View Full Version : Gears & Axles
- What gears should I run
- which rear?
- what will 3.42 give me over 3.23s?
- What are the odds of me breaking rearend with.....
- anyone use b&m synthetic trick shift?
- Update on my RAM 910 VDS chatter problem
- Moser 9" Gear Selections
- 4:10, 3:73 RPM range
- Anyone have a TCI convertor and N20
- Rev Lok II came apart
- Problems with SPOHN TQ arm?
- transmission lines
- Anyone have a TCI Super Streetfighter TC
- T -56 HELP
- TCS on a rear end??
- Stupid Updated hydrolics question...
- TCS Module
- New Product - Urethane Motor Mounts
- Rearend question
- Moser 12bolt T/A problems, Solution....
- RPM's at speed with 4:10's
- need new rear
- Moser 12-bolt Torque Arm Bolts
- Yank vs Precision Industries Vigilante
- Upgraded hydralics? were do you get them.
- Who sells the lakewood D/S loop?
- 3.42 or 3.73 or 4.10
- Broke my 12 bolt again
- Spec III Do i still need shim
- WTF?!?! Hitting rev limiter between 2nd and 3rd at WOT and won't shift
- spec 3
- Broke Driveshaft & 12 Bolt at TR Shootout!
- Driveshaft loop, that fit's with MAC headers on lowered car? Which one?
- Found a potential geometry problem with some Moser 9" fords
- traction control
- SLP girdle....99bucks..
- Will a....
- metal in tranny filter?
- If you have changed your shifter--Please Read!
- please help>>>>>>>>>>
- What could cause a trans to rob power?
- Need help read within!
- 10 bolt w/ 4.10's and 420RWHP
- Ticking sound coming from passenger rear....Axle bearing?
- rearend whine
- Slip Yoke Depth
- Broke Torsen and lost 3rd/4th
- Diagnosing Trans Issues
- PY3400 is the Bomb!
- 12-bolt/9inch guys..... check your nuts! (seriously)
- BOOMCASE
- Something feels like friction in my drivetrain...
- ABS/TCS rear /ABS only rear
- 1998 T/A rear-end: will it fit in an '85 Camaro???
- Ahhh!!! Need Traction Help!
- Daily Driver, what set-up
- McCleod Revlok II ABSOLUTEY ROCKS
- what times can i expect with 4.10s?
- C-Clips ??
- Anyone with a M22?
- lakewood sfi scatter shield????
- shifting problem
- which brand gear???
- Loud bang
- Tranny troubles, please help
- Figured out what was wrong with my car. Now need some suggestions
- Is it worth going to 3800 SS from PT4000 ? with this setup
- 12 bolt v/s 10 bolt
- Using Chris Alston's Fab9 rear??
- 4:10s in a 10 bolt YES or NO
- Aftermarket axles for a 10 bolt, suggestions
- My skinnies won't clear my new brakes, should I go with a BIGGER spacer?
- 4.10 gear accessories
- How Much $$$$$
- Check out this 6 speed article
- 26" Slicks, 4:10's perfect for 1'4 mile
- Can I see your pic of your LOCK-UP Switch?
- Any rear axle powder coating pics?
- Should i do gears or not?...
- RAM 910 VDS started chattering... BAD.... need some suggestions.
- quick help please......
- Paging Kevin Winstead
- 3.73 vs 4.10 for gas mileage?
- Are you SURE I have posi??
- Top speed in each gear with 4:10 gears?
- Part numbers for 4.33 gears for 12 bolt?
- 3.23 car upgrade 3.73's or 4.10's?
- Doing it bass akwards
- Gear advise
- How much ET am I losing with my 4.30 gear?
- 245/75 vs 265/75 HD2500?
- 4.10 OR 3.73???
- Gear noise, please help!!!!!!!!!!
- Need advice on trans
- need part numbers for ten bolt and all parts within it
- A3 users: What Length shifter cable?
- auto powerglide?
- I have a Dilemma?
- Why is my pedal sticking to the floor?
- Need Tranny help ASAP!
- kirban shifter questions
- Am I right?
- rear problem?
- 10 Bolt Idea...
- to go from carrier 2 to 3, or not to go?
- For those with a Strange 12-bolt - what is the 1602 yoke?
- Drive shaft issue
- Transmission ? please help.
- narrowed rear question...
- gear slipping...what is it ?
- NEED Part # for ABS/TCS Reluctor rings, Pronto!
- Need a new tranny! What kind?
- STOCK DRIVE SHAFT??
- Driveshaft
- Parts list for tranny conversion! please help
- need bell housing info and pictures
- U-joint question
- 4:10's & 3:90's Pros and Cons
- More on Pinion Angle
- Going to 4:10's... Advice?
- Will The Trans Handle this? Please help!
- Gear Change
- Read every wheel hop thread and still no answer? Please help
- Will G2 torque arm fit a moser 12 bolt???
- Chrome lugs for 12 bolt rear
- Finally thinking about getting rid of the 2:73s.
- noise from a aftermarket shifter?
- Anyone using a Currie 9" Rear?
- 12 bolt build up
- spohn torque arm and 9 inch rear
- What carrier? How can I find out?
- Went from 323's to 373's. Have ?'s
- Going from 9 inch back to stock... have some ?'s
- What differential would a '97 Z28 have...
- Tranny probs. Need answers!!!!!!!!!!!!!!!!!!!!
- carbon driveshafts???
- P0740 TCC Enable solenoid circuit-electical code
- Popping Out of 3rd
- What breaks in the factory 10 bolt??
- blown motor...does that equal bad trans???
- Interesting info on Pinion Angle
- Rear end making noise, Any ideas?
- At what point should you upgraded the driveshaft
- looking at getting 4.10's have some ?'s
- transmission questions HURRY!
- Ring & Pinion Upgrade
- how would size of the rear end gears effect horse power and your torque ?
- will a 98 trans fit an 01?
- Strange 12 Bolt Fluid
- Conv. shudder with cam? Whats up??
- 273s to 342 ?????
- 28" tire gear ratio question.....
- Detroit Locker on the street????
- need advice on TC
- auto trans options
- My baby fixed!
- Pinion Angle please help
- Ram 6130 or 910
- Who uses a Ford 9" in their 4th Gen F-body?
- Anybody actually dynoed 10 bolt -vs- 12 bolt -vs- 9" drivetrain losses???
- Cleaning out the pumpkin...
- Buying Gears Question
- What are symptoms of a bad axle bearing?
- Another mosier 12 bolt post : owners inside...
- Do I have a problem?
- Need help ASAP Moser 9" wheel stud question
- SPEC S4 failure at High RPM racing
- Question about Ram discs-910 or 6130?
- Whining noise????
- How much noise are 10 bolts supposed to make?
- weak rearend??
- Opinion Needed
- Rear End Banging
- Thinking of going from 2.73 to 3.42...what do I gain in time? Lose in reliability?
- who is using GM 5 PINION PLANET ASSEMBLIES
- Quick Question
- Stock axles power limit??????
- Where is my ABS sensor located on pumpkin?
- Clunky Moser 12 Bolt
- Danny Miller Rear Gears
- Rear End Whinning
- Rear End 101
- I have two ?'s
- tranny problems or pcm problems?
- Getting a Trans Am, Need opinions?
- Can I get anything between...
- Car vibrates at high MPH in 6th gear.. Is this my Torque arm?
- Speedometer pulsates
- Help with gear swap
- Need some Help
- Urgent Need Help w/10 bolt sensor...please see inside.
- Manual transmission queston (Rookie)
- traction
- traction
- Why is my Moser 1310 yoke u-joint smaller than my 10-bolt?
- Is there a reasonably quiet 9" or 12 bolt? (LONG)
- Control arms for upgraded rear axle?
- Question for those of you running the Cheeta shifter
- PLEASE HELP!
- TRADE NEW 4.10 FOR NEW 3.73
- TH-400: Full Manual, Full Automatic or Both?
- Stocks Trans LIMIT
- Went to the track last night... two drivetrain issues to report.
- Will the lakewood DSL Fit with BMR Track Pack?
- 4.10's or 3.73's
- built tranny break in?
- built tranny? what type of tranny fluid you use?
- Will the "767" slave fit the LS1?
- shifters -- stock hurst w/lss vs. 5.0 vs. other
- Solid ponion spacer questions
- AHHHHHH My axle fell out while driving!!!!!
- HELP! HELP!
- twin disk and street driving
- Stronger 10 bolt ???
- Calculating MPH & RPM with 4.30s & 26" ET Streets
- Will a 95 10 bolt fit in a 99 car
- rearend bearing cap bolt torque specs
- Rear Dif and Tranny Fluid
- help me decide on gears
- 4.10 Gears
- Need help. Longer wheel studs, and open end lugs
- what posi with 3.73?
- change rearend gearing
- 3.23 to 3.42 swap..how much gain?
- how to remove tranny? (reply asap)
- TP4400 is in!!!!
- What to do...Moser sent wrong gears in 12 bolt
- Ford 9" questions
- Tailshaft houseing
- PT 4400 or PT4000
- Kirban shifter....anyone
- Formula to figure rwhp loss with.....
- Simple Girdle Question
- 6k launches on a STOCK rear???
- Can you put a 5 speed automatic into a 01' WS6?
- AARRGGHH car wont shift good!!
- what happened to 3rd gear!
- RAM 310 organic disk OR 6130 metallic???
- Why doesn't the Moser 12-bolt Performance cover have no magnet?
- The frustrations of stupidity
- Remove or not remove?
- Opinion: Shifters w/stops helpful or not?
- 2 series or 3 series carrier?
- Torque Managment!!!
- Where can I find Axle Reluctor Rings (ABS/TCS 4-channel)?
- Don't need to break, please help!
- Tore my carbon fiber driveshaft...maybe tranny damage too?
- Auto->Manual Tranny Swap, need advice.
- Is there a diff between a hex head and a allen head?
- Need Help-Do It Yourself Automatic Tranny Flush????
