- Speedometer Problems
- regearing questions here
- TCS/ASR Questions
- Changing to Auburn Posi in my '01 - what type fluid?
- Giving up on search, Stock Aluminum Driveshaft and 1350 yoke Question
- plug on differential
- slave cylinder tbl??
- gear at the line
- Swaybar hitting 9" torque arm mount
- Did I avoid transmission death?
- Help..spohn torque arm is thudding
- 6 speed shifter Question
- How can you tell a Stock or Z06 disc is shot?
- Building up the 12-bolt vs. buying a ford 9''
- Torque Management
- Buy 12 bolt or upgrade 10-bolt and use extra $$ for mods??
- Why is the Spec 4 not recommended for daily driving?
- Which 12 bolt is the best and quiet...pros-cons?
- Why can't my tranny shift in to 3rd?!?
- 4.10 -> 3.23 swap, what will happen to my shift ext?
- Moser 12-bolt brake question..
- 4-L65-E is in the H2 what is it.
- How would you make 4.30 gears work using a HPP3?
- Currently... where can I get the best deal on a Moser 12-bolt
- Is anything worth a crap on our cars??
- synthetic in the transmission?
- faster downshifts
- Transmission question
- What's the part# for the 1LE tranny mount?
- how long for moser 12 to ship
- Is this a good price for this work?
- Changing Tranny Fluid?
- Add me to the "stuck in fourth" list.
- Help adjusting master cylinder?
- Slow Leak from rearend
- trans help please
- 6-spd down shift problem
- SFI Bellhousing and Scatter shield?
- Moser quality???
- Thumping Noise....Need Help
- SNAPPED DRIVESHAFT W/ 12BOLT MOSER
- WILL HPP3 HELP TORQUE MANAGEMENT???
- Need REAL QUICK answer on tranny filter seal!
- Anyone running this 12 bolt carrier??
- Question about 3.73's
- Will a ACPT Carbon Fiber Driveshaft fit with a Moser 12 Bolt with a 1350 Billet Yoke?
- All heads together on this question please
- Axle bearings
- Well, its decision time, 4.11s, 4.30s, or 4.56s????
- What would make a brand new tranny get stuck in 4th gear?
- Vibrations?
- 3.73 or 4.10 Gear
- Ratech Solid Collar...
- How loud is a 9" supposed to be?
- Paging Fireball
- really weird situation with broken rear
- Chattering coming from back of the car
- How much whine is normal?
- limit
- Nitrous & High Stall TC - No Lockup?
- would I need a 12-bolt?
- 9" with Auburn and U-joint help!!
- Moser 12-bolt in stock!
- Anyone know anything about the 5L60-E in the Catera
- Why non-synthetic gear oil in my new 12 bolt !?!?!
- What is involved in swaping to a 350T?
- what can i do?????
- Transmission or Gear Growl: Anyone else?
- Need to get intouch with Star/Spec
- To gear or not to gear?????????
- how much should 430s help me
- 6 speed shifter
- 5-speed auto in new trucks?
- How can I use ATAP to check if tranny is slipping?
- One wheel burnout =trans stuck in 2nd??
- rear end problems
- Master Cylinder Mod
- 12 bolt bearing HELP asap
- Need some info please...
- @#$% rear end cover leaking again
- Scattershield
- Gear change question...
- Trans leaking at U-joint?
- Rear-end Question???
- Have Mac reinforced cover for 10-bolt, what do I torque the bolts to?
- going from 3.73 to 4.10, is it worth it.
- having problems and dont know where to begin
- Shifter Help???
- I need help!!! ANd some reason the back tires locked up and i went spinningeverywhere
- Spohn torque arm setup help
- Need part # for pinion seal?
- Speedo/tach off after 3.73
- Mobil 1 vs. "Dyno" for MN6
- Gear "?"
- shift kit ?
- Tranny problems
- RAM INFO
- I think GM lied to me..
- Ford 9" vs. 12-bolt questions?
- 4.10's in a ten bolt?
- GM oil aditive.
- Trans shifting a little too hard.
- Hey Joseph....? for Ya....
- Need help guys , anyone currently have their tranny out of the car ?
- Rear Diff Cover, need help. *URGENT*
- what is the best way to bleed slave cylinder
- do you people help others with their questions or just ignore them?
- GM Factory Replacement Gears?
- 4.10 and locker or posi?
- Blowing up the Bellhousing, Disc flying apart, pieces coming out thru the windshield
- Dyno results on 200-4R (motor and spray)
- 02 Z06 slave
- Finally found out why my motor wouldn't spin.
- One wheel burn-out. Help.
- Rearend help!
- Ford 9" question...
- Stock replacement U-joint??
- No OD and getting code P1870
- ~~~~Help me, axle stuck in diff~~~~
- Need HELP Diagnosing sound!!!
- Moser 9" with ABS/Traction control?
- 2 series carrier question, are the "thick" gears stronger?
- Which gears are stronger for 10 bolt, the series 2, or series 3?
- gear change
- Is DRILL OUT MOD applicable to LT1 or is it just LS1 mod???
- shift kit
- mid west tc....
- doing 120mph and tranny breaks
- Anyone have step by step instructions for doing an A4 to M6 swap?
- Rear Diff Question. It has been leaking but isn't low... HELP
- Help: Differential fluid very low: What do I use?
- Bent driveshaft???
- How about a SFI approved flex plate????
- gear ratios
- Who builds a STRONG 4L60E...
- HELP ASAP
- Rear end out of line after 12 bolt???
- Tranny and D.S. length issues...
- How many Zexel-Torsen failures??
- when does stuff break?
- Ready to order12-bolt, options???
- How to get axles out???
- shift kit
- question about slave cylinder
- Tight spot in rear end.
- ATTENTION: SIG LENGTH LIMIT!!!
- Getting a weird growling noise when I turn right
- Slips out of 3rd, why?
- Any known problems with used ripppers?
- Which Driveshaft Loop ?
- Have a wierd problem and nobody knows the solution...Need Help!!
- broke my bellhousing
- help bad vibration at wot at about 70
- moser 12 bolt tighten preload bolts to 5 or 10 ft lbs?
- Which is better?
- How do you attatch torque arm with T400 swap?
- 4.56's in a 12 bolt, anyone not have a howling banshee?
- convertor / gear choice for street use
- Rear End Gear Swap - DIY or Pay The Guy?
- Rear-end noise while cornering hard...
- Detroit locker...
- G2 aluminum D.S.
- New 12 Bolt on the way
- 3.42 vs. 3.73
- Where to get an Aluminum D.S from??
- 2002 '767' Upgraded Slave ??
- How long for a Moser 12-bolt???
- How much for a trans. rebuild?
- Torque Arm problem. You will laugh cause it didn't happen to you.
- moser 12 bolt w/ ta cover what to torque preload bolts to?
- Need Transmission Parts Thanks To Poor Workmanship
- Best Place to buy 12 Bolt
- How do you make the stock 10 bolt last
- moser 12 bolt w/ ta cover leaking what gasket? bolts?
- Best Aftermarket TQ arm?
- WTB t400 for 97 z
- Tranny Fluid???
- Need help with T/C lock-up switch
- Moser 12 Bolt 4.10's or 4.30's?????
- How much of the slip yoke needs to be in the trans?
- Slave Cylinder under Warranty?
- Moser 9" 3.73 Howling
- thumper?
- really bad shutter problem....help??
- Posi or not???
- Please Help!
- Calling BLU11SECTA.
- 12 Bolt break in period
- Moser 12 bolt 1350 yoke Spicer U-joint???
- Moser 12 bolt 4ch fitting??
- 1st impressions of RAM 402/6130
- lowered car now rear is too far fwd..wtf
- Which gears for TCI Super Street Fighter?
- 99 HOE tranny problems
- TC AND GEARS?
- Need an Opinion Please
- all 10 bolts suck
- Tranny noise between shifts
- Help with gear setup?
- speedo troubles!
- Drill Mod ????????
- Anyone have a stock TQ arm mount.......
- BEST REAR??? Opinions PLEASE, good and bad.
- Gas pedal problem HELP!!!!!
- TC install Problems!!
- How to make stock master cylinder - Adjustable?
- General Question
- If you go between 1st & 3rd...
- TC 's and speedo readings
- Strange 12 bolt help!
- 4:10 gear noise
- Gear Recommendation: 421rwhp/400tq N/A 540hp/590tq N2o
- Anyone using the 8.5 inch 10 bolt rear?????
- LM Performance is selling the Qwik Stick
- what driveshaft are you guys running
- Broke my 12-Bolt!!!!!
- Rear End
- 3.90 gears
- Anyone know where I can find the line from the master to the slave.???
- Just ordered PT4000 - have a question...
- 1/2" studs with stock 16s
- My Pro-Stars won't fit up front w/ my new AutoZone brakes, why?
- Swapping the Gears in a 3.42 C5 carrier
- Broken wheel stud im a dumbass!
- 3.5" vs. 3" driveshaft...
- How good/bad is the stock rear end?
- Genuine GM 3.73's
- Does descreened MAF cause TC chatter?
- poping out of 5th
- How to us Spohn torque arm with moser 12 bolt
- Shake, Rattle, and Roll
- ST4000 vs TP4000
- Need unbiased info on using 3.90/4.10 in C5 CORVETTE..is it safe?
- Another TP4400 question...
- Cheapest place to get a modified stock adj m/c?
- need help
- Anyone here with TP4400 and 3.23s?
- Shifters??? what kind?
- What rearend do I have
- Paging *stick only* (MIKE)
- Master Cylinder Question? Question
- Which master/slave cylinders? 2000 car
- Wheel Rim Screws
- Noises in the drivetrain, take you best shot!
- Another gear ?
- TC or Gears?
- How can I make a lockup switch?
- STR differances????
- Which Rear end do i have?
