View Full Version : Drag Racing Tech
- TH350C anyone?
- BFG G-force DRs
- SDPC heads ?
- Rear Wing on 98-02 Camaro
- Power cable, Driver's side firewall
- Motor Mounts....Solid or Poly?
- How to tell if I need adjustable lower control arms
- 02 camaro street car build
- Rear arm and chassis bracing
- Can I put a lightweight battery *here*?
- Going for the Record
- AFCO settings
- What size tire th350 and possible nitrous
- e.t. gain from removing front sway bar?
- ? Shock and spring
- Drag Bar ripped from frame. OOPS!!
- Lets talk about Nitrous 6 speed cars and Gear and tire combos.
- Smaller tires in rear than up front, is this safe?
- Burkhart Chassis Tax Sale
- Balancing a Drag Radial??
- sonoco extended lifting at top end
- After crash rebuild by Midwest Chassis!
- Dana S60 spool and gear set
- Cutting Dash With For Roll Bar
- NEW: Burkhart rear Bumper Support
- Why Is Concrete Better?
- Big discount on Rhino Ramps - car inspection/maintenance ramps
- problems with door bars hitting door panels
- Lightweight battery
- What kind of Motor Mounts
- What else do I need?
- Roll bar padding
- Using stock steering rack wo the pump in a race application
- Is 1 5/8 .134" ews 10point roll cage nhra legal?
- World`s Quickest ZR1
- Going down the 1/4 for the first time... Come give me tips
- Do slicks provide the same grip spinning at higher speeds?
- Driveshaft safety loop recomendations?
- Bmr Xtreme Rear Drag Bar
- blown 434 4th gen tubbed
- Optima yellow ?
- opening weekend of race season
- motor plate/mid plate question
- Compression/Boost
- Lighter ele. fans
- Chicago People or anyone within 100miles take a look! Chassis Seminar
- What Harnesses are you guys using in your cars?
- 98 Camaro Drag Build
- RCI trans blanket for TH400?
- Airbag delete w/out taking dash out?
- Kuwaiti 25.3 tran am @ burkhart chassi .
- Truck coils relocation places on a camaro
- removing powersteering with 17" rims...
- need help: drag wheel fitment pics inside
- Pics of pin on hatches.
- BBC, F3-r, on alcohol, HELP!!!!
- Champion wheels?
- Question on 6 point roll bar
- Feedback on helmet for autox
- 26x10.5 et street on 15x10 wheel
- GZ LSX Vaccum pump need help pls!!!
- 4150 air cleaner pics!!
- Made it to 11s but trap might be low, ideas?
- Drag Racers: Optimum gearing suggestion
- what is that canister on the back of AA fuel dragsters?
- moroso electric water pump drive for drag racing
- Reared gear selection? Need advice!!
- Those who have installed front AFCO's
- Hvac delete plate that bolts in engine bay
- Best drag tire on a stock 9.5 ws-6 rim to hold 500rwhp
- ACE Racing's Racing Season
- M6 Nitrous Gear Qs
- Radiator support/rules
- what trans fluid for race built th400
- Mig welding a chromoly cage? is it against nhra rules?
- 4.56 & 28in tire
- Skinny Wheels and Tires
- New suspension/rear setup, need advice on launch and tires
- Lower control arm brackets
- Remote mount water pump setups
- Vic junior, accufab and LS6 valley cover questions.
- Which muffler/bullet after flowmaster merge fits
- Vacume pump on stock motor LS1, and street drivien?
- How are you guys running your positive cables from the rear?
- M6 4:30's and slicks question
- How are you venting a sumped tank?
- Kooks 2" and manual rack
- M6.. 28W vs28S
- Turbo 400 LT1 Gear Ratio for 1/8 or 1/4 Mile or Compromise for Both
- Transmission Lines for TH-400
- Extended Hood
- Seats For An F-Body
- Whats Next?
- Attn: in the pits.....
- lt1 m6 cross member for th350 swap?
- Hardware for ABS Delete
- Motorplate ?
- Tim99ws6 25.3 Real Street 275 Build
- c.b.m. -pacific street car association
- ac delete please help!
- Drag bar?
- Vacuum Pumps
- Fitting a 325/50/15 successfully ? and options for rear coilovers?
- Slicks age?
- Check out my cage and seat brackets!
- set up/track questisons
- Bought a caged/9" RS roller, have some questions, PICS
- Car weighs 3700lbs...looking for ways to remove weight...by cutting?..
- Single Rear Brake and Rotor with Spooled S60
- Draglite questions
- Window Net Mounting??? Window net people come on in please ....
- Speed Inc Lightweight Carpet
- roll cage question
- What do ya think she will do after diet and tire swap???
- "Bulkhead" Rules?
- MSD 2 step question
- 6 pt or 8 pt rollbar
- Best stock LS1 A4 w/ 2.73's 1/4 mile times
- Draglite question
- 26" DR and gearing???????
- Mardi gras grudge race @ hub city Dragway
- 60' times
- What can i expect with my suspension and gear?
- rear end and wheels
- braket racing my stock lt1?
- HELP ME PICK A TIRE/Wheel COMBO for my setup
- Russell traction bar system
- Wolfe spring adjustment kit
- 26", 27" or 28" tire
- Wheel weight/HP
- Aftermarket Radiators setup
- Best way to get air to 4150 tb
- What oil pan should I get ?
- brake caliper question
- STUPID 10 bolt!!!!
- Gear Ratio Opinions
- I need a roll cage pic. Cant find what im lookin for.
- Torque Arm mount??
- Sliders with roll bar and harness
- What fly wheel are u running for a 60E
- No Console set-ups
- Street tires
- What's needed for a Bulletproof TH-400
- strut tower & fender supports
- wire removal
- Launch RPM's?
- Need some help...
- Shift points..Who's logged changes. What RPM?
- Yes, another exhaust setup question...
- Getting Tuned, 93 or 100 Octane
- Removing antenna from 1/4 panel
- Aerospace rear brake ?
- Panhard bracket removal/reconstruction.. maybe pics?
- 4th Gen Replacement Floor Pans
- Comp eng & jegster roll bars
- can I remove EBCM
- is it hard to srpay paint a roll cage that is installed?
- Who uses or used trans am seats with 5 points?
- 1/4 guesses and advice
- SFI Safety belt question
- 12 BOLT street opinions !
- Dummy Airbag
- Deleting power steering , quick question
- New LSX TH-400 JW Ultra Bell???
- driveshaft loop
- interior wiring harness pinout
- Quick release steering wheels
- Manual to TH-350 gear question
- Stripper build wiring help.
- Spring rate for rear w/ afco double adjustable
- Question for those running vacuum pumps
- My new RSD NHRA 10.00 135 LEGAL cage!!
- KY-Turbo Inc and Nitrous Cars
- drag brake pad options
- Cam ideas for 90% drag car
- New drag racing forum
- School me on 8" vs 10" converters
- Boosted 347 LS's
- Harness guides for factory seats
- Burkhart Anti Roll bar pics
- My buddie's newly caged 3rd Gen Vert
- Glass or Carbon Front Fenders ( 4th Gen )
- narrowing rearend and 315 tire?
- Th400 gains.
- F body Metal gas tank sump
- When is a glide better then a th350?
- 295-55-15 M/T's!! Fit real nice
- which backspacing billit specialty wheels
- estimated hp and et
- Drag car ride height
- Where to mount battery in the back
- Really cool vid! Traction with slicks, moving out, and tire shake example.
- What mods are next to get it to the 12's
- power to weight ratio for 10/9s
- Fuel Cell in T-top area
- t tops?
- Which individual EGT system?
- Bogart 15x3.5 with 2.25BS, clear stock ls1 brakes?
- Structural, or not so much?
- 10 sec. 370lsx 91 b4c build
- HVAC delete
- Negative effects of seam sealer removal
- What makes the back Hatch so heavy?
- Alternative to Percy's Speedglass
- radial to bias ply sizes
- Deck lid trunk lid
- Aftermarket bellhousing
- Good Enough for Mid Low 10's???
- wiring question
- camaro front grill
- Best Rear drag brake
- Advice For New Drag Racer
- Champion Wheel C1 beadlock reviews?
- We are Moving
- What drag stripes are open
- Trans shop called...Christmas came early!
- Aiming for low 7s 1/8th mile, how's this setup sound?
- Seat install help.
- wheel/tire/gear changes. any gains?
- What did you do to the steel part of the dash
- any weight difference t56 to th400 swap?
- hvac delete
- Few questions on power and gear setup
- Starting Line Ratio
- LS Hemi head
- Stick with 28" or go with 26"?
- Need VSS with powerglide and aerospace brakes!!! HELP
- M&H Racemasters
- Burkhart Chassis 25.3 pics
- Burkhart CHassis bolt in Chute mount
- Burkhart Chassis TA FireBird and Camaro wing
- switching from 26in to 28in tire how much will it hurt my times?
- Gear/Tire combo Questions
- Cages and Kids?????
- what would you like to see brought to the market?
- AFCO rear shocks with BMR Xtreme drag bar
- Trans Time Th-400 or Glide
- what to do for coolant over flow tank...
- Best Race Header??
- Parachute?
- whats the best driveshaft for me?
- How can I get my front wheels to stick in the fenderwell more?
- Afco shock settings
- Power Cell Lithium Vs Red Top Battery
- Need help
- What can come out?? Car is tore apart
- Making my "car" faster.......parasitic losses and weight.....
- new BMR xtreme anti-roll bar install!
- I was wondering .....
- TH350 w/lockup??
