PDA
View Full Version : Drag Racing Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
  1. Does offset matter for drag tires?
  2. Is there a 6 speed drag radial record?
  3. '02 Z06 in the 1/8th?
  4. 346ci 6speed record??
  5. set-up times?
  6. Question for those with the wolfe adjustable rear spring mounts
  7. finally got my wheels on *pics*
  8. Any guess on what my idea will run
  9. NMRA Drag Radial Setups?
  10. NHRA required parts per E.T. class
  11. can you mount these to a cage and be legal?
  12. Is 1000cfm big enough to support 600-625 NA hp???
  13. LSX Mustang Videos
  14. gauges R done whattaya guys think?
  15. If Chromoly can be Mig welded, Why all the Fuss?
  16. Can I put a 28" slick on a 8" rim?
  17. 60' Question
  18. drag struts 90/10???
  19. cutting bumpstops
  20. Symptoms of Converter Failure?
  21. Helmet question, I wear glasses, which one?
  22. rear girdles?
  23. Will this car ever go down the 1320?
  24. Where to get 2 step?
  25. Will this suspension help
  26. adding a delay box
  27. Roll Bar question
  28. Floor modifications for 9" rear?
  29. What should I do to get my car to hook up
  30. My first time running...Advice?
  31. fabbed door panel pics.
  32. Will I notice any difference?
  33. How's my TA running?
  34. ride height with qa1's
  35. Is a 325 M/T drag radial too much tire?
  36. Need Some Predictions
  37. What length QA1 springs?
  38. more rolling resistence? 325 radial vs. 10.5 slick?
  39. Hey Dopefed Z
  40. M6 guys, what 60' broke your 10 bolt?
  41. Tire treatment
  42. qa1's
  43. Mustang 5.0
  44. Need HELP, LS series engine with a Pro-Charger
  45. Got my thru the floor SFC's, doesn't look so good.
  46. Whos gone M6 to A3?
  47. Anyone who's run a Carb'd LS1/6: info needed
  48. qa1 spring choice
  49. Need Advice I Am Stuck
  50. How much nitrous will I need to run 8's?
  51. Can I pass tech
  52. rear seats
  53. will 15x10 prostars fit on my car with 3-1/2 backspacing
  54. Summit "prostar" weights vs real prostars
  55. I Don't get it. Inconsistent times with M/T et drags
  56. Help me choose a tire
  57. tips for keeping engine cool?
  58. Biggest Nail in "Street Car" coffin?
  59. help please
  60. attn, MADMAN,picts on 25.2 stock susp [lots of picts]
  61. How do I know what converter speed for the track?
  62. What is the Fastest.......
  63. How much faster would I be
  64. best spring rate front and rear?
  65. Slowing down on the big end
  66. Guys with ATI 5500 8" ls1 th-400
  67. Whats your best 60' on M/T Drag Radials with an M6
  68. Front coil overs strange or qa1
  69. First time questions...
  70. 9 Second guys. What size tire?
  71. Cam only numbers.
  72. 6speed Ls1's with 4.10s
  73. Project 02 Silver Z Update 8/23
  74. Steering wheel recommendations
  75. track times...launching problems
  76. How to Launch a cam only, full bolt on, 10 bolt, with 342's
  77. Powersteering Delete questions
  78. pulling the wheels at the track
  79. pulling the wheels
  80. My thoughts on M6 drag racing for the newbie
  81. Stupid Weld Prostar Question
  82. 4.33 or 4.56 w/TH400 N/A!!!
  83. how fast have f-bodies gone on 26x10 slicks?
  84. Bulkhead
  85. Weight transfer..
  86. a few suspension questions...
  87. Cage Question
  88. help with 60's
  89. Best weight reduction yet, dropped 70lbs....
  90. Help with 25.5 Cert
  91. Newbie to the f-body ?'s
  92. Serious race help needed, no haters please
  93. 16 Volt Battery, Fix Starting Problems?
  94. Alumastar question
  95. Failed 25.5 certification
  96. BFG DRs at track
  97. Help me pick a veter?
  98. Weld Wheels - Bankrupt!
  99. lakewood traction action bars
  100. ET Drags Question
  101. Log books
  102. Level car?? then set pinion angle??
  103. List of NHRA Legal Batteries?
  104. Help with launching with an auto
  105. Disappointed with 1/4 Mile Times
  106. i need your info!
  107. ? about draglites
  108. Project 98, Pt. 2
  109. Stock Z06 1/4m results inside!!
  110. Best way out of the hole fast??
  111. Engine Damper instead of motor mounts
  112. Weight Reduction?
  113. removing abs
  114. Fiberglass Hood vs Stock - Weight
  115. How to launch a turbo ls1
  116. aftermarket racing seats
  117. 4.10s=Out Of Gear By The Traps?
  118. What kind of battery setups are you guys running in back?
  119. Peeps with no bumper supports...
  120. looking for 5point harness pics
  121. possible to run 3" x 0.5" wheels studs up front?
  122. DR's on 18" Wheel?
  123. Pics of 315/60/15 MT DR's with mini-tubs
  124. Looking for feedback from people with a glide...
  125. Whos has tried these efi direct port nozzle systems?
  126. need suspension advice
  127. Alumastar BS
  128. Removing power steering
  129. What are current NHRA rules on roll bars for 10.00et
  130. Critique my launch
  131. Rear spring/ride height/weight transfer Question
  132. pics of my cars progress/cage pics
  133. diamond piston sales rep.
  134. Whats the best way to shift in a drag race?
  135. Stock ls1 water pump(heater lines)
  136. What Kinda Times Am I Looking At???
  137. Whats a good 3" muffler for true duels thats not too loud
  138. Traction vs Gearing question...
  139. I need a 5 point roll bar!
  140. Subframe connectors ?
  141. Help me figure out what happened to my steering...
  142. N2o and stall question.
  143. Too much rear squat?
  144. i need help with requirments under 12s
  145. long wheel studs in the front with aerospace drag brakes?
  146. New times.
  147. Wolfe Torque arm and true duals
  148. Trak times ( comments please)
  149. Pic of Trans Am rear exhaust inserts for true dual turndown set up
  150. removing brake booster?
  151. First Track Times
  152. Autometer shift light problem.
  153. Anybody DD a Roll Cage?
  154. Stock tire air pressure for the strip?
  155. Rossler Trans Brake 4L60 Trans
  156. Problems with BMR kmember
  157. What's with V6 rear springs?
  158. Tire selection with new stall
  159. Madman Manual Rack fitment question
  160. 10s for cheap
  161. air pressure and Qa1 settings.
  162. Wheelie almost flips!
  163. t56 bellhousing
  164. COld Air intake question?
  165. Mickey Thompson 255/50/16 DRs
  166. Fuel Cell Pics?
  167. guys with no HVAC and stock water pump
  168. a4's at the track...
  169. 28x12.5 ET street or 325/50/15 radial?
  170. Trans am weight?
  171. Solid motor mounts ???
  172. The best and cheapest lightweight seats
  173. Some nice local racecars (pics)
  174. No hood
  175. Air pressure in Nitto drag radials?
  176. This Friday (8-11-06), US41, Milan, or Norwalk???
  177. Need a helmet... nice one for good price?
  178. The fastest anyone has gone with a TNT ring kit & LSx F-body?
  179. How much will my 27" ET streets grow @ 120 mph?
  180. Running ET Streets..
  181. What size MT radials?
  182. Lanching problems
  183. Alcohol LS2 drag car
  184. girdle
  185. interior setups..gauges, cages, etc.
  186. hal springs?
  187. Help W/launing My A4?
  188. Will spacers clear 15x3.5 Prostars w/o grinding?
  189. How do I launch a Turbo car?
  190. PROGRESS PICS:Got the interior done
  191. Stagging lights
  192. Gears/convertor revisited..
  193. Radiators
  194. National Street Car Association web site?
  195. help best gearing for my set up
  196. lost 5 mph???
  197. M6 guys, best 60' stock on stock tires?
  198. 9 Second combos on ls1 F-bodies??
  199. what the hell?
  200. Can't lower 60' to save my life, someone help me!
  201. TCI Trans what fluid..?
  202. What Should I Be Running??
  203. 500rwhp on a 275/60/15 MT DR?
  204. Need to squeeze out another tenth or two...what mod?
  205. QA1 Settings?
  206. Guys with roll cages and carpet come on in
  207. Newbie Heads Up Race Questions
  208. ATTN: Drag Car for Country music Video
  209. Launching on nitrous
  210. What is the bolt circle measurement on the Fbody wheels?
  211. flywheels for ls1+ 350 turbo
  212. disabling airbag light after installing aftermarket steering wheel?
  213. heading to the track for the first time!
  214. what should my pinion angle be set at
  215. cold packs?
  216. battery relocation write up?
  217. Roll Cage: What do you have? (I need one soon!)
  218. LW fan mod...
  219. Launching with McLeod Twin DIsk
  220. what rear drag swaybar-wolf or BMR xtreme duty?
  221. Check out this car..
  222. Best ET/MPH for cam only A4 w/ stock converter
  223. gearing with a th350
  224. route 66 IL conditions
  225. help figuring da
  226. Madman, harness question
  227. how many single digit guys with no upper panhard???
  228. Drag car exhaust?
  229. I need stronger wheel studs, any suggestions
  230. Low ET with High HP T56 tranny,s?
  231. Windshield Options?
  232. are swing-outs NHRA legal??
  233. Need wheels/tires for track... 16" TA wheels or 17" WS6? MT's....
  234. What will give me the best gains?
  235. Drag Racing Experts Get In Here Please!
  236. 93 cobra vs. 99 TA for $300 bucks
  237. a couple of ?'s for yall
  238. Launching with 4400 stall and ET Streets
  239. Z06's virgin 1/4m Visit
  240. Front End Frame modifications
  241. Tire opinion's please
  242. M/T ET Front Runners
  243. How much Tubing to order for 10pt cage install??
  244. BMR or SPOHN Swaybar
  245. 03 cobra with pulley and programmer?
  246. Tell me the REAL world difference between 275/40/17 & 315/35/17 drag radials..
  247. 2.73s to 3.73s
  248. What do you guys use to 'cut stuff out'
  249. rear sway bar???
  250. Red Rocket Update
