View Full Version : Gears & Axles
- Anybody using the Richmond 3.91 gears (in a 12-bolt)?
- Driveshaft length with a 9" rear?
- need help bad!!! how do i fix my moser axle leak???
- Tremec 3550 and 3550 TKO
- 3.42s over 3.23s
- Pinion Bearing removal
- RAM 402 PP users inside please...
- Transmission Mount.......?
- Performance Automotive & Trans Center (PATC)
- Need advice on 3.73 gears
- Strange 12 Bolt - How much needs painting?
- Stock 2001 ss conv.
- 3.23 vs 4.10
- Metal Shavings in Differential a bad sign?
- auto transmission guys
- rear end shift
- What happened????
- Has anyone built their own 12 bolt?
- gears and locker
- are these spec stage III the new revised or gen II
- Moser users or future Moser Buyers, advice inside
- susp. how long?
- what's the best DS loop for aftermarket y-pipe?
- What exactly would I need...
- Hurst Shifter, reverse in a pain
- How long til my stock trans gives up
- 1st impressions of TCI 4400 & shift kit
- Limits of the 4.10 gears?
- Rear end Lube :) .......???
- Will a 1998 LS1 non TCS 10 bolt bolt up to a 2000 SS 10 bolt w/TCS?
- th 400 detent
- All camaro's have aluminum drive shafts??
- Can you help me with this please
- What gears???
- Straight to the Tranny Cooler
- Gear ratio help
- Difference between spool and posi...
- Need Help Transmission stuck in reverse!
- Loud clanking out of new rear... possible suspension issue
- Differences in Moser vs. Strange 12 Bolt? - Fitment etc....
- Moser whine, more off than on
- 12 Bolt Questions
- moser good : )???
- Girdle/pinion cap stud torque spec
- Really scary noise
- Which DS Loop for Hooker LTs Mufflex Ypipe/4" Catback
- people w/ poly trans mounts inside. got a question...
- Lingenfelter 3.5" HD Alum. DS on Sale!
- Tranny Dip Stick tube - Fluid Leak
- 2000 up cars get vented rears?
- Tranny and Rear End advice needed
- U-Joint Replacement Tips
- How tight does the diffy need to be??
- pedal or tranny problem
- transmission
- Part # for TO bearing only (ie not with the slave)
- part no for a stock Hurst i bought please help!!!
- Tranny shift ?'s
- Rear Swap?Do I have a 3 series carrier on my 02?
- First Impressions of TCS 4400.
- Help!Will this fit?
- b@m
- Clicking sound coming from rear of car
- Is a McCleod adj. master cylinder really needed with...
- ET Streets with Stock A4, Driveshaft, Rearend
- synthetic trans & diff fluids
- should i stay stock or 373??
- Driveshaft length Question
- sign of problems to come?
- What is needed for a 200-4R swap ???
- ES tranny mount?
- Question about rear-end...
- Question about needs for tranny swap
- help, adjusting presure on street tires and warming them up?
- Breather on Moser 12 bolt.
- For the record- Putting a 9" in your trunk...
- LS6 and LS1?
- 2 series to 3 series carriers... will I need a new ABS ring?
- 9-Bolt Rearend...
- Would this work?
- how do ya know if my tranny mount is broken
- did I destroy my tranny?
- ...HELP
- will a 7.5 fit my c ar
- when changing your rearend ............
- Need help,please.
- Possible tranny/tuning problems?
- What is the quietest set of 4.10s available
- additive in rear?
- NHRA DS Loop
- Drops of Tranny Fluid Leakin?
- Anybody using a gear splitter?
- PT4400 vs ST3800..wow
- Is Slave broken
- Rear End Help
- Moser 12-bolt oil level? Help!
- tranny swap ?
- Speed Inc/Stage 2or 3-who has one?
- What is the Size of the Pinion gear nut?
- rear end info?
- fastest 2.73 geared car?
- Drivetrain experts help. Vibration question
- QUES? ABOUT MY NEW TA COVER
- Tranny problem???
- maintenance ? - rear end
- 1810 SES light
- 98 front brake drag
- will i go faster with an auto 400 turbo
- Strange 12 bolt, 3 Channel Center or 4 Channel Axle???
- Drill mod or NOT?
- is rear the same width for 82-02 f-bods
- Lakewood 18022 and mac off road Y:(
- Percentage loss threw a 12-bolt ???
- Rear End Noise
- TC lock up speed?
- 3" Studs with stock wheels possible?
- Someone tell me the best short shifter!
- WTF?!?!? Torque arm mount came loose on its own??
- Bench bleeding the hyd.'s ??
- Gun Drilled axles? Pros and Cons within please.
- Spec Stage 3 and Moser in!
- need some help
- spinning the race on the rear bearing??????
- LG torque arm problem...
- need 9" pics
- Pinion seal leaking?
- WHICH TRANNY LINE IS THE RETURN?
- New improved girdle
- Genuine GM 3.73's
- rear end swap went bad
- Extended Wheel Studs and ZR1's
- 9" with spool ?
- Poly Tranny mount questions inside:
- Most successful 10-bolt w/4.10 setup?
- how hard is a gear swap for my ten bolt?
- Independent Rear Suspension
- could i have any worse luck?
- Wheelhop issues with 9"??
- hot swap gears
- trans fluid
- hurst billet plus
- Anyone running Moser Billet Aluminum yoke?
- Vibration. Please read...
- will there be any trouble running 12 bolt?
- Busted Tailshaft
- TRANSMISSION SWAP
- Tranny problems **Update**
- HELP!!! WHATS WRONG WITH MY BRAKES???
- Am I gonna break my rear end ?
- moser 12 bolt or strange rear
- Please HELP!!! I'm a hydraulic idiot!!! How do I bench bleed my M/C???
- What gears to run up to and over 200mph
- Tranny Rebuilt.. New problems...
- Lakewood DS Loop pn#18022
- SLP or Superior 3.73 gears?
- Early shifting problem, possibly cam related? Please Help.
- Speed Sensor for a Powerglide
- SHHHHHHH noise from rear
- Gears making noise again
- Yet another 3.73 question
- Transmission power flush
- Help me spend $800- $1000!!
- ASR?
- moser 12 bolt people inside - many questions
- How to tighten emergency brake cable...
- Best 3.73 gears?
- Which 12 bolt to go with??
- rear swap
- Well, tranny took a dump today...
- Slave Cylinder
- anybody using straight cut gears/nickel?
- Automatic vs Manual 6 Speed
- Gear Whine
- Anyone using this tranny?
- Will a bigger tire (slick) make my car shift earlier?
- Need part number for 1350 ujoint (NOT CONVERSION UJOINT)
- QuickTime Pros any good?
- changing gears from 2.73 to 3.42??
- Recomend me a driveshaft
- Longer Wheel Studs for 15x10's (strange 12 bolt)
- 3.73 gears
- Question about 4.10's?
- Weld Magnum Drags?
- Bogging issues, etc.
- weight saving by going with a spool
- TCI 3500 Track Time:
- slp drive shaft anyone have one?
- Milage and RPMs
- Missing plastic clip on Hydraulic line
- Tranny Help.... ASAP
- Torque Arm suggestions???
- Vibrating at idle!?
- Not sure how to shift race style
- tranny lines?
- Shifter handle thread size
- Rearend for sale
- driveshaft length?
- Shifting problems after TC & Shift kit
- Question about the Pinion Depth Tool?
- STUPID QUESTION?
- 9inch blowing fuild out around vent hose??
- Help PT4400 TC ran but now i have no gears
- New SPEC III Ceramic pics
- Car will not shift at high RPM...
- Nicest Differencial Girdle?
- Linear and Progressive Rate Coil Springs
- REAR END INTERCHANGE?
- Shift problems
- All guys running a vacum modded trans?
- Just bought a 12 bolt, how well did I do?
- I need MUCH QUIETER Moser 4.10 gears
- Stock or Built transmission: Which lasted longer?
- Need some info on some things
- Driveshaft length for 12 bolt vs. 10 bolt??
- 98 rear end in a 94????
- More Rear Noises
- 3.73 help...
- Adjustment of pinion angle, does it require adj lower control arms?
- OD,D,2,1 or D,3,2,1
- Who's got the biggest...
- es trans mount
- Stripped bell housing bolt....Any tips?
- Wheelhop from HELL
- moiser 12 bolt vs strange 12bolt
- racing in overdrive?
- anyone run a 325/50/15 BFG DR?
- Slave and Master cylinder part # question
- Spec stage III.. carbon or ceramic??
- PHR doesn't clear 12 bolt
- Question about gears...
- Strange 12 bolt?
- Strange 12 bolt Longer Wheel studs...any help? (pics inside)
- speed/power shifting question???
- Where's the beef?!!!!!!!!!
- transmission moving?!
- best atf fluid
- LS1 to Z06 conversion, help
- Tranny fluid...
- Strange 12- bolts any good?
- what additive to use??
- Best place to get a 12 Bolt
- 3.73's or 4.10's
- 12 Bolt dimensions
- Comparison between Vig.3200 and TCS4200 within!
- B&M deep pan helps alot!
- Am I Asking for Troubles ?????
- 10-bolt + nitrous from a roll, safe??
