View Full Version : Gears & Axles
- 3:73's, Motive or Strange? Opinions Please.
- Tbyrne Performance Parts
- TH 350 dipsticks
- 4l60E removal and install instructions
- Will I break my rear-end if?
- Clunking noise when I repeatedly engage and disengage the gas pedal at low rpms?
- What is the Best RAM setup?
- Changing to 3:73's
- swapping from 4.10s to 3.73s
- Suspension upgrades?
- broken posi?
- How much fluid does a 10 bolt hold???
- How many broken 4.10s
- Is this normal?
- stock rear leaking?
- Warrenty Help
- Slave disconnect trouble
- 9" Rear End
- Slave cylinder help.
- Will I have to shift to 5th in the 1/4 with 4.30 gears?
- Please answer this question for me.
- Sintered iron and steep driveways....
- Royal Purple 85W40.... do I need the GM additive?
- Need Help Identifying Genuine GM 4.10's
- Moser 12-Bolt Performance Cover Bolts (one sticking out)...
- ANYONE HELP WITH GEARS!!
- Tranny moving?
- DS vibration
- code for gears
- posi???
- Pre Loading Rear
- Whats going on?
- MAJOR TRANNY PROBLEMS PLEASE HELP!!!1
- How rough is missing a shift on drivetrain?
- metco lca relo. brackets work on moser 12 bolt? weld?
- Is 3500 too much stall for a street car?
- Found someone to swap me trannies!
- Can't wait
- the best tran (AUTO)
- Ditching the 10 bolt for a 9" or a 12 Bolt...help
- Thorugh Out Bearing
- Hooking hard on the Street?
- Hydraulics shot?
- Switching from 3.23 to 3.73 gears
- t400 & 3.73's tach out in the 1/4?
- Help, gas pedal works when in Park but doesn't work when in Drive
- Shift Kit does it really help or really hurt???
- What gears do I need?
- manual shifting an automatic
- HELP?
- Anyway to do 2nd gear burnout in pre 2k cars??
- Wider 16" Rims
- 12 bolt with spool weight?
- Rear Gear Noise in a Convertible
- 12-bolt dripping some fluid....
- How do you check Pinion Angle?
- Another Ram 6130 bites the dust.....
- Knock Noise coming from Rear End
- Gears on Stock Rear End?
- Rearend Noisy. Is that Normal?
- Tranny went out.... question
- ET Streets on stock rear
- 2K silverado trans pan owners please come in
- What gears?
- What do you think.Th-400 all the bolt ons and 10 BOLT LAST WITH ET STREETS?
- which sway bar is better
- 3rd gear woes after rebuild
- Which one usually goes first??
- Beeffing Up My Tranny
- how much LSD additive in your 12bolt???
- 9 inch is in, but noisy
- Rear question
- Do SS's come with a Auburn carrier?
- What 12 bolt is better?
- Customer service @ Speed Inc.
- Is there a way to reduce gear whine.... cheaply?
- gear swap questions
- 4.10 gears????
- Will my rear handle this???
- SLP TC
- Shifting/Cluth Problems.
- 12 bolt Options?
- Motive 4.10's are actually 4.11's !!
- Gears
- $450+ dollars for second gears, 2 cones, and 2 shift forks?? WTF?!!
- 4.10's on a Torsion???
- Problems engaging 2nd gear
- Need some opinions...
- What usually breaks on a stock rear...
- **2001 WS6 gear ratio**
- Has anyone ever switched from a M6 TO a A4???
- How many quarts does my 10 bolt hold?
- what goes?
- Level 10 in latest HPP
- Are Moser 9 inch axles supposed to be different lengths?
- how to tell if master cylinder needs bled??
- Rear End Noise
- what type of a product...
- Diagnostic Codes????
- speedo help
- Nobody EVER had loud gears? I'm invisible? Just ignoring me?
- Is my rear end a 3 or a 4 channel ABS?
- SES light and ASR off all the time after TH-400 Swap.HELP!!!
- 10-bolt solid crush sleeve?
- Wanted: 10-bolt breakage reports
- Maybe the most newbie question ever!
- How do you know where to adjust the adjustable torque arm?
- pt 4400 in a 2001 owners please answer ?
- Nasty Nasty Gear Noise..HELP!!!
- Need some tranny help please
- How to take apart master cylinder?
- When racing, my car doesn't shift into the next gear?
- Question about Energy Suspension torque arm mount...
- What year did the LS1 cars switch to the better slave cylinder?
- SY 3500 Launch???
- What PCM connector block is C2?
- Driveshaft Q
- 3.73s...
- PT4400 on daily driver...
- Pulse Width Modulator....
- What would be the best TC for the 1/8?
- Moser 12 bolt with 1350 yoke. Driveshaft length?
- How to swap my TC-lockup from PWM to non-PWM ?
- real deal with N2O and trannies...
- 98 t/a
- Another Driveshaft Question
- Question on torque arms?
- Would a synthetic get rid of most of my gear noise ?
- Changed the tranny fluid last night, Uhhhh!
- How do we change all the tranny fluid: tranny and TC?
- BMR Standard tail shaft torque arm VS. Trak Pak style tq arm
- i think something's very wrong
- Getting custom EW tune....
- 19k GVW v. 24k
- New Street Twin - temporary pedal pressure loss - help?
- Popping out of third
- Shortest Shifter
- Motor mount ?
- Rear end rebuild?
- Driveshaft Question
- Tranny maintenance Qs
- Possible rear end problem
- Yoke for a ACPT Driveshaft ?
- RAM torque spec question?
- Wheel Studs - which ones?
- Moser 12 bolt - very loud! how do I fix?
- Who has the nicest rearend?
- Gear noise... need help
- Gear Swap/HPP3 Question
- How do I know if I have the Auburn or the Torsen in my 98 Z28?
- Result of rearend check
- Master Cylinder Drill mod?
- Asking for some advise
- Inspecting Rear
- Broke something last night bad - come inside help
- Moser 12 Bolt
- carbon fiber driveshaft
- YTPE4400 WITH N20 guys step inside...
- Please help with Tranny/cluth disaster
- Where is the Vehicle Speed Sensor (VSS) located?
- Question about 4.10s
- Swapping out the rear end-- Piece of cake right?
- what would be the best/recommended trans fluid/filter ?
- Changing my Differential fluid this week...questions...
- Clunk Sound
- HELP!!! I snapped my random tech torque arm.. I need something stronger!!!!
- Rearend life expectency
- buying new trans am need help
- LS1Speed.com's "race-prepped tranny"
- transmission trouble
- Water Pump
- AAM Differencial cover MODIFICATION Ques...
- tranny problem
- Longer front wheel stud question......
- How streetable would this be?
- Gear/Rearend Question
- What is the correct gear to dyno with?
- convert for highway
- Pinion Bolt Torque Spec?
- jerking at low rpm's
- 2 Speed shops now that have said YTP4400 is WAY TOO HIGH for bolton car :-/
- Odd TC lock up issue...
- Flex plate bolts?
- Rearend broken???
- 2nd Gear Shifting Problems
- Transmission fluid Tube and Dipstick help!!!!
- Yank TC question
- Whats the shortest gears (numerically highest) you can put in?
- Do all 6M trans have plastic cup to hold the end of the shifter?
- How much does a Strange 12 bolt weigh when delivered?
- shifter question
- Rapid Motorsports is awesome!
- Thread size of shifter handle? 16mm, 19mm, 24mm?
- Need Help I think my right rear axle is too loose
- Need Help
- Lots of noises
- shift kit or hypertech programmer
- Mark Williams rear
- B&M Deep tranny pan
- Funny noise...
- Should I switch from vig2800 to a yank ST3500
- Differentials?
- will hot tranny cause shifting probs?
- I like to hit 170 plus at times.. Do 4.10's continue to pull in 6th?
- Getting some serious wheelhop with a fully modded suspension....ideas?
- Can I get less vibration with a Poly Tranny mount? I think I can!
- B&M transpak
- higher idle speed
- Think I fried my auto
- Shift kit Qs
- Lost Top Bolt For TA Tranny Mount - HELP!!
- Help choosing a 9 inch
- A question on size of rear axle cover bolt
- Final drive gear identification
- What gears would you suggest
- how do i calculate effective gear ratio with shorter tires?
- Torque Management is a biatch!
- High RPM shifts => Problem
- gear oil leak?
- which STR on stock motor, 3.23's for the street?
- I need some advice on a 12 bolt
- HELP....warrenty work.....TA cover qestion w/in
- Dropping a Ford-9 Question
- Number for McCloed tech line.
- Help?
- Very bad noise...... please advise.....
- SES Light!! What is this code and why?
- High RPM Shifting Problems.
- Shifter Rattle in 3rd Gear
- shifter
- anyone happy with there spec
- Adjustable Master Question??
- 3rd Gen Vehical info?????
- a much discussed subject
- Trying to pick a tranny?? help!
- Rear-End question, (technical) please help.......
- Who has broken some spider gears on here?
- probably get flamed for this but.....
- A3/Electric Speedo, ABS Sensor?
- Hey Moderators....
- question about torque management??
- stupid question about the rear end, please reply
- 10-bolt question
- Do 2002`s have 1LE trans mounts?
- richmond gears
- Anyone with 2004R Tranny in their Ls1 car???
- 3.73, 3.90, or 4.10? Which, and why?
- Broken Torque Arm Mount
- (9 inch) which 1
- Question about drilling the Ram PP??
