View Full Version : Gears & Axles
- 12 Bolt Moser Question
- Gas tank clearance with 12 bolt - WTF???
- 02 Rear in 96
- Anyonw want to trade TP 4000 for ST 3500...
- From 2.73 to 3.42, what kind of mileage losses?
- TC for A3, which ones are being used?
- What Next?
- Help adjusting the torque arm
- Tranny Fluid???
- Jason 99 TA...Phoenix Injector ?'s
- Denny's or Carbon fiber DS
- Lou's Short Stick?
- ABS
- HELP! NEED spohn new style torque arm! what's this flow tech ta?
- Anyone's DS loop hitting the weight on the driveshaft
- 9" with 2" taken off each side!
- 97 rear in an 02?
- 1LE Trans Mount People quick question
- Cheese with that gear whine?
- A quick rearend question...
- What do yall think..Will My rear end Hold??
- Does anyone have a?
- Need tranny help please
- Twin disk roll call......
- posi rebuild kit???
- Remaining Adj. Master threads...
- Who's running a YTP4200?
- Torque Management?
- Can you make a 4 channel ABS 12-bolt work with 3 channel?
- Denny's driveshaft questions
- Does the stock torque arm have a bow to it?
- SLP Bolt In Subframe connectors
- Installing A TC Rear End in a NON-TC Car
- 12 bolt options
- 12 bolt
- Odd whistle noise from the rear...
- CRACKED my Moser 12 bolt housing
- TR224 and 4.30's ?
- Who has a Thruster Pro 4000? Whatcha Think?
- Odd high pitched noise .....
- Torque management experts, is this TM?
- can i get a measurement please???
- 3 Leaky Pinion Seals in 42K..Anybody Else?
- Rear sway bar Question...Off or ON??
- OPINIONS WANTED: ABOUT TO BUY GEARS.. WHICH BRAND AND WHAT RATIO?
- How much torque does it take to take the slop out of the pinion yoke?
- How to fix a Moser 12bolt leak at the end of the axle tubes?
- Torsen, which end is up on the c-clip retainer block??
- ARRGGHH!! Are ring gear bolts Righthand thread???
- What kind of combo would you use a UY6000 on
- Won't Shift Into 3rd At WOT Help!!
- STUCK... Where do I find the special bolts to hold the axles onto the rear (8 bolts)
- Looking for Kevin Winstead
- Is this a good price for a 12 Bolt?
- HPP3 shift firmness????
- TA that will fit with true duals?
- Ram 6130 did its job!
- Speedometer
- HELP Where is trans servo?
- V6 rear springs
- what grade rear end fluid should I use for my Strange 12 bolt?
- Shifting problems 2nd and 5th
- my moser only spins one tire!!!
- 410 Gears?
- Anyone seen any write-ups for replacing the Torsen diff?
- shift kit
- Cracks in rear end housing
- Maybee low fluid was my problem.
- 2001 Trans Am posi???????
- Thinking of taking out a personal loan for a new trans.
- How do I know if I have LSD?
- Remember that Ferrari shifter I was building? Here's where I am today.
- Differential fluid...mix?
- help!!! hypertech shift settings???
- Turbo350 with OD or better??
- Not again
- auto trans stuck in 3rd
- Spohn Torque arm with front and rear DS Loops -- BIG PROBLEM
- Do 4.10's pull harder than 3.42's all the way down the quarter mile?
- break-in period for 12 bolt?
- Return of the infamous driveshaft TINK
- Factory Shifter?
- Re-shimming backlash ?
- people w/ spohn torque arm...
- Alternative Diff in 12 Bolt
- Who makes a carrier shim kit for my stock rear??
- squeel sound !! help!
- 30'tall tire and 5.13 gears What do you think?
- How hard is it to do a gear swap
- need info on the new setup...
- Hurst Shifters?
- Do I swap to 4.10s in my 10-bolt or save for the 12-bolt?
- SHIFTER?????
- TP4400
- Rear end still leaks...
- Vibration
- Replacing Tranny Mounts
- 02's need skip shift?
- I win hands down!
- Did I get screwed ?
- Strange 12 bolt-is this normall?
- Spohn torque arm and SLP LT's
- 12 bolt/ 9inch drivability loss???
- Problems/questions with new 4000 stall TC.
- auto transmission won't downshift...any ideas?
- can anyone help me out with instruction on modifying a stock MC to adjustable??
- How to rebuild an Auburn posi?
- New Info on Solid Crush Sleeve
- TORQUE ARMS ??
- Whats the torque on the Strange U-bolts?
- Help? My Shifter Stick is spinning
- Need part #'s ASAP for deep tranny pan!
- Which is truly faster?
- Need a rear end for my 96Z28
- Opinions and suggestions for 'perfect drivetrain'
- Question concerning Differential oil weight
- Need part number
- need help picking a tranny???
- what will tp4400 do on n20
- What is it about power shifting thats soo bad?
- ??SHIFTER??
- Any idea how we could get a shifter similar to this one?
- how do i remove pilot bearing?
- Next step up over 4.10's with stock rear???
- how can you decide which TC/gear ratio combo to go with??
- suspension rattle
- Do I need to upgrade my stock tranny with these mods????
- 2800 Stall - Should I get 2.0 or 2.5 STR???
- 9 " OR 12 BOLT ???? PLEASE HELP??
- rear end is clunking bad- what are the chances its my axles?
- DRILL MOD
- PLEASE HELP!!!
- Need Help Please
- Please help me identify this noise.....
- Launching at the track w/a 6-speed
- Spohn Adj TA on lowered F-body....
- Ratio question?
- Built 10 bolt??
- Shifter stop bolt question
- Ported MAF+2800 TC = chatter?
- Who uses a LG toque arm
- Help with hop
- Why wse never talk how to make our new TCs work ?
- Anybody else try that thick Redline fluid yet?
- Auto driveshaft length????
- STR of Vig 2800?
- traction
- Location Of Speedometer Sensor on Tranny?
- Whats the difference between the nitrous ready and heavy duty driveshafts?
- Gear Whine question?
- Is there any way to build a strong 10 bolt?
- Looking for ABS on my Strange 12 bolt. "Sensor not on top of pumpkin" help!!
- 3.5 CF driveshaft----->
- TC lockup switch
- What Tranny filter and Fluid to use?
- Parking brake will not
- Interesting topic inside here!!!
- ALL 1LE Trans Mount Owners, Have youhad this problem?
- Stiffer 1LE tranny mount part number
- How much hp/tq can the drivetrain handle??
- trans stuck in 4th for 30 miles, WHY
- WTF is wrong with my rearend?!
- Who knows......? (fitting size question)
- Help needed.. How do you remove the axles off the 10 bolt?
- Ring gear bolt torque for '99 Z28
- The Truth about 12 Bolt Rears please...
- Has anyone broken a stock 2.73 rear? If so...
- Speedometer not working!!
- Won't poly trans mount mod change pinion angle?
- Car pops out of reverse (normal)?
- lt1 tranny in a ls1 fbody
- Why does my TC only lock right with the A/C on?
- Lost close to 100rwhp through drivetrain: What could've caused it?
- Transmission Noise After Gear Change?
- 28" slick question
- Question on BMR chromoly K-member
- moser leaks out of the vent tube.. wtf?
- ST2800 lockup
- Chatter going into OD under light acceleration-HELP
- Strange's website???
- what is unlock/lock TC?!?!?!
- **Pro's and Con's to 4.10's or even 4.88's?
- gear change ?
- Stock tire height of a 245/50/16 GSC ?
- bad vibration/clunking question?
- Where can I buy a poly trans mount?
- Need gear setup specs: pinion depth and backlash etc.
- TP4400 vs TP4400E
- Ragtop99 did good
- transmission problem
- Rev-lok II question
- 12-bolt prices
- Do we have posi-traction?
- What year TA had a performance shift switch
- HELP!!Loud popping/Clunking Coming from rear of car only when Im going slow?
- 4.10 and moser 12 bolt on z28...
- how did i crack my torque arm???
- Does anyone know if the stock LT1 torque arm is interchangable with the LS1?
- Any info on the better sun shell,input shaft,and planetarys?
- rear end problem? please help
- does anyone have gears that dont whine?
- Synthetic or regular oil with an Auburn?
- Anyone have a stock Torque arm lying around?
- Motive Gear Question/Problem
- Mustang rearend on f-bodies??!!
- 4.10 Help
- rear pinion seal leaks
- Hitting the rev limit
- I gotta slight problem.
- How do gears affect dyno?
- What is a drive shaft made of?
- DRIVESHAFT
- Chewed pinion bearing...
- Question for ALL LS1 owners
- Tranny and/or read-end clunk?
- 3.73 Gears What's the best to buy??
- Poll of how many H/C cars running TA girdle...
- Whats this hose?
- Driveline slack
- Stock to 3.73
- Simple and prob dumb Q
- PY3400E in a N/A car?
- Bad Seal? Differential leak??
- Questions regarding an m6 to th350 swap, gears, stall,etc
- CENTERFORCE DF......NEED HELP QUICK!!!
- What is the secret too......
- How much leakage in the differential is normal?
- Which Sliks?
- MPG loss........3.23s to 3.73s
- LOOKING FOR V6 ANSWERS!
- Will GM Synromesh work in the 6 speeds?
- Drag Radials
- Can someone tell me how to change out the Manual Tranny Fluid
- 2,73 to 3.42's....what do i need??
- 4.33's --vrs- 4.56's
- How much can a stock driveshaft take
- Question about Transbrakes
- looking for some chrome ZO6 WHEELS for my C5
- BMR K Member... How do you choose which one? Please reply if you know
- 9" vs 12 Bolt......
- How strong is a Carbon fibre driveshaft
- My 3.73's are in!
- need help locating some tools for the trans
- GEARS AND CARRIER QUESTIONS
- axle spline ?
- What RPM to lock TC
- Is the dealer trying to screw me? Please Help!!!!!
- I need a 12 bolt. Strange or Moser?
- HELP ASAP PLEASE! Can't connect the master quick fit to the slave cylinder!
