View Full Version : Gears & Axles
- Do I need a rear end?
- 9" axle/pinion dimensions needed <<HELP>>
- Torsen or Auburn...which is stronger?
- 10 bolt swap with 12 bolt
- Best Brand for Gears
- S60 driveshafts
- rear end ?
- How fast have you gone on 2.73?
- 8.8 ford rear in 4th gen T/A
- 3.42's Installed, major deadspot help!!
- rear end question
- How to tell if a differential is going bad?
- pinion angle and new 9"
- Axle Spline
- Rear swap.. Reprogramming?
- 98 ta gears ?
- NewB wants to overhaul rear
- swaping 97 rear end to 2002??
- S10 Rear??
- is it true that a 12 bolt can make you slower?
- Richmond 3.73's... what series do i need??
- Rear End Fluids
- Best place to get shims?
- Crazy F-body/GTO IRS Question
- Where to buy parts?
- Problem with TA Girdle Load Bolts and PHB Support- Pics
- Hoping some of you guys can talk to me about this rear end I just bought....
- Again: rear end is leaking and making clunking noises
- 10 Bolt Posi HELP!!
- Swapping the rear..
- 3.42 vs. 3.73 gear poll!
- Has anyone heard from Scott @ DLS?
- stock rear axle swap questions???
- stock '01 Z28 M6, do I need posi additive?
- Motive gears in stock...
- T/A Cover Torque Specs
- what gains
- Installing 3.42s in a 2.73 carrier--need new???
- Type of Paint for the 9" housing
- Pics Inside is my Driveshaft too Long???
- Help in DFW, axles needed ASAP
- Please Help Guys!!!! :confused:
- Posi-traction burned out?
- who has the Motive 3.90's??
- can this be right
- ford 9'' ??
- Limited Slip??
- determing rear-end gears
- rearend
- need a stock rearend
- Rear end width
- Drivetrain loss for stock 10 bolt M6
- Shipping a rear end
- What gears do I have?
- 4L80 + 9" = What rear gears?
- new gears in 10 bolt question
- Anyone have a Moser Drain Plug Leak?
- 4.10's in 6th gear
- DS question
- Moser 12 = Blowed up = Bummer = Pics
- dte rearend
- Need help!!!!
- Backlash question
- new brake lines with ford 9" ????
- Post up pics of your shredded 10-Bolt
- ladder bar conversion??
- Moser 9" problems
- dana 60
- 3.90 in stock rear.
- 4.10s or 4.30s?
- What is the stock width of the 00 Z28 diff.
- A4+4.10s+28" tires
- 4.10s, gas mileage
- Synthetic Gear Oil in my 10 bolt
- Slight Whinning from 40mph to Stop
- using F-body for swap platform need final drive advice
- getting new 4.10's.... Richmond or Motive??
- How do you measure pinion angle?
- WTB: Stock axles in good shape!
- lock up? rear end problems
- 9" is on its way woo hoo
- Article for fabricating a 4th gen 12 bolt?
- what is a 10-bolt between a 99 10-bolt and a 95 10-bolt???
- Dumb question but need Help ASAP
- Need Help ASAP!!!!
- 9" Wants to tilt up when car is lifted!
- What direction do wheel bearings get pressed on?
- grind/whine 2nd time
- Prob with rear end... need HELP!!
- 3.42 gears - looking to trade Raleigh NC
- 373 1/4 mile
- From 10 bolt to 8.8
- crap...
- MS4 is 410 gears the right choice?
- Rearend Help
- comparable rear widths
- 3.15 case for 3.42 gears
- Strange Dana 60
- Getting sideways!
- Clunk when accel and decel! Any ideas?
- Did I get the right gears?
- What to expect after a gear swap?
- causes of gear noise?
- How Much For Gears In My 1999 T/a A4
- General Motors 12 Bolt Rear End Assy
- Why cant we use synth gear oil on our 10 bolts
- What type of rear end??
- GM 12 Bolt?
- define "built 10 bolt"
- any v6 cars come with limited slip
- help*asap*bad sound when i drive!!!
- Fab your own 12 bolt article?
- Rear Diff oil change
- What oil is best for my rear diif????
- any way to get rid of that sound??
- Scratches on Driveshaft. Yay or nay
- What Brand & Weight Gear Oil for New Rear End?
- graphite powder lubercation on gears
- What type of center section is this?
- Spohn Driveshaft and u-joint
- DLS 9inch rear problem?
- 9'' prob
- What carrier so I have?
- New Moser M9 rear with Moser torque arm!
- Quick Performance ?
- 1 wheel spinning?
- Weird Noise???
- 4.56's???
- Edelbrock adj TA with Moser 9"?
- dana 60/ driveshaft problems! please help
- pos 10 bolts
- Stock aluminum SS driveshafts M6 A4 same?
- 4.10s or 4.11s
- Need 9in. axle bearings locally
- witch torque arm works best with moser 9in.
- do bearings come with a new moser 9"?
- HELP Thumping noise
- 9" is in, went for a ride
- 4.10s or 4.56s
- help!! axle shaft removal
- Whine with my 3.73s..
- I put a 4.56 in an A4
- Posi identification
- 9" Assembly
- Want to be sure on buying a 3 channel 96 rear end for my 01 bird
- 4th gen carrier in 3rd gen rear end?
- difference between 7.5 and 8.5 10 bolt
- 373s
- e-z locker
- ques on 9"
- gears or tranny??
- How thick is the thick ring gear?
- axle shaft replacements?
- quick ?
- Need some input, stuck on what to do!
- rear info
- 'Bolt-in' Moser 9" Housing lol
- A decision to make
- just broke my rear end witch on is the best??
- Have a howl on right turns after gear swap.
- 10 bolt question
- 2.73 to 3.42 with Yank SS4000
- 9 inch question
- How much HP / tenths do you you lose but swapping to 12 bolt or 9inch ?
- what gears for a 500rwhp A3?
- Stock Carrier question
- Mechanic left a bolt loose on my rear - can I drive about 5 miles with it half-full?
- 2 Series Carrier
- What auburn differential should I get?
- Fastest 10 Bolt Rearend???
- Trax's 9-inch assembly question thread
- what kind of gains
- 4.10's for a Strange 12bolt
- Vibration Driving Me Crazy
- good price on posi and gears
- What kind of noise does a rear end make when it's going bad?
- LSD only install
- Axle R&R instructions
- Moser Wheel Stud ???
- anyone make a spool for c5 corvette?
- F-Body Gears in stock, Install Special!
- Noisy Rear End
- How hard is it to do a gear swap?
- DS Loop problems!
- Rear End Fluid Leak - What do you recommend?
- rear end oil change?
- posi and gears
- rear ends
- Pressing on u-joint and axel bearings
- Ring gear runout? Teeth seem to have a "wave" in them as I spin the diff...
- Found my axle noise
- Summit Ring and Pinon Gears???
- another 10 bolt noise question
- What with 3.73's?
- Stock 1998 Trans Am Gear Ratio
- Moser 9" - Brand NEW and NOISY!
- How do you install a pilot bearing in a 9-inch center section?
- clicking noise
- Broken 12 bolt?
- Warped axle????? Idk
- Going from a 3.15 to 3.42 rear end
- quick question
- TA Cover/Girdle magnet?
- Which rear end to use - 92 3.23 or 2000 LS1 3.46
- How to change fluid?
- Can you keep your ls1 brakes with a 9inch ?
- what is a 9' bolt in worth
- Anyone Running 3.90s or 4.10s in a 10 bolt M6
- need help with 4:10
- Rear End is Humming/Whinning??
- Gears that haul ass 3.90 or 4.11 ?
- 3.90s to 4.10s?
- which gears to run with eaton posi?
- LT1 and LS1 interchangeability and ABS problem
- will a 7.5 posi fit our rear axles? (7.625?)
- Need help diagnosing rear end problem, please help!
- How bad is my rear end?
- Gear Whine?
- I need some help
- Why does it seem that my read end isnt centered?!
- new rear
- 9 inch axel seal HELP!!
- Rear end Fluid??!!??
- What gear ratio is this
- What the heck's making all that noise
- LS1 rearend on an LT1 Fbody?
- Rear End Upgrades... Want to know ET Differences
- Harsh disengagement of driveline
- Bad Posi? Rear End?
- 2-series vs 3-series rear end noise
- loud noise help??
- do i really need a 9"?
- Carbon Fiber
- help! something broke.
- What will break next?
- rear end locks up when going in reverse?
- So I searched... no results. 3.42 question
- question for strange 12bolt users
- Replaced pinion seal, now major leaking
- Need some help on new rear
- lsd oil additive neccessary?
- Which LSD/POSI/LOCKER should I buy for my 10 bolt???
- We(me and my friend) totally hate the adj sphon TA
- U joint question
- so my car has steel driveshaft, should i bother?
- Initial thoughts on 4.10s/spool install...
- how to replace strange 12 bolt axle seals??
- Newer T2Rs Less Reliable?
- Only difference between 2 and 3 rears?
- 3.43 to replace my 2.73's
