View Full Version : Drag Racing Tech
- Does any one Bracket Race on this site?
- Ok guys, help me out . . . my times SUCK!
- can i take a stock vette?
- Can someone post a pic of Harlan's 2-step installed?
- Sept. 28th. at LACR is next West Coast Corvette Challenge!
- can you get a 12 bolt w/ 5.13's? Would you make it 60' in 1st gear?
- What 3.5in tires and rims are you running for track only?
- my et tonight!
- How to launch??????
- ATTENTION: SIG LENGTH LIMT!!!
- BeastSS/Sonof BeastSS
- need help getting into 12's
- Darn Weld 15x10s! Anyone running a spacer?
- 2nd time to track and made it into 12's
- New Member: 13.Doh Club!
- Blew some serious ass at Track tonight....
- 3600+lbs + T56 + N2O=10.14 @ 135.11mph, 1.40 60'... almost there :)
- What slicks to hook up a sprayed 422?
- New Best
- cooler fuel better???
- Got some preliminary dyno results.
- Is there a new record for the fastest LS1 F-Body? Is it 9.29@142.4?
- Weight and F/I
- Tires for Bogart 16x4
- Thunder Racing is Great!
- Any Pics of Camaros with Rodlite wheels?
- ET Streets (11.5 vs 10.5)
- Any 16" Slicks Out There?
- Draglites XPs and lugnut questions
- I tried to dyno my car today...
- So...who's the fastest NA, internally stock, 2;73 geared LS1?
- Best Shift Point for My Setup??
- ET streets with stock rear end??
- Any one running MT ET Streets 26 X 11.5 X 15
- Vid of me racing against 510RWHP Vortech LT1 car
- seem right????
- new best, but is there more.
- Madman's Motor is IN!!
- 11's last nigh
- Speedtek shop car...1/8th mile shake down pass (video inside)
- Feathering the throttle........?
- New best with Z06... I'm still the Slowest Stock Corvette in History!!!
- 99 Cobra calling out Bolt-on LS1's - MMRA Race!
- 0-60; 4.95s
- The Hot Rod Wins this weekend!
- hook ground under hood back up?
- anyone using the dyna batt battery thunder sells?
- Texas SLP day - Who is going?
- removed styrofoam behind front bumper
- HELP! which lightweight battery WILL start car from trunk?
- Coach is a driving MOFO
- Operation TH350 is a bust.
- 4.30 gears w/ lightweight spool?
- Traction, G-Tech, 1/4 Mile, etc...
- Fun at the track last night!
- New Best @ Carlsbad
- Does this suck or what??
- Damn it was hot and humid today...went racing anyway
- New Best - Look out 9's Here I Come...
- New best with the PT4200 in the heat.
- Another New Best Last Night!
- 9.1 rut, is this normal?
- I have an A3 again.
- Spare Tire...
- Question: Spraying 100 shot with Stage II heads and cam with SY3500..
- First Dyno (graph inside) - How can I lean the A/F?
- (sigh) another new best...
- A-arms...which better/lighter? BMR or PA
- drill mod
- MMRA event Labor Day weekend...I hope you guys can make it!
- Tire size and type help.
- LS1 Cutaway Image???
- M6 guys....please post your quickest 60' with an aluminum flywheel
- ROLE CALL, "SOUTHERN SHOOTOUT"
- What's involved with a new steering wheel?
- 28x9 ET Drags have arrived!
- Stock shifting RPM
- A4 launch at track
- Need help sizing the right rim and tire combo for the strip
- Convince me to get a spool
- Got new times, need a little input...
- Tried my hand at bracket racing!
- The 'Hot Rod" goes to another Final.
- Where can I get info on the Super Chevy shoot out?
- Cutting rear springs
- What should I run in a 1/8 ????
- Going to the track Thurs . . . .
- You guys know where I can find a decently accurate HP calculator?
- wilwood drag brakes
- Finally in the 7's ( in the 1/8)
- which bushings for LCA's?????
- Short belt analysis,what do you think?
- Typical bolt-ons, TP4200 - help me pick a tire.
- Clutch info needed???
- hmmm..., 03 Cobra vs 02 SS ???
- where can I get a two step for LS1??
- any gains going from 3:73's to 4:30's
- et streets + stock Ls1= BOG
- what do you all think????
- et's??
- 28x9 ET DRAGS,anybody run 'em?
- How much do stock leather front seats weigh??
- full tank or near empty when drag racing?
- New bests last night, Powerglide may stay in.
- Paging Dave Dubberly (The BeaSSt)!!!!!
- M6 Bracket racers?
- How fast is this car???
- Full Bolt Ons M6, 12.57 at 111.9, Whats wrong
- What a FUN day at the track :)
- Nitto has a screw in it
- Question 1/4 mile
- New Best Last Night!
- New motor has some balls...but I need to learn to drive
- More new bests, still cant figure out this 60' thing though...
- more crap weather, some new best, and KILLER VIDEO!
- Billingsley Racing torque arm?
- Playback Tach?
- Back to back identical runs?!?
- Madman's got Power!
- How much weight will this save?
- I'm Alive and Kicking
- Taking the car for some shakedown passes tonight
- Paging Terryble Burger
- ET gains w/ short belt?
- SOM Z28 M6 results
- Tach lead for 2002 Z28?
- What is DA
- Submit a video for MMRA TV commercials.
- Nitto DR's on 16 x 8's vs. 17 x 9's
- More shakedown runs last night...
- What is a radial slick?
- Project LS1 Monte SS earns it keep at the dragstrip tonight....can you say 12's!!!!
- My First Run Ever Good Or Bad
- Import vs Domestic Shootout
- need answers for bad night
- Track rules...
- Has anyone run a radial Slick?
- What Brand/Size Wheels & ET Streets are you running?
- LS1 Motorplate Design Finished!!
- Stock internal M6-11.72@116.59
- New Summer Best!
- 26x10 ET DRAGS on an 8" Draglite rim...will it work?
- Harlan 2-step installed today!
- speedshifting?
- 15" vs 16" draglites
- LS1 Motor Plate almost finished...
- Cant race my SS anymore
- Some summer time passes and a new best mph
- !rear swaybar? good mod?
- what'll my NEW mods run> mti stage 2.......
- Got that 10 sec pass finally!! Video!!
- My first time at the track
- My first shake down run on my new setup.. I am rusty..
- Where can I get a trans temp. gage?
- ET Street vs ET Drag (or any other similar comparison)
- New best 1/8 mile time with my small cam combo
- Drag Racing on a Plugged Nitto
- Whats the best slick available?
- I raced the tow truck today!
- New best with Hotcam+TNT!!!!
- Ford 9" center section weights for ya
- 2003 Cobra at Bristol Dragway
- Best drag only little mufflers?
- paging 9ball....
- Lets talk torque arms.. Need suggestions.
- A night at the track
- need sealed battery box to fit in spare tire well...
- Bogart wheel/tires mounted ..pics inside!!
- What's the biggest tire I can run on a 15x10 Convo Pro?
- ST3500 kicked butt at the track tonite
- Got some shakedown testing done tonight...
- Anyone with BMR Kmember and A-Arms please help
- Louisiana Viper/Vette Shootout! Come out and play!
- Optima battery
- 15x10 Convo pros-Spacer,grinding?
- What angle should I set my BMR tq arm at?
- Short Belt
- thoughts on this setup...
- Paging Terry Berger
- What Gain With Welds ?
- Today's progress report
- Who has run 11's Stock Internal with no weight reduction?
- VIDEO of my 3598lbs T/A
- The BEAST is coming along! :-)
- World's Slowest 2002 Z06??? IAT Sensor to blame?
- Tire pressure for ET Streets
- Tbyrne's Camaro???
- Colonel cant hang
- No track time yet, but I'm still hopeful
- How much does the high temps and hi hum. effect the 1/4?
- DoO you think the following will offset any weight gain?
- The "Hot Rod" meets Madman.
- Adjustable Drag Shocks for a 3rd gen...
- Mac Headers with o/p OR 4.10's with Flomaster Exhaust?
- 60ft question....
- A few pics of the new motor install
- New motor is installed, but I still have alot of work to do!
- Any tips on how to launch A4 SS? 60 ft. Sucks
- Guys with line locks in here please!!
- Anyone with Centerline Wheels Warrior Rim?
- 9" or 12 bolt and why....
- Hard launch on sticky tires=KABOOM! for the A4
- racing a gsxr600
- Which car would win?
- Will I have to grind calipers with these 15's?
- My new Wolfe roll bar (Pics)
- Paging GeorgeC
- coil overs for drag racing
- Blew out a Slick at the top end of the track.
- in the summer heat, what kind of DA are you guys seeing?
- 01 GT vs me in the 00Z28
- overdrive vs. drive?
- Not another 127mph heads/cam car?
- i got the new time at the track
- This is what I done to the Spohn Torque Arm!
- The "Other Car" is King of the Mountain!!!!
- NEW N/A PERSONAL BEST WITH MY CARTEK 415
- what gears should I run in a 9"
- Got into the 12s Today!
- Left lane or Right lane?
- 11.88 in the Heat!
- Weighed the Stock Torque Arm and Spohn Torque Arm.
- Harlan 2-Step is the SH!T
- 3.73 vs 4.10 for street/strip combination
- DA and E.T. (kinda long)
- Harlan two step install question?
- Meziere Water Pump let's figure it out
- New Best!!!
- Killer times and MPH
- New lightweight G2 rear suspension components for you hardcore racers!
- Stumped!
- Has anyone run a 315/40/17 BF Drag radial on a 9" rim?
- Will this stuff ad up?
- 3.73's vs. 4.10 on the street from 30-120, whats the bottom line best ratio?
- My LCA's dont seem even to the ground after the 12 bolt install, is this normal?
- tiny improvement to my best.
- Got new Times tonight
- NEED EST. 1/4 MILE TIME
- Pictures of Hoosier QTP 27-11.50x15's on my lowered SS
- Best 12-bolt and where to buy it at the cheapest price?
- Top 25 Fastest Stock Block 4th Gen F-Bodies
- For those of you wanting to work on your reaction time.......
- Finally made it to the track.
- I'm almost back!
- Anyone Go to Union Grove Dragaway?
- Would there be interest in LS1Tech track dates?
- F-body & Corvette Southern Shootout!
- New tire question.
- Will the Cannibal ever lose any weight?
