PDA
View Full Version : Gears & Axles
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 [98] 99 100 101 102 103 104 105 106 107 108 109
  1. who sells the lous short stick???
  2. Why does my car sound like old people ******g?
  3. how long will stock tranny last w/heads and cam?
  4. Shift kit or no?????
  5. Met the Colonel this week...
  6. Opinions needed please......
  7. Who here has changed out their tranny gears for more agressive ratios?
  8. Correct length driveshaft 400-12bolt
  9. How strong would this 10 Bolt rear be?
  10. Pulled out my Ram 402/6130 after 4K miles.......
  11. Build sheet and Door jam codes for gears
  12. Rear end torque specs needed
  13. lou's short stick feedback, yey or ney
  14. 12 bolt questions, need help please!
  15. Believe it or not, I need MORE 9" help.
  16. Y'all notice the "Pros" take on stall TCs?
  17. Gear question
  18. Interest in a built 8.8 for your F-body
  19. How do you shift your auto
  20. Today is the day for a Strange 12 bolt
  21. 3.23 to 373s
  22. Centerforce dual friction
  23. Anyone running aftermarket axles/posi units
  24. Your DANA did WHAT?
  25. Truck trans slipping on the 1-2
  26. How to test pinion drag torque
  27. Final Word on Poly mount?
  28. Stock Trans Am Weight
  29. Loss of traction and bad wheel hop... need help!
  30. 3.42s, 3.73s, or 4.10s??
  31. Tire Height ????
  32. whats the best 60ft you have cut on a stock 10 bolt?
  33. Whos drive shaft are you running
  34. Woo Hoo 4.10's are in!!!!!!!!!!
  35. Tranny problems!
  36. 12 bolt question, please help?
  37. Lost 3rd and 4th gear
  38. Dyno Question
  39. Some info about drill mod..?
  40. BAD vibration at WOT
  41. WOO HOO!!!! Ordered my ACPT CF driveshaft
  42. Clutch In, Revs Down
  43. Transmission Swap!!!!
  44. 10 bolt spool Q/Idea
  45. aftermarket axles for 10 bolt?
  46. LPE Drive Shaft
  47. how many shims did you use on your RAM CLTUCH??????? HELP ASAP
  48. Padle Kit for 4:10 Gears
  49. Anyone running longer torque arm bolts in Moser 12 bolt?
  50. All those w/ a spool, come in...
  51. What brand gears?
  52. need advice!
  53. is there a write up on a rear end swap?
  54. Tranny Swap
  55. Where to find best price for rearend?
  56. Hitting rev limiter
  57. Torque tube trans and gearbox from 98 vette???
  58. Denny's Nitrous Ready shaft on sale
  59. 12 Bolt to 9" driveshaft
  60. Good Cheap DS Loop
  61. Just ordered a 402/910, did I choose the right disk?
  62. Art Carr Transmission??????????????
  63. What's the best 12 bolt to buy?
  64. torque management !
  65. TCI streetfighter
  66. 3:73 GEAR RATIO
  67. 3.73's to 4.10's, how much et did you guys gain
  68. Bad idea ?
  69. Detroit Trutrac or soft locker???
  70. Opinions needed
  71. Rapid Motorsports Master Cylinder?
  72. whats with this noise?
  73. Straightening A Bent Axle
  74. Transmission SWAP
  75. 10-bolts suck! What next?
  76. what cluch is a good buy
  77. DriveShaft
  78. do all SS's come with torsen rears?
  79. pro's and cons and lca and swaybar relocation brackets?
  80. 3rd gear is good up to what mph?
  81. Power loss through a Ford 9"?
  82. tranny fluid
  83. How can I tell...
  84. Help please!
  85. bleeding process question...
  86. Gear shop needed for Ford 9" in Atlanta
  87. Drive shaft
  88. Fireball...how about a Strange aluminum Daytona-style pinion support?
  89. Jericho 4 speed? Whats the scoop on this for an LS1?
  90. Gear Shop Recommendation for Dayton, OH area
  91. 8.8 REAR ENDS
  92. Best differential??
  93. Aluminum driveshaft question
  94. What's the smallest tire I can safely put on my factory 17x9's for the winter?
  95. Pilot Bearing Failure Experiences?
  96. sloppy and notchy shifting when trans is cold?
  97. Good 12-bolt...is there such a thing?
  98. posi rear end or not?
  99. 12-bolt weight vs. 10-bolt factory weight.
  100. ? on B&M hammer shifter
  101. Tire help quick!!!
  102. How do you open the side fill hole on the Moser 12 bolt?
  103. shut down?
  104. TH200R Conversion questions
  105. High HP Auto trans which one?
  106. SPEC 3 Ceramic Ordered (Ceramic vs. Carbon?)
  107. what would you do?????
  108. stupid question
  109. drive shaft
  110. How to check pinion angle without a lift
  111. HotCam or Comp Cam?
  112. Anyone use a Torsen T2R?
  113. SPEC 4 Disc Material? Break-in/Daily Driver?
  114. LT1(383) and PY3400 problems
  115. I've got problems...need help building a new drivetrain...
  116. Carbon Fiber Driveshaft: PST or ACPT???
  117. Who makes the stock diff in our car?
  118. 2.73s to 3.42s?
  119. is a strange as strong???
  120. non stock rearend?
  121. ? about Tranny removal????????please help
  122. help changing trans fluid ..I have the pan off now..
  123. Tranny slipping? How do I know?
  124. Got my rear today, its Strange with 3.90s in it
  125. I broke my car
  126. please someone.......
  127. Drill mod for Master cylinder, works???
  128. Help! Can't decide on gear?
  129. 12 bolt or 9"?????
  130. Nitto tire size question?
  131. transmission went buh-bye, what next?
  132. th-375/350 drive shaft length
  133. Whats everyone putting in their 12 bolt w/ Eaton HD?
  134. lsd, posi or whatever....
  135. ford 8.8???
  136. Pics of my new LPE driveshaft (warning big rear users)
  137. Spohn Torque Arm
  138. vibrations at 2000-2200 rpm ???
  139. How do you tell what rear differential you have???
  140. Lingenfelter 3.5" DS users: What DS loop are you running?
  141. Adj LCA?'s
  142. Moser 12-bolt: A Work of Art
  143. Anybody know of a transmission jack for the floor
  144. Redo carrier bearings when redoing pinion bearing? (99Tahoe)
  145. Is there an easy way to shorten a stock DS?
  146. is this how to do it????
  147. Here they are, SS3800 track results
  148. Strange v. Moser
  149. Tranny problem or tuning problem?
  150. Shift extension question
  151. Can a stock rear-end handle Drag Radials
  152. {{{{Boomcase}}}}
  153. Help selecting gears!
  154. Help - Loud clanking in the Rear
  155. tranny help
  156. Pro's and Con's of diffrent auto trannies
  157. Pinion Angle help please....
  158. Positraction Question
  159. Please help - contents of a 10 bolt STOCK firebird rear...
  160. is this a good idea?
  161. 3:73s or 4:11s?
  162. Help one last time...almost done! U-bolts?
  163. where can I get a new 6-speed?
  164. My new Ford 9" for $1800!
  165. Those in the Detroit area:
  166. Could I damage anything by dong this
  167. paddle shift
  168. Help need ASAP: How to remove axles from 9 inch?
  169. need some questions answered
  170. Does Tire Diameter Effect Dyno Readings???
  171. Strange 3 months old leaking fromthe axles tubes, is this BAD?
  172. Help Needed: w/12-Bolt & TA Cover
  173. How to carry your Auburn diff in a ZipLoc bag...
  174. Need Help Please
  175. What is STR correction?
  176. LT1 vs LS1 TCS Axles???
  177. ST3800 owners......
  178. Longer wheel studs?
  179. Ford 9" users inside please...
  180. Amount of fluid for a moser 9" change?
  181. How do I change rear end gears oil?
  182. damn moser 12 bolt leaking at pinion after three days...
  183. how much can the factory rearend take???
  184. 2.73 or 3.42?
  185. SS3600 or 3800 w/ 3.73's ?
  186. High Rpm Launching
  187. Rearend Question
  188. Big thumbs up to RAM
  189. I have a idea, but need some specs first
  190. Should I go with 3.73's?
  191. rev limiter with 422?
  192. best torque arm for the buck???
  193. Will my 3.42 gear work in a impala?
  194. NOISEY WHINE WITH A MOSER 12 BOLT??
  195. Tranny pops out of 3rd gear at low rpms!!
  196. Strongest 10 bolt gears
  197. got it
  198. PT4400?
  199. What Gear Do I Have !?!
  200. What gear?
  201. Anyone using the Qwik Stick?
  202. Patrick G...SS3600 or SS3800 for my car?
  203. moser 9"
  204. New guy needs help!
  205. Why "updated hydraulics"?
  206. Steeda Tri-ax
  207. will a 2.73 geared 10bolt work for now?
  208. Rearend Girdle Help? Please
  209. 02 Slave part #
  210. KTRE or Currie
  211. rear end fluid
  212. Transmission rebuild ??
  213. What gear ratio do I need to run?
  214. Drill mod for 01 or 02, is it necessary?
  215. tranny slipping
  216. MTI or THUNDERRACING
  217. Did I break my rear end...??
  218. ? about transbrakes
  219. Poly Trans Mount ???
  220. Popping noise from the rear end?
  221. Can you put 3.90 gears in a 12-bolt...
  222. Broken RAM 402/6130 setup
  223. What driveshaft loop does everyone recommend?
  224. Removing Traction control
  225. BAD SHIFTING STILL
  226. Nitrous and H/C + 3.73???
  227. Differental Question
  228. Rearend snaps hard sometimes
  229. Wheel bearing or rearend
  230. Trans & Diff fluid change
  231. Shifting difference in D and OD
  232. 3.73's from 3rd gen, will they work in 4th gen?? Gear suggestion also
  233. anyone have an Auburn in there 12bolt?
  234. Needing a Performance Comparison between the TCI 4400 and the YTP4400
  235. First drive train mod???
  236. Another 9" question...nodular center section?
  237. Is anyones tranny shifts/doing the same here?
  238. Shift Kit
  239. If I had a 9" with an Auburn posi and I wanted to put a spool in it...
  240. Break in period for gears
  241. spec III problem?
  242. Part number for 4.56 gears for 12 bolt
  243. would this help?
  244. How to quieten shifter vibration
  245. Will 3.73's benefit me with my 224 cam??
  246. SPEC stag 3 how to break in
  247. Why not use overdrive???
  248. 3:73's or 4:11's- need help deciding which to use?
  249. U-Joint for a 1350 Yoke/12bolt???
  250. shiftkit ?
