View Full Version : Gears & Axles
- Old question....need fresh opinions.
- where to get royal purple
- 1300mile m-6 rebuilt already??not my fault!
- Can hot tranny/fluid sets on the PCM code?
- 4.10 SOTP difference??
- putting a 3 channel abs rear in a 4 channel TCS/ABS car?
- Will Z06 tranny bolt up in a F-body
- all of a sudden it's hard to put into Reverse!
- Driveline experts please help me out!
- Anyone know the mathmatical forumula for...
- how to cool down my tranny?!
- Is there a break in period for new trans?
- Rear End Fluid Change
- What is the size and type of the side fill plug on the Moser?
- Anyone gone from 3:73 to 4:10??
- are any rear end noises normal??
- What's the Difference -- 1310 vs 1350 Yoke?
- What are "C" Clips?
- How hard is it to replace 3rd-4th shift fork assembly
- Reuse pinion shim or new shim? 4.10's
- WANTED A 12 BOLT OR 9"
- Moser 33 spline worth the added cost?
- TCI 4400 track results
- Going to 4.10's from 3.73's feels like another 30HP!
- Thinking of a spool in my 9". Will I need new axles?
- Torque Specs for Bellhousing bolts please?.....
- Rear End Post-Mortem
- Need a part # for Moser axle tube seals
- Is this busted rear end?
- Trans and rear-end vibrations are nuts over 100!? HELP!
- Gear break-in recommendations
- Enlighten me as to how the F*CK this happened (MOSER pre-load bolts)
- Which is Faster? Manual vs. Auto
- driveshaft
- Help...Cant dissconect Transmission from Engine!
- which thirdmember
- 4.10 gear is in, reporgrammed with edit but something doesn't look right
- driveline strength
- Axles bearing press rings.....
- Need a complete manual trans
- How much power will it hold??
- Trying to figure out gears!
- Anybody using bolt-in BMR relocation brackets on Strange 12-bolt?
- What is "adjustable" about an adjustable master?
- pinion seal on Moser 12bolt
- will my chatter go away???
- P0757 Code (can only use second gear)
- Anyone running a spool with 4ch ABS???
- What type of tranny fluid and filter shoud I get?
- alum driveshaft from 12 bolt back to stock
- I guess there is no warranty on the Moser... what breaks on these if anything?
- 4.56 Gearing
- ne1 used a ford 8.8(mustang rear)in their f-bod?
- Moser 12 bolt noise. What's too loud? How do you know when there is a problem?
- Moser Prep
- Will a 275-60-15 Nitto fit?
- Mount your torque arm directly to trans x-member
- Do Mosers come painted?
- Has anyone tried the Qwik Stick.?
- Rearend swap... what is involved?
- Motive Gears
- what ever happened to the ST4000 guys?
- Any modifiactions for a moser 12 bolt?
- new gears
- Stock Rear End
- Who has 4.56s, and what is your combo, ET, MPH, RPM, etc.
- rear end poping?
- help and advice needed, just broke new 4.56s after THIRD launch!
- Paging PSJ and others...(Locker question)
- 3.73 or 4.10
- tranny
- how big gear?
- Anyones driveline feel loose? Mine does HELP
- Gears
- Quick ? about differentials...
- Me and My TCI
- How to tell what gears in moser 12 bolt
- Rear End Noise
- TA cover...worth it? Or waste?
- On average, at what HP/TQ should I start worrying about the 10-bolt.
- Hey Weather guy
- Where to find Denny's driveshafts?
- Difference in RPM's after I shift between 3.73's & 4.30's
- Does anybody have a Dennys Heavy Duty Aluminum Driveshaft? Have you broke it?
- HELP: wierd vibration from transmission at idle
- H/D Aluminum Driveshaft or Carbon Fiber???
- 3.90 gears????
- what series carrier
- PLEASE, help me choose a gear
- probs w/series 2 carrier ricmonds? 3.73's
- Extra cap. truck trans. pan P/N??
- 400/350THM low cost swap.
- What the heck is this??? (Jason, you might be able to figure this one out)
- Manuel Lockup switch
- Transmission Problem...
- How would this affect my driveshaft?
- Anyone have their tranny rebuilt by D&D performance?
- Are you supposed to tip the 12-bolt delivery man?
- ? on 2 series carrier
- T/C and higher miles?
- Derale or TCI Transmission Pans - Who's got one?
- Please recomend a cluch (explain why)
- Mr. Tightwad here...
- ? weight gear lube for Strange 12 bolt
- ST3800 vs TP4000
- Moser 12-bolt for sale at dealer cost!
- TP4000 vs. TP4400
- Situation...
- Adjusting Spohn TQ arm?
- Difference between spool and mini spool
- 430 gears do i need 5 th gear in quater
- Will my transmission blow
- Trans Pan Torque Specs?
- Energy Suspension Tq Arm Bushing & Tranny Mount?
- Moser 12 bolt guys!..need answers please...
- I'm gunna try to get rid of the noises/vibrations.(joints and tranny mount)
- Hardened but STOCK lenght studs?
- YANK 4400 on the street?
- what's the difference bewteen alum and steel driveshafts?!
- Bellhousing??????????
- 6 speed automatic?
- Can't powershift, WTF????????
- won't go into 2nd, 2th, or 6th...?
- Would a 1" taller rear tire wreak havoc on ABS/TCS???
- normal pro5.0 noises or not?
- best torque arm for drag racing
- unknown part, I'm guessing transmission
- 9" moser rear and spohn torque arm
- New Transmission ... break in procedure?
- Napa #447.... I got it, and it has a grease fitting... is it the right one.
- B&M Shift Plus
- Auburn Pro-Series v/s Torsen Zexel Unit? Best Price for Auburn?
- ? about odd p.p./disk wear
- help...I think my new star stage 3 is slipping
- Lockup switch: What's the deal?
- Why do I have to hit 5th w/3.73
- Borg Warner Transmission? help
- Speedometer Problems
- regearing questions here
- TCS/ASR Questions
- Changing to Auburn Posi in my '01 - what type fluid?
- Giving up on search, Stock Aluminum Driveshaft and 1350 yoke Question
- plug on differential
- slave cylinder tbl??
- gear at the line
- Swaybar hitting 9" torque arm mount
- Did I avoid transmission death?
- Help..spohn torque arm is thudding
- 6 speed shifter Question
- How can you tell a Stock or Z06 disc is shot?
- Building up the 12-bolt vs. buying a ford 9''
- Torque Management
- Buy 12 bolt or upgrade 10-bolt and use extra $$ for mods??
- Why is the Spec 4 not recommended for daily driving?
- Which 12 bolt is the best and quiet...pros-cons?
- Why can't my tranny shift in to 3rd?!?
- 4.10 -> 3.23 swap, what will happen to my shift ext?
- Moser 12-bolt brake question..
- 4-L65-E is in the H2 what is it.
- How would you make 4.30 gears work using a HPP3?
- Currently... where can I get the best deal on a Moser 12-bolt
- Is anything worth a crap on our cars??
- synthetic in the transmission?
- faster downshifts
- Transmission question
- What's the part# for the 1LE tranny mount?
- how long for moser 12 to ship
- Is this a good price for this work?
- Changing Tranny Fluid?
- Add me to the "stuck in fourth" list.
- Help adjusting master cylinder?
- Slow Leak from rearend
- trans help please
- 6-spd down shift problem
- SFI Bellhousing and Scatter shield?
- Moser quality???
- Thumping Noise....Need Help
- SNAPPED DRIVESHAFT W/ 12BOLT MOSER
- WILL HPP3 HELP TORQUE MANAGEMENT???
- Need REAL QUICK answer on tranny filter seal!
- Anyone running this 12 bolt carrier??
- Question about 3.73's
- Will a ACPT Carbon Fiber Driveshaft fit with a Moser 12 Bolt with a 1350 Billet Yoke?
- All heads together on this question please
- Axle bearings
- Well, its decision time, 4.11s, 4.30s, or 4.56s????
- What would make a brand new tranny get stuck in 4th gear?
- Vibrations?
- 3.73 or 4.10 Gear
- Ratech Solid Collar...
- How loud is a 9" supposed to be?
- Paging Fireball
- really weird situation with broken rear
- Chattering coming from back of the car
- How much whine is normal?
- limit
- Nitrous & High Stall TC - No Lockup?
- would I need a 12-bolt?
- 9" with Auburn and U-joint help!!
- Moser 12-bolt in stock!
- Anyone know anything about the 5L60-E in the Catera
- Why non-synthetic gear oil in my new 12 bolt !?!?!
- What is involved in swaping to a 350T?
- what can i do?????
- Transmission or Gear Growl: Anyone else?
- Need to get intouch with Star/Spec
- To gear or not to gear?????????
- how much should 430s help me
- 6 speed shifter
- 5-speed auto in new trucks?
- How can I use ATAP to check if tranny is slipping?
- One wheel burnout =trans stuck in 2nd??
- rear end problems
- Master Cylinder Mod
- 12 bolt bearing HELP asap
- Need some info please...
- @#$% rear end cover leaking again
- Scattershield
- Gear change question...
- Trans leaking at U-joint?
- Rear-end Question???
- Have Mac reinforced cover for 10-bolt, what do I torque the bolts to?
- going from 3.73 to 4.10, is it worth it.
- having problems and dont know where to begin
- Shifter Help???
- I need help!!! ANd some reason the back tires locked up and i went spinningeverywhere
- Spohn torque arm setup help
- Need part # for pinion seal?
- Speedo/tach off after 3.73
- Mobil 1 vs. "Dyno" for MN6
- Gear "?"
- shift kit ?
- Tranny problems
- RAM INFO
- I think GM lied to me..
- Ford 9" vs. 12-bolt questions?
- 4.10's in a ten bolt?
- GM oil aditive.
- Trans shifting a little too hard.
- Hey Joseph....? for Ya....
- Need help guys , anyone currently have their tranny out of the car ?
- Rear Diff Cover, need help. *URGENT*
- what is the best way to bleed slave cylinder
- do you people help others with their questions or just ignore them?
- GM Factory Replacement Gears?
- 4.10 and locker or posi?
- Blowing up the Bellhousing, Disc flying apart, pieces coming out thru the windshield
- Dyno results on 200-4R (motor and spray)
- 02 Z06 slave
