dyno results for my stock '02 T/A and a question or 2
  153. 4.8 2000 silverado
  154. Anyone have any before & after dyno results on cleaning up/porting FAST 90mm intake?
  155. Got my car dynoed
  156. SLP Package claims 500HP
  157. pp heads/231/237 dyno #'s!
  158. G5X3 and PRC results
  159. Serious Power thread.... 500hp+
  160. Are these normal, or do I have some sort of "freak"?
  161. Cam only dyno #'s
  162. Car will be done this week! Guess the HP
  163. 6.0 w/ls1 heads 383 w/stock heads what did you get?
  164. What kind of dyno #'s do you think I will have
  165. Mustang Dyno Results...A Couple Questions
  166. Any place in IL. to get my car dynoed?
  167. Possible for 350rwhp with bolt ons only?
  168. TSP torquer cam, 98 A4 results
  169. TR224 112 lsa
  170. X4 dyno numbers and X3/X4 overlay
  171. SPM & HPTuners Dyno Results
  172. 2000 Z28 M6 dyno results...
  173. LS2 w G5X-4 cam only, LG Headers, Fast intake-460rwhp 425rwtq
  174. AFRs 205s and 224/224 cam A4
  175. MTI 427 LS2 - 554 RWHP & 535 RWTQ, Long Read
  176. Vette + F-15 cam only. Vids :)
  177. Final F14 only A4 results
  178. 99 SS A4 dyno results
  179. Do gear ratios change dyno numbers
  180. TSP torquer cam, afrs, graph
  181. Confused on Dyno Numbers
  182. Another Dominator 402 LS2 Hits the Streets
  183. 452 rwhp - no head work...
  184. Bone Stock HP?
  185. How much HP?
  186. Average H/C dyno numbers
  187. Mufflex OR pipes comparison....
  188. stock vs Yank PY3400E converter
  189. Austin/Houston area speed shops
  190. TTP Stage 4R 346ci Heads/Cam dyno results
  191. More FM13 dyno #'s
  192. Help!!!!!!!!!!!!! Wtf
  193. Dyno #'s for Crane Gold Race Rocker Arms
  194. Anyone Have Stock Dyno numbers
  195. anybody have a vinci 224 dyno and sound clip?????anybody??
  196. TR230/224 dyno results
  197. New dyno today, may have problems on my hands..
  198. Dyno Chart for TSP235/240 cam
  199. Finally, Dyno Results on 235/240 Cam!
  200. baseline run with Absolute 2.5s/g5x3/90mm lsx
  201. 1st Dyno on this car...completely stock & no tuning
  202. APE Heads/FM13 Dyno Results..
  203. G5X3 stock heads.
  204. Low dyno #s with headers
  205. Just curious what you all think it will do..
  206. FM13 new dyno #'s
  207. TR224 .563 114 lSA ?
  208. 395 stroker/150 shot
  209. sea correction?
  210. Dyno results~tell me what you think
  211. TEA S2.5 LS6 HEADS & FTI(EDC) CAM
  212. WTF??!! 347 rwhp w/ G5X2
  213. dynoed my cammed, 150-shot M6
  214. How much HORSEPOWER?
  215. Newbie LS1 dyno ?
  216. What gear should a car have most power in on dyno
  217. What kind of power should i expect???
  218. FM11 and GMPP LS6 heads dyno graph
  219. F13 112+4 and TNT 100 results
  220. Z06 G5X3 & LGM LongTube Headers Dyno Results
  221. ls1 with macs
  222. LS1 Dyno Results
  223. Removed cats and got 1.1rwhp and .8rwtq
  224. Not Bad....stock Lt1!
  225. new dyno #'s
  226. G5X2 with FFHP heads
  227. 350 rwhp possible on a all motor L98?
  228. Just back from Dyno
  229. LG works its magic! G5x3 & cartek headers results
  230. ls6 intake
  231. what cam?
  232. lock TC dyno instructions - in neutral?
  233. magicstick&afr205results
  234. Dynoing Car
  235. So Many Mods and so Little Power
  236. FM11 and LS6 GMPP heads
  237. most economic way to 400rwhp??
  238. R my #s good or crap.
  239. 2001 Camaro SS STS Turbo Equalizer Cam Only
  240. 2001ws6ramair's 408ci Dyno Sheet
  241. dyno predictions
  242. AFR 205 only head swap. 50rwhp/40rwtq
  243. 97 Vette with a built 346 + D1
  244. 2002 WS6 A4 F13 results.....
  245. Your Dyno # Winner Is
  246. Trex dyno #
  247. Before and after dyno on 385 ci motor with TEA heads FMS cam
  248. DYNO info. re AFR 205 vs. stage 2 or 3 LS heads
  249. 01 Z06 cam?
  250. Just got back from dyno tuning @ CAM
