PDA
View Full Version : Gears & Axles
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 [108] 109
  1. transmission is for sale.
  2. Tranny Removal
  3. What are the benefits of a Carbon Fiber Drive Shaft?
  4. Pinion gear shim question?
  5. 9" Noise... gears going out?
  6. Whos running the Gearvendors unit?
  7. Thinking about going back to 4.10s
  8. Ok.. I HAVE to get rid of my fender gap. WHATS the BEST SOLUTION!?!
  9. Master Cylinder/Drill Mod Instruct's are on my website now
  10. Instant Center-Torque Arm and LCAs
  11. Finally found the problem
  12. Where is center of gravity on f-body
  13. Panhard rod - why at an angle?
  14. steel DS stronger?
  15. Anyone have springs by Suspension Techniques? Pics on a T/A?
  16. Guys with Hotchkis subframes connectors>>>>>>>
  17. Thinking of swapping back to 2:73s but....
  18. Mark Williams driveshaft question.
  19. Torque Arm for road racing
  20. Rearend noise...need help!
  21. Check out the metal shavings on my Diffy Cover! [pic]
  22. How exactly does the B&M ratchet shifter for the TH400 work??
  23. Went over to Speed Inc. and worked on the 9"...
  24. Deep transmission oil pan?
  25. Tire Question
  26. Anyone running manly 4.88 gears?
  27. How much E.T. is a t-brake worth?
  28. Coule of LCA questions.
  29. when do you need a torque arm?? do i need one?
  30. My shift at WOT sounds wierd??
  31. D vs. OD?????
  32. Used rearends???
  33. replacing slave cyl. which one to use
  34. What should my next mod be?
  35. Best place to buy a 12-bolt?
  36. Considering going from 3.73 gears to 2.73s. Crazy?
  37. Linelock?
  38. What company do you recommend for under-drive pulleys?
  39. Should this be your next Transmission?
  40. What's the advantage of 315 Nittos vs. 275's
  41. Which torque arm??
  42. does the ta girdle really make the 10 bolt stronger
  43. front brace question
  44. 1-2 shift wierd lately?
  45. Automatic Trans. Discussion
  46. anyone have the spohn torque arm
  47. Have a chance to buy an almost new Summers Brothers 12-bolt. What do you think?
  48. global west kit......
  49. UNDERDRIVE PULLEY ?
  50. Trouble powershifting into 2nd
  51. Boxed or tubular LCA's
  52. Need HELP with torque mgt. program. Please
  53. Hurst shifter problem - any advice welcome
  54. How do you break in new gears???
  55. Brake Package
  56. First suspension mod?
  57. SFC's on 2001/2002 convertible
  58. Suspension mods for vert daily driver
  59. Nitto drag radials
  60. Okay, tranny experts in here------> Her is a tranny mystery for you!
  61. who's running 4.56's
  62. For those worried about C/M products from PAracing.net.....
  63. Desperately need help with pinion angle
  64. Took Pic of my Home made adjustable master Cylinder
  65. Is it normal for the my Differential cover to be HOT after driving?
  66. Strange 12 bolt
  67. how man y have bought a new shifter?................
  68. DIFFY CHOICE: Eaton vs Auburn (Need help quick!)
  69. weak t/a rearend
  70. WS6 "upgraded suspension" on invoice
  71. Pics of lowered LS1s
  72. Whee Fitment. 2000 Camaro
  73. OK are lower control arms worth it?
  74. 12 bolt owners , within!!!
  75. Tranny Tricker
  76. Help! Thinking about lowering my car, but need advice!
  77. slight whine/howl at VERY low speed
  78. Fried posi..... help with dealer fixing!
  79. Trans fluid leaking from bellhousing!!
  80. TC Install Question
  81. Shifting Problem
  82. SS suspension help
  83. LCAs needed for me?
  84. pickup from 3.23's to 3.73's?? how much?
  85. if im going for performance not looks should i lower my car?
  86. Stock 3.42 or 3.73 with spray
  87. Better ride: Pro-Kit or LG lowering springs...
  88. Mark Williams or Dennys?
  89. Time for new rotors, what do you guys recommend?
  90. Will I need a realignment after putting in springs?
  91. GM 3:73 Gears
  92. Eibach Pro Kit....what will I need to change?
  93. Clunk in the rear, but only on left turns
  94. I own a Yank TC and never thrown a code...
  95. Finally have a few pic's of the BMR tq arm.I split in half at the track..
  96. Who can tell me about Madman's torque arm?
  97. 3.42 or 3.73's what do you recomend
  98. SFC's are a good mod...
  99. Can Anyone Explain PI T/C Pump #s
  100. Anyone have a Stock Fan that doesn't work?
  101. Something different.. Camaro catching some air...
  102. Suspension mods that worked for you, Suspension mods that didnt work
  103. How Many of you.......
  104. The car MOVES !!!!
  105. my trans spins in second???
  106. Mysterious Wheel Stud Bending Problem?
  107. do I need a panhard rod?
  108. Nitto's Purchase
  109. Instant Center
  110. Thunk...thunk
  111. Tranny rebuild costs...
  112. Pinion Angle - How important is it for Drag Racing?
  113. Independent Rear Suspensions
  114. Chrome Moly Drive Shaft....
  115. PLEASE HELP!!!!
  116. Will I have problems with Boxed SFC's on lowered car??
  117. How much difference with SFC's???
  118. what else should i do to beef up my suspension
  119. Will 335's fit onto 11" ZR1 rims?
  120. 10 second suspension?
  121. Tire pressure (not at strip)
  122. Right Rear Airbag?
  123. y2khawk
  124. weird clunk when downshifting...???
  125. Is my axle giving me signs off it going out?
  126. Those with ST-3500 DTC code issues, just talked to Mike Senia at Yank....
  127. Eibach Drag Launch Springs
  128. TM Question?
  129. Carbon Fiber Driveshaft equal to Aluminum?
  130. 12bolts and cornering
  131. Got slicks, need to program computer
  132. Rearend loking up.
  133. Eibach Drag Launch Springs
  134. Drive Shaft Clicking Noise......Question
  135. FYI 9" people check the nuts holding your backing plates on...
  136. 12 bolt from 1969 Chevelle
  137. Will lowering my car hurt my track performance?
  138. 3.23 to 3.73 is it worth it?
  139. Vibration with rubbing noise under partial load!
  140. Paging Colonel
  141. Might be buying a 12-bolt soon. I need advice.
  142. Breaking in new gears?
  143. Broke My Axle - Bye 10 Bolt Hello 12-bolt
  144. I want to get some 15 x 10 prostars and some 28" tires, what is needed...............
  145. power lost w/ 12bolt?
  146. Will too much tranny fluid cause shift hesitation?
  147. torque management on a '98????
  148. Best Front End Brake Setup on a Camaro?
  149. Anyone know the correct Ujoint size
  150. Lowering my car...lose any performance?
  151. *****MARKER*****
  152. "Hardcore" drag racers, list your suspension.....
  153. Paging Trevor & Patrick G re: TPS Shift Control
  154. Some RAM questions
  155. My Lemon Tranny
  156. Spherical-end Control Arms
  157. Performance Friction Carbon Metallic brake pads; are they worth it?
  158. Transmission mount bolts?
  159. IS THIS LS1.com?
  160. Think I lost my posi
  161. Popping noise in front end
  162. New guy trying to get traction...
  163. Anyone running the JFP / Stealth torque arm?
  164. How much horsepower and torque can the stock aluminum drive shaft hold?
  165. Please Guide Me!!!
  166. SLP Eibach's?
  167. Where to buy Syncronizers and blocking rings, other than GM
  168. BEST pads to use with power slot rotors?
  169. Need Anyone who has... Broken their Driveshaft or C5 Torque Tube...
  170. Adjustable Vs. Non-Adjustable LCA's and Panhart
  171. Weird sound coming from rearend
  172. Will a 12 bolt brke w/out the TA cover?
  173. Will Eradispeeds fit 16" wheels?
  174. questions on springs
  175. Oh nooo!! The steering shaft won't align! Please help!!!!!!
  176. Rear Springs
  177. Can of Marbles???
  178. 12 bolt or 9" ????
  179. adjustable master cylinder...made mine
  180. wheel hop elimination
  181. How much does 4.10's weaken the rear end ?
  182. Presure Plates
  183. Hard shifting
  184. Suspension ?
  185. STR on a pi3200
  186. Could you order a 3.73 gear in a SS?
  187. Broken Rear Diagnosis
  188. Having a hard time trying to get a 1LE Transmission Mount
  189. Moser 1310 yoke+OEM steel DS...Which u-joint?
  190. torque arm bolts
  191. Rear end pinion seal
  192. What are my lugnuts options with long Wheel studs?
  193. Where did you put your line-lock button?
  194. 3.23 swap to 3.42 or 3.73??
  195. lite weight
  196. Please post your comments about the Spohn or LG motorsports torque arm.
  197. Anyone actually like their poly transmission mount?
  198. diff plug question
  199. Bumper braces?
  200. QUICK!!! Does anyone happen to have a pic of their diff. cover.
  201. Who makes the strongest gears?
  202. Best airbag for right rear spring?
  203. Bar above panhard rod removal??
  204. Y-pipe banging floor board...???
  205. 9" Ford Or GM 12 bolt!!
  206. Piece of JUNK
  207. Posi Test?
  208. Can somebody tell me what the name of this is?
  209. Do I NEED lca brackets and an adj. PHR?
  210. Looking for a approximate price...
  211. 3.42s or 4.10s with my new Nitrous Setup
  212. TH 350 Users
  213. drivetrain stress at high HP only on launch?
  214. Weird notchy feeling after tranny rebuild......ideas??
  215. Anyone make a mini spool for a F-Body 10 bolt?
  216. BFG G-Force KD vs Nitto ???
  217. new noise (sorry this is a bit long)...
  218. Any company making a manual rack?
  219. What weight gear oil for 12 bolt?
  220. OK What's the deal on Moser 12 bolts...?
  221. Deprived of my rights!!
  222. Do I really need a 12-bolt?? Opinions, please....
  223. Adj. Tourq arm (Need Heavy Duty)
  224. Shifter Mod - Check it out.....
  225. Noise in car, coming from rear.....
  226. Anyone know why my car would lean to one side?
  227. Rear End Making Clunking Sound?...
  228. Gutting CATS or OFF-Road pipe?
  229. What is the weight difference between...
  230. How to pick out a 12 bolt???
  231. Should I replace the stock Steel Driveshaft ?
  232. Does anybody have detailed instructions for a TC install?
  233. Question about Gears and Dyno
  234. Gauging interest in a Torque Management removal (!TM) group purchase.
  235. Tire recomendations ??
  236. DTC P0751 1-2 Shift Solenoid????
  237. New Gears for 12 bolt
  238. Any Experience with the Currie 12bolt or 9Plus Units?
  239. Car is Howling
  240. 700-R4... How strong can they be built?
  241. Any Tubular K Member owners in here?
  242. Subframes?
  243. Will stock 3.42 gears swap into my 2.73 rear?
  244. Anyone swapped a C4 IRS into 4th gen?
  245. Please recommend me a torque arm...
  246. Alternatives to a moser/strange 12bolt or 9"
  247. Torque management??
  248. ? Use of ring gear spacer
  249. Star Stage 3 carbon noise went away after....
  250. So can I go to the junkyard tomorrow and pic up '93 v-6 spings?
